path: root/arch/sparc/boot
2009-11-15arch/sparc/boot/*.c: Mark various internal functions staticJosh Triplett
Signed-off-by: Josh Triplett <josh@joshtriplett.org>
2009-08-16sparc64: build compressed image (zImage) by defaultJurij Smakov
Besides creating the uncompressed vmlinux image for sparc64, also create a compressed zImage. This is more consistent with other architectures and required to make the 'deb-pkg' target work. Signed-off-by: Jurij Smakov <jurij@wooyd.org> Signed-off-by: Frans Pop <elendil@planet.nl> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-25sparc32: Fix makefile not generating required filesJulian Calaby
The tftpboot build was failing with missing file errors. It turns out that $(obj)/image wasn't being generated which was causing the a.out conversion to be skipped and hence piggyback to be called with nonexistent files. Signed-off-by: Julian Calaby <julian.calaby@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-25sparc32: Fix tftpboot.img MakefileJulian Calaby
2009-06-25sparc: fix tftpboot.img buildSam Ravnborg
Kjetil Oftedal mentioned that piggyback_32 was failing when building a sparc image. I tracked this down to the fact that the kernel no longer provided an absolute symbol named "end". Commit 86ed40bd6fe511d26bb8f3fa65a84cb65c235366 ("sparc: unify sections.h") renamed end to _end but failed to update piggyback_32. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Kjetil Oftedal <oftedal@gmail.com> Cc: Robert Reif <reif@earthlink.net> Signed-off-by: Julian Calaby <julian.calaby@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-25sparc32: Fix obvious build issues for tftpboot.img build.Robert Reif
Signed-off-by: Robert Reif <reif@earthlink.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-25sparc64: Fix build warnings in piggyback_64.cJulian Calaby
This patch fixes the following build warnings: arch/sparc/boot/piggyback_64.c: In function 'main': arch/sparc/boot/piggyback_64.c:44: warning: 'end' may be used uninitialized in this function arch/sparc/boot/piggyback_64.c:44: warning: 'start' may be used uninitialized in this function Signed-off-by: Julian Calaby <julian.calaby@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-04sparc,sparc64: unify boot/Sam Ravnborg
Simple unification: o renamed piggyback to *_32.c/*_64.c o copied content of Makefile from sparc64 to sparc and guard it o updated sparc/boot/.gitignore o deleted remaining files in sparc64/boot Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-04sparc: gitignore a few filesSam Ravnborg
With this 'git status' no longer reports any new files At least not for a sparc allnoconfig build Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-04sparc: clean boot/Sam Ravnborg
Leave all cleaning to boot/Makefile and delete zImage too when we do a 'make clean' Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-04sparc: refactor MakefileSam Ravnborg
The btfixup step needs knowledge of all the .o files, but there is no need to pass them in independent variables. Simplify it to use only two variables. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-24sparc: Add target for a stripped kernelMartin Habets
Add a target for a stripped kernel. This is used for the various packaging targets (*-pkg). Signed-off-by: Martin Habets <errandir_news@mph.eclipse.co.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-20sparc: remove CVS keywordsAdrian Bunk
This patch removes the CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
