path: root/arch/sh
2018-12-18sh: dreamcast: rtc: push down rtc class ops into driverArnd Bergmann
The SH RTC support has an extra level of indirection to provide either the old read_persistent_clock/update_persistent_clock interface or the rtc-generic device for hctosys/systohc. Both do the same thing for dreamcast, so we can do away with the abstraction and simply let the RTC core code to take care of it. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2018-12-17sh: ecovec24: Fix an ifdefLinus Walleij
I managed to put the ifdef/else statements wrong when registering the GPIO descriptor table for MMC CD/WP. Fixing it up! Cc: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com> Cc: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Fixes: babd0b238d11 ("mmc: host: tmio: Use GPIO descriptors") Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
2018-12-17mmc: host: tmio: Use GPIO descriptorsLinus Walleij
The TMIO MMC driver was passing global GPIO numbers around for card detect. It turns out only one single board in the kernel was actually making use of this feature so it is pretty easy to convert the driver to use only GPIO descriptors. The lines are flagged as GPIO_ACTIVE_[LOW|HIGH] as that is what they are, and since we can now rely on the descriptors to have the right polarity, we set the "override_active_level" to false in mmc_gpiod_request_cd() and mmc_gpiod_request_ro(). Reviewed-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com> Acked-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
2018-12-17mmc: spi: Convert to use GPIO descriptorsLinus Walleij
Switch the SPI MMC driver to use GPIO descriptors internally and just look those up using the standard slot GPIO functions mmc_gpiod_request_cd() and mmc_gpiod_request_ro(). Make sure to request index 0 and 1 in accordance with the SPI MMC DT binding, and add the same GPIOs in machine descriptor tables on all boards that use SPI MMC in board files. The lines are flagged as GPIO_ACTIVE_[LOW|HIGH] as that is what they are, and since we can now rely on the descriptors to have the right polarity, we set the "override_active_level" to false in mmc_gpiod_request_cd() and mmc_gpiod_request_ro(). Cc: Hartley Sweeten <hsweeten@visionengravers.com> # Vision EP9307 Cc: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Reviewed-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
2018-12-14arch/sh/include/asm/io.h: provide prototypes for PCI I/O mapping in asm/io.hMark Brown
Most architectures provide prototypes for the PCI I/O mapping operations when asm/io.h is included but SH doesn't currently do that, leading to for example warnings in sound/pci/hda/patch_ca0132.c when pci_iomap() is used on current -next. Make SH more consistent with other architectures by including asm-generic/pci_iomap.h in asm/io.h. Link: http://lkml.kernel.org/r/20181106175142.27988-1-broonie@kernel.org Signed-off-by: Mark Brown <broonie@kernel.org> Reported-by: kbuild test robot <lkp@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Rich Felker <dalias@libc.org> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-12-13dma-mapping: always build the direct mapping codeChristoph Hellwig
All architectures except for sparc64 use the dma-direct code in some form, and even for sparc64 we had the discussion of a direct mapping mode a while ago. In preparation for directly calling the direct mapping code don't bother having it optionally but always build the code in. This is a minor hardship for some powerpc and arm configs that don't pull it in yet (although they should in a relase ot two), and sparc64 which currently doesn't need it at all, but it will reduce the ifdef mess we'd otherwise need significantly. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Jesper Dangaard Brouer <brouer@redhat.com> Tested-by: Jesper Dangaard Brouer <brouer@redhat.com> Tested-by: Tony Luck <tony.luck@intel.com>
2018-11-27sh/function_graph: Simplify with function_graph_enter()Steven Rostedt (VMware)
The function_graph_enter() function does the work of calling the function graph hook function and the management of the shadow stack, simplifying the work done in the architecture dependent prepare_ftrace_return(). Have superh use the new code, and remove the shadow stack management as well as having to set up the trace structure. This is needed to prepare for a fix of a design bug on how the curr_ret_stack is used. Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Rich Felker <dalias@libc.org> Cc: linux-sh@vger.kernel.org Cc: stable@kernel.org Fixes: 03274a3ffb449 ("tracing/fgraph: Adjust fgraph depth before calling trace return callback") Reviewed-by: Masami Hiramatsu <mhiramat@kernel.org> Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
