path: root/arch/tile/kernel
2010-11-01arch/tile: bomb raw_local_irq_ to arch_local_irq_Chris Metcalf
This completes the tile migration to the new naming scheme for the architecture-specific irq management code. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2010-11-01arch/tile: complete migration to new kmap_atomic schemeChris Metcalf
This change makes KM_TYPE_NR independent of the actual deprecated list of km_type values, which are no longer used in tile code anywhere. For now we leave it set to 8, allowing that many nested mappings, and thus reserving 32MB of address space. A few remaining places using KM_* values were cleaned up as well. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2010-10-27Remove duplicate includes from many filesZimny Lech
Signed-off-by: Zimny Lech <napohybelskurwysynom2010@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27ptrace: cleanup arch_ptrace() on tileNamhyung Kim
Remove checking @addr less than 0 because @addr is now unsigned. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Acked-by: Chris Metcalf <cmetcalf@tilera.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27ptrace: change signature of arch_ptrace()Namhyung Kim
Fix up the arguments to arch_ptrace() to take account of the fact that @addr and @data are now unsigned long rather than long as of a preceding patch in this series. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: <linux-arch@vger.kernel.org> Acked-by: Roland McGrath <roland@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tileLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: arch/tile: convert a BUG_ON to BUILD_BUG_ON arch/tile: make ptrace() work properly for TILE-Gx COMPAT mode arch/tile: support new info op generated by compiler arch/tile: minor whitespace/naming changes for string support files arch/tile: enable single-step support for TILE-Gx arch/tile: parameterize system PLs to support KVM port arch/tile: add Tilera's <arch/sim.h> header as an open-source header arch/tile: Bomb C99 comments to C89 comments in tile's <arch/sim_def.h> arch/tile: prevent corrupt top frame from causing backtracer runaway arch/tile: various top-level Makefile cleanups arch/tile: change lower bound on syscall error return to -4095 arch/tile: properly export __mb_incoherent for modules arch/tile: provide a definition of MAP_STACK kmemleak: add TILE to the list of supported architectures. char: hvc: check for error case arch/tile: Add a warning if we try to allocate too much vmalloc memory. arch/tile: update some comments to clarify register usage. arch/tile: use better "punctuation" for VMSPLIT_3_5G and friends arch/tile: Use <asm-generic/syscalls.h> tile: replace some BUG_ON checks with BUILD_BUG_ON checks
2010-10-22Merge branch 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bklLinus Torvalds
* 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl: vfs: make no_llseek the default vfs: don't use BKL in default_llseek llseek: automatically add .llseek fop libfs: use generic_file_llseek for simple_attr mac80211: disallow seeks in minstrel debug code lirc: make chardev nonseekable viotape: use noop_llseek raw: use explicit llseek file operations ibmasmfs: use generic_file_llseek spufs: use llseek in all file operations arm/omap: use generic_file_llseek in iommu_debug lkdtm: use generic_file_llseek in debugfs net/wireless: use generic_file_llseek in debugfs drm: use noop_llseek
2010-10-15arch/tile: convert a BUG_ON to BUILD_BUG_ONChris Metcalf
Inspired by Akinobu Mita's cleanup work. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2010-10-15arch/tile: make ptrace() work properly for TILE-Gx COMPAT modeChris Metcalf
Previously, we tried to pass 64-bit arguments through the "COMPAT" mode 32-bit syscall API, which turned out not to work well. Now we just use straight 32-bit arguments in COMPAT mode, thus requiring individual registers to be read/written with two syscalls. Of course this is uncommon, since usually all the registers are read or written at once. The restructuring applies to all the tile platforms, but is plausibly better than the original code in any case. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2010-10-15arch/tile: support new info op generated by compilerChris Metcalf
This just syncs the backtracing support in the kernel to the upstream backtrace library. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2010-10-15arch/tile: enable single-step support for TILE-GxChris Metcalf
This is not quite the complete support, since we're not yet shipping intvec_64.S, but it is the support relevant to the set of files we are currently shipping, and makes it easier to track changes between our internal sources and our public GIT repository. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2010-10-15arch/tile: parameterize system PLs to support KVM portChris Metcalf
