path: root/arch/tile/lib/memcpy_tile64.c
2011-03-10arch/tile: support 4KB page size as well as 64KBChris Metcalf
The Tilera architecture traditionally supports 64KB page sizes to improve TLB utilization and improve performance when the hardware is being used primarily to run a single application. For more generic server scenarios, it can be beneficial to run with 4KB page sizes, so this commit allows that to be specified (by modifying the arch/tile/include/hv/pagesize.h header). As part of this change, we also re-worked the PTE management slightly so that PTE writes all go through a __set_pte() function where we can do some additional validation. The set_pte_order() function was eliminated since the "order" argument wasn't being used. One bug uncovered was in the PCI DMA code, which wasn't properly flushing the specified range. This was benign with 64KB pages, but with 4KB pages we were getting some larger flushes wrong. The per-cpu memory reservation code also needed updating to conform with the newer percpu stuff; before it always chose 64KB, and that was always correct, but with 4KB granularity we now have to pay closer attention and reserve the amount of memory that will be requested when the percpu code starts allocating. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2010-11-01arch/tile: complete migration to new kmap_atomic schemeChris Metcalf
This change makes KM_TYPE_NR independent of the actual deprecated list of km_type values, which are no longer used in tile code anywhere. For now we leave it set to 8, allowing that many nested mappings, and thus reserving 32MB of address space. A few remaining places using KM_* values were cleaned up as well. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2010-07-06arch/tile: Miscellaneous cleanup changes.Chris Metcalf
This commit is primarily changes caused by reviewing "sparse" and "checkpatch" output on our sources, so is somewhat noisy, since things like "printk() -> pr_err()" (or whatever) throughout the codebase tend to get tedious to read. Rather than trying to tease apart precisely which things changed due to which type of code review, this commit includes various cleanups in the code: - sparse: Add declarations in headers for globals. - sparse: Fix __user annotations. - sparse: Using gfp_t consistently instead of int. - sparse: removing functions not actually used. - checkpatch: Clean up printk() warnings by using pr_info(), etc.; also avoid partial-line printks except in bootup code. - checkpatch: Use exposed structs rather than typedefs. - checkpatch: Change some C99 comments to C89 comments. In addition, a couple of minor other changes are rolled in to this commit: - Add support for a "raise" instruction to cause SIGFPE, etc., to be raised. - Remove some compat code that is unnecessary when we fully eliminate some of the deprecated syscalls from the generic syscall ABI. - Update the tile_defconfig to reflect current config contents. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> Acked-by: Arnd Bergmann <arnd@arndb.de>
2010-06-04arch/tile: core support for Tilera 32-bit chips.Chris Metcalf
This change is the core kernel support for TILEPro and TILE64 chips. No driver support (except the console driver) is included yet. This includes the relevant Linux headers in asm/; the low-level low-level "Tile architecture" headers in arch/, which are shared with the hypervisor, etc., and are build-system agnostic; and the relevant hypervisor headers in hv/. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Reviewed-by: Paul Mundt <lethal@linux-sh.org>