2018-11-23pcmcia: allow PCMCIA support independent of the architectureChristoph Hellwig
There is nothing architecture specific in the PCMCIA core, so allow building it everywhere. The actual host controllers will depend on ISA, PCI or a specific SOC. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Dominik Brodowski <linux@dominikbrodowski.net> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Paul Burton <paul.burton@mips.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-11-23PCI: consolidate the PCI_DOMAINS and PCI_DOMAINS_GENERIC config optionsChristoph Hellwig
Move the definitions to drivers/pci and let the architectures select them. Two small differences to before: PCI_DOMAINS_GENERIC now selects PCI_DOMAINS, cutting down the churn for modern architectures. As the only architectured arm did previously also offer PCI_DOMAINS as a user visible choice in addition to selecting it from the relevant configs, this is gone now. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Paul Burton <paul.burton@mips.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-11-23PCI: consolidate PCI config entry in drivers/pciChristoph Hellwig
There is no good reason to duplicate the PCI menu in every architecture. Instead provide a selectable HAVE_PCI symbol that indicates availability of PCI support, and a FORCE_PCI symbol to for PCI on and the handle the rest in drivers/pci. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Palmer Dabbelt <palmer@sifive.com> Acked-by: Max Filippov <jcmvbkbc@gmail.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Paul Burton <paul.burton@mips.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-10-31mm: remove include/linux/bootmem.hMike Rapoport
Move remaining definitions and declarations from include/linux/bootmem.h into include/linux/memblock.h and remove the redundant header. The includes were replaced with the semantic patch below and then semi-automated removal of duplicated '#include <linux/memblock.h> @@ @@ - #include <linux/bootmem.h> + #include <linux/memblock.h> [sfr@canb.auug.org.au: dma-direct: fix up for the removal of linux/bootmem.h] Link: http://lkml.kernel.org/r/20181002185342.133d1680@canb.auug.org.au [sfr@canb.auug.org.au: powerpc: fix up for removal of linux/bootmem.h] Link: http://lkml.kernel.org/r/20181005161406.73ef8727@canb.auug.org.au [sfr@canb.auug.org.au: x86/kaslr, ACPI/NUMA: fix for linux/bootmem.h removal] Link: http://lkml.kernel.org/r/20181008190341.5e396491@canb.auug.org.au Link: http://lkml.kernel.org/r/1536927045-23536-30-git-send-email-rppt@linux.vnet.ibm.com Signed-off-by: Mike Rapoport <rppt@linux.vnet.ibm.com> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chris Zankel <chris@zankel.net> Cc: "David S. Miller" <davem@davemloft.net> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Greentime Hu <green.hu@gmail.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Guan Xuetao <gxt@pku.edu.cn> Cc: Ingo Molnar <mingo@redhat.com> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Jonas Bonn <jonas@southpole.se> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Ley Foon Tan <lftan@altera.com> Cc: Mark Salter <msalter@redhat.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Matt Turner <mattst88@gmail.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Michal Simek <monstr@monstr.eu> Cc: Palmer Dabbelt <palmer@sifive.com> Cc: Paul Burton <paul.burton@mips.com> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Richard Weinberger <richard@nod.at> Cc: Rich Felker <dalias@libc.org> Cc: Russell King <linux@armlinux.org.uk> Cc: Serge Semin <fancer.lancer@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Luck <tony.luck@intel.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-10-31memblock: rename free_all_bootmem to memblock_free_allMike Rapoport
The conversion is done using sed -i 's@free_all_bootmem@memblock_free_all@' \ $(git grep -l free_all_bootmem) Link: http://lkml.kernel.org/r/1536927045-23536-26-git-send-email-rppt@linux.vnet.ibm.com Signed-off-by: Mike Rapoport <rppt@linux.vnet.ibm.com> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chris Zankel <chris@zankel.net> Cc: "David S. Miller" <davem@davemloft.net> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Greentime Hu <green.hu@gmail.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Guan Xuetao <gxt@pku.edu.cn> Cc: Ingo Molnar <mingo@redhat.com> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Jonas Bonn <jonas@southpole.se> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Ley Foon Tan <lftan@altera.com> Cc: Mark Salter <msalter@redhat.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Matt Turner <mattst88@gmail.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Michal Simek <monstr@monstr.eu> Cc: Palmer Dabbelt <palmer@sifive.com> Cc: Paul Burton <paul.burton@mips.com> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Richard Weinberger <richard@nod.at> Cc: Rich Felker <dalias@libc.org> Cc: Russell King <linux@armlinux.org.uk> Cc: Serge Semin <fancer.lancer@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Luck <tony.luck@intel.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-10-31memblock: replace alloc_bootmem_pages with memblock_allocMike Rapoport
