path: root/arch/sparc/kernel/ioport.c
2010-07-24sparc: remove references to of_device and to_of_deviceGrant Likely
of_device is just a #define alias to platform_device. This patch replaces all references to it with platform_device. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: David S. Miller <davem@davemloft.net>
2010-05-18of: Always use 'struct device.of_node' to get device node pointer.Grant Likely
The following structure elements duplicate the information in 'struct device.of_node' and so are being eliminated. This patch makes all readers of these elements use device.of_node instead. (struct of_device *)->node (struct dev_archdata *)->prom_node (sparc) (struct dev_archdata *)->of_node (powerpc & microblaze) Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-03-12dma-mapping: sparc: unify 32bit and 64bit dma_set_maskFUJITA Tomonori
This patchset transforms the PCI DMA API into the generic device model. It's one of the reasons why we introduced the generic DMA API long ago; driver writers are always able to use the generic DMA API with any bus instead of using bus specific DMA APIs such as pci_map_single, sbus_map_single, etc (only two bus specific APIs exist now; pci and ssb). Some of the PCI DMA API are already implented on the top of the generic DMA API (include/asm-generic/pci-dma-compat.h). But there are some exceptions. This patchset finishes the transformation. This patch: sparc has two dma_set_mask implementations for 32bit and 64bit. They are same except for the error returned value. We can safely unify them since the error returned value doesn't matter as long as it is negative (as DMA-API.txt describes). This patch also changes dma_set_mask not to call pci_set_dma_mask. Instead, dma_set_mask does the same thing that pci_set_dma_mask does. This change enables ut to change pci_set_dma_mask to call dma_set_mask; we can implement pci_set_dma_mask as pci-dma-compat.h does. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: David Miller <davem@davemloft.net> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Matt Turner <mattst88@gmail.com> Cc: James Bottomley <James.Bottomley@suse.de> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Greg KH <greg@kroah.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-11-02sparc,leon: Sparc-Leon SMP supportKonrad Eisele
Support SMP for a Sparc-Leon multiprocessor system. Add Leon specific SMP code to arch/sparc/kernel/leon_smp.c. Signed-off-by: Konrad Eisele <konrad@gaisler.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-11Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
Conflicts: arch/sparc/Kconfig
2009-09-01sparc: convert /proc/io_map, /proc/dvma_map to seq_fileAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-10sparc: Add CONFIG_DMA_API_DEBUG supportFUJITA Tomonori
All we need to do for CONFIG_DMA_API_DEBUG support is call dma_debug_init() in DMA code common for SPARC32 and SPARC64. Now SPARC32 uses two dma_map_ops structures for pci and sbus so there is not much dma stuff for SPARC32 in kernel/dma.c. kernel/ioport.c also includes dma stuff for SPARC32. So let's put all the dma stuff for SPARC32 in kernel/ioport.c and make kernel/dma.c common for SPARC32 and SPARC64. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Tested-by: Robert Reif <reif@earthlink.net> Acked-by: David S. Miller <davem@davemloft.net> Cc: tony.luck@intel.com Cc: fenghua.yu@intel.com LKML-Reference: <1249872797-1314-9-git-send-email-fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-10sparc: Use asm-generic/pci-dma-compatFUJITA Tomonori
This converts SPARC to use asm-generic/pci-dma-compat instead of the homegrown mechnism. SPARC32 has two dma_map_ops structures for pci and sbus (removing arch/sparc/kernel/dma.c, PCI and SBUS DMA accessor). The global 'dma_ops' is set to sbus_dma_ops and get_dma_ops() returns pci32_dma_ops for pci devices so we can use the appropriate dma mapping operations. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Tested-by: Robert Reif <reif@earthlink.net> Acked-by: David S. Miller <davem@davemloft.net> Cc: tony.luck@intel.com Cc: fenghua.yu@intel.com LKML-Reference: <1249872797-1314-8-git-send-email-fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-10sparc: Replace sbus_map_single and sbus_unmap_single with sbus_map_page and ↵FUJITA Tomonori
sbus_unmap_page This is a preparation for using asm-generic/pci-dma-compat.h; SPARC32 has two dma_map_ops structures for pci and sbus (removing arch/sparc/kernel/dma.c, PCI and SBUS DMA accessor). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Tested-by: Robert Reif <reif@earthlink.net> Acked-by: David S. Miller <davem@davemloft.net> Cc: tony.luck@intel.com Cc: fenghua.yu@intel.com LKML-Reference: <1249872797-1314-7-git-send-email-fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-08sparc: move EXPORT_SYMBOL to the symbols definitionSam Ravnborg
