path: root/arch/um/include/user.h
2007-11-14uml: fix build for !CONFIG_PRINTKJeff Dike
Handle the case of CONFIG_PRINTK being disabled. This requires a do-nothing stub to be present in arch/um/include/user.h so that we don't get references to printk from libc code. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: stop saving process FP stateJeff Dike
Throw out a lot of code dealing with saving and restoring floating-point state. In skas mode, where processes run in a restoring floating-point state on kernel entry and exit is pointless. This eliminates most of arch/um/os-Linux/sys-{i386,x86_64}/registers.c. Most of what remained is now arch-indpendent, and can be moved up to arch/um/os-Linux/registers.c. Both arches need the jmp_buf accessor get_thread_reg, and i386 needs {save,restore}_fp_regs because it cheats during sigreturn by getting the fp state using ptrace rather than copying it out of the process sigcontext. After this, it turns out that arch/um/include/skas/mode-skas.h is almost completely unneeded. The declarations in it are variables which either don't exist or which don't have global scope. The one exception is kill_off_processes_skas. If that's removed, this header can be deleted. This uncovered a bug in user.h, which wasn't correctly making sure that a size_t definition was available to both userspace and kernelspace files. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07uml: fix prototypesPaolo 'Blaisorblade' Giarrusso
Declare strlcpy and strlcat more correctly. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07uml: move remaining useful contents of user_util.hJeff Dike
Rescue the useful contents of the soon-to-be-gone user-util.h. pty.c now gets ptsname from stdlib.h like it should have always done. CATCH_EINTR is now in os.h, although perhaps all usage should be under os-Linux at some point. get_pty is also in os.h. This patch restores the old definition of ARRAY_SIZE in user.h. This file is included only in userspace files, so there will be no conflict with the kernel's new ARRAY_SIZE. The copy of the kernel's ARRAY_SIZE and associated infrastructure is now gone. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-20[PATCH] uml: split memory allocation prototypes out of user.hPaolo 'Blaisorblade' Giarrusso
user.h is too generic a header name. I've split out allocation routines from it. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] uml: request format warnings to GCC for appropriate functionsPaolo 'Blaisorblade' Giarrusso
Add the format attribute to prototypes so GCC warns about improper usage. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] uml: avoid malloc to sleep in atomic sectionsPaolo 'Blaisorblade' Giarrusso
Ugly trick to help make malloc not sleeping - we can't do anything else. But this is not yet optimal, since spinlock don't trigger in_atomic() when preemption is disabled. Also, even if ugly, this was already used in one place, and was even more bogus. Fix it. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-22[PATCH] strlcat: use for uml umid.cPaolo 'Blaisorblade' Giarrusso
Simplify the code by using strlcat() instead of strncat() and manual appending. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
