path: root/arch/sparc/kernel
2010-07-24of: make of_find_device_by_node genericJonas Bonn
There's no need for this function to be architecture specific and all four architectures defining it had the same definition. The function has been moved to drivers/of/platform.c. Signed-off-by: Jonas Bonn <jonas@southpole.se> [grant.likely@secretlab.ca: moved to drivers/of/platform.c, simplified code, and added kerneldoc comment] Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: David S. Miller <davem@davemloft.net>
2010-07-24sparc: remove references to of_device and to_of_deviceGrant Likely
of_device is just a #define alias to platform_device. This patch replaces all references to it with platform_device. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: David S. Miller <davem@davemloft.net>
2010-07-24of/platform: remove all of_bus_type and of_platform_bus_type referencesGrant Likely
Both of_bus_type and of_platform_bus_type are just #define aliases for the platform bus. This patch removes all references to them and switches to the of_register_platform_driver()/of_unregister_platform_driver() API for registering. Subsequent patches will convert each user of of_register_platform_driver() into plain platform_drivers without the of_platform_driver shim. At which point the of_register_platform_driver()/of_unregister_platform_driver() functions can be removed. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: David S. Miller <davem@davemloft.net>
2010-07-24of: Merge of_platform_bus_type with platform_bus_typeGrant Likely
of_platform_bus was being used in the same manner as the platform_bus. The only difference being that of_platform_bus devices are generated from data in the device tree, and platform_bus devices are usually statically allocated in platform code. Having them separate causes the problem of device drivers having to be registered twice if it was possible for the same device to appear on either bus. This patch removes of_platform_bus_type and registers all of_platform bus devices and drivers on the platform bus instead. A previous patch made the of_device structure an alias for the platform_device structure, and a shim is used to adapt of_platform_drivers to the platform bus. After all of of_platform_bus drivers are converted to be normal platform drivers, the shim code can be removed. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: David S. Miller <davem@davemloft.net>
2010-07-24Merge commit 'v2.6.35-rc6' into devicetree/nextGrant Likely
Conflicts: arch/sparc/kernel/prom_64.c
2010-07-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6: math-emu: correct test for downshifting fraction in _FP_FROM_INT() perf: Add DWARF register lookup for sparc MAINTAINERS: Add SBUS driver path to sparc entry. drivers/sbus: Remove unnecessary casts of private_data sparc: remove homegrown L1_CACHE_ALIGN macro sparc64: fix the build error due to smp_kgdb_capture_client() sparc64: Fix maybe_change_configuration() PCR setting. arch/sparc/kernel: Eliminate what looks like a NULL pointer dereference sparc64: Update defconfig. sunsu: Fix use after free in su_remove(). sunserial: Don't call add_preferred_console() when console= is specified. sparc32: Kill none_mask, it's bogus.
