path: root/arch/sparc/mm/init.c
2007-08-20[SPARC32]: Revert f642b263800e6e57c377d630be6d2a999683b579.David S. Miller
This causes boot failures for some people. It looks like in fact that some SILO provided ramdisk images should not be KERNBASE normalized. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-08-14[SPARC32]: Fix bogus ramdisk image location check.Mark Fortescue
This mirrors sparc64 commit 715a0ecc29c850d2b2f76e1803d3f22cd5a0ac0d sparc_ramdisk_image should always be decremented by KERNBASE. Signed-off-by: Mark Fortescue <mark@mtfhpc.demon.co.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-21[SPARC32]: Make PAGE_SHARED a read-mostly variable.Al Viro
same scheme as for sparc64, same rationale Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-14[PATCH] sparc: nr_free_pages() is unsigned longAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: William Irwin <wli@holomorphy.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-06-23[SPARC]: Port sparc64 in-kernel device tree code to sparc32.David S. Miller
2006-03-22[PATCH] remove set_page_count() outside mm/Nick Piggin
set_page_count usage outside mm/ is limited to setting the refcount to 1. Remove set_page_count from outside mm/, and replace those users with init_page_count() and set_page_refcounted(). This allows more debug checking, and tighter control on how code is allowed to play around with page->_count. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-29[SPARC]: remove use of asm/segment.hKumar Gala
Removed sparc architecture specific users of asm/segment.h and asm-sparc/segment.h itself Signed-off-by: Kumar Gala <kumar.gala@freescale.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-21[PATCH] mm: remove PG_highmemBadari Pulavarty
Remove PG_highmem, to save a page flag. Use is_highmem() instead. It'll generate a little more code, but we don't use PageHigheMem() in many places. Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
