The Tile architecture port was added by Chris Metcalf in 2010, and
maintained until early 2018 when he orphaned it due to his departure
from Mellanox, and nobody else stepped up to maintain it. The product
line is still around in the form of the BlueField SoC, but no longer
uses the Tile architecture.
There are also still products for sale with Tile-GX SoCs, notably the
Mikrotik CCR router family. The products all use old (linux-3.3) kernels
with lots of patches and won't be upgraded by their manufacturers. There
have been efforts to port both OpenWRT and Debian to these, but both
projects have stalled and are very unlikely to be continued in the future.
Given that we are reasonably sure that nobody is still using the port
with an upstream kernel any more, it seems better to remove it now while
the port is in a good shape than to let it bitrot for a few years first.
Cc: Chris Metcalf <chris.d.metcalf@gmail.com>
Cc: John Paul Adrian Glaubitz <glaubitz@physik.fu-berlin.de>
Link: http://www.mellanox.com/page/npu_multicore_overview
Link: https://jenkins.debian.net/view/rebootstrap/job/rebootstrap_tilegx_gcc7/
And other message logging neatening.
Other miscellanea:
o coalesce formats
o realign arguments
o standardize a couple of macros
o use __func__ instead of embedding the function name
Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
This change introduces new flags for the hv_install_context()
API that passes a page table pointer to the hypervisor. Clients
can explicitly request 4K, 16K, or 64K small pages when they
install a new context. In practice, the page size is fixed at
kernel compile time and the same size is always requested every
time a new page table is installed.
The <hv/hypervisor.h> header changes so that it provides more abstract
macros for managing "page" things like PFNs and page tables. For
example there is now a HV_DEFAULT_PAGE_SIZE_SMALL instead of the old
HV_PAGE_SIZE_SMALL. The various PFN routines have been eliminated and
only PA- or PTFN-based ones remain (since PTFNs are always expressed
in fixed 2KB "page" size). The page-table management macros are
renamed with a leading underscore and take page-size arguments with
the presumption that clients will use those macros in some single
place to provide the "real" macros they will use themselves.
I happened to notice the old hv_set_caching() API was totally broken
(it assumed 4KB pages) so I changed it so it would nominally work
correctly with other page sizes.
Tag modules with the page size so you can't load a module built with
a conflicting page size. (And add a test for SMP while we're at it.)
Use the more commonly used __noreturn instead of ATTRIB_NORETURN.
Cc: Haavard Skinnemoen <hskinnemoen@gmail.com>
Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Acked-by: Ralf Baechle <ralf@linux-mips.org>
Cc: Chris Metcalf <cmetcalf@tilera.com>
It's a very old and now unused prototype marking so just delete it.
Neaten panic pointer argument style to keep checkpatch quiet.
The Tilera architecture traditionally supports 64KB page sizes
to improve TLB utilization and improve performance when the
hardware is being used primarily to run a single application.
For more generic server scenarios, it can be beneficial to run
with 4KB page sizes, so this commit allows that to be specified
(by modifying the arch/tile/include/hv/pagesize.h header).
As part of this change, we also re-worked the PTE management
slightly so that PTE writes all go through a __set_pte() function
where we can do some additional validation. The set_pte_order()
function was eliminated since the "order" argument wasn't being used.
One bug uncovered was in the PCI DMA code, which wasn't properly
flushing the specified range. This was benign with 64KB pages,
but with 4KB pages we were getting some larger flushes wrong.
The per-cpu memory reservation code also needed updating to
conform with the newer percpu stuff; before it always chose 64KB,
and that was always correct, but with 4KB granularity we now have
to pay closer attention and reserve the amount of memory that will
be requested when the percpu code starts allocating.
This change makes KM_TYPE_NR independent of the actual deprecated
list of km_type values, which are no longer used in tile code anywhere.
For now we leave it set to 8, allowing that many nested mappings,
and thus reserving 32MB of address space.
A few remaining places using KM_* values were cleaned up as well.
This commit is primarily changes caused by reviewing "sparse"
and "checkpatch" output on our sources, so is somewhat noisy, since
things like "printk() -> pr_err()" (or whatever) throughout the
codebase tend to get tedious to read. Rather than trying to tease
apart precisely which things changed due to which type of code
review, this commit includes various cleanups in the code:
- sparse: Add declarations in headers for globals.
- sparse: Fix __user annotations.
- sparse: Using gfp_t consistently instead of int.
- sparse: removing functions not actually used.
- checkpatch: Clean up printk() warnings by using pr_info(), etc.;
also avoid partial-line printks except in bootup code.
- checkpatch: Use exposed structs rather than typedefs.
- checkpatch: Change some C99 comments to C89 comments.
In addition, a couple of minor other changes are rolled in
to this commit:
- Add support for a "raise" instruction to cause SIGFPE, etc., to be raised.
- Remove some compat code that is unnecessary when we fully eliminate
some of the deprecated syscalls from the generic syscall ABI.
- Update the tile_defconfig to reflect current config contents.
This change is the core kernel support for TILEPro and TILE64 chips.
No driver support (except the console driver) is included yet.
This includes the relevant Linux headers in asm/; the low-level
low-level "Tile architecture" headers in arch/, which are
shared with the hypervisor, etc., and are build-system agnostic;
and the relevant hypervisor headers in hv/.
Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Reviewed-by: Paul Mundt <lethal@linux-sh.org>