2010-07-14of/sparc: move is_root_node() to of.hAndres Salomon
Rename is_root_node() to of_node_is_root() and make it available for all archs to use, as it's not PROM-specific. Signed-off-by: Andres Salomon <dilinger@queued.net> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-07-14lmb: rename to memblockYinghai Lu
via following scripts FILES=$(find * -type f | grep -vE 'oprofile|[^K]config') sed -i \ -e 's/lmb/memblock/g' \ -e 's/LMB/MEMBLOCK/g' \ $FILES for N in $(find . -name lmb.[ch]); do M=$(echo $N | sed 's/lmb/memblock/g') mv $N $M done and remove some wrong change like lmbench and dlmb etc. also move memblock.c from lib/ to mm/ Suggested-by: Ingo Molnar <mingo@elte.hu> Acked-by: "H. Peter Anvin" <hpa@zytor.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-06-28sparc/of: Move of_device fields into struct pdev_archdataGrant Likely
This patch moves SPARC architecture specific data members out of struct of_device and into the pdev_archdata structure. The reason for this change is to unify the struct of_device definition amongst all the architectures. It also remvoes the .sysdata, .slot, .portid and .clock_freq properties because they aren't actually used by anything. A subsequent patch will replace struct of_device entirely with struct platform_device and the of_platform support code will share common routines with the platform bus (but the bus instances themselves can remain separate). This patch also adds 'struct resources *resource' and num_resources to match the fields defined in struct platform_device. After this change, 'struct platform_device' can be used as a drop-in replacement for 'struct of_platform'. This change is in preparation for merging the of_platform_bus_type with the platform_bus_type. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: David S. Miller <davem@davemloft.net> Cc: Stephen Rothwell <sfr@canb.auug.org.au>
2010-06-26Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
2010-06-25sparc64: fix the build error due to smp_kgdb_capture_client()Dongdong Deng
Signed-off-by: Dongdong Deng <dongdong.deng@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-23sparc64: Fix maybe_change_configuration() PCR setting.David S. Miller
Need to mask out the existing event bits before OR'ing in the new ones. Noticed by Peter Zijlstra. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-04arch/sparc/kernel: Eliminate what looks like a NULL pointer dereferenceJulia Lawall
At the point of the test, action cannot be NULL, as it has been dereferenced in the code just above. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r exists@ expression E,E1; identifier f; statement S1,S2,S3; @@ if ((E == NULL && ...) || ...) { ... when != if (...) S1 else S2 when != E = E1 * E->f ... when any } else S3 // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-27Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (61 commits) tracing: Add __used annotation to event variable perf, trace: Fix !x86 build bug perf report: Support multiple events on the TUI perf annotate: Fix up usage of the build id cache x86/mmiotrace: Remove redundant instruction prefix checks perf annotate: Add TUI interface perf tui: Remove annotate from popup menu after failure perf report: Don't start the TUI if -D is used perf: Fix getline undeclared perf: Optimize perf_tp_event_match() perf: Remove more code from the fastpath perf: Optimize the !vmalloc backed buffer perf: Optimize perf_output_copy() perf: Fix wakeup storm for RO mmap()s perf-record: Share per-cpu buffers perf-record: Remove -M perf: Ensure that IOC_OUTPUT isn't used to create multi-writer buffers perf, trace: Optimize tracepoints by using per-tracepoint-per-cpu hlist to track events perf, trace: Optimize tracepoints by removing IRQ-disable from perf/tracepoint interaction perf tui: Allow disabling the TUI on a per command basis in ~/.perfconfig ...
2010-05-22Merge remote branch 'origin' into secretlab/next-devicetreeGrant Likely
Merging in current state of Linus' tree to deal with merge conflicts and build failures in vio.c after merge. Conflicts: drivers/i2c/busses/i2c-cpm.c drivers/i2c/busses/i2c-mpc.c drivers/net/gianfar.c Also fixed up one line in arch/powerpc/kernel/vio.c to use the correct node pointer. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-05-22of: Remove duplicate fields from of_platform_driverGrant Likely
.name, .match_table and .owner are duplicated in both of_platform_driver and device_driver. This patch is a removes the extra copies from struct of_platform_driver and converts all users to the device_driver members. This patch is a pretty mechanical change. The usage model doesn't change and if any drivers have been missed, or if anything has been fixed up incorrectly, then it will fail with a compile time error, and the fixup will be trivial. This patch looks big and scary because it touches so many files, but it should be pretty safe. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Sean MacLennan <smaclennan@pikatech.com>
