path: root/arch/sparc/include/asm/dma.h
2012-05-13sparc32: Convert mmu_* interfaces from btfixup to method ops.David S. Miller
This set of changes displays one major danger of btfixup, interface signatures are not always type checked fully. As seen here the iounit variant of the map_dma_area routine had an incorrect type for one of it's arguments. It turns out to be harmless in this case, but just imagine trying to debug something involving this kind of problem. No thanks. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-13sparc: Kill mmu_{un,}lockarea().David S. Miller
These were used on sun4c during floppy data transfers since on that chip we had to lock the cpu mappings into the TLB because we cannot take a TLB miss during the assembler floppy interrupt handler that does the data transfer. That is no longer necessary since we've removed sun4c support, thus this stuff can disappear completely. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-12sparc32: Trivial removal of sun4c references in comments.David S. Miller
I left some around, like the ones in the openprom headers, since we need to think about which pieces of those datastructures and code we can completely toss now. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-29sparc: Kill now spurious includes of sbus.hDavid S. Miller
In order to make this week I also had to add an include of linux/dma-mapping.h to asm/pci_32.h because drivers/pci/pci.c really depends upon getting this header somehow. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-29sparc32: Make mmu_map_dma_area and mmu_unmap_dma_area take a device pointer.David S. Miller
This lets us kill this "map it in every IOMMU" crazy code, and also some of the final references to sbus_root. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-29sparc32: Kill mmu_translate_dvma and implementations.David S. Miller
No longer used. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-29sparc32: Make mmu_{get,release}_*() take a struct device pointer.David S. Miller
2008-08-29sparc: Kill SBUS DVMA layer.David S. Miller
This thing was completely pointless. Just find the OF device in the parent of drivers that want to program this device, and map the DMA regs inside such drivers too. This also moves the dummy claim_dma_lock() and release_dma_lock() implementation to floppy_32.h, which makes it handle this issue just like floppy_64.h does. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-27sparc, sparc64: use arch/sparc/includeSam Ravnborg
The majority of this patch was created by the following script: *** ASM=arch/sparc/include/asm mkdir -p $ASM git mv include/asm-sparc64/ftrace.h $ASM git rm include/asm-sparc64/* git mv include/asm-sparc/* $ASM sed -ie 's/asm-sparc64/asm/g' $ASM/* sed -ie 's/asm-sparc/asm/g' $ASM/* *** The rest was an update of the top-level Makefile to use sparc for header files when sparc64 is being build. And a small fixlet to pick up the correct unistd.h from sparc64 code. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