While not a port to KVM (yet), this change modifies the kernel to be able to build either at PL1 or at PL2 with a suitable config switch. Pushing up this change avoids handling branch merge issues going forward with the KVM work. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2010-10-15arch/tile: add Tilera's <arch/sim.h> header as an open-source headerChris Metcalf
This change adds one of the Tilera standard <arch> headers to the set of headers shipped with Linux. The <arch/sim.h> header provides methods for programmatically interacting with the Tilera simulator. The current <arch/sim.h> provides inline assembly for the _sim_syscall function, so the declaration and definition previously provided manually in Linux are no longer needed. We now use the standard sim_validate_lines_evicted() method from <arch/sim.h> rather than rolling our own direct call to sim_syscall(). Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
All file_operations should get a .llseek operation so we can make nonseekable_open the default for future file operations without a .llseek pointer. The three cases that we can automatically detect are no_llseek, seq_lseek and default_llseek. For cases where we can we can automatically prove that the file offset is always ignored, we use noop_llseek, which maintains the current behavior of not returning an error from a seek. New drivers should normally not use noop_llseek but instead use no_llseek and call nonseekable_open at open time. Existing drivers can be converted to do the same when the maintainer knows for certain that no user code relies on calling seek on the device file. The generated code is often incorrectly indented and right now contains comments that clarify for each added line why a specific variant was chosen. In the version that gets submitted upstream, the comments will be gone and I will manually fix the indentation, because there does not seem to be a way to do that using coccinelle. Some amount of new code is currently sitting in linux-next that should get the same modifications, which I will do at the end of the merge window. Many thanks to Julia Lawall for helping me learn to write a semantic patch that does all this. ===== begin semantic patch ===== // This adds an llseek= method to all file operations, // as a preparation for making no_llseek the default. // // The rules are // - use no_llseek explicitly if we do nonseekable_open // - use seq_lseek for sequential files // - use default_llseek if we know we access f_pos // - use noop_llseek if we know we don't access f_pos, // but we still want to allow users to call lseek // @ open1 exists @ identifier nested_open; @@ nested_open(...) { <+... nonseekable_open(...) ...+> } @ open exists@ identifier open_f; identifier i, f; identifier open1.nested_open; @@ int open_f(struct inode *i, struct file *f) { <+... ( nonseekable_open(...) | nested_open(...) ) ...+> } @ read disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ read_no_fpos disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { ... when != off } @ write @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ write_no_fpos @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { ... when != off } @ fops0 @ identifier fops; @@ struct file_operations fops = { ... }; @ has_llseek depends on fops0 @ identifier fops0.fops; identifier llseek_f; @@ struct file_operations fops = { ... .llseek = llseek_f, ... }; @ has_read depends on fops0 @ identifier fops0.fops; identifier read_f; @@ struct file_operations fops = { ... .read = read_f, ... }; @ has_write depends on fops0 @ identifier fops0.fops; identifier write_f; @@ struct file_operations fops = { ... .write = write_f, ... }; @ has_open depends on fops0 @ identifier fops0.fops; identifier open_f; @@ struct file_operations fops = { ... .open = open_f, ... }; // use no_llseek if we call nonseekable_open //////////////////////////////////////////// @ nonseekable1 depends on !has_llseek && has_open @ identifier fops0.fops; identifier nso ~= "nonseekable_open"; @@ struct file_operations fops = { ... .open = nso, ... +.llseek = no_llseek, /* nonseekable */ }; @ nonseekable2 depends on !has_llseek @ identifier fops0.fops; identifier open.open_f; @@ struct file_operations fops = { ... .open = open_f, ... +.llseek = no_llseek, /* open uses nonseekable */ }; // use seq_lseek for sequential files ///////////////////////////////////// @ seq depends on !has_llseek @ identifier fops0.fops; identifier sr ~= "seq_read"; @@ struct file_operations fops = { ... .read = sr, ... +.llseek = seq_lseek, /* we have seq_read */ }; // use default_llseek if there is a readdir /////////////////////////////////////////// @ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier readdir_e; @@ // any other fop is used that changes pos struct file_operations fops = { ... .readdir = readdir_e, ... +.llseek = default_llseek, /* readdir is present */ }; // use default_llseek if at least one of read/write touches f_pos ///////////////////////////////////////////////////////////////// @ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read.read_f; @@ // read fops use offset struct file_operations fops = { ... .read = read_f, ... +.llseek = default_llseek, /* read accesses f_pos */ }; @ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, ... + .llseek = default_llseek, /* write accesses f_pos */ }; // Use noop_llseek if neither read nor write accesses f_pos /////////////////////////////////////////////////////////// @ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; identifier write_no_fpos.