2010-05-20kgdb,sparc: Add in kgdb_arch_set_pc for sparcJason Wessel
The new debug core api requires all architectures that use to debug core to implement a function to set the program counter. Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Acked-by: David S. Miller <davem@davemloft.net>
2010-05-19Merge branch 'timers-for-linus-cleanups' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-for-linus-cleanups' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: avr32: Fix typo in read_persistent_clock() sparc: Convert sparc to use read/update_persistent_clock cris: Convert cris to use read/update_persistent_clock m68k: Convert m68k to use read/update_persistent_clock m32r: Convert m32r to use read/update_peristent_clock blackfin: Convert blackfin to use read/update_persistent_clock ia64: Convert ia64 to use read/update_persistent_clock avr32: Convert avr32 to use read/update_persistent_clock h8300: Convert h8300 to use read/update_persistent_clock frv: Convert frv to use read/update_persistent_clock mn10300: Convert mn10300 to use read/update_persistent_clock alpha: Convert alpha to use read/update_persistent_clock xtensa: Fix unnecessary setting of xtime time: Clean up direct xtime usage in xen
2010-05-18of: eliminate of_device->node and dev_archdata->{of,prom}_nodeGrant Likely
This patch eliminates the node pointer from struct of_device and the of_node (or prom_node) pointer from struct dev_archdata since the node pointer is now part of struct device proper when CONFIG_OF is set, and all users of the old pointer locations have already been converted over to use device->of_node. Also remove dev_archdata_{get,set}_node() as it is no longer used by anything. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-05-18of: Always use 'struct device.of_node' to get device node pointer.Grant Likely
The following structure elements duplicate the information in 'struct device.of_node' and so are being eliminated. This patch makes all readers of these elements use device.of_node instead. (struct of_device *)->node (struct dev_archdata *)->prom_node (sparc) (struct dev_archdata *)->of_node (powerpc & microblaze) Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-05-18perf, sparc: Implement group scheduling transactional APIsLin Ming
Convert to the transactional PMU API and remove the duplication of group_sched_in(). [cross build only] Signed-off-by: Lin Ming <ming.m.lin@intel.com> Acked-by: David Miller <davem@davemloft.net> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1272002193.5707.65.camel@minggr.sh.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-04-28driver-core: Add device node pointer to struct deviceGrant Likely
Currently, platforms using CONFIG_OF add a 'struct device_node *of_node' to dev->archdata. However, with CONFIG_OF becoming generic for all architectures, it makes sense for commonality to move it out of archdata and into struct device proper. This patch adds a struct device_node *of_node member to struct device and updates all locations which currently write the device_node pointer into archdata to also update dev->of_node. Subsequent patches will modify callers to use the archdata location and ultimately remove the archdata member entirely. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> CC: Michal Simek <monstr@monstr.eu> CC: Greg Kroah-Hartman <gregkh@suse.de> CC: Benjamin Herrenschmidt <benh@kernel.crashing.org> CC: "David S. Miller" <davem@davemloft.net> CC: Stephen Rothwell <sfr@canb.auug.org.au> CC: Jeremy Kerr <jeremy.kerr@canonical.com> CC: microblaze-uclinux@itee.uq.edu.au CC: linux-kernel@vger.kernel.org CC: linuxppc-dev@ozlabs.org CC: sparclinux@vger.kernel.org
2010-04-21sparc64: Fix stack dumping and tracing when function graph is enabled.David S. Miller
Like x86, when the function graph tracer is enabled, emit the ftrace stub as well as the program counter it will be transformed back into. We duplicate a lot of similar stack walking logic in 3 or 4 spots, so eventually we should consolidate things like x86 does. Thanks to Frederic Weisbecker for pointing this out. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-21sparc64: Show stack backtrace from show_regs() just like other platforms.David S. Miller
2010-04-20sparc64: Fix hardirq tracing in trap return path.David S. Miller
We can overflow the hardirq stack if we set the %pil here so early, just let the normal control flow do it. This is fine as we are allowed to do the actual IRQ enable at any point after we call trace_hardirqs_on. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-19sparc64: Use correct pt_regs in decode_access_size() error paths.David S. Miller
