path: root/arch/sparc/kernel/vmlinux.lds.S
2010-04-12sparc64: Support kmemleak.David S. Miller
Only missing thing was an _sdata marker in vmlinux.lds.S Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-12sparc64: Add function graph tracer support.David S. Miller
2009-09-18sparc: Clean up linker script using new linker script macros.Geoffrey Thomas
Signed-off-by: Geoffrey Thomas <geofft@ksplice.com> Signed-off-by: Tim Abbott <tabbott@ksplice.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-09linker script: unify usage of discard definitionTejun Heo
Discarded sections in different archs share some commonality but have considerable differences. This led to linker script for each arch implementing its own /DISCARD/ definition, which makes maintaining tedious and adding new entries error-prone. This patch makes all linker scripts to move discard definitions to the end of the linker script and use the common DISCARDS macro. As ld uses the first matching section definition, archs can include default discarded sections by including them earlier in the linker script. ia64 is notable because it first throws away some ia64 specific subsections and then include the rest of the sections into the final image, so those sections must be discarded before the inclusion. defconfig compile tested for x86, x86-64, powerpc, powerpc64, ia64, alpha, sparc, sparc64 and s390. Michal Simek tested microblaze. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Mike Frysinger <vapier@gentoo.org> Tested-by: Michal Simek <monstr@monstr.eu> Cc: linux-arch@vger.kernel.org Cc: Michal Simek <monstr@monstr.eu> Cc: microblaze-uclinux@itee.uq.edu.au Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Tony Luck <tony.luck@intel.com>
2009-06-24linker script: throw away .discard sectionTejun Heo
x86 throws away .discard section but no other archs do. Also, .discard is not thrown away while linking modules. Make every arch and module linking throw it away. This will be used to define dummy variables for percpu declarations and definitions. This patch is based on Ivan Kokshaysky's alpha percpu patch. [ Impact: always throw away everything in .discard ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Cc: Russell King <linux@arm.linux.org.uk> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Bryan Wu <cooloney@kernel.org> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Tony Luck <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Michal Simek <monstr@monstr.eu> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: David S. Miller <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Chris Zankel <chris@zankel.net> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Ingo Molnar <mingo@elte.hu>
2009-04-26sparc: convert to use __HEAD and HEAD_TEXT macros.Tim Abbott
This has the consequence of changing the section name use for head code from ".text.head" to ".head.text". Since this commit changes all users in the architecture, this change should be harmless. Signed-off-by: Tim Abbott <tabbott@mit.edu> Cc: David S. Miller <davem@davemloft.net> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-27sparc: unify sections.hSam Ravnborg
While doing this use standard names for start/end so we could use definitions straight from asm-generic for all the typical symbols. This also allowed us to drop the use of PROVIDE in the linker script so sprc is less non-standard on this area. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-27sparc: use .data.init_task section for init_thread_unionSam Ravnborg
Use a dedicated aligned section for the init_thread_union variable and declare this section in vmlinux.lds. This align sparc with most other architectures. Eventually this allow the init_task bits to be unified across all architectures. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-04sparc,sparc64: prepare vmlinux.lds.S for unificationSam Ravnborg
This patch makes the two vmlinux.lds.S files identical and serve as documentation for the changes in each file. This mainly add stuffs to sparc32 that is otherwise only used by sparc64 and thus it should have no effect. Build tested only. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-30fix the section noise in sparc head.SAl Viro
usual .text.head trick Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-09[SPARC]: Merge asm-sparc{,64}/cache.hDavid S. Miller
2008-01-28all archs: consolidate init and exit sections in vmlinux.lds.hSam Ravnborg
This patch consolidate all definitions of .init.text, .init.data and .exit.text, .exit.data section definitions in the generic vmlinux.lds.h. This is a preparational patch - alone it does not buy us much good. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-13[SPARC]: beautify vmlinux.ldsSam Ravnborg
Make vmlinux.lds almost readable. When going through the file fixed the following: - Use PAGE_SIZE as replacement for hardcoded 4096 - Moves label definitions inside {} to avoid ld alignment that may be added between label and section Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-24[SPARC]: Add missing NOTES section.David S. Miller
This fixes boot failures when the build-id LD option is actually used, because without it we end up with multiple PT_LOAD sections which the SILO boot loader cannot handle. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-19define new percpu interface for shared dataFenghua Yu
