The patch below corrects multiple occurances of "the the"
typos across several files, both in source comments and KConfig files.
There is no actual code changed, only text. Note this only affects the /arch
directory, and I believe I could find many more elsewhere. :)
As part of an SMP cleanliness pass over UML, I consted a bunch of
structures in order to not have to document their locking. One of these
structures was a struct tty_operations. In order to const it in UML
without introducing compiler complaints, the declaration of
tty_set_operations needs to be changed, and then all of its callers need to
be fixed.
This patch declares all struct tty_operations in the tree as const. In all
cases, they are static and used only as input to tty_set_operations. As an
extra check, I ran an i386 allyesconfig build which produced no extra
warnings.
53 drivers are affected. I checked the history of a bunch of them, and in
most cases, there have been only a handful of maintenance changes in the
last six months. serial_core.c was the busiest one that I looked at.
Signed-off-by: Jeff Dike <jdike@addtoit.com>
Acked-by: Alan Cox <alan@redhat.com>
Use the existing random_ether_addr() instead of cooking up my own
version. Pointed out by Dave Hollis and Jason Lunz.
Mechanical, hopefully non-functional changes stemming from
setup_etheraddr always succeeding now that it always assigns a MAC,
either from the command line or generated randomly:
the test of the return of setup_etheraddr is removed, and code
dependent on it succeeding is now unconditional
setup_etheraddr can now be made void
struct uml_net.have_mac is now always 1, so tests of it can be
similarly removed, and uses of it can be replaced with 1
struct uml_net.have_mac is no longer used, so it can be removed
struct uml_net_private.have_mac is copied from struct uml_net, so
it is always 1
tests of uml_net_private.have_mac can be removed
uml_net_private.have_mac can now be removed
the only call to dev_ip_addr was removed, so it can be deleted
It also turns out that setup_etheraddr is called only once, from the same
file, so it can be static and its declaration removed from net_kern.h.
Similarly, set_ether_mac is defined and called only from one file.
Finally, setup_etheraddr and set_ether_mac were moved to avoid needing forward
declarations.
Assign a random MAC to an ethernet interface if one was not provided on the
command line. This became pressing when distros started bringing interfaces
up before assigning IPs to them. The previous pattern of assigning an IP then
bringing it up allowed the MAC to be generated from the first IP assigned.
However, once the thing is up, it's probably a bad idea to change the MAC, so
the MAC stayed initialized to fe:fd:0:0:0:0.
Now, if there is no MAC from the command line, one is generated. We use the
microseconds from gettimeofday (20 bits), plus the low 12 bits of the pid to
seed the random number generator. random() is called twice, with 16 bits of
each result used. I didn't want to have to try to fill in 32 bits optimally
given an arbitrary RAND_MAX, so I just assume that it is greater than 65536
and use 16 bits of each random() return.
There is also a bit of reformatting and whitespace cleanup here.
fork on UML has always somewhat subtle. The underlying cause has been the
need to initialize a stack for the new process. The only portable way to
initialize a new stack is to set it as the alternate signal stack and take a
signal. The signal handler does whatever initialization is needed and jumps
back to the original stack, where the fork processing is finished. The basic
context switching mechanism is a jmp_buf for each process. You switch to a
new process by longjmping to its jmp_buf.
Now that UML has its own implementation of setjmp and longjmp, and I can poke
around inside a jmp_buf without fear that libc will change the structure, a
much simpler mechanism is possible. The jmpbuf can simply be initialized by
hand.
This eliminates -
the need to set up and remove the alternate signal stack
sending and handling a signal
the signal blocking needed around the stack switching, since
there is no stack switching
setting up the jmp_buf needed to jump back to the original
stack after the new one is set up
In addition, since jmp_buf is now defined by UML, and not by libc, it can be
embedded in the thread struct. This makes it unnecessary to have it exist on
the stack, where it used to be. It also simplifies interfaces, since the
switch jmp_buf used to be a void * inside the thread struct, and functions
which took it as an argument needed to define a jmp_buf variable and assign it
from the void *.
Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it>
Mark a symbol and file as being tt-mode only. This shrinks the binary
slightly when tt mode support is compiled out and makes it easier to identity
stuff when tt mode is removed.
The UML/x86_64 headers were missing ptrace support for some segment registers.
The underlying problem was that the x86_64 kernel uses user_regs_struct
rather than the ptrace register definitions in ptrace. This patch switches
UML/x86_64 to using user_regs_struct for its definitions of the host's
registers.
Make lots of structures const in order to make it obvious that they need no
locking.
The KSTK_* macros used an inordinate amount of stack. In order to overcome
an impedance mismatch between their interface, which just returns a single
register value, and the interface of get_thread_regs, which took a full
pt_regs, the implementation created an on-stack pt_regs, filled it in, and
returned one field. do_task_stat calls KSTK_* twice, resulting in two
local pt_regs, blowing out the stack.
This patch changes the interface (and name) of get_thread_regs to just
return a single register from a jmp_buf.