The alloc_bootmem_pages() function allocates PAGE_SIZE aligned memory. memblock_alloc() with alignment set to PAGE_SIZE does exactly the same thing. The conversion is done using the following semantic patch: @@ expression e; @@ - alloc_bootmem_pages(e) + memblock_alloc(e, PAGE_SIZE) Link: http://lkml.kernel.org/r/1536927045-23536-20-git-send-email-rppt@linux.vnet.ibm.com Signed-off-by: Mike Rapoport <rppt@linux.vnet.ibm.com> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chris Zankel <chris@zankel.net> Cc: "David S. Miller" <davem@davemloft.net> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Greentime Hu <green.hu@gmail.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Guan Xuetao <gxt@pku.edu.cn> Cc: Ingo Molnar <mingo@redhat.com> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Jonas Bonn <jonas@southpole.se> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Ley Foon Tan <lftan@altera.com> Cc: Mark Salter <msalter@redhat.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Matt Turner <mattst88@gmail.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Michal Simek <monstr@monstr.eu> Cc: Palmer Dabbelt <palmer@sifive.com> Cc: Paul Burton <paul.burton@mips.com> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Richard Weinberger <richard@nod.at> Cc: Rich Felker <dalias@libc.org> Cc: Russell King <linux@armlinux.org.uk> Cc: Serge Semin <fancer.lancer@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Luck <tony.luck@intel.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-10-31mm: remove CONFIG_HAVE_MEMBLOCKMike Rapoport
All architecures use memblock for early memory management. There is no need for the CONFIG_HAVE_MEMBLOCK configuration option. [rppt@linux.vnet.ibm.com: of/fdt: fixup #ifdefs] Link: http://lkml.kernel.org/r/20180919103457.GA20545@rapoport-lnx [rppt@linux.vnet.ibm.com: csky: fixups after bootmem removal] Link: http://lkml.kernel.org/r/20180926112744.GC4628@rapoport-lnx [rppt@linux.vnet.ibm.com: remove stale #else and the code it protects] Link: http://lkml.kernel.org/r/1538067825-24835-1-git-send-email-rppt@linux.vnet.ibm.com Link: http://lkml.kernel.org/r/1536927045-23536-4-git-send-email-rppt@linux.vnet.ibm.com Signed-off-by: Mike Rapoport <rppt@linux.vnet.ibm.com> Acked-by: Michal Hocko <mhocko@suse.com> Tested-by: Jonathan Cameron <jonathan.cameron@huawei.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chris Zankel <chris@zankel.net> Cc: "David S. Miller" <davem@davemloft.net> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Greentime Hu <green.hu@gmail.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Guan Xuetao <gxt@pku.edu.cn> Cc: Ingo Molnar <mingo@redhat.com> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Jonas Bonn <jonas@southpole.se> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Ley Foon Tan <lftan@altera.com> Cc: Mark Salter <msalter@redhat.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Matt Turner <mattst88@gmail.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Michal Simek <monstr@monstr.eu> Cc: Palmer Dabbelt <palmer@sifive.com> Cc: Paul Burton <paul.burton@mips.com> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Richard Weinberger <richard@nod.at> Cc: Rich Felker <dalias@libc.org> Cc: Russell King <linux@armlinux.org.uk> Cc: Serge Semin <fancer.lancer@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Luck <tony.luck@intel.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-10-31mm: remove CONFIG_NO_BOOTMEMMike Rapoport
