path: root/arch/sparc64/kernel
2008-08-04sparc64: Build cpu list and mondo block at top-level xcall_deliver().David S. Miller
Then modify all of the xcall dispatch implementations get passed and use this information. Now all of the xcall dispatch implementations do not need to be mindful of details such as "is current cpu in the list?" and "is cpu online?" Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-04sparc64: Disable local interrupts around xcall_deliver_impl() invocation.David S. Miller
2008-08-04sparc64: Make all xcall_deliver's go through common helper function.David S. Miller
This just facilitates the next changeset where we'll be building the cpu list and mondo block in this helper function. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-04sparc64: Always allocate the send mondo blocks, even on non-sun4v.David S. Miller
The idea is that we'll use this cpu list array and mondo block even for non-hypervisor platforms. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-04sparc64: Make smp_cross_call_masked() take a cpumask_t pointer.David S. Miller
Ideally this could be simplified further such that we could pass the pointer down directly into the xcall_deliver() implementation. But if we do that we need to do the "cpu_online(cpu)" and "cpu != self" checks down in those functions. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-04sparc64: Directly call xcall_deliver() in smp_start_sync_tick_client.David S. Miller
We know the cpu is online and not the current cpu here. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-04sparc64: Call xcall_deliver() directly in some cases.David S. Miller
For these cases the callers make sure: 1) The cpus indicated are online. 2) The current cpu is not in the list of indicated cpus. Therefore we can pass a pointer to the mask directly. One of the motivations in this transformation is to make use of "&cpumask_of_cpu(cpu)" which evaluates to a pointer to constant data in the kernel and thus takes up no stack space. Hopefully someone in the future will change the interface of arch_send_call_function_ipi() such that it passes a const cpumask_t pointer so that this will optimize ever further. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-04sparc64: Use cpumask_t pointers and for_each_cpu_mask_nr() in xcall_deliver.David S. Miller
2008-08-04sparc64: Use xcall_deliver() consistently.David S. Miller
There remained some spots still vectoring to the appropriate *_xcall_deliver() function manually. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-04sparc64: Use function pointer for cross-call sending.David S. Miller
Initialize it using the smp_setup_processor_id() hook. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-04arch/sparc64/kernel/signal.c: removed duplicated #includeHuang Weiyi
Removed duplicated #include <linux/tracehook.h> in arch/sparc64/kernel/signal.c. Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-31sparc64: Do not clobber %g7 in setcontext() trap.David S. Miller
That's the userland thread register, so we should never try to change it like this. Based upon glibc bug nptl/6577 and suggestions by Jakub Jelinek. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-31sparc64: Kill __show_regs().David S. Miller
The story is that what we used to do when we actually used smp_report_regs() is that if you specifically only wanted to have the current cpu's registers dumped you would call "__show_regs()" otherwise you would call show_regs() which also invoked smp_report_regs(). Now that we killed off smp_report_regs() there is no longer any reason to have these two routines, just show_regs() is sufficient. Also kill off a stray declaration of show_regs() in sparc64_ksym.c Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-31sparc64: Kill smp_report_regs().David S. Miller
All the call sites are #if 0'd out and we have a much more useful global cpu dumping facility these days. smp_report_regs() is way too verbose to be usable. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-31sparc64: Kill VERBOSE_SHOWREGS code.David S. Miller
It just clutters everything up and even though I wrote that hack I can't remember having used it in the last 5 years or so. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-30sparc64: Hook up trigger_all_cpu_backtrace().David S. Miller
We already have code that does this, but it is only currently attached to sysrq-'y'. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-30sparc64: Make global reg dumping even more useful.David S. Miller
Record one more level of stack frame program counter. Particularly when lockdep and all sorts of spinlock debugging is enabled, figuring out the caller of spin_lock() is difficult when the cpu is stuck on the lock. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-29sparc64: Kill isa_bus_type.David S. Miller
I forgot to delete this when I removed the ISA bus layer from the sparc ports. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-28sparc64: Fix global reg snapshotting on self-cpu.David S. Miller
We were picking %i7 out of the wrong register window stack slot. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-27sparc64: tracehook_signal_handlerRoland McGrath
Call the standard hook after setting up signal handlers. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-27sparc64: tracehook: TIF_NOTIFY_RESUMERoland McGrath
This adds TIF_NOTIFY_RESUME support for sparc64. When set, we call tracehook_notify_resume() on the way to user mode. Signed-off-by: Roland McGrath <roland@redhat.com>
2008-07-27sparc64: tracehook syscallRoland McGrath
This changes sparc64 syscall tracing to use the new tracehook.h entry points. [ Add assembly changes to force an immediate -ENOSYS return from the system call when syscall_trace() returns non-zero at syscall entry. -DaveM ] Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-27sparc, sparc64: use arch/sparc/includeSam Ravnborg
The majority of this patch was created by the following script: *** ASM=arch/sparc/include/asm mkdir -p $ASM git mv include/asm-sparc64/ftrace.h $ASM git rm include/asm-sparc64/* git mv include/asm-sparc/* $ASM sed -ie 's/asm-sparc64/asm/g' $ASM/* sed -ie 's/asm-sparc/asm/g' $ASM/* *** The rest was an update of the top-level Makefile to use sparc for header files when sparc64 is being build. And a small fixlet to pick up the correct unistd.h from sparc64 code. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-07-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6: sparc: Wire up new system calls.
