path: root/arch/um/os-Linux/process.c
2012-10-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull third pile of kernel_execve() patches from Al Viro: "The last bits of infrastructure for kernel_thread() et.al., with alpha/arm/x86 use of those. Plus sanitizing the asm glue and do_notify_resume() on alpha, fixing the "disabled irq while running task_work stuff" breakage there. At that point the rest of kernel_thread/kernel_execve/sys_execve work can be done independently for different architectures. The only pending bits that do depend on having all architectures converted are restrictred to fs/* and kernel/* - that'll obviously have to wait for the next cycle. I thought we'd have to wait for all of them done before we start eliminating the longjump-style insanity in kernel_execve(), but it turned out there's a very simple way to do that without flagday-style changes." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: alpha: switch to saner kernel_execve() semantics arm: switch to saner kernel_execve() semantics x86, um: convert to saner kernel_execve() semantics infrastructure for saner ret_from_kernel_thread semantics make sure that kernel_thread() callbacks call do_exit() themselves make sure that we always have a return path from kernel_execve() ppc: eeh_event should just use kthread_run() don't bother with kernel_thread/kernel_execve for launching linuxrc alpha: get rid of switch_stack argument of do_work_pending() alpha: don't bother passing switch_stack separately from regs alpha: take SIGPENDING/NOTIFY_RESUME loop into signal.c alpha: simplify TIF_NEED_RESCHED handling
2012-10-12x86, um: convert to saner kernel_execve() semanticsAl Viro
2012-10-09um: get rid of pointless include "..." where include <...> will doAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Richard Weinberger <richard@nod.at>
2011-11-02um: shared/process.h is empty now; kill itAl Viro
2011-11-02um: fill the handlers array at build timeAl Viro
2011-11-02um: simplify set_handler()Al Viro
For one thing, we always block the same signals (IRQ ones - IO, WINCH, VTALRM), so there's no need to pass sa_mask elements in arguments. For another, the flags depend only on whether it's an IRQ signal or not (we add SA_RESTART for them). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Richard Weinberger <richard@nod.at>
2011-11-02um: don't bother blocking SIGARLM and SIGUSR1Al Viro
We used to generate those, but we hadn't done that for a long time. No need to bother blocking them for signal handlers. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Richard Weinberger <richard@nod.at>
2011-11-02um: -include user.h for USER_OBJ, trim includesAl Viro
2011-05-25um: fix crash while os_dump_core()Richard Weinberger
os_dump_core() emits SIGTERM to terminate all UML processes. Kernel threads have to exit on SIGTERM instead of calling last_ditch_exit(). Multiple calls to last_ditch_exit() can cause a crash. Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08uml: style fixes in arch/um/os-LinuxJeff Dike
Style changes under arch/um/os-Linux: include trimming CodingStyle fixes some printks needed severity indicators make_tempfile turns out not to be used outside of mem.c, so it is now static. Its declaration in tempfile.h is no longer needed, and tempfile.h itself is no longer needed. create_tmp_file was also made static. checkpatch moans about an EXPORT_SYMBOL in user_syms.c which is part of a macro definition - this is copying a bit of kernel infrastructure into the libc side of UML because the kernel headers can't be included there. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: remove init_irq_signalsJeff Dike
init_irq_signals doesn't need to be called from the context of a new process. It initializes handlers, which are useless in process context. With that call gone, init_irq_signals has only one caller, so it can be inlined into init_new_thread_signals. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-17uml: stop gdb from deleting breakpoints when running UMLStanislaw Gruszka
Sometimes when UML is debugged gdb miss breakpoints. When process traced by gdb do fork, debugger remove breakpoints from child address space. There is possibility to trace more than one fork, but this not work with UML, I guess (only guess) there is a deadlock - gdb waits for UML and UML waits for gdb. When clone() is called with SIGCHLD and CLONE_VM flags, gdb see this as PTRACE_EVENT_FORK not as PTRACE_EVENT_CLONE and remove breakpoints from child and at the same time from traced process, because either have the same address space. Maybe it is possible to do fix in gdb, but I'm not sure if there is easy way to find out if traced and child processes share memory. So I do fix for UML, it simply do not call clone() with both SIGCHLD and CLONE_VM flags together. Additionally __WALL flag is used for waitpid() to assure not miss clone and normal process events. [ jdike - checkpatch fixes ] Signed-off-by: Stanislaw Gruszka <stf_xl@wp.pl> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: eliminate SIGALRMJeff Dike