The include of archsetjmp.h" in registers.h to get the definition of
jmp_buf exposed a bogus include of <setjmp.h> in start_up.c. <setjmp.h>
shouldn't be used anywhere any more since UML uses the klibc
setjmp/longjmp.
Clean set_ether_mac usage. Maybe could also be removed, but surely it can't
be a global function taking a void* argument.
Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it>
Acked-by: Jeff Dike <jdike@addtoit.com>
Cc: Jeff Garzik <jeff@garzik.org>
timer_irq_inited was useless, so it is removed.
set_interval returns an error instead of panicing if setitimer fails. Some of
its callers now check the return.
enable_timer is largely tt-mode-specific, so it is marked as such, and the
only skas-mode caller is made to call set-interval instead.
user_time_init was a no-value-added wrapper around set_interval, so it is
gone.
Since set_interval is now called from kernel code, callers no longer pass
ITIMER_* to it. Instead, they pass a flag which is converted into ITIMER_REAL
or ITIMER_VIRTUAL.
Have most signals go through an arch-provided handler which recovers the
sigcontext and then calls a generic handler. This replaces the
ARCH_GET_SIGCONTEXT macro, which was somewhat fragile. On x86_64, recovering
%rdx (which holds the sigcontext pointer) must be the first thing that
happens. sig_handler duly invokes that first, but there is no guarantee that
I can see that instructions won't be reordered such that %rdx is used before
that. Having the arch provide the handler seems much more robust.
Some signals in some parts of UML require their own handlers - these places
don't call set_handler any more. They call sigaction or signal themselves.
- Various cleanups in the sigio code.
- Removed explicit zero-initializations of a few structures.
- Improved some error messages.
- An API change - there was an asymmetry between reactivate_fd calling
maybe_sigio_broken, which goes through all the machinery of figuring out if
a file descriptor supports SIGIO and applying the workaround to it if not,
and deactivate_fd, which just turns off the descriptor.
This is changed so that only activate_fd calls maybe_sigio_broken, when
the descriptor is first seen. reactivate_fd now calls add_sigio_fd, which
is symmetric with ignore_sigio_fd.
This removes a recursion which makes a critical section look more critical
than it really was, obsoleting a big comment to that effect. This requires
keeping track of all descriptors which are getting the SIGIO treatment, not
just the ones being polled at any given moment, so that reactivate_fd,
through add_sigio_fd, doesn't try to tell the SIGIO thread about descriptors
it doesn't care about.
This patch adds an implementation of setjmp and longjmp to UML, allowing
access to the inside of a jmpbuf without needing the access macros formerly
provided by libc.
The implementation is stolen from klibc. I copy the relevant files into
arch/um. I have another patch which avoids the copying, but requires klibc be
in the tree.
setjmp and longjmp users required some tweaking. Includes of <setjmp.h> were
removed and includes of the UML longjmp.h were added where necessary. There
are also replacements of siglongjmp with UML_LONGJMP which I somehow missed
earlier.
Clean up whitespace and return syntax in os.h.
The UML_SETJMP macro was requiring its users to pass in a argument which it
could supply itself, since it wasn't used outside that invocation of the
macro.
A few sigio-related things can be made static.
os_isatty can be made to disappear by moving maybe_sigio_broken from kernel to
user code. This also lets write_sigio_workaround become static.
The irq_spinlock is not needed from user code any more, so the irq_lock and
irq_unlock wrappers can go away. This also changes the name of the lock to
irq_lock.
Mark forward_interrupts as being tt-mode only.
uml_idle_timer is tt-mode only, so ifdef it as such to make it easier to spot
when tt mode is killed.
It turns out that init_new_thread_signals is always called with altstack == 1,
so we can eliminate the parameter.
When UML is built as a static binary, it segfaults when run. The reason is
that a memory hole that is present in dynamic binaries isn't there in static
binaries, and it contains essential stuff.
This fix removes the code which maps some anonymous memory into that hole and
cleans up some related code.
This cleans up the mess that is the timer initialization. There used to be
two timer handlers - one that basically ran during delay loop calibration and
one that handled the timer afterwards. There were also two sets of timer
initialization code - one that starts in user code and calls into the kernel
side of the house, and one that starts in kernel code and calls user code.
This eliminates one timer handler and consolidates the two sets of
initialization code.
[akpm@osdl.org: use new INTF_ flags]
I was looking at the code of the UML and more precisely at the functions
set_task_sizes_tt and set_task_sizes_skas. I noticed that these 2 functions
take a paramater (arg) which is not used : the function is always called with
the value 0.
I suppose that this value might change in the future (or even can be
configured), so I added a constant in mem_user.h file.
Also, I rounded CONFIG_HOST_TASk_SIZE to a 4M.
Signed-off-by: Tyler <tyler@agat.net>
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
Also fixes all drivers that set this field.
Became irrelevant when x86_64 unexported ia32_sys_call_table.
Cc: Andi Kleen <ak@muc.de>
Cc: Jeff Dike <jdike@addtoit.com>
Initialize wall_to_monotonic correctly. This fixes a problem where sleeps
lasted about one secone less than they should. This also called for a bit of
code restructuring, following a patch which Blaisorblade had been keeping.