2008-07-25sparc: Wire up new system calls.David S. Miller
This wires up the recently added Wire up signalfd4, eventfd2, epoll_create1, dup3, pipe2, and inotify_init1 system calls. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-25kprobes: improve kretprobe scalability with hashed lockingSrinivasa D S
Currently list of kretprobe instances are stored in kretprobe object (as used_instances,free_instances) and in kretprobe hash table. We have one global kretprobe lock to serialise the access to these lists. This causes only one kretprobe handler to execute at a time. Hence affects system performance, particularly on SMP systems and when return probe is set on lot of functions (like on all systemcalls). Solution proposed here gives fine-grain locks that performs better on SMP system compared to present kretprobe implementation. Solution: 1) Instead of having one global lock to protect kretprobe instances present in kretprobe object and kretprobe hash table. We will have two locks, one lock for protecting kretprobe hash table and another lock for kretporbe object. 2) We hold lock present in kretprobe object while we modify kretprobe instance in kretprobe object and we hold per-hash-list lock while modifying kretprobe instances present in that hash list. To prevent deadlock, we never grab a per-hash-list lock while holding a kretprobe lock. 3) We can remove used_instances from struct kretprobe, as we can track used instances of kretprobe instances using kretprobe hash table. Time duration for kernel compilation ("make -j 8") on a 8-way ppc64 system with return probes set on all systemcalls looks like this. cacheline non-cacheline Un-patched kernel aligned patch aligned patch =============================================================================== real 9m46.784s 9m54.412s 10m2.450s user 40m5.715s 40m7.142s 40m4.273s sys 2m57.754s 2m58.583s 3m17.430s =========================================================== Time duration for kernel compilation ("make -j 8) on the same system, when kernel is not probed. ========================= real 9m26.389s user 40m8.775s sys 2m7.283s ========================= Signed-off-by: Srinivasa DS <srinivasa@in.ibm.com> Signed-off-by: Jim Keniston <jkenisto@us.ibm.com> Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: David S. Miller <davem@davemloft.net> Cc: Masami Hiramatsu <mhiramat@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24Merge branch 'timers-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: nohz: adjust tick_nohz_stop_sched_tick() call of s390 as well nohz: prevent tick stop outside of the idle loop
2008-07-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6: sparc64: Fix cpufreq notifier registry. sparc64: Fix lockdep issues in LDC protocol layer.