Now that ITIMER_REAL is no longer used, there is no need for any use of SIGALRM whatsoever. This patch removes all mention of it. In addition, real_alarm_handler took a signal argument which is now always SIGVTALRM. So, that is gone. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: userspace files should call libc directlyJeff Dike
A number of files that were changed in the recent removal of tt mode are userspace files which call the os_* wrappers instead of calling libc directly. A few other files were affected by this, through This patch makes these call glibc directly. There are also style fixes in the affected areas. os_print_error has no remaining callers, so it is deleted. There is a interface change to os_set_exec_close, eliminating a parameter which was always the same. The callers are fixed as well. os_process_pc got its error path cleaned up. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: get rid of do_longjmpJeff Dike
do_longjmp used to be needed when UML didn't have its own implementation of setjmp and longjmp. They came from libc, and couldn't be called directly from kernel code, as the libc jmp_buf couldn't be imported there. do_longjmp was a userspace function which served to provide longjmp access to kernel code. This is gone, and a number of void * pointers can now be jmp_buf *. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: style fixes pass 3Jeff Dike
Formatting changes in the files which have been changed in the course of folding foo_skas functions into their callers. These include: copyright updates header file trimming style fixes adding severity to printks These changes should be entirely non-functional. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: remove code made redundant by CHOOSE_MODE removalJeff Dike
This patch makes a number of simplifications enabled by the removal of CHOOSE_MODE. There were lots of functions that looked like int foo(args){ foo_skas(args); } The bodies of foo_skas are now folded into foo, and their declarations (and sometimes entire header files) are deleted. In addition, the union uml_pt_regs, which was a union between the tt and skas register formats, is now a struct, with the tt-mode arm of the union being removed. It turns out that usr2_handler was unused, so it is gone. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: throw out CONFIG_MODE_TTJeff Dike
This patchset throws out tt mode, which has been non-functional for a while. This is done in phases, interspersed with code cleanups on the affected files. The removal is done as follows: remove all code, config options, and files which depend on CONFIG_MODE_TT get rid of the CHOOSE_MODE macro, which decided whether to call tt-mode or skas-mode code, and replace invocations with their skas portions replace all now-trivial procedures with their skas equivalents There are now a bunch of now-redundant pieces of data structures, including mode-specific pieces of the thread structure, pt_regs, and mm_context. These are all replaced with their skas-specific contents. As part of the ongoing style compliance project, I made a style pass over all files that were changed. There are three such patches, one for each phase, covering the files affected by that phase but no later ones. I noticed that we weren't freeing the LDT state associated with a process when it exited, so that's fixed in one of the later patches. The last patch is a tidying patch which I've had for a while, but which caused inexplicable crashes under tt mode. Since that is no longer a problem, this can now go in. This patch: Start getting rid of tt mode support. This patch throws out CONFIG_MODE_TT and all config options, code, and files which depend on it. CONFIG_MODE_SKAS is gone and everything that depends on it is included unconditionally. The few changed lines are in re-written Kconfig help, lines which needed something skas-related removed from them, and a few more which weren't strictly deletions. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-24uml: more __init annotationsJeff Dike
2.6.23-rc1 turned up another batch of references from non-__init code to __init code. In most cases, these were missing __init annotations. In one case (os_drop_memory), the annotation was present but wrong. init_maps is __init, but for some reason was being very careful about the mechanism by which it allocated memory, checking whether it was OK to use kmalloc (at this point in the boot, it definitely isn't) and using either alloc_bootmem_low_pages or kmalloc/vmalloc. So, the kmalloc/vmalloc code is removed. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09uml: mark a tt-only functionJeff Dike
Mark another function as tt-mode only. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07uml: convert libc layer to call read and writeJeff Dike