2010-04-14sparc64: Run NMIs on the hardirq stack.David S. Miller
Otherwise we can overflow the main stack with the function tracer enabled. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-13sparc: Fix forgotten kmemleak headers inclusionFrederic Weisbecker
Fix forgotten kmemleak headers inclusion for kmemleak_not_leak() declaration. This fixes the following build error: arch/sparc/kernel/irq_64.c: In function ‘sun4v_build_virq’: arch/sparc/kernel/irq_64.c:657: error: implicit declaration of function ‘kmemleak_not_leak’ Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-13Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
Conflicts: lib/Kconfig.debug
2010-04-12sparc64: Fix memory leak in pci_register_iommu_region().David S. Miller
Found by kmemleak. If request_resource() fails, we leak the struct resource we allocated to represent the IOMMU mapping area. This actually happens on sun4v machines because the IOMEM area is only reported sans the IOMMU region, unlike all previous systems. I'll need to fix that at some point, but for now fix the leak. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-12sparc64: Add kmemleak annotation to sun4v_build_virq()David S. Miller
The only reference we store to this memory is in the form of a physical address, so kmemleak can't see it. Add a kmemleak_not_leak() annotation. It's probably useful to be able to look at a dump of these things either via debugfs or similar, and thus we could at some point store them in some kind of table and therefore get rid of this annotation. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-12sparc64: Support kmemleak.David S. Miller
Only missing thing was an _sdata marker in vmlinux.lds.S Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-12sparc64: Add function graph tracer support.David S. Miller
2010-04-12sparc64: Use a seperate counter for timer interrupts and NMI checks, like x86.David S. Miller
This keeps us from having to use kstat_irqs_cpu() from the NMI handler, the former of which is a profiled function. Instead we use a currently empty slot in the cpu_data Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-12sparc64: Remove profiling from some low-level bits.David S. Miller
These include the timer implementation, perf events support, and the performance counter register (pcr) programming layer. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-12sparc64: Kill unnecessary static on local var in ftrace_call_replace().David S. Miller
2010-04-12sparc64: Use kstack_valid() in die_if_kernel().David S. Miller
This gets rid of a local function (is_kernel_stack()) which tries to do the same thing, yet poorly in that it doesn't handle IRQ stacks properly. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-05Merge branch 'master' into export-slabhTejun Heo
2010-04-03sparc64: Implement perf_arch_fetch_caller_regsDavid S. Miller
We provide regs->tstate, regs->tpc, regs->tnpc and regs->u_regs[UREG_FP]. regs->tstate is necessary for: user_mode() (via perf_exclude_event()) perf_misc_flags() (via perf_prepare_sample()) regs->tpc is necessary for: perf_instruction_pointer() (via perf_prepare_sample()) and regs->u_regs[UREG_FP] is necessary for: perf_callchain() (via perf_prepare_sample()) The regs->tnpc value is provided just to be tidy. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-03Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
2010-03-31sparc: Fix regset register window handling.David S. Miller
We have to adjust 'reg_window' down by 16 becuase the 'pos' iterator we'll use to index into the stack slots will be between 16 and 32. Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6: sparc64: Properly truncate pt_regs framepointer in perf callback. arch/sparc/kernel: Use set_cpus_allowed_ptr sparc: Fix use of uid16_t and gid16_t in asm/stat.h
2010-03-29sparc64: Properly truncate pt_regs framepointer in perf callback.David S. Miller
For 32-bit processes, we save the full 64-bits of the regs in pt_regs. But unlike when the userspace actually does load and store instructions, the top 32-bits don't get automatically truncated by the cpu in kernel mode (because the kernel doesn't execute with PSTATE_AM address masking enabled). So we have to do it by hand. Reported-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-27arch/sparc/kernel: Use set_cpus_allowed_ptrJulia Lawall