All achitectures select NO_BOOTMEM which essentially becomes 'Y' for any kernel configuration and therefore it can be removed. [alexander.h.duyck@linux.intel.com: remove now defunct NO_BOOTMEM from depends list for deferred init] Link: http://lkml.kernel.org/r/20180925201814.3576.15105.stgit@localhost.localdomain Link: http://lkml.kernel.org/r/1536927045-23536-3-git-send-email-rppt@linux.vnet.ibm.com Signed-off-by: Mike Rapoport <rppt@linux.vnet.ibm.com> Signed-off-by: Alexander Duyck <alexander.h.duyck@linux.intel.com> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chris Zankel <chris@zankel.net> Cc: "David S. Miller" <davem@davemloft.net> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Greentime Hu <green.hu@gmail.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Guan Xuetao <gxt@pku.edu.cn> Cc: Ingo Molnar <mingo@redhat.com> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Jonas Bonn <jonas@southpole.se> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Ley Foon Tan <lftan@altera.com> Cc: Mark Salter <msalter@redhat.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Matt Turner <mattst88@gmail.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Michal Simek <monstr@monstr.eu> Cc: Palmer Dabbelt <palmer@sifive.com> Cc: Paul Burton <paul.burton@mips.com> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Richard Weinberger <richard@nod.at> Cc: Rich Felker <dalias@libc.org> Cc: Russell King <linux@armlinux.org.uk> Cc: Serge Semin <fancer.lancer@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Luck <tony.luck@intel.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-10-31treewide: remove current_text_addrNick Desaulniers
Prefer _THIS_IP_ defined in linux/kernel.h. Most definitions of current_text_addr were the same as _THIS_IP_, but a few archs had inline assembly instead. This patch removes the final call site of current_text_addr, making all of the definitions dead code. [akpm@linux-foundation.org: fix arch/csky/include/asm/processor.h] Link: http://lkml.kernel.org/r/20180911182413.180715-1-ndesaulniers@google.com Signed-off-by: Nick Desaulniers <ndesaulniers@google.com> Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-10-29Merge tag 'tty-4.20-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull tty/serial updates from Greg KH: "Here is the big tty and serial pull request for 4.20-rc1 Lots of little things here, including a merge from the SPI tree in order to keep things simpler for everyone to sync around for one platform. Major stuff is: - tty buffer clearing after use - atmel_serial fixes and additions - xilinx uart driver updates and of course, lots of tiny fixes and additions to individual serial drivers. All of these have been in linux-next with no reported issues for a while" * tag 'tty-4.20-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (66 commits) of: base: Change logic in of_alias_get_alias_list() of: base: Fix english spelling in of_alias_get_alias_list() serial: sh-sci: do not warn if DMA transfers are not supported serial: uartps: Do not allow use aliases >= MAX_UART_INSTANCES tty: check name length in tty_find_polling_driver() serial: sh-sci: Add r8a77990 support tty: wipe buffer if not echoing data tty: wipe buffer. serial: fsl_lpuart: Remove the alias node dependence TTY: sn_console: Replace spin_is_locked() with spin_trylock() Revert "serial:serial_core: Allow use of CTS for PPS line discipline" serial: 8250_uniphier: add auto-flow-control support serial: 8250_uniphier: flatten probe function serial: 8250_uniphier: remove unused "fifo-size" property dt-bindings: serial: sh-sci: Document r8a7744 bindings serial: uartps: Fix missing unlock on error in cdns_get_id() tty/serial: atmel: add ISO7816 support tty/serial_core: add ISO7816 infrastructure serial:serial_core: Allow use of CTS for PPS line discipline serial: docs: Fix filename for serial reference implementation ...
2018-10-26Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge updates from Andrew Morton: - a few misc things - ocfs2 updates - most of MM * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (132 commits) hugetlbfs: dirty pages as they are added to pagecache mm: export add_swap_extent() mm: split SWP_FILE into SWP_ACTIVATED and SWP_FS tools/testing/selftests/vm/map_fixed_noreplace.c: add test for MAP_FIXED_NOREPLACE mm: thp: relocate flush_cache_range() in migrate_misplaced_transhuge_page() mm: thp: fix mmu_notifier in migrate_misplaced_transhuge_page() mm: thp: fix MADV_DONTNEED vs migrate_misplaced_transhuge_page race condition mm/kasan/quarantine.c: make quarantine_lock a raw_spinlock_t mm/gup: cache dev_pagemap while pinning pages Revert "x86/e820: put !E820_TYPE_RAM regions into memblock.reserved" mm: return zero_resv_unavail optimization mm: zero remaining unavailable struct pages tools/testing/selftests/vm/gup_benchmark.c: add MAP_HUGETLB option tools/testing/selftests/vm/gup_benchmark.c: add MAP_SHARED option tools/testing/selftests/vm/gup_benchmark.c: allow user specified file tools/testing/selftests/vm/gup_benchmark.c: fix 'write' flag usage mm/gup_benchmark.c: add additional pinning methods mm/gup_benchmark.c: time put_page() mm: don't raise MEMCG_OOM event due to failed high-order allocation mm/page-writeback.c: fix range_cyclic writeback vs writepages deadlock ...