This patch converts calls in the os layer to os_{read,write}_file to calls directly to libc read() and write() where it is clear that the I/O buffer is in the kernel. We can do that here instead of calling os_{read,write}_file_k since we are in libc code and can call libc directly. With the change in the calls, error handling needs to be changed to refer to errno directly rather than the return value of the call. CATCH_EINTR wrappers were also added where needed. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07uml: tidy libc codeJeff Dike
This patch lays some groundwork for the next one, which converts calls to os_{read,write}_file into {read,write}, by doing some tidying in the affected areas. do_not_aio gets restructured to make the final result a bit cleaner. There are also whitespace and other formatting fixes, fixes in error messages, and a typo fix. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07uml: remove page_size()Jeff Dike
userspace code used to have to call the kernelspace function page_size() in order to determine the value of the kernel's PAGE_SIZE. Since this is now available directly from kern_constants.h as UM_KERN_PAGE_SIZE, page_size() can be deleted and calls changed to use the constant. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07uml: add missing __init declarationsJeff Dike
The build started finding calls from non-init to init functions. These are just cases of init functions not being properly marked, so this patch fixes that. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07uml: remove user_util.hJeff Dike
user_util.h isn't needed any more, so delete it and remove all includes of it. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-08[PATCH] um: remove dead code about os_usr1_signal() and os_usr1_process()Paolo 'Blaisorblade' Giarrusso
os_usr1_signal() is totally unused, os_usr1_process() is used only by TT mode. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Acked-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-11-03[PATCH] uml: include tidyingJeff Dike
In order to get the __NR_* constants, we need sys/syscall.h. linux/unistd.h works as well since it includes syscall.h, however syscall.h is more parsimonious. We were inconsistent in this, and this patch adds syscall.h includes where necessary and removes linux/unistd.h includes where they are not needed. asm/unistd.h also includes the __NR_* constants, but these are not the glibc-sanctioned ones, so this also removes one such inclusion. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] Remove the use of _syscallX macros in UMLArnd Bergmann
User mode linux uses _syscallX() to call into the host kernel. The recommended way to do this is to use the syscall() function from libc. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Andi Kleen <ak@muc.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Hirokazu Takata <takata.hirokazu@renesas.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Richard Curnow <rc@rc0.org.uk> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: Chris Zankel <chris@zankel.net> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] uml: Move signal handlers to arch codeJeff Dike
Have most signals go through an arch-provided handler which recovers the sigcontext and then calls a generic handler. This replaces the ARCH_GET_SIGCONTEXT macro, which was somewhat fragile. On x86_64, recovering %rdx (which holds the sigcontext pointer) must be the first thing that happens. sig_handler duly invokes that first, but there is no guarantee that I can see that instructions won't be reordered such that %rdx is used before that. Having the arch provide the handler seems much more robust. Some signals in some parts of UML require their own handlers - these places don't call set_handler any more. They call sigaction or signal themselves. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] uml: Use klibc setjmp/longjmpJeff Dike
This patch adds an implementation of setjmp and longjmp to UML, allowing access to the inside of a jmpbuf without needing the access macros formerly provided by libc. The implementation is stolen from klibc. I copy the relevant files into arch/um. I have another patch which avoids the copying, but requires klibc be in the tree. setjmp and longjmp users required some tweaking. Includes of <setjmp.h> were removed and includes of the UML longjmp.h were added where necessary. There are also replacements of siglongjmp with UML_LONGJMP which I somehow missed earlier. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-14[PATCH] uml: tidy longjmp macroJeff Dike
The UML_SETJMP macro was requiring its users to pass in a argument which it could supply itself, since it wasn't used outside that invocation of the macro. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] uml: signal initialization cleanupJeff Dike
It turns out that init_new_thread_signals is always called with altstack == 1, so we can eliminate the parameter. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-01[PATCH] uml: clean up after MADVISE_REMOVEJeff Dike
The MADVISE_REMOVE-checking code didn't clean up after itself. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-19[PATCH] uml: change sigjmp_buf to jmp_bufJeff Dike