Move all applicable EXPORT_SYMBOL()s to the file where the respective symbol is defined. Removed all the includes that are no longer needed in sparc_ksyms_32.c Comment all remaining EXPORT_SYMBOL()s in sparc_ksyms_32.c Two symbols are shared with sparc64 thus the exports were removed from the sparc_ksyms_64.c too, along with the include their ommission made redundant. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Additions by Julian Calaby: * Moved EXPORT_SYMBOL()s for prom functions to their rightful places. * Made some minor cleanups to the includes and comments of sparc_ksyms_32.c * Made another subtraction from sparc_ksyms_64.c * Updated and tidied commit message. * Rebased patch over sparc-2.6.git HEAD. * Ensured that all modified files have the correct includes. Signed-off-by: Julian Calaby <julian.calaby@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-11sparc: use sparc64 version of scatterlist.hRobert Reif
Use sparc64 version of scatterlist.h. There are three main differences: dma_addr_t replaces __u32 dma_address replaces dvma_address dma_length replaces dvma_length dma_addr_t is a u32 on sparc32. Boot tested on sparc32. Signed-off-by: Robert Reif <reif@earthlink.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-29sparc: Kill now spurious includes of sbus.hDavid S. Miller
In order to make this week I also had to add an include of linux/dma-mapping.h to asm/pci_32.h because drivers/pci/pci.c really depends upon getting this header somehow. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-29sparc: Remove generic SBUS probing layer.David S. Miller
The individual SBUS IOMMU arch code now sets the IOMMU information directly into the OF device objects. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-29sparc: Kill sbus_arch_preinit().David S. Miller
32-bit sparc just needed it to register the ioport procfs bits, do this via an arch_initcall() instead. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-29sparc: Kill sbus_ioremap() and sbus_iounmap().David S. Miller
No more users. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-29sparc: Remove SBUS layer resource and irq handling.David S. Miller
All the drivers use OF device objects now for this information. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-29sparc: Kill SBUS layer IRQ hooks.David S. Miller
IRQs are obtained by drivers from the of_device struct. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-29sparc32: Make mmu_map_dma_area and mmu_unmap_dma_area take a device pointer.David S. Miller
This lets us kill this "map it in every IOMMU" crazy code, and also some of the final references to sbus_root. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-29sparc32: Kill mmu_translate_dvma() usage.David S. Miller
Just simply use virt_to_page() on the provided virtual address pointer. Kill #if 0'd code. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-29sparc: Move SBUS DMA attribute interfaces out of asm/sbus.hDavid S. Miller
This is in preparation for the subsequent asm/sbus.h removal. Also, make these routines take a "struct device" or no arguments, as appropriate. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-29sparc32: Implement more generic dma_*() interfaces.David S. Miller
These dispatch to either PCI or SBUS routines based upon the device bus type. This will allow us to let SBUS drivers call these routines. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-29sparc32: Make mmu_{get,release}_*() take a struct device pointer.David S. Miller
2008-08-29sparc: Make SBUS DMA interfaces take struct device.David S. Miller
This is the first step in converting all the SBUS drivers over to generic dma_*(). Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-29sparc32: Make IOMMU and IO-UNIT init work with device nodes.David S. Miller
And stick the iommu archdata pointer into the generic OF device tree of_device struct as well. We still have to pass the sbus_bus object down into the routines so that the SBUS bus objects get the iommu cookies set properly. After drivers get converted to being pure OF drivers, that can go away. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-07sparc: don't use asm/of_device.hStephen Rothwell
Use linux/of_device.h instead. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-17sparc/kernel/: possible cleanupsAdrian Bunk
This patch contains the following possible cleanups: - make the following needlessly global code static: - apc.c: apc_swift_idle() - ebus.c: ebus_blacklist_irq() - ebus.c: fill_ebus_child() - ebus.c: fill_ebus_device() - entry.S: syscall_is_too_hard - etra: tsetup_sun4c_stackchk - head.S: cputyp - head.S: prom_vector_p - idprom.c: Sun_Machines[] - ioport.c: _sparc_find_resource() - ioport.c: create_proc_read_entry() - irq.c: struct sparc_irq[] - rtrap.S: sun4c_rett_stackchk - setup.c: prom_sync_me() - setup.c: boot_flags - sun4c_irq.c: sun4c_sbint_to_irq() - sun4d_irq.c: sbus_tid[] - sun4d_irq.c: struct sbus_actions - sun4d_irq.c: sun4d_sbint_to_irq() - sun4m_irq.c: sun4m_sbint_to_irq() - sun4m_irq.c: sun4m_get_irqmask() - sun4m_irq.c: sun4m_timers - sun4m_smp.c: smp4m_cross_call() - sun4m_smp.c: smp4m_blackbox_id() - sun4m_smp.c: