path: root/arch/um/kernel/tt/unmap.c
2005-06-21[PATCH] uml: fix linkage of tt mode against NPTLPaolo 'Blaisorblade' Giarrusso
With Al Viro <viro@parcelfarce.linux.theplanet.co.uk> To make sure switcheroo() can execute when we remap all the executable image, we used a trick to make it use a local copy of errno... this trick does not work with NPTL glibc, only with LinuxThreads, so use another (simpler) one to make it work anyway. Hopefully, a lot improved thanks to merging with the version of Al Viro (which had his part of problems, though, i.e. removing a fix to another bug and not fixing the problem on i386). Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