2018-10-26hugetlb: introduce generic version of huge_ptep_getAlexandre Ghiti
ia64, mips, parisc, powerpc, sh, sparc, x86 architectures use the same version of huge_ptep_get, so move this generic implementation into asm-generic/hugetlb.h. [arnd@arndb.de: fix ARM 3level page tables] Link: http://lkml.kernel.org/r/20181005161722.904274-1-arnd@arndb.de Link: http://lkml.kernel.org/r/20180920060358.16606-12-alex@ghiti.fr Signed-off-by: Alexandre Ghiti <alex@ghiti.fr> Reviewed-by: Luiz Capitulino <lcapitulino@redhat.com> Reviewed-by: Mike Kravetz <mike.kravetz@oracle.com> Tested-by: Helge Deller <deller@gmx.de> [parisc] Acked-by: Catalin Marinas <catalin.marinas@arm.com> [arm64] Acked-by: Paul Burton <paul.burton@mips.com> [MIPS] Acked-by: Ingo Molnar <mingo@kernel.org> [x86] Cc: Arnd Bergmann <arnd@arndb.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David S. Miller <davem@davemloft.net> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: James E.J. Bottomley <jejb@parisc-linux.org> Cc: James Hogan <jhogan@kernel.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Paul Mackerras <paulus@samba.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Rich Felker <dalias@libc.org> Cc: Russell King <linux@armlinux.org.uk> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Luck <tony.luck@intel.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-10-26hugetlb: introduce generic version of huge_ptep_set_access_flags()Alexandre Ghiti
arm, ia64, sh, x86 architectures use the same version of huge_ptep_set_access_flags, so move this generic implementation into asm-generic/hugetlb.h. Link: http://lkml.kernel.org/r/20180920060358.16606-11-alex@ghiti.fr Signed-off-by: Alexandre Ghiti <alex@ghiti.fr> Reviewed-by: Luiz Capitulino <lcapitulino@redhat.com> Reviewed-by: Mike Kravetz <mike.kravetz@oracle.com> Tested-by: Helge Deller <deller@gmx.de> [parisc] Acked-by: Catalin Marinas <catalin.marinas@arm.com> [arm64] Acked-by: Paul Burton <paul.burton@mips.com> [MIPS] Acked-by: Ingo Molnar <mingo@kernel.org> [x86] Cc: Arnd Bergmann <arnd@arndb.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David S. Miller <davem@davemloft.net> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: James E.J. Bottomley <jejb@parisc-linux.org> Cc: James Hogan <jhogan@kernel.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Paul Mackerras <paulus@samba.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Rich Felker <dalias@libc.org> Cc: Russell King <linux@armlinux.org.uk> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Luck <tony.luck@intel.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-10-26hugetlb: introduce generic version of huge_ptep_set_wrprotect()Alexandre Ghiti
arm, ia64, mips, powerpc, sh, x86 architectures use the same version of huge_ptep_set_wrprotect, so move this generic implementation into asm-generic/hugetlb.h. Link: http://lkml.kernel.org/r/20180920060358.16606-10-alex@ghiti.fr Signed-off-by: Alexandre Ghiti <alex@ghiti.fr> Reviewed-by: Luiz Capitulino <lcapitulino@redhat.com> Reviewed-by: Mike Kravetz <mike.kravetz@oracle.com> Tested-by: Helge Deller <deller@gmx.de> [parisc] Acked-by: Catalin Marinas <catalin.marinas@arm.com> [arm64] Acked-by: Paul Burton <paul.burton@mips.com> [MIPS] Acked-by: Ingo Molnar <mingo@kernel.org> [x86] Cc: Arnd Bergmann <arnd@arndb.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David S. Miller <davem@davemloft.net> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: James E.J. Bottomley <jejb@parisc-linux.org> Cc: James Hogan <jhogan@kernel.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Paul Mackerras <paulus@samba.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Rich Felker <dalias@libc.org> Cc: Russell King <linux@armlinux.org.uk> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Luck <tony.luck@intel.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-10-26hugetlb: introduce generic version of prepare_hugepage_rangeAlexandre Ghiti
