path: root/arch/sparc/kernel/irq.c
2006-12-13[PATCH] getting rid of all casts of k[cmz]alloc() callsRobert P. J. Day
Run this: #!/bin/sh for f in $(grep -Erl "\([^\)]*\) *k[cmz]alloc" *) ; do echo "De-casting $f..." perl -pi -e "s/ ?= ?\([^\)]*\) *(k[cmz]alloc) *\(/ = \1\(/" $f done And then go through and reinstate those cases where code is casting pointers to non-pointers. And then drop a few hunks which conflicted with outstanding work. Cc: Russell King <rmk@arm.linux.org.uk>, Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Greg KH <greg@kroah.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Paul Fulghum <paulkf@microgate.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Karsten Keil <kkeil@suse.de> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Ian Kent <raven@themaw.net> Cc: Steven French <sfrench@us.ibm.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-17[SPARC]: Sparc compilation fix with floppy enabledKrzysztof Helt
This patch fixes a typo to make kernel compilable when floppy driver for Sparc is build. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-09IRQ: Use the new typedef for interrupt handler function pointersDavid Howells
Use the new typedef for interrupt handler function pointers rather than actually spelling out the full thing each time. This was scripted with the following small shell script: #!/bin/sh egrep -nHrl -e 'irqreturn_t[ ]*[(][*]' $* | while read i do echo $i perl -pi -e 's/irqreturn_t\s*[(]\s*[*]\s*([_a-zA-Z0-9]*)\s*[)]\s*[(]\s*int\s*,\s*void\s*[*]\s*[)]/irq_handler_t \1/g' $i || exit $? done Signed-Off-By: David Howells <dhowells@redhat.com>
2006-10-08[PATCH] sparc32 pt_regs fixesAl Viro
2006-07-21[SPARC]: Do not call sun4m_irq_rotate on sun4d.Raymond Burns
2006-07-02[PATCH] irq-flags: SPARC: Use the new IRQF_ constantsThomas Gleixner
Use the new IRQF_ constants and remove the SA_INTERRUPT define Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[SPARC]: Try to start getting SMP back into shape.Bob Breuer
Todo items: - IRQ_INPROGRESS flag - use sparc64 irq buckets, or generic irq_desc? - sun4d - re-indent large chunks of sun4m_smp.c - some places assume sequential cpu numbering (i.e. 0,1 instead of 0,2) Last I checked (with 2.6.14), random programs segfault with dual HyperSPARC. And with SuperSPARC II's, it seems stable but will eventually die from a write lock error (wrong lock owner or something). I haven't tried the HyperSPARC + highmem combination recently, so that may still be a problem. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-23[PATCH] more for_each_cpu() conversionsAndrew Morton
When we stop allocating percpu memory for not-possible CPUs we must not touch the percpu data for not-possible CPUs at all. The correct way of doing this is to test cpu_possible() or to use for_each_cpu(). This patch is a kernel-wide sweep of all instances of NR_CPUS. I found very few instances of this bug, if any. But the patch converts lots of open-coded test to use the preferred helper macros. Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Acked-by: Kyle McMartin <kyle@parisc-linux.org> Cc: Anton Blanchard <anton@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: Andi Kleen <ak@muc.de> Cc: Christian Zankel <chris@zankel.net> Cc: Philippe Elie <phil.el@wanadoo.fr> Cc: Nathan Scott <nathans@sgi.com> Cc: Jens Axboe <axboe@suse.de> Cc: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
