Don't include ptrace uapi stuff in arch headers, it will
pollute the kernel namespace and conflict with existing
stuff.
In this case it fixes clashes with common names like R8.
Signed-off-by: Richard Weinberger <richard@nod.at>
tracehook_report_syscall_entry() is allowed to fail,
in case of failure we have to abort the current syscall.
Before we had SKAS0 UML had two modes of operation
TT (tracing thread) and SKAS3/4 (separated kernel address space).
TT was known to be insecure and got removed a long time ago.
SKAS3/4 required a few (3 or 4) patches on the host side which never went
mainline. The last host patch is 10 years old.
With SKAS0 mode (separated kernel address space using 0 host patches),
default since 2005, SKAS3/4 is obsolete and can be removed.
We have a function where the arch can be queried, syscall_get_arch().
So rather than have every single piece of arch specific code use and/or
duplicate syscall_get_arch(), just have the audit code use the
syscall_get_arch() code.
Based-on-patch-by: Richard Briggs <rgb@redhat.com>
Signed-off-by: Eric Paris <eparis@redhat.com>
Cc: linux-alpha@vger.kernel.org
Cc: linux-ia64@vger.kernel.org
Cc: microblaze-uclinux@itee.uq.edu.au
Cc: linux-mips@linux-mips.org
Cc: linux@lists.openrisc.net
Cc: linux-parisc@vger.kernel.org
Cc: linuxppc-dev@lists.ozlabs.org
Cc: linux-s390@vger.kernel.org
Cc: linux-sh@vger.kernel.org
Cc: sparclinux@vger.kernel.org
Cc: user-mode-linux-devel@lists.sourceforge.net
Cc: linux-xtensa@linux-xtensa.org
Cc: x86@kernel.org
[richard@nod.at: Fixed some minor build issues]
Every arch calls:
if (unlikely(current->audit_context))
audit_syscall_entry()
which requires knowledge about audit (the existance of audit_context) in
the arch code. Just do it all in static inline in audit.h so that arch's
can remain blissfully ignorant.
The audit system previously expected arches calling to audit_syscall_exit to
supply as arguments if the syscall was a success and what the return code was.
Audit also provides a helper AUDITSC_RESULT which was supposed to simplify things
by converting from negative retcodes to an audit internal magic value stating
success or failure. This helper was wrong and could indicate that a valid
pointer returned to userspace was a failed syscall. The fix is to fix the
layering foolishness. We now pass audit_syscall_exit a struct pt_reg and it
in turns calls back into arch code to collect the return value and to
determine if the syscall was a success or failure. We also define a generic
is_syscall_success() macro which determines success/failure based on if the
value is < -MAX_ERRNO. This works for arches like x86 which do not use a
separate mechanism to indicate syscall failure.
We make both the is_syscall_success() and regs_return_value() static inlines
instead of macros. The reason is because the audit function must take a void*
for the regs. (uml calls theirs struct uml_pt_regs instead of just struct
pt_regs so audit_syscall_exit can't take a struct pt_regs). Since the audit
function takes a void* we need to use static inlines to cast it back to the
arch correct structure to dereference it.
The other major change is that on some arches, like ia64, MIPS and ppc, we
change regs_return_value() to give us the negative value on syscall failure.
THE only other user of this macro, kretprobe_example.c, won't notice and it
makes the value signed consistently for the audit functions across all archs.
In arch/sh/kernel/ptrace_64.c I see that we were using regs[9] in the old
audit code as the return value. But the ptrace_64.h code defined the macro
regs_return_value() as regs[3]. I have no idea which one is correct, but this
patch now uses the regs_return_value() function, so it now uses regs[3].
For powerpc we previously used regs->result but now use the
regs_return_value() function which uses regs->gprs[3]. regs->gprs[3] is
always positive so the regs_return_value(), much like ia64 makes it negative
before calling the audit code when appropriate.