per cpu data section contains two types of data. One set which is exclusively accessed by the local cpu and the other set which is per cpu, but also shared by remote cpus. In the current kernel, these two sets are not clearely separated out. This can potentially cause the same data cacheline shared between the two sets of data, which will result in unnecessary bouncing of the cacheline between cpus. One way to fix the problem is to cacheline align the remotely accessed per cpu data, both at the beginning and at the end. Because of the padding at both ends, this will likely cause some memory wastage and also the interface to achieve this is not clean. This patch: Moves the remotely accessed per cpu data (which is currently marked as ____cacheline_aligned_in_smp) into a different section, where all the data elements are cacheline aligned. And as such, this differentiates the local only data and remotely accessed data cleanly. Signed-off-by: Fenghua Yu <fenghua.yu@intel.com> Acked-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Christoph Lameter <clameter@sgi.com> Cc: <linux-arch@vger.kernel.org> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-19all-archs: consolidate .data section definition in asm-genericSam Ravnborg
With this consolidation we can now modify the .data section definition in one spot for all archs. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-05-19all-archs: consolidate .text section definition in asm-genericSam Ravnborg
Move definition of .text section to asm-generic. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-05-02[PATCH] x86: Allow percpu variables to be page-alignedJeremy Fitzhardinge
Let's allow page-alignment in general for per-cpu data (wanted by Xen, and Ingo suggested KVM as well). Because larger alignments can use more room, we increase the max per-cpu memory to 64k rather than 32k: it's getting a little tight. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Andi Kleen <ak@suse.de> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2007-02-11[PATCH] disable init/initramfs.c: architecturesJean-Paul Saman
Update all arch/*/kernel/vmlinux.lds.S to not include space for initramfs when CONFIG_BLK_DEV_INITRAMFS is not selected. This saves another 4 kbytes on most platfoms (some reserve PAGE_SIZE for initramfs). Signed-off-by: Jean-Paul Saman <jean-paul.saman@nxp.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-07[PATCH] relocatable kernel: Kallsyms generate relocatable symbolsEric W. Biederman
Print the addresses of non-absolute symbols relative to _text so that ld will generate relocations. Allowing a relocatable kernel to relocate them. We can't actually use the symbol names because kallsyms includes static symbols that are not exported from their object files. Add the _text symbol definitions to the architectures which don't define it otherwise linker will fail. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andi Kleen <ak@suse.de>
2006-10-27[PATCH] vmlinux.lds: consolidate initcall sectionsAndrew Morton
Add a vmlinux.lds.h helper macro for defining the eight-level initcall table, teach all the architectures to use it. This is a prerequisite for a patch which performs initcall synchronisation for multithreaded-probing. Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> [ Added AVR32 as well ] Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[SPARC32]: Fix sparc32 modpost warnings.Martin Habets
Fix these 2.6.19-rc1 build warnings from modpost: WARNING: vmlinux - Section mismatch: reference to .init.text:_sinittext from .text between 'core_kernel_text' (at offset 0x3e060) and '__kernel_text_address' WARNING: vmlinux - Section mismatch: reference to .init.text:_sinittext from .text between 'core_kernel_text' (at offset 0x3e064) and '__kernel_text_address' WARNING: vmlinux - Section mismatch: reference to .init.text:_einittext from .text between 'core_kernel_text' (at offset 0x3e07c) and '__kernel_text_address' WARNING: vmlinux - Section mismatch: reference to .init.text:_einittext from .text between 'core_kernel_text' (at offset 0x3e080) and '__kernel_text_address' WARNING: vmlinux - Section mismatch: reference to .init.text:_sinittext from .text between 'is_ksym_addr' (at offset 0x4b3a4) and 'kallsyms_expand_symbol' WARNING: vmlinux - Section mismatch: reference to .init.text:_sinittext from .text between 'is_ksym_addr' (at offset 0x4b3a8) and 'kallsyms_expand_symbol' WARNING: vmlinux - Section mismatch: reference to .init.text:_einittext from .text between 'is_ksym_addr' (at offset 0x4b3b4) and 'kallsyms_expand_symbol' WARNING: vmlinux - Section mismatch: reference to .init.text:_einittext from .text between 'is_ksym_addr' (at offset 0x4b3e4) and 'kallsyms_expand_symbol' WARNING: vmlinux - Section mismatch: reference to .init.text:_sinittext from .text between 'get_symbol_pos' (at offset 0x4b640) and 'kallsyms_lookup_size_offset' WARNING: vmlinux - Section mismatch: reference to .init.text:_sinittext from .text between 'get_symbol_pos' (at offset 0x4b644) and 'kallsyms_lookup_size_offset' WARNING: vmlinux - Section mismatch: reference to .init.text:_einittext from .text between 'get_symbol_pos' (at offset 0x4b654) and 'kallsyms_lookup_size_offset' WARNING: vmlinux - Section mismatch: reference to .init.text:_einittext from .text between 'get_symbol_pos' (at offset 0x4b658) and 'kallsyms_lookup_size_offset' WARNING: vmlinux - Section mismatch: reference to .init.text:_sinittext from .text between 'get_symbol_pos' (at offset 0x4b68c) and 'kallsyms_lookup_size_offset' The crux of the matter is that modpost only checks the relocatable sections. i386 vmlinux has none, so modpost does no checking on it (it does on the modules). However, sparc vmlinux has plenty of relocatable sections because it is being built with 'ld -r' (to allow for btfixup processing). So for sparc, modpost does do a lot of checking. Sure enough, running modpost on arch/sparc/boot/image yields no output (i.e. all is well). modpost.c check_sec_ref() has: /* We want to process only relocation sections and not .init */ if (sechdrs[i].sh_type == SHT_RELA) { // check here } else if (sechdrs[i].sh_type == SHT_REL) { // check here } Signed-off-by: Martin Habets <errandir_news@mph.eclipse.co.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-12-28[SPARC]: Use STABS_DEBUG and DWARF_DEBUG macros in vmlinux.lds.SDavid S. Miller