Clean up the jmpbuf code. Since softints, we no longer use sig_setjmp, so
the UML_SIGSETJMP wrapper now has a misleading name. Also, I forgot to
change the buffers from sigjmp_buf to jmp_buf.
MADV_REMOVE fixes - change the test mapping to be MAP_SHARED instead of
MAP_PRIVATE, as MADV_REMOVE on MAP_PRIVATE maps won't work. Also, use
the kernel's definition of MADV_REMOVE instead of hardcoding it if there
isn't a libc definition.
Cc: Hugh Dickins <hugh@veritas.com>
Cc: <stable@kernel.org>
Move the prototype from arch-generic to arch-specific includes because on
x86_64 these functions are two static inlines.
Add the format attribute to prototypes so GCC warns about improper usage.
If running on a host not supporting TLS (for instance 2.4) we should report
that cleanly to the user, instead of printing not comprehensible "error 5" for
that.
Additionally, i386 and x86_64 support different ranges for
user_desc->entry_number, and we must account for that; we couldn't pass
ourselves -1 because we need to override previously existing TLS descriptors
which glibc has possibly set, so test at startup the range to use.
x86 and x86_64 existing ranges are hardcoded.
Copy the definition of struct user_desc (with another name) for use by
userspace sources (where we use the host headers, and we can't be sure about
their content) to make sure UML compiles.
Implement sys_[gs]et_thread_area and the corresponding ptrace operations for
UML. This is the main chunk, additional parts follow. This implementation is
now well tested and has run reliably for some time, and we've understood all
the previously existing problems.
Their implementation saves the new GDT content and then forwards the call to
the host when appropriate, i.e. immediately when the target process is
running or on context switch otherwise (i.e. on fork and on ptrace() calls).
In SKAS mode, we must switch registers on each context switch (because SKAS
does not switches tls_array together with current->mm).
Also, added get_cpu() locking; this has been done for SKAS mode, since TT does
not need it (it does not use smp_processor_id()).
Call arch_switch also in switch_to_skas, even if it's, for now, a no-op for
that case (and mark this in the comment); this will change soon.
Also, arch_switch for TT mode is actually useless when the PT proxy (a
complicate debugging instrumentation for TT mode) is not enabled. In fact, it
only calls update_debugregs, which checks debugregs_seq against seq (to check
if the registers are up-to-date - seq here means a "version number" of the
registers).
If the ptrace proxy is not enabled, debugregs_seq always stays 0 and
update_debugregs will be a no-op. So, optimize this out (the compiler can't
do it).
Also, I've been disappointed by the fact that it would make a lot of sense if,
after calling a successful
update_debugregs(current->thread.arch.debugregs_seq),
current->thread.arch.debugregs_seq were updated with the new debugregs_seq.
But this is not done. Is this a bug or a feature? For all purposes, it seems
a bug (otherwise the whole mechanism does not make sense, which is also a
possibility to check), which causes some performance only problems (not
correctness), since we write_debugregs when not needed.
Also, as suggested by Jeff, remove a redundant enabling of SIGVTALRM,
comprised in the subsequent local_irq_enable(). I'm just a bit dubious if
ordering matters there...
misc sparse annotations
The earlier printf patch missed a corresponding change in the printed
variable.
Changes since first version
added check for MADV_REMOVE support on the host
fixed error return botch
shrunk sprintf array by one character
This adds hotplug memory support to UML. The mconsole syntax is
config mem=[+-]n[KMG]
In other words, add or subtract some number of kilobytes, megabytes, or
gigabytes.
Unplugged pages are allocated and then madvise(MADV_TRUNCATE), which is a
currently experimental madvise extension. These pages are tracked so they
can be plugged back in later if the admin decides to give them back. The
first page to be unplugged is used to keep track of about 4M of other
pages. A list_head is the first thing on this page. The rest is filled
with addresses of other unplugged pages. This first page is not madvised,
obviously.
When this page is filled, the next page is used in a similar way and linked
onto a list with the first page. Etc. This whole process reverses when
pages are plugged back in. When a tracking page no longer tracks any
unplugged pages, then it is next in line for plugging, which is done by
freeing pages back to the kernel.
This rearranges the OS declarations by moving some declarations into os.h.
The serial UML OS-abstraction layer patch (um/kernel dir).
This moves sigio_user.c to os-Linux dir
Signed-off-by: Gennady Sharapov <Gennady.V.Sharapov@intel.com>
This moves all startup code from sigio_user.c file under os-Linux dir
This moves all systemcalls from irq_user.c file under os-Linux dir
This fixes a conflict between a header and what gcc "knows" the declaration'
to be.
Use __attribute_used__ instead of __attribute__ ((unused)). This will help
with GCC > 3.2.
To avoid conflicts, in kernel files errno is expanded to kernel_errno, to
distinguish it from glibc errno. In this case, the code wants to use the libc
errno but the kernel one is used; in the other usage, we return errno in place
of -errno in case of an error.
We weren't making sure that we initialized the FP registers of new processes
to sane values.
This patch also moves some defines in the affected area closer to where they
are used.