2008-07-24flag parameters: pipeUlrich Drepper
This patch introduces the new syscall pipe2 which is like pipe but it also takes an additional parameter which takes a flag value. This patch implements the handling of O_CLOEXEC for the flag. I did not add support for the new syscall for the architectures which have a special sys_pipe implementation. I think the maintainers of those archs have the chance to go with the unified implementation but that's up to them. The implementation introduces do_pipe_flags. I did that instead of changing all callers of do_pipe because some of the callers are written in assembler. I would probably screw up changing the assembly code. To avoid breaking code do_pipe is now a small wrapper around do_pipe_flags. Once all callers are changed over to do_pipe_flags the old do_pipe function can be removed. The following test must be adjusted for architectures other than x86 and x86-64 and in case the syscall numbers changed. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ #include <fcntl.h> #include <stdio.h> #include <unistd.h> #include <sys/syscall.h> #ifndef __NR_pipe2 # ifdef __x86_64__ # define __NR_pipe2 293 # elif defined __i386__ # define __NR_pipe2 331 # else # error "need __NR_pipe2" # endif #endif int main (void) { int fd[2]; if (syscall (__NR_pipe2, fd, 0) != 0) { puts ("pipe2(0) failed"); return 1; } for (int i = 0; i < 2; ++i) { int coe = fcntl (fd[i], F_GETFD); if (coe == -1) { puts ("fcntl failed"); return 1; } if (coe & FD_CLOEXEC) { printf ("pipe2(0) set close-on-exit for fd[%d]\n", i); return 1; } } close (fd[0]); close (fd[1]); if (syscall (__NR_pipe2, fd, O_CLOEXEC) != 0) { puts ("pipe2(O_CLOEXEC) failed"); return 1; } for (int i = 0; i < 2; ++i) { int coe = fcntl (fd[i], F_GETFD); if (coe == -1) { puts ("fcntl failed"); return 1; } if ((coe & FD_CLOEXEC) == 0) { printf ("pipe2(O_CLOEXEC) does not set close-on-exit for fd[%d]\n", i); return 1; } } close (fd[0]); close (fd[1]); puts ("OK"); return 0; } ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Signed-off-by: Ulrich Drepper <drepper@redhat.com> Acked-by: Davide Libenzi <davidel@xmailserver.org> Cc: Michael Kerrisk <mtk.manpages@googlemail.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24PAGE_ALIGN(): correctly handle 64-bit values on 32-bit architecturesAndrea Righi
On 32-bit architectures PAGE_ALIGN() truncates 64-bit values to the 32-bit boundary. For example: u64 val = PAGE_ALIGN(size); always returns a value < 4GB even if size is greater than 4GB. The problem resides in PAGE_MASK definition (from include/asm-x86/page.h for example): #define PAGE_SHIFT 12 #define PAGE_SIZE (_AC(1,UL) << PAGE_SHIFT) #define PAGE_MASK (~(PAGE_SIZE-1)) ... #define PAGE_ALIGN(addr) (((addr)+PAGE_SIZE-1)&PAGE_MASK) The "~" is performed on a 32-bit value, so everything in "and" with PAGE_MASK greater than 4GB will be truncated to the 32-bit boundary. Using the ALIGN() macro seems to be the right way, because it uses typeof(addr) for the mask. Also move the PAGE_ALIGN() definitions out of include/asm-*/page.h in include/linux/mm.h. See also lkml discussion: http://lkml.org/lkml/2008/6/11/237 [akpm@linux-foundation.org: fix drivers/media/video/uvc/uvc_queue.c] [akpm@linux-foundation.org: fix v850] [akpm@linux-foundation.org: fix powerpc] [akpm@linux-foundation.org: fix arm] [akpm@linux-foundation.org: fix mips] [akpm@linux-foundation.org: fix drivers/media/video/pvrusb2/pvrusb2-dvb.c] [akpm@linux-foundation.org: fix drivers/mtd/maps/uclinux.c] [akpm@linux-foundation.org: fix powerpc] Signed-off-by: Andrea Righi <righi.andrea@gmail.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-23sparc64: Fix cpufreq notifier registry.David S. Miller
Based upon a report by Daniel Smolik. We do it too early, which triggers a BUG in cpufreq_register_notifier(). Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-22sparc64: Fix lockdep issues in LDC protocol layer.David S. Miller
We're calling request_irq() with a IRQs disabled. No straightforward fix exists because we want to enable these IRQs and setup state atomically before getting into the IRQ handler the first time. What happens now is that we mark the VIRQ to not be automatically enabled by request_irq(). Then we make explicit enable_irq() calls when we grab the LDC channel. This way we don't need to call request_irq() illegally under the LDC channel lock any more. Bump LDC version and release date. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linusLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: remove CONFIG_KMOD from core kernel code remove CONFIG_KMOD from lib remove CONFIG_KMOD from sparc64 rework try_then_request_module to do less in non-modular kernels remove mention of CONFIG_KMOD from documentation make CONFIG_KMOD invisible modules: Take a shortcut for checking if an address is in a module module: turn longs into ints for module sizes Shrink struct module: CONFIG_UNUSED_SYMBOLS ifdefs module: reorder struct module to save space on 64 bit builds module: generic each_symbol iterator function module: don't use stop_machine for waiting rmmod