Clean up the jmpbuf code. Since softints, we no longer use sig_setjmp, so the UML_SIGSETJMP wrapper now has a misleading name. Also, I forgot to change the buffers from sigjmp_buf to jmp_buf. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-19[PATCH] uml: MADV_REMOVE fixesJeff Dike
MADV_REMOVE fixes - change the test mapping to be MAP_SHARED instead of MAP_PRIVATE, as MADV_REMOVE on MAP_PRIVATE maps won't work. Also, use the kernel's definition of MADV_REMOVE instead of hardcoding it if there isn't a libc definition. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-31[PATCH] UML: Hotplug memory, take 2Jeff Dike
Changes since first version added check for MADV_REMOVE support on the host fixed error return botch shrunk sprintf array by one character This adds hotplug memory support to UML. The mconsole syntax is config mem=[+-]n[KMG] In other words, add or subtract some number of kilobytes, megabytes, or gigabytes. Unplugged pages are allocated and then madvise(MADV_TRUNCATE), which is a currently experimental madvise extension. These pages are tracked so they can be plugged back in later if the admin decides to give them back. The first page to be unplugged is used to keep track of about 4M of other pages. A list_head is the first thing on this page. The rest is filled with addresses of other unplugged pages. This first page is not madvised, obviously. When this page is filled, the next page is used in a similar way and linked onto a list with the first page. Etc. This whole process reverses when pages are plugged back in. When a tracking page no longer tracks any unplugged pages, then it is next in line for plugging, which is done by freeing pages back to the kernel. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-24[PATCH] uml: fix usage of kernel_errno in place of errnoPaolo 'Blaisorblade' Giarrusso
To avoid conflicts, in kernel files errno is expanded to kernel_errno, to distinguish it from glibc errno. In this case, the code wants to use the libc errno but the kernel one is used; in the other usage, we return errno in place of -errno in case of an error. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Acked-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] uml: implement soft interruptsJeff Dike
This patch implements soft interrupts. Interrupt enabling and disabling no longer map to sigprocmask. Rather, a flag is set indicating whether interrupts may be handled. If a signal comes in and interrupts are marked as OK, then it is handled normally. If interrupts are marked as off, then the signal handler simply returns after noting that a signal needs handling. When interrupts are enabled later on, this pending signals flag is checked, and the IRQ handlers are called at that point. The point of this is to reduce the cost of local_irq_save et al, since they are very much more common than the signals that they are enabling and disabling. Soft interrupts produce a speed-up of ~25% on a kernel build. Subtleties - UML uses sigsetjmp/siglongjmp to switch contexts. sigsetjmp has been wrapped in a save_flags-like macro which remembers the interrupt state at setjmp time, and restores it when it is longjmp-ed back to. The enable_signals function has to loop because the IRQ handler disables interrupts before returning. enable_signals has to return with signals enabled, and signals may come in between the disabling and the return to enable_signals. So, it loops for as long as there are pending signals, ensuring that signals are enabled when it finally returns, and that there are no pending signals that need to be dealt with. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] uml: move libc-dependent code from signal_user.cGennady Sharapov
The serial UML OS-abstraction layer patch (um/kernel dir). This moves all systemcalls from signal_user.c file under os-Linux dir Signed-off-by: Gennady Sharapov <Gennady.V.Sharapov@intel.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-21[PATCH] uml: readd removed unistd.h inclusionPaolo 'Blaisorblade' Giarrusso
Readd this header (deleted in 60d339f6fe0831060600c62418b71a62ad26c281). A warning is spit out here about undeclared getpgrp(). Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] uml: move libc-dependent startup and signal codeGennady Sharapov
The serial UML OS-abstraction layer patch (um/kernel dir). This moves all systemcalls from process.c file under os-Linux dir and join process.c and process_kern.c files. Signed-off-by: Gennady Sharapov <gennady.v.sharapov@intel.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-05[PATCH] uml: Fix SIGWINCH relayingJeff Dike
This makes SIGWINCH work again, and fixes a couple of SIGWINCH-associated crashes. First, the sigio thread disables SIGWINCH because all hell breaks loose if it ever gets one and tries to call the signal handling code. Second, there was a problem with deferencing tty structs after they were freed. The SIGWINCH support for a tty wasn't being turned off or freed after the tty went away. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
