path: root/arch/um/os-Linux/irq.c
2018-02-19Epoll based IRQ controllerAnton Ivanov
1. Removes the need to walk the IRQ/Device list to determine who triggered the IRQ. 2. Improves scalability (up to several times performance improvement for cases with 10s of devices). 3. Improves UML baseline IO performance for one disk + one NIC use case by up to 10%. 4. Introduces write poll triggered IRQs. 5. Prerequisite for introducing high performance mmesg family of functions in network IO. 6. Fixes RNG shutdown which was leaking a file descriptor Signed-off-by: Anton Ivanov <anton.ivanov@cambridgegreys.com> Signed-off-by: Richard Weinberger <richard@nod.at>
2012-10-09um: get rid of pointless include "..." where include <...> will doAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Richard Weinberger <richard@nod.at>
2011-11-02um: shared/process.h is empty now; kill itAl Viro
2011-11-02um: -include user.h for USER_OBJ, trim includesAl Viro
2008-02-05uml: remove init_irq_signalsJeff Dike
init_irq_signals doesn't need to be called from the context of a new process. It initializes handlers, which are useless in process context. With that call gone, init_irq_signals has only one caller, so it can be inlined into init_new_thread_signals. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: syle fixes in arch/um/os-LinuxJeff Dike
Style fixes in arch/um/os-Linux/irq.c and arch/um/os-Linux/sigio.c: Updated copyrights trimmed includes added severity indicators to printks CodingStyle fixes turned an bunch of panics into printks call some libc functions directly instead of going through the os_* wrappers Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: tidy kern_util.hJeff Dike
Tidy kern_util.h. It turns out that most of the function declarations aren't used, so they can go away. os.h no longer includes kern_util.h, so files which got it through os.h now need to include it directly. A number of other files never needed it, so these includes are deleted. The structure which was used to pass signal handlers from the kernel side to the userspace side is gone. Instead, the handlers are declared here, and used directly from libc code. This allows arch/um/os-Linux/trap.c to be deleted, with its remnants being moved to arch/um/os-Linux/skas/trap.c. arch/um/os-Linux/tty.c had its inclusions changed, and it needed some style attention, so it got tidied. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: eliminate SIGALRMJeff Dike
Now that ITIMER_REAL is no longer used, there is no need for any use of SIGALRM whatsoever. This patch removes all mention of it. In addition, real_alarm_handler took a signal argument which is now always SIGVTALRM. So, that is gone. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: separate timer initializationJeff Dike
Move timer signal initialization from init_irq_signals to a new function, timer_init. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07uml: remove user_util.hJeff Dike
user_util.h isn't needed any more, so delete it and remove all includes of it. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] uml: IRQ handler tidyingJeff Dike
Tidying the irq code - make a variable static activate_fd can call kmalloc directly since it's now kernel code added a no-locking comment fixed a style violation Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-20[PATCH] uml: split memory allocation prototypes out of user.hPaolo 'Blaisorblade' Giarrusso
user.h is too generic a header name. I've split out allocation routines from it. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] uml: Move signal handlers to arch codeJeff Dike
Have most signals go through an arch-provided handler which recovers the sigcontext and then calls a generic handler. This replaces the ARCH_GET_SIGCONTEXT macro, which was somewhat fragile. On x86_64, recovering %rdx (which holds the sigcontext pointer) must be the first thing that happens. sig_handler duly invokes that first, but there is no guarantee that I can see that instructions won't be reordered such that %rdx is used before that. Having the arch provide the handler seems much more robust. Some signals in some parts of UML require their own handlers - these places don't call set_handler any more. They call sigaction or signal themselves. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] uml: remove os_isattyJeff Dike
os_isatty can be made to disappear by moving maybe_sigio_broken from kernel to user code. This also lets write_sigio_workaround become static. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] uml: timer initialization cleanupJeff Dike
This cleans up the mess that is the timer initialization. There used to be two timer handlers - one that basically ran during delay loop calibration and one that handled the timer afterwards. There were also two sets of timer initialization code - one that starts in user code and calls into the kernel side of the house, and one that starts in kernel code and calls user code. This eliminates one timer handler and consolidates the two sets of initialization code. [akpm@osdl.org: use new INTF_ flags] Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-01[PATCH] uml: remove NULL checks and add some CodingStyleJesper Juhl
Remove redundant NULL checks before [kv]free + small CodingStyle cleanup for arch/ Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] uml: move libc-dependent irq code to os-LinuxJeff Dike
The serial UML OS-abstraction layer patch (um/kernel dir). This moves all systemcalls from irq_user.c file under os-Linux dir Signed-off-by: Gennady Sharapov <Gennady.V.Sharapov@intel.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