Acked-by: H. Peter Anvin <hpa@zytor.com> [for x86 portion]
Acked-by: Tony Luck <tony.luck@intel.com> [for ia64]
Acked-by: Richard Weinberger <richard@nod.at> [for uml]
Acked-by: David S. Miller <davem@davemloft.net> [for sparc]
Acked-by: Ralf Baechle <ralf@linux-mips.org> [for mips]
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> [for ppc]
1) take subarch-specific stuff to subarch_ptrace()
2) PTRACE_{PEEK,POKE}{TEXT,DATA} is handled by ptrace_request() just fine...
Both commits 0a3d763f1a68 ("ptrace: cleanup arch_ptrace() on um") and
9b05a69e0534 ("ptrace: change signature of arch_ptrace()") broke the um
build. This patch fixes the issues.
0a3d763f1a68 introduced the undeclared variable "datavp". The patch seems
completely untested. :-(
9b05a69e0534 changed arch_ptrace()'s signature but did not update
um/include/asm/ptrace-generic.h.
Cc: Namhyung Kim <namhyung@gmail.com>
Cc: Jeff Dike <jdike@addtoit.com>
Tested-by: Will Newton <will.newton@gmail.com>
Remove unnecessary castings using void pointer and fix copy_to_user()
return value. Also add missing __user markup on the argument of
arch_ptrctl().
Signed-off-by: Namhyung Kim <namhyung@gmail.com>
Fix up the arguments to arch_ptrace() to take account of the fact that
@addr and @data are now unsigned long rather than long as of a preceding
patch in this series.
Cc: <linux-arch@vger.kernel.org>
Acked-by: Roland McGrath <roland@redhat.com>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
PROC_MM doesn't exist in Kconfig. Looking around it looks like a
left-over from 2.6.0 or even 2.4 times, last mentioned in a fedora patch
for 2.6.10. I believe it's time to get rid of that last tiny parts here
that are still around.
Signed-off-by: Christoph Egger <siccegge@cs.fau.de>
Use the generic ptrace_resume code for PTRACE_SYSCALL, PTRACE_CONT,
PTRACE_KILL and PTRACE_SINGLESTEP. This implies defining
arch_has_single_step in <asm/ptrace.h> and implementing the
user_enable_single_step and user_disable_single_step functions, which also
causes the breakpoint information to be cleared on fork, which could be
considered a bug fix.
Also the TIF_SYSCALL_TRACE thread flag is now cleared on PTRACE_KILL which
it previously wasn't which is consistent with all architectures using the
modern ptrace code.
XXX: I'm not sure arch_has_single_step() is placed in the exactly correct
location, please verify in which of the ptrace headers it should really
be.
Cc: Roland McGrath <roland@redhat.com>
It is currently impossible to run a user-mode linux machine inside another
user-mode linux (UML on UML). It breaks after a few instructions. When
it tries to check whether SYSEMU is installed (the inner) UML receives an
inconsistent result (from the outer UML).
This is the output of a broken attempt:
$ ./linux mem=256m ubd0=cow
Locating the bottom of the address space ... 0x0
Locating the top of the address space ... 0xc0000000
Core dump limits :
soft - 0
hard - NONE
Checking that ptrace can change system call numbers...OK
Checking ptrace new tags for syscall emulation...unsupported
Checking syscall emulation patch for ptrace...check_sysemu : expected SIGTRAP, got status = 256
The problem is the following:
PTRACE_SYSCALL/SINGLESTEP is currently managed inside arch_ptrace for ARCH=um.
PTRACE_SYSEMU/SUSEMU_SINGLESTEP is not captured in arch_ptrace's switch,
therefore it is erroneously passed back to ptrace_request (in
kernel/ptrace).
This simple patch simply forces ptrace to return an error on
PTRACE_SYSEMU/SUSEMU_SINGLESTEP as it is unsupported on ARCH=um, and fixes
the problem.
Signed-off-by: Renzo Davoli <renzo@cs.unibo.it>
Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com>
- Make some variables and functions static, since they don't need to be
global.
- Remove an unused function - arch/um/kernel/time.c::sched_clock().
- Clean the style a bit as complained by checkpatch.pl.