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, .read = read_f, ... +.llseek = noop_llseek, /* read and write both use no f_pos */ }; @ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write_no_fpos.write_f; @@ struct file_operations fops = { ... .write = write_f, ... +.llseek = noop_llseek, /* write uses no f_pos */ }; @ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; @@ struct file_operations fops = { ... .read = read_f, ... +.llseek = noop_llseek, /* read uses no f_pos */ }; @ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; @@ struct file_operations fops = { ... +.llseek = noop_llseek, /* no read or write fn */ }; ===== End semantic patch ===== Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Julia Lawall <julia@diku.dk> Cc: Christoph Hellwig <hch@infradead.org>
2010-10-14arch/tile: prevent corrupt top frame from causing backtracer runawayChris Metcalf
The backtracer will normally cut itself off after 100 frames anyway, but it's messy. With this change we notice that the frame being reported is the same as the last one, and cut off the dump with a message similar to what gdb displays in the same circumstance. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2010-10-14arch/tile: change lower bound on syscall error return to -4095Chris Metcalf
Previously we were using -1023, which is fine for normal syscall error returns, but the common value in use for other platforms is -4095, and one Tilera-specific driver does use values in the -1100 range, so tickled this bug. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2010-10-14arch/tile: Add a warning if we try to allocate too much vmalloc memory.Chris Metcalf
2010-10-14arch/tile: update some comments to clarify register usage.Chris Metcalf
2010-10-14arch/tile: Use <asm-generic/syscalls.h>Chris Metcalf
With this change we now include <asm-generic/syscalls.h> into the "tile" version of the header. To take full advantage of the prototypes there, we also change our naming convention for "struct pt_regs *" syscalls so that, e.g., _sys_execve() is the "true" syscall entry, which sets the appropriate register to point to the pt_regs before calling sys_execve(). While doing this I realized I no longer needed the fork and vfork entry point stubs, since those functions aren't in the generic syscall ABI, so I removed them as well. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2010-10-12Merge branch 'x86/urgent' of into irq/sparseirqThomas Gleixner
Reason: Pull in the latest io_apic bugfixes Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-09-24arch/tile: remove dead code from intvec_32.SChris Metcalf
This "bpt_code" instruction was killed off in our development line a while ago (the actual definition of bpt_code that is used is in kernel/traps.c) but I didn't push it for 2.6.36 because it seemed harmless and I didn't want to try to push more than absolutely necessary. However, we recently fixed a bug in our gcc that had been causing "-gdwarf2" not to be passed to the assembler, and passing this flag causes an erroneous assembler failure in the presence of code in a data section, sometimes. While we'd like to track down the bug in the assembler, we'd also like to make sure 2.6.36 builds with the current toolchain, so I'm removing this dead code as well. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2010-09-23genirq: Cleanup irq_chip->typename leftoversThomas Gleixner
3 years transition phase is enough. Cleanup the last users and remove the cruft. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Leo Chen <leochen@broadcom.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Chris Zankel <chris@zankel.net>
2010-09-15arch/tile: fix formatting bug in register dumpsChris Metcalf
This cut-and-paste bug was caused by rewriting the register dump code to use only a single printk per line of output. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2010-09-15arch/tile: Save and restore extra user state for tilegxChris Metcalf
During context switch, save and restore a couple of additional bits of tilegx user state that can be persistently modified by userspace. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2010-09-15arch/tile: Change struct sigcontext to be more usefulChris Metcalf
