path: root/arch/sparc/mm/fault.c
2005-11-09[SPARC]: Use ARRAY_SIZE macroTobias Klauser
Use ARRAY_SIZE macro instead of sizeof(x)/sizeof(x[0]) and remove a duplicate of ARRAY_SIZE which is never used anyways. Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[SPARC]: remove use of asm/segment.hKumar Gala
Removed sparc architecture specific users of asm/segment.h and asm-sparc/segment.h itself Signed-off-by: Kumar Gala <kumar.gala@freescale.com> Signed-off-by: David S. Miller <davem@davemloft.net>