Signed-off-by: WANG Cong <wangcong@zeuux.org>
Spelling fixes in arch/um/.
Signed-off-by: Simon Arlott <simon@fire.lp0.eu>
Acked-by: Jeff Dike <jdike@addtoit.com>
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Tidy the code affected by the floating point fixes.
A bunch of unused stuff is gone, including two sigcontext.c files,
which turned out to be entirely unneeded.
There are the usual fixes -
whitespace and style cleanups
copyright updates
emacs formatting comments gone
include cleanups
adding severities to printks
Signed-off-by: Jeff Dike <jdike@linux.intel.com>
Handle floating point state better in ptrace. The code now correctly
distinguishes between PTRACE_[GS]ETFPREGS and PTRACE_[GS]ETFPXREGS. The FPX
requests get handed off to arch-specific code because that's not generic.
get_fpregs, set_fpregs, set_fpregs, and set_fpxregs needed real
implementations.
Something here exposed a missing include in asm/page.h, which needed
linux/types.h in order to get gfp_t, so that's fixed here.
Formatting changes in the files which have been changed in the course
of folding foo_skas functions into their callers. These include:
copyright updates
header file trimming
style fixes
adding severity to printks
These changes should be entirely non-functional.
This patch makes a number of simplifications enabled by the removal of
CHOOSE_MODE. There were lots of functions that looked like
int foo(args){
foo_skas(args);
The bodies of foo_skas are now folded into foo, and their declarations (and
sometimes entire header files) are deleted.
In addition, the union uml_pt_regs, which was a union between the tt and skas
register formats, is now a struct, with the tt-mode arm of the union being
removed.
It turns out that usr2_handler was unused, so it is gone.
Identical handlers of PTRACE_DETACH go into ptrace_request().
Not touching compat code.
Not touching archs that don't call ptrace_request.
Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru>
Acked-by: Christoph Hellwig <hch@infradead.org>
Identical implementations of PTRACE_POKEDATA go into generic_ptrace_pokedata()
function.
AFAICS, fix bug on xtensa where successful PTRACE_POKEDATA will nevertheless
return EPERM.
Identical implementations of PTRACE_PEEKDATA go into generic_ptrace_peekdata()
function.
This patch fixes some missing ptrace bits on x86_64. PTRACE_ARCH_PRCTL is
hooked up and implemented. This required generalizing arch_prctl_skas
slightly to take a task_struct to modify. Previously, it always operated on
current.
Reading and writing the debug registers is also enabled by un-ifdefing the
code that implements that. It turns out that x86_64 is identical to i386, so
the same code can be used.
Signed-off-by: Jeff Dike <jdike@addtoit.com>
Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it>
... it's always current, and that's a good thing - allows simpler locking.
Implement sys_[gs]et_thread_area and the corresponding ptrace operations for
UML. This is the main chunk, additional parts follow. This implementation is
now well tested and has run reliably for some time, and we've understood all
the previously existing problems.
Their implementation saves the new GDT content and then forwards the call to
the host when appropriate, i.e. immediately when the target process is
running or on context switch otherwise (i.e. on fork and on ptrace() calls).
In SKAS mode, we must switch registers on each context switch (because SKAS
does not switches tls_array together with current->mm).
Also, added get_cpu() locking; this has been done for SKAS mode, since TT does
not need it (it does not use smp_processor_id()).
Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it>
misc sparse annotations
The sys_ptrace boilerplate code (everything outside the big switch
statement for the arch-specific requests) is shared by most architectures.
This patch moves it to kernel/ptrace.c and leaves the arch-specific code as
arch_ptrace.
Some architectures have a too different ptrace so we have to exclude them.
They continue to keep their implementations. For sh64 I had to add a
sh64_ptrace wrapper because it does some initialization on the first call.
For um I removed an ifdefed SUBARCH_PTRACE_SPECIAL block, but
SUBARCH_PTRACE_SPECIAL isn't defined anywhere in the tree.