Rather than just using pt_regs, it now contains the actual saved state explicitly, similar to pt_regs. By doing it this way, we provide a cleaner API for userspace (or equivalently, we avoid the need for libc to provide its own definition of sigcontext). While we're at it, move PT_FLAGS_xxx to where they are not visible from userspace. And always pass siginfo and mcontext to signal handlers, even if they claim they don't need it, since sometimes they actually try to use it anyway in practice. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2010-09-15arch/tile: finish const-ifying sys_execve()Chris Metcalf
The sys_execve() implementation was properly const-ified but not the declaration, the syscall wrappers, or the compat version. This change completes the constification process. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2010-08-17Make do_execve() take a const filename pointerDavid Howells
Make do_execve() take a const filename pointer so that kernel_execve() compiles correctly on ARM: arch/arm/kernel/sys_arm.c:88: warning: passing argument 1 of 'do_execve' discards qualifiers from pointer target type This also requires the argv and envp arguments to be consted twice, once for the pointer array and once for the strings the array points to. This is because do_execve() passes a pointer to the filename (now const) to copy_strings_kernel(). A simpler alternative would be to cast the filename pointer in do_execve() when it's passed to copy_strings_kernel(). do_execve() may not change any of the strings it is passed as part of the argv or envp lists as they are some of them in .rodata, so marking these strings as const should be fine. Further kernel_execve() and sys_execve() need to be changed to match. This has been test built on x86_64, frv, arm and mips. Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-13arch/tile: extend syscall ABI to set r1 on return as well.Chris Metcalf
Until now, the tile architecture ABI for syscall return has just been that r0 holds the return value, and an error is only signalled like it is for kernel code, with a negative small number. However, this means that in multiple places in userspace we end up writing the same three-cycle idiom that tests for a small negative number for error. It seems cleaner to instead move that code into the kernel, and set r1 to hold zero on success or errno on failure; previously, r1 was just zeroed on return from the kernel (to avoid leaking kernel state). This way a single conditional branch after the syscall is sufficient to test for the failure case. The number of cycles taken is the same, but the error-checking code is in just one place, so total code size is smaller, and random userspace syscall code is easier to understand. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2010-08-13arch/tile: support backtracing on TILE-GxChris Metcalf
This functionality was stubbed out until recently. Now we support our normal backtracing API on TILE-Gx as well as on TILE64/TILEPro. This change includes a tweak to the instruction encoding caused by adding addxli for compat mode. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2010-08-13arch/tile: Fix a couple of issues with the COMPAT code for TILE-Gx.Chris Metcalf
First, the siginfo preamble wasn't quite right; we need to indicate that we are padding up to 4 ints of preamble for 64-bit code, and then for compat mode we need to pad differently, using only 3 ints. Second, the C ABI requires a save area of two registers, not two pointers, since in compat mode we have 64-bit registers all of which we need to save, even though we only have 32-bit VAs. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2010-08-13arch/tile: Use separate, better minsec values for clocksource and sched_clock.Chris Metcalf
We were using the same 5-sec minsec for the clocksource and sched_clock that we were using for the clock_event_device. For the clock_event_device that's exactly right since it has a short maximum countdown time. But for sched_clock we want to avoid wraparound when converting from ticks to nsec over a much longer window, so we force a shift of 10. And for clocksource it seems dodgy to use a 5-sec minsec as well, so we copy some other platforms and force a shift of 22. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2010-08-13arch/tile: correct a bug in freeing bootmem by VA for the optional second ↵Chris Metcalf
initrd. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2010-08-13arch: tile: kernel/proc.c Removed duplicated #includeAndrea Gelmini
Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net> Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2010-07-16arch/tile: check kmalloc() resultKulikov Vasiliy
If kmalloc() fails exit with -ENOMEM. Signed-off-by: Kulikov Vasiliy <segooon@gmail.com> Acked-by: Chris Metcalf <cmetcalf@tilera.com>
2010-07-06arch/tile: avoid erroneous error return for PTRACE_POKEUSR.Chris Metcalf
Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> Acked-by: Arnd Bergmann <arnd@arndb.de>
2010-07-06arch/tile: Miscellaneous cleanup changes.Chris Metcalf