arm, arm64, powerpc, sparc, x86 architectures use the same version of prepare_hugepage_range, so move this generic implementation into asm-generic/hugetlb.h. Link: http://lkml.kernel.org/r/20180920060358.16606-9-alex@ghiti.fr Signed-off-by: Alexandre Ghiti <alex@ghiti.fr> Reviewed-by: Luiz Capitulino <lcapitulino@redhat.com> Reviewed-by: Mike Kravetz <mike.kravetz@oracle.com> Tested-by: Helge Deller <deller@gmx.de> [parisc] Acked-by: Catalin Marinas <catalin.marinas@arm.com> [arm64] Acked-by: Paul Burton <paul.burton@mips.com> [MIPS] Acked-by: Ingo Molnar <mingo@kernel.org> [x86] Cc: Arnd Bergmann <arnd@arndb.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David S. Miller <davem@davemloft.net> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: James E.J. Bottomley <jejb@parisc-linux.org> Cc: James Hogan <jhogan@kernel.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Paul Mackerras <paulus@samba.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Rich Felker <dalias@libc.org> Cc: Russell King <linux@armlinux.org.uk> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Luck <tony.luck@intel.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-10-26hugetlb: introduce generic version of huge_pte_wrprotectAlexandre Ghiti
arm, arm64, ia64, mips, parisc, powerpc, sh, sparc, x86 architectures use the same version of huge_pte_wrprotect, so move this generic implementation into asm-generic/hugetlb.h. Link: http://lkml.kernel.org/r/20180920060358.16606-8-alex@ghiti.fr Signed-off-by: Alexandre Ghiti <alex@ghiti.fr> Reviewed-by: Luiz Capitulino <lcapitulino@redhat.com> Reviewed-by: Mike Kravetz <mike.kravetz@oracle.com> Tested-by: Helge Deller <deller@gmx.de> [parisc] Acked-by: Catalin Marinas <catalin.marinas@arm.com> [arm64] Acked-by: Paul Burton <paul.burton@mips.com> [MIPS] Acked-by: Ingo Molnar <mingo@kernel.org> [x86] Cc: Arnd Bergmann <arnd@arndb.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David S. Miller <davem@davemloft.net> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: James E.J. Bottomley <jejb@parisc-linux.org> Cc: James Hogan <jhogan@kernel.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Paul Mackerras <paulus@samba.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Rich Felker <dalias@libc.org> Cc: Russell King <linux@armlinux.org.uk> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Luck <tony.luck@intel.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-10-26hugetlb: introduce generic version of huge_pte_none()Alexandre Ghiti
arm, arm64, ia64, mips, parisc, powerpc, sh, sparc, x86 architectures use the same version of huge_pte_none, so move this generic implementation into asm-generic/hugetlb.h. Link: http://lkml.kernel.org/r/20180920060358.16606-7-alex@ghiti.fr Signed-off-by: Alexandre Ghiti <alex@ghiti.fr> Reviewed-by: Luiz Capitulino <lcapitulino@redhat.com> Reviewed-by: Mike Kravetz <mike.kravetz@oracle.com> Tested-by: Helge Deller <deller@gmx.de> [parisc] Acked-by: Catalin Marinas <catalin.marinas@arm.com> [arm64] Acked-by: Paul Burton <paul.burton@mips.com> [MIPS] Acked-by: Ingo Molnar <mingo@kernel.org> [x86] Cc: Arnd Bergmann <arnd@arndb.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David S. Miller <davem@davemloft.net> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: James E.J. Bottomley <jejb@parisc-linux.org> Cc: James Hogan <jhogan@kernel.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Paul Mackerras <paulus@samba.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Rich Felker <dalias@libc.org> Cc: Russell King <linux@armlinux.org.uk> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Luck <tony.luck@intel.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-10-26hugetlb: introduce generic version of huge_ptep_clear_flushAlexandre Ghiti