Acked-by: Paul Mackerras <paulus@samba.org>
Acked-By: David Howells <dhowells@redhat.com>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Acked-by: Paul Mundt <lethal@linux-sh.org>
Eliminate an unused variable warning in ptrace.c and a size mismatch warning
by adding a cast to __pa.
Some changes that I sent in didn't make 2.6.12-rc4 for some reason. This
adds them back. We have
an x86_64 definition of TOP_ADDR
a reimplementation of the x86_64 csum_partial_copy_from_user
some syntax fixes in arch/um/kernel/ptrace.c
removal of a CFLAGS definition in the x86_64 Makefile
some include changes in the x86_64 ptrace.c and user-offsets.h
a syntax fix in elf-x86_64.h
Also moved an include in the i386 and x86_64 Makefiles to make the symlinks
work, and some small fixes from Al Viro.
Cc: <viro@parcelfarce.linux.theplanet.co.uk>
s390 needs to change some parts of arch/um/kernel/ptrace.c. Thus, the code
regarding PEEKUSER and POKEUSER are shifted to arch/um/sys-<subarch>/ptrace.c.
Also s390 debug registers need to be updated, when singlestepping is switched
on / off. Thus, setting/resetting of singlestepping is centralized in the new
function set_singlestep(), which also inserts the macro
SUBARCH_SET_SINGLESTEP(mode), if defined.
Finally, s390 has the "ieee_instruction_pointer" in its
registers, which also is allowed to be read via
ptrace( PTRACE_PEEKUSER, getpid(), PT_IEEE_IP, 0);
To implement this feature, sys_ptrace inserts the macro
SUBARCH_PTRACE_SPECIAL, if defined.
Signed-off-by: Bodo Stroesser <bstroesser@fujitsu-siemens.com>
Remove some definitions and declarations from arch/um/include/skas_ptrace.h,
as they have moved to arch/um/include/sysdep/skas_ptrace.h
Also, remove PTRACE_SIGPENDING support in UML at all.
This patch removes the arch-specific fault/trap-infos from thread and
skas-regs.
It adds a new struct faultinfo, that is arch-specific defined in
sysdep/faultinfo.h.
The structure is inserted in thread.arch and thread.regs.skas and
thread.regs.tt
Now, segv and other trap-handlers can copy the contents from regs.X.faultinfo
to thread.arch.faultinfo with one simple assignment.
Also, the number of macros necessary is reduced to
FAULT_ADDRESS(struct faultinfo)
extracts the faulting address from faultinfo
FAULT_WRITE(struct faultinfo)
extracts the "is_write" flag
SEGV_IS_FIXABLE(struct faultinfo)
is true for the fixable segvs, i.e. (TRAP == 14)
on i386
UPT_FAULTINFO(regs)
result is (struct faultinfo *) to the faultinfo
in regs->skas.faultinfo
GET_FAULTINFO_FROM_SC(struct faultinfo, struct sigcontext *)
copies the relevant parts of the sigcontext to
struct faultinfo.
On SIGSEGV, call user_signal() instead of handle_segv(), if the architecture
provides the information needed in PTRACE_FAULTINFO, or if PTRACE_FAULTINFO is
missing, because segv-stub will provide the info.
The benefit of the change is, that in case of a non-fixable SIGSEGV, we can
give user processes a SIGSEGV, instead of possibly looping on pagefault
handling.
Since handle_segv() sikked arch_fixup() implicitly by passing ip==0 to segv(),
I changed segv() to call arch_fixup() only, if !is_user.
This patch does some totally trivial compilation fixes. It also restores the
debugregs manipulation, which was commented out simply because it doesn't
compile on x86_64 (we haven't yet implemented there debugregs handling).
This patch is for -mm only. It should probably be included in git-audit,
and should be forwarded to Linus iff git-audit is.
It updates the audit-syscall-{entry,exit} calls to current -mm.
Convert most of the current code that uses _NSIG directly to instead use
valid_signal(). This avoids gcc -W warnings and off-by-one errors.
Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk>
infrastructure for it.
Let it rip!