This commit is primarily changes caused by reviewing "sparse" and "checkpatch" output on our sources, so is somewhat noisy, since things like "printk() -> pr_err()" (or whatever) throughout the codebase tend to get tedious to read. Rather than trying to tease apart precisely which things changed due to which type of code review, this commit includes various cleanups in the code: - sparse: Add declarations in headers for globals. - sparse: Fix __user annotations. - sparse: Using gfp_t consistently instead of int. - sparse: removing functions not actually used. - checkpatch: Clean up printk() warnings by using pr_info(), etc.; also avoid partial-line printks except in bootup code. - checkpatch: Use exposed structs rather than typedefs. - checkpatch: Change some C99 comments to C89 comments. In addition, a couple of minor other changes are rolled in to this commit: - Add support for a "raise" instruction to cause SIGFPE, etc., to be raised. - Remove some compat code that is unnecessary when we fully eliminate some of the deprecated syscalls from the generic syscall ABI. - Update the tile_defconfig to reflect current config contents. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> Acked-by: Arnd Bergmann <arnd@arndb.de>
2010-07-06arch/tile: Shrink the tile-opcode files considerably.Chris Metcalf
The C file (tile-desc_{32,64}.c) was about 300KB before this change, and is now shrunk down to 100K. The original file included support for BFD in the binutils toolchain, which is not necessary in the kernel; the kernel version only needs to include enough support to enable the single-stepper and backtracer. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> Acked-by: Arnd Bergmann <arnd@arndb.de>
2010-07-06arch/tile: Add driver to enable access to the user dynamic network.Chris Metcalf
This network (the "UDN") connects all the cpus on the chip in a wormhole-routed dynamic network. Subrectangles of the chip can be allocated by a "create" ioctl on /dev/hardwall, and then to access the UDN in that rectangle, tasks must perform an "activate" ioctl on that same file object after affinitizing themselves to a single cpu in the region. Sending a wormhole-routed message that tries to leave that subrectangle causes all activated tasks to receive a SIGILL (just as they would if they tried to access the UDN without first activating themselves to a hardwall rectangle). The original submission of this code to LKML had the driver instantiated under /proc/tile/hardwall. Now we just use a character device for this, conventionally /dev/hardwall. Some futures planning for the TILE-Gx chip suggests that we may want to have other types of devices that share the general model of "bind a task to a cpu, then 'activate' a file descriptor on a pseudo-device that gives access to some hardware resource". As such, we are using a device rather than, for example, a syscall, to set up and activate this code. As part of this change, the compat_ptr() declaration was fixed and used to pass the compat_ioctl argument to the normal ioctl. So far we limit compat code to 2GB, so the difference between zero-extend and sign-extend (the latter being correct, eventually) had been overlooked. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> Acked-by: Arnd Bergmann <arnd@arndb.de>
2010-07-06arch/tile: Enable more sophisticated IRQ model for 32-bit chips.Chris Metcalf
This model is based on the on-chip interrupt model used by the TILE-Gx next-generation hardware, and interacts much more cleanly with the Linux generic IRQ layer. The change includes modifications to the Tilera hypervisor, which are reflected in the hypervisor headers in arch/tile/include/arch/. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> Acked-by: Thomas Gleixner <tglx@linutronix.de>
2010-06-07Revert adding some arch-specific signal syscalls to <linux/syscalls.h>.Chris Metcalf
It turns out there is some variance on the calling conventions for these syscalls, and <asm-generic/syscalls.h> is already the mechanism used to handle this. Switch arch/tile over to using that mechanism and tweak the calling conventions for a couple of tile syscalls to match <asm-generic/syscalls.h>. Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2010-06-05arch/tile: Do not use GFP_KERNEL for dma_alloc_coherent().Chris Metcalf
Feedback from fujita.tomonori@lab.ntt.co.jp. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2010-06-04arch/tile: core support for Tilera 32-bit chips.Chris Metcalf
This change is the core kernel support for TILEPro and TILE64 chips. No driver support (except the console driver) is included yet. This includes the relevant Linux headers in asm/; the low-level low-level "Tile architecture" headers in arch/, which are shared with the hypervisor, etc., and are build-system agnostic; and the relevant hypervisor headers in hv/. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Reviewed-by: Paul Mundt <lethal@linux-sh.org>