smp4m_blackbox_current() - time.c: sp_clock_typ - time.c: sbus_time_init() - traps.c: instruction_dump() - wof.S: spwin_sun4c_stackchk - wuf.S: sun4c_fwin_stackchk - #if 0 the following unused code: - process.c: sparc_backtrace_lock - process.c: __show_backtrace() - process.c: show_backtrace() - process.c: smp_show_backtrace_all_cpus() - remove the following unused code: - entry.S: __handle_exception - smp.c: smp_num_cpus - smp.c: smp_activated - smp.c: __cpu_number_map[] - smp.c: __cpu_logical_map[] - smp.c: bitops_spinlock - traps.c: trap_curbuf - traps.c: trapbuf[] - traps.c: linux_smp_still_initting - traps.c: thiscpus_tbr - traps.c: thiscpus_mid Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-20sparc: remove CVS keywordsAdrian Bunk
This patch removes the CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-03Spelling fixes: lenght->lengthPaulius Zaleckas
Signed-off-by: Paulius Zaleckas <pauliusz@yahoo.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-22Update arch/ to use sg helpersJens Axboe
2007-10-16SPARC: sg chaining supportJens Axboe
This updates the sparc iommu/pci dma mappers to sg chaining. Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-05-11[SPARC]: Spelling fixes.Simon Arlott
Spelling fixes in arch/sparc/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-31[SPARC64]: Fix of_iounmap() region release.David S. Miller
We need to pass in the resource otherwise we cannot release the region properly. We must know whether it is an I/O or MEM resource. Spotted by Eric Brower. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-30[PATCH] sparc32: add offset in pci_map_sg()Jan Andersson
Add sg->offset to sg->dvma_address in pci_map_sg() on sparc32. Without the offset, transfers to buffers that do not begin on a page boundary will not work as expected. Signed-off-by: Jan Andersson <jan.andersson@ieee.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: William Lee Irwin III <wli@holomorphy.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-10[SPARC]: Replace kmalloc+memset with kzallocYan Burman
Replace kmalloc+memset with kzalloc Signed-off-by: Yan Burman <burman.yan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-04Remove all inclusions of <linux/config.h>Dave Jones
kbuild explicitly includes this at build time. Signed-off-by: Dave Jones <davej@redhat.com>
2006-09-22[PATCH] sun4: fix sbus_setup_iommu()Al Viro
iommu_init() and iounit_init() are never called for sun4, but that's not enough - these calls should be ifdefed out since the functions in question simply do not exist for CONFIG_SUN4 kernel. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29[SPARC]: Add of_io{remap,unmap}().David S. Miller
2006-06-27[PATCH] 64bit resource: change resource core to use resource_size_tGreg Kroah-Hartman
Based on a patch series originally from Vivek Goyal <vgoyal@in.ibm.com> Cc: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-27[PATCH] 64bit resource: fix up printks for resources in arch and core codeGreg Kroah-Hartman
This is needed if we wish to change the size of the resource structures. Based on an original patch from Vivek Goyal <vgoyal@in.ibm.com> and Andrew Morton. (tweaked by Andy Isaacson <adi@hexapodia.org>) Cc: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Andy Isaacson <adi@hexapodia.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-23[SBUS]: Rewrite and plug into of_device framework.David S. Miller
I severely apologize, I was still learning how to program in C when I wrote this stuff 10 years ago... Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-23[SBUS]: Start cleaning up generic sbus support layer.David S. Miller
In particular, move the IRQ probing out to sparc32/sparc64 arch specific code where it belongs. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-05-07[SPARC]: show device name in /proc/dvma_mapMartin Habets
This patch will set the device name in a resource, which will be shown in /proc/dvma_map. Signed-off-by: Martin Habets <errandir_news@mph.eclipse.co.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SPARC]: BUG_ON() Conversion in arch/sparc/kernel/ioport.cEric Sesterhenn
this changes if() BUG(); constructs to BUG_ON() which is cleaner and can better optimized away Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-22[PATCH] unpaged: fix sound Bad page statesHugh Dickins
Earlier I unifdefed PageCompound, so that snd_pcm_mmap_control_nopage and others can give out a 0-order component of a higher-order page, which won't be mistakenly freed when zap_pte_range unmaps it. But many Bad page states reported a PG_reserved was freed after all: I had missed that we need to say __GFP_COMP to get compound page behaviour. Some of these higher-order pages are allocated by snd_malloc_pages, some by snd_malloc_dev_pages; or if SBUS, by sbus_alloc_consistent - but that has no gfp arg, so add __GFP_COMP into its sparc32/64 implementations. I'm still rather puzzled that DRM seems not to need a similar change. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
