path: root/arch/um/os-Linux/aio.c
2005-11-07[PATCH] uml: separate libc-dependent helper codeJeff Dike
The serial UML OS-abstraction layer patch (um/kernel dir). This moves all systemcalls from helper.c file under os-Linux dir Signed-off-by: Gennady Sharapov <Gennady.V.Sharapov@intel.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-12[PATCH] uml: revert block driver use of host AIOJeff Dike
The patch to use host AIO support that I submitted early after 2.6.13 exposed some problems in the block driver. I have fixes for these, but am not comfortable putting them into 2.6.14 at this late date. So, this patch reverts the use of host AIO. I will resubmit the original patch, plus fixes to the driver after 2.6.14 in order to get a reasonable amount of testing before they're exposed to the general public. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-21[PATCH] uml: comment about cast build fixPaolo 'Blaisorblade' Giarrusso
Explain why the casting we do to silence this warning is indeed safe. It is because the field we're casting from, though being 64-bit wide, was filled with a pointer in first place by ourselves. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-17[PATCH] uml: return a real error codeJeff Dike
do_aio used to return -1 on error instead of errno. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-17[PATCH] uml: preserve errno in error pathsJeff Dike
The poster child for this patch is the third tuntap_user hunk. When an ioctl fails, it properly closes the opened file descriptor and returns. However, the close resets errno to 0, and the 'return errno' that follows returns 0 rather than the value that ioctl set. This caused the caller to believe that the device open succeeded and had opened file descriptor 0, which caused no end of interesting behavior. The rest of this patch is a pass through the UML sources looking for places where errno could be reset before being passed back out. A common culprit is printk, which could call write, being called before errno is returned. In some cases, where the code ends up being much smaller, I just deleted the printk. There was another case where a caller of run_helper looked at errno after a failure, rather than the return value of run_helper, which was the errno value that it wanted. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-17[PATCH] uml: Remove some build warningsJeff Dike
These ugly double-casts are the result of gdb complaining about size Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] uml: add host AIO support to block driverJeff Dike
This adds AIO support to the ubd driver. The driver breaks a struct request into IO requests to the host, based on the hardware segments in the request and on any COW blocks covered by the request. The ubd IO thread is gone, since there is now an equivalent thread in the AIO module. There is provision for multiple outstanding requests now. Requests aren't retired until all pieces of it have been completed. The AIO requests have a shared count, which is decremented as IO operations come in until it reaches 0. This can be possibly moved to the request struct - haven't looked at this yet. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] uml: use host AIO supportJeff Dike
This patch makes UML use host AIO support when it (and /usr/include/linux/aio_abi.h) are present. This is only the support, with no consumers - a consumer is coming in the next patch. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