Use set_cpus_allowed_ptr rather than set_cpus_allowed. The semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression E1,E2; @@ - set_cpus_allowed(E1, cpumask_of_cpu(E2)) + set_cpus_allowed_ptr(E1, cpumask_of(E2)) @@ expression E; identifier I; @@ - set_cpus_allowed(E, I) + set_cpus_allowed_ptr(E, &I) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-13Merge branch 'perf-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: perf: Provide generic perf_sample_data initialization MAINTAINERS: Add Arnaldo as tools/perf/ co-maintainer perf trace: Don't use pager if scripting perf trace/scripting: Remove extraneous header read perf, ARM: Modify kuser rmb() call to compile for Thumb-2 x86/stacktrace: Don't dereference bad frame pointers perf archive: Don't try to collect files without a build-id perf_events, x86: Fixup fixed counter constraints perf, x86: Restrict the ANY flag perf, x86: rename macro in ARCH_PERFMON_EVENTSEL_ENABLE perf, x86: add some IBS macros to perf_event.h perf, x86: make IBS macros available in perf_event.h hw-breakpoints: Remove stub unthrottle callback x86/hw-breakpoints: Remove the name field perf: Remove pointless breakpoint union perf lock: Drop the buffers multiplexing dependency perf lock: Fix and add misc documentally things percpu: Add __percpu sparse annotations to hw_breakpoint
2010-03-13sparc: Convert sparc to use read/update_persistent_clockJohn Stultz
This patch converts the sparc architecture to use the generic read_persistent_clock and update_persistent_clock interfaces, reducing the amount of arch specific code we have to maintain, and allowing for further cleanups in the future. [ davem: compile fix: Here's a version that compiles, you have to get rid of the now unused variably last_rtc_update since we build with -Werror ] Signed-off-by: John Stultz <johnstul@us.ibm.com> Acked-by: David S. Miller <davem@davemloft.net> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: sparclinux@vger.kernel.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-03-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (56 commits) doc: fix typo in comment explaining rb_tree usage Remove fs/ntfs/ChangeLog doc: fix console doc typo doc: cpuset: Update the cpuset flag file Fix of spelling in arch/sparc/kernel/leon_kernel.c no longer needed Remove drivers/parport/ChangeLog Remove drivers/char/ChangeLog doc: typo - Table 1-2 should refer to "status", not "statm" tree-wide: fix typos "ass?o[sc]iac?te" -> "associate" in comments No need to patch AMD-provided drivers/gpu/drm/radeon/atombios.h devres/irq: Fix devm_irq_match comment Remove reference to kthread_create_on_cpu tree-wide: Assorted spelling fixes tree-wide: fix 'lenght' typo in comments and code drm/kms: fix spelling in error message doc: capitalization and other minor fixes in pnp doc devres: typo fix s/dev/devm/ Remove redundant trailing semicolons from macros fix typo "definetly" -> "definitely" in comment tree-wide: s/widht/width/g typo in comments ... Fix trivial conflict in Documentation/laptops/00-INDEX
2010-03-12dma-mapping: sparc: unify 32bit and 64bit dma_set_maskFUJITA Tomonori
This patchset transforms the PCI DMA API into the generic device model. It's one of the reasons why we introduced the generic DMA API long ago; driver writers are always able to use the generic DMA API with any bus instead of using bus specific DMA APIs such as pci_map_single, sbus_map_single, etc (only two bus specific APIs exist now; pci and ssb). Some of the PCI DMA API are already implented on the top of the generic DMA API (include/asm-generic/pci-dma-compat.h). But there are some exceptions. This patchset finishes the transformation. This patch: sparc has two dma_set_mask implementations for 32bit and 64bit. They are same except for the error returned value. We can safely unify them since the error returned value doesn't matter as long as it is negative (as DMA-API.txt describes). This patch also changes dma_set_mask not to call pci_set_dma_mask. Instead, dma_set_mask does the same thing that pci_set_dma_mask does. This change enables ut to change pci_set_dma_mask to call dma_set_mask; we can implement pci_set_dma_mask as pci-dma-compat.h does. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: David Miller <davem@davemloft.net> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Matt Turner <mattst88@gmail.com> Cc: James Bottomley <James.Bottomley@suse.de> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Greg KH <greg@kroah.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12improve sys_newuname() for compat architecturesChristoph Hellwig
On an architecture that supports 32-bit compat we need to override the reported machine in uname with the 32-bit value. Instead of doing this separately in every architecture introduce a COMPAT_UTS_MACHINE define in <asm/compat.h> and apply it directly in sys_newuname(). Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: James Morris <jmorris@namei.org> Cc: Andreas Schwab <schwab@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
