path: root/arch/sparc/include/asm/asi.h
2012-10-09UAPI: (Scripted) Disintegrate arch/sparc/include/asmDavid Howells
Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2012-10-05sparc64: Niagara-4 bzero/memset, plus use MRU stores in page copy.David S. Miller
This adds optimized memset/bzero/page-clear routines for Niagara-4. We basically can do what powerpc has been able to do for a decade (via the "dcbz" instruction), which is use cache line clearing stores for bzero and memsets with a 'c' argument of zero. As long as we make the cache initializing store to each 32-byte subblock of the L2 cache line, it works. As with other Niagara-4 optimized routines, the key is to make sure to avoid any usage of the %asi register, as reads and writes to it cost at least 50 cycles. For the user clear cases, we don't use these new routines, we use the Niagara-1 variants instead. Those have to use %asi in an unavoidable way. A Niagara-4 8K page clear costs just under 600 cycles. Add definitions of the MRU variants of the cache initializing store ASIs. By default, cache initializing stores install the line as Least Recently Used. If we know we're going to use the data immediately (which is true for page copies and clears) we can use the Most Recently Used variant, to decrease the likelyhood of the lines being evicted before they get used. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-18sparc64: Add PCR ops for SPARC-T4.David S. Miller
This is enough to get the NMIs working, more work is needed for perf events. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-27sparc32: drop LEON hack for ASI_M_MMUREGSSam Ravnborg
All users of MMUREGS ASI is now LEON/SUN aware, so this is no longer required. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Daniel Hellstrom <daniel@gaisler.com> Cc: Konrad Eisele <konrad@gaisler.com>
2012-05-19sparc32,leon: move leon ASI definitions to asi.hSam Ravnborg
Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Konrad Eisele <konrad@gaisler.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-17sparc,leon: Redefine MMU register access asi if CONFIG_LEONKonrad Eisele
SPARC-LEON has a different ASI for mmu register accesses. Signed-off-by: Konrad Eisele <konrad@gaisler.com> Reviewed-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-27sparc, sparc64: use arch/sparc/includeSam Ravnborg
The majority of this patch was created by the following script: *** ASM=arch/sparc/include/asm mkdir -p $ASM git mv include/asm-sparc64/ftrace.h $ASM git rm include/asm-sparc64/* git mv include/asm-sparc/* $ASM sed -ie 's/asm-sparc64/asm/g' $ASM/* sed -ie 's/asm-sparc/asm/g' $ASM/* *** The rest was an update of the top-level Makefile to use sparc for header files when sparc64 is being build. And a small fixlet to pick up the correct unistd.h from sparc64 code. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