arm, x86 architectures use the same version of huge_ptep_clear_flush, so move this generic implementation into asm-generic/hugetlb.h. Link: http://lkml.kernel.org/r/20180920060358.16606-6-alex@ghiti.fr Signed-off-by: Alexandre Ghiti <alex@ghiti.fr> Reviewed-by: Luiz Capitulino <lcapitulino@redhat.com> Reviewed-by: Mike Kravetz <mike.kravetz@oracle.com> Tested-by: Helge Deller <deller@gmx.de> [parisc] Acked-by: Catalin Marinas <catalin.marinas@arm.com> [arm64] Acked-by: Paul Burton <paul.burton@mips.com> [MIPS] Acked-by: Ingo Molnar <mingo@kernel.org> [x86] Cc: Arnd Bergmann <arnd@arndb.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David S. Miller <davem@davemloft.net> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: James E.J. Bottomley <jejb@parisc-linux.org> Cc: James Hogan <jhogan@kernel.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Paul Mackerras <paulus@samba.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Rich Felker <dalias@libc.org> Cc: Russell King <linux@armlinux.org.uk> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Luck <tony.luck@intel.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-10-26hugetlb: introduce generic version of huge_ptep_get_and_clear()Alexandre Ghiti
arm, ia64, sh, x86 architectures use the same version of huge_ptep_get_and_clear, so move this generic implementation into asm-generic/hugetlb.h. Link: http://lkml.kernel.org/r/20180920060358.16606-5-alex@ghiti.fr Signed-off-by: Alexandre Ghiti <alex@ghiti.fr> Reviewed-by: Luiz Capitulino <lcapitulino@redhat.com> Reviewed-by: Mike Kravetz <mike.kravetz@oracle.com> Tested-by: Helge Deller <deller@gmx.de> [parisc] Acked-by: Catalin Marinas <catalin.marinas@arm.com> [arm64] Acked-by: Paul Burton <paul.burton@mips.com> [MIPS] Acked-by: Ingo Molnar <mingo@kernel.org> [x86] Cc: Arnd Bergmann <arnd@arndb.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David S. Miller <davem@davemloft.net> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: James E.J. Bottomley <jejb@parisc-linux.org> Cc: James Hogan <jhogan@kernel.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Paul Mackerras <paulus@samba.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Rich Felker <dalias@libc.org> Cc: Russell King <linux@armlinux.org.uk> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Luck <tony.luck@intel.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-10-26hugetlb: introduce generic version of set_huge_pte_at()Alexandre Ghiti
arm, ia64, mips, powerpc, sh, x86 architectures use the same version of set_huge_pte_at, so move this generic implementation into asm-generic/hugetlb.h. Link: http://lkml.kernel.org/r/20180920060358.16606-4-alex@ghiti.fr Signed-off-by: Alexandre Ghiti <alex@ghiti.fr> Reviewed-by: Luiz Capitulino <lcapitulino@redhat.com> Reviewed-by: Mike Kravetz <mike.kravetz@oracle.com> Tested-by: Helge Deller <deller@gmx.de> [parisc] Acked-by: Catalin Marinas <catalin.marinas@arm.com> [arm64] Acked-by: Paul Burton <paul.burton@mips.com> [MIPS] Acked-by: Ingo Molnar <mingo@kernel.org> [x86] Cc: Arnd Bergmann <arnd@arndb.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David S. Miller <davem@davemloft.net> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: James E.J. Bottomley <jejb@parisc-linux.org> Cc: James Hogan <jhogan@kernel.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Paul Mackerras <paulus@samba.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Rich Felker <dalias@libc.org> Cc: Russell King <linux@armlinux.org.uk> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Luck <tony.luck@intel.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-10-26hugetlb: introduce generic version of hugetlb_free_pgd_rangeAlexandre Ghiti
arm, arm64, mips, parisc, sh, x86 architectures use the same version of hugetlb_free_pgd_range, so move this generic implementation into asm-generic/hugetlb.h. Link: http://lkml.kernel.org/r/20180920060358.16606-3-alex@ghiti.fr Signed-off-by: Alexandre Ghiti <alex@ghiti.fr> Reviewed-by: Luiz Capitulino <lcapitulino@redhat.com> Reviewed-by: Mike Kravetz <mike.kravetz@oracle.com> Tested-by: Helge Deller <deller@gmx.de> [parisc] Acked-by: Catalin Marinas <catalin.marinas@arm.com> [arm64] Acked-by: Paul Burton <paul.burton@mips.com> [MIPS] Acked-by: Ingo Molnar <mingo@kernel.org> [x86] Cc: Arnd Bergmann <arnd@arndb.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David S. Miller <davem@davemloft.net> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: James E.J. Bottomley <jejb@parisc-linux.org> Cc: James Hogan <jhogan@kernel.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Paul Mackerras <paulus@samba.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Rich Felker <dalias@libc.org> Cc: Russell King <linux@armlinux.org.uk> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Luck <tony.luck@intel.