2008-07-22remove CONFIG_KMOD from sparc64Johannes Berg
One place is just a comment, the other a conditional, unused inclusion of linux/kmod.h. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-07-21sparc64: fix up bus_id changes in sparc core codeGreg Kroah-Hartman
This converts all instances of bus_id in the sparc core kernel to use either dev_set_name(), or dev_name() depending on the need. This is done in anticipation of removing the bus_id field from struct driver. Cc: Kay Sievers <kay.sievers@vrfy.org> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21sysdev: Pass the attribute to the low level sysdev show/store functionAndi Kleen
This allow to dynamically generate attributes and share show/store functions between attributes. Right now most attributes are generated by special macros and lots of duplicated code. With the attribute passed it's instead possible to attach some data to the attribute and then use that in shared low level functions to do different things. I need this for the dynamically generated bank attributes in the x86 machine check code, but it'll allow some further cleanups. I converted all users in tree to the new show/store prototype. It's a single huge patch to avoid unbisectable sections. Runtime tested: x86-32, x86-64 Compiled only: ia64, powerpc Not compile tested/only grep converted: sh, arm, avr32 Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21driver core: remove KOBJ_NAME_LEN defineKay Sievers
Kobjects do not have a limit in name size since a while, so stop pretending that they do. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-18Merge branch 'linus' into timers/nohzIngo Molnar
2008-07-18nohz: prevent tick stop outside of the idle loopThomas Gleixner
Jack Ren and Eric Miao tracked down the following long standing problem in the NOHZ code: scheduler switch to idle task enable interrupts Window starts here ----> interrupt happens (does not set NEED_RESCHED) irq_exit() stops the tick ----> interrupt happens (does set NEED_RESCHED) return from schedule() cpu_idle(): preempt_disable(); Window ends here The interrupts can happen at any point inside the race window. The first interrupt stops the tick, the second one causes the scheduler to rerun and switch away from idle again and we end up with the tick disabled. The fact that it needs two interrupts where the first one does not set NEED_RESCHED and the second one does made the bug obscure and extremly hard to reproduce and analyse. Kudos to Jack and Eric. Solution: Limit the NOHZ functionality to the idle loop to make sure that we can not run into such a situation ever again. cpu_idle() { preempt_disable(); while(1) { tick_nohz_stop_sched_tick(1); <- tell NOHZ code that we are in the idle loop while (!need_resched()) halt(); tick_nohz_restart_sched_tick(); <- disables NOHZ mode preempt_enable_no_resched(); schedule(); preempt_disable(); } } In hindsight we should have done this forever, but ... /me grabs a large brown paperbag. Debugged-by: Jack Ren <jack.ren@marvell.com>, Debugged-by: eric miao <eric.y.miao@gmail.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-07-18sparc64: Add missing hypervisor service group numbers.David S. Miller
2008-07-17sparc64: Convert to generic helpers for IPI function calls.David S. Miller
2008-07-17sparc: Use new '%pS' infrastructure to print symbols.David S. Miller
2008-07-17sparc: Merge asm-sparc{,64}/mman.hSam Ravnborg
Renaming the function sparc64_mmap_check() to sparc_mmap_check() was enough to make the two header files identical. :$ diff -u include/asm-sparc/mman.h include/asm-sparc64/mman.h :-- include/asm-sparc/mman.h 2008-06-13 06:46:39.000000000 +0200 :++ include/asm-sparc64/mman.h 2008-06-13 06:46:39.000000000 +0200 :@@ -1,5 +1,5 @@ :-#ifndef __SPARC_MMAN_H__ :-#define __SPARC_MMAN_H__ :+#ifndef __SPARC64_MMAN_H__ :+#define __SPARC64_MMAN_H__ : : #include <asm-generic/mman.h> : :@@ -23,9 +23,9 @@ : : #ifdef __KERNEL__ : #ifndef __ASSEMBLY__ :-#define arch_mmap_check(addr,len,flags) sparc_mmap_check(addr,len) :-int sparc_mmap_check(unsigned long addr, unsigned long len); :+#define arch_mmap_check(addr,len,flags) sparc64_mmap_check(addr,len) :+int sparc64_mmap_check(unsigned long addr, unsigned long len); : #endif : #endif : :-#endif /* __SPARC_MMAN_H__ */ :+#endif /* __SPARC64_MMAN_H__ */ Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-07-17sparc64/kernel/: make code staticAdrian Bunk
This patch makes the following needlessly global code static: - central.c: struct central_bus - central.c: struct fhc_list - central.c: apply_fhc_ranges() - central.c: apply_central_ranges() - ds.c: struct ds_states_template[] - pci_msi.c: sparc64_setup_msi_irq() - pci_msi.c: sparc64_teardown_msi_irq() - pci_sun4v.c: struct sun4v_dma_ops - sys_sparc32.c: cp_compat_stat64() Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-16Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (72 commits) Revert "x86/PCI: ACPI based PCI gap calculation" PCI: remove unnecessary volatile in PCIe hotplug struct controller x86/PCI: ACPI based PCI gap calculation PCI: include linux/pm_wakeup.h for device_set_wakeup_capable PCI PM: Fix pci_prepare_to_sleep x86/PCI: Fix PCI config space for domains > 0 Fix acpi_pm_device_sleep_wake() by providing a stub for CONFIG_PM_SLEEP=n PCI: Simplify PCI device PM code PCI PM: Introduce pci_prepare_to_sleep and pci_back_from_sleep PCI ACPI: Rework PCI handling of wake-up ACPI: Introduce new device wakeup flag 'prepared' ACPI: Introduce acpi_device_sleep_wake function PCI: rework pci_set_power_state function to call platform first PCI: Introduce platform_pci_power_manageable function ACPI: Introduce acpi_bus_power_manageable function PCI: make pci_name use dev_name PCI: handle pci_name() being const PCI: add stub for pci_set_consistent_dma_mask() PCI: remove unused arch pcibios_update_resource() functions PCI: fix pci_setup_device()'s sprinting into a const buffer ... Fixed up conflicts in various files (arch/x86/kernel/setup_64.c, arch/x86/pci/irq.c, arch/x86/pci/pci.h, drivers/acpi/sleep/main.c, drivers/pci/pci.c, drivers/pci/pci.h, include/acpi/acpi_bus.h) from x86 and ACPI updates manually.
2008-07-15Merge branch 'generic-ipi' into generic-ipi-for-linusIngo Molnar
Conflicts: arch/powerpc/Kconfig arch/s390/kernel/time.c arch/x86/kernel/apic_32.c arch/x86/kernel/cpu/perfctr-watchdog.c arch/x86/kernel/i8259_64.c arch/x86/kernel/ldt.c arch/x86/kernel/nmi_64.c arch/x86/kernel/smpboot.c arch/x86/xen/smp.c include/asm-x86/hw_irq_32.h include/asm-x86/hw_irq_64.h include/asm-x86/mach-default/irq_vectors.h include/asm-x86/mach-voyager/irq_vectors.h include/asm-x86/smp.h kernel/Makefile Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-15Merge branch 'core/stacktrace' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core/stacktrace' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: generic-ipi: powerpc/generic-ipi tree build failure stacktrace: fix build failure on sparc64 stacktrace: export save_stack_trace[_tsk] stacktrace: fix modular build, export print_stack_trace and save_stack_trace backtrace: replace timer with tasklet + completions stacktrace: add saved stack traces to backtrace self-test stacktrace: print_stack_trace() cleanup debugging: make stacktrace independent from DEBUG_KERNEL stacktrace: don't crash on invalid stack trace structs
2008-07-14Merge branch 'tracing/for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing/for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (228 commits) ftrace: build fix for ftraced_suspend ftrace: separate out the function enabled variable ftrace: add ftrace_kill_atomic ftrace: use current CPU for function startup ftrace: start wakeup tracing after setting function tracer ftrace: check proper config for preempt type ftrace: trace schedule ftrace: define function trace nop ftrace: move sched_switch enable after markers ftrace: prevent ftrace modifications while being kprobe'd, v2 fix "ftrace: store mcount address in rec->ip" mmiotrace broken in linux-next (8-bit writes only) ftrace: avoid modifying kprobe'd records ftrace: freeze kprobe'd records kprobes: enable clean usage of get_kprobe ftrace: store mcount address in rec->ip ftrace: build fix with gcc 4.3 namespacecheck: fixes ftrace: fix "notrace" filtering priority ftrace: fix printout ...
2008-07-14Merge commit 'v2.6.26' into bkl-removalJonathan Corbet
2008-07-08stacktrace: fix build failure on sparc64Stephen Rothwell
Today's linux-next build (spac64 allmodconfig) failed like this: arch/sparc64/kernel/stacktrace.c:50: warning: type defaults to `int' in declaration of `EXPORT_SYMBOL_GPL' arch/sparc64/kernel/stacktrace.c:50: warning: parameter names (without types) in function declaration arch/sparc64/kernel/stacktrace.c:50: warning: data definition has no type or storage class Signed-off-by: Stephen Rothwell <sf@canb.auug.org.au> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Ingo Molnar <mingo@elte.hu>