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-10-26Merge tag 'devicetree-for-4.20' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux Pull Devicetree updates from Rob Herring: "A bit bigger than normal as I've been busy this cycle. There's a few things with dependencies and a few things subsystem maintainers didn't pick up, so I'm taking them thru my tree. The fixes from Johan didn't get into linux-next, but they've been waiting for some time now and they are what's left of what subsystem maintainers didn't pick up. Summary: - Sync dtc with upstream version v1.4.7-14-gc86da84d30e4 - Work to get rid of direct accesses to struct device_node name and type pointers in preparation for removing them. New helpers for parsing DT cpu nodes and conversions to use the helpers. printk conversions to %pOFn for printing DT node names. Most went thru subystem trees, so this is the remainder. - Fixes to DT child node lookups to actually be restricted to child nodes instead of treewide. - Refactoring of dtb targets out of arch code. This makes the support more uniform and enables building all dtbs on c6x, microblaze, and powerpc. - Various DT binding updates for Renesas r8a7744 SoC - Vendor prefixes for Facebook, OLPC - Restructuring of some ARM binding docs moving some peripheral bindings out of board/SoC binding files - New "secure-chosen" binding for secure world settings on ARM - Dual licensing of 2 DT IRQ binding headers" * tag 'devicetree-for-4.20' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: (78 commits) ARM: dt: relicense two DT binding IRQ headers power: supply: twl4030-charger: fix OF sibling-node lookup NFC: nfcmrvl_uart: fix OF child-node lookup net: stmmac: dwmac-sun8i: fix OF child-node lookup net: bcmgenet: fix OF child-node lookup drm/msm: fix OF child-node lookup drm/mediatek: fix OF sibling-node lookup of: Add missing exports of node name compare functions dt-bindings: Add OLPC vendor prefix dt-bindings: misc: bk4: Add device tree binding for Liebherr's BK4 SPI bus dt-bindings: thermal: samsung: Add SPDX license identifier dt-bindings: clock: samsung: Add SPDX license identifiers dt-bindings: timer: ostm: Add R7S9210 support dt-bindings: phy: rcar-gen2: Add r8a7744 support dt-bindings: can: rcar_can: Add r8a7744 support dt-bindings: timer: renesas, cmt: Document r8a7744 CMT support dt-bindings: watchdog: renesas-wdt: Document r8a7744 support dt-bindings: thermal: rcar: Add device tree support for r8a7744 Documentation: dt: Add binding for /secure-chosen/stdout-path dt-bindings: arm: zte: Move sysctrl bindings to their own doc ...
2018-10-25Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timekeeping updates from Thomas Gleixner: "The timers and timekeeping departement provides: - Another large y2038 update with further preparations for providing the y2038 safe timespecs closer to the syscalls. - An overhaul of the SHCMT clocksource driver - SPDX license identifier updates - Small cleanups and fixes all over the place" * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (31 commits) tick/sched : Remove redundant cpu_online() check clocksource/drivers/dw_apb: Add reset control clocksource: Remove obsolete CLOCKSOURCE_OF_DECLARE clocksource/drivers: Unify the names to timer-* format clocksource/drivers/sh_cmt: Add R-Car gen3 support dt-bindings: timer: renesas: cmt: document R-Car gen3 support clocksource/drivers/sh_cmt: Properly line-wrap sh_cmt_of_table[] initializer clocksource/drivers/sh_cmt: Fix clocksource width for 32-bit machines clocksource/drivers/sh_cmt: Fixup for 64-bit machines clocksource/drivers/sh_tmu: Convert to SPDX identifiers clocksource/drivers/sh_mtu2: Convert to SPDX identifiers clocksource/drivers/sh_cmt: Convert to SPDX identifiers clocksource/drivers/renesas-ostm: Convert to SPDX identifiers clocksource: Convert to using %pOFn instead of device_node.name tick/broadcast: Remove redundant check RISC-V: Request newstat syscalls y2038: signal: Change rt_sigtimedwait to use __kernel_timespec y2038: socket: Change recvmmsg to use __kernel_timespec y2038: sched: Change sched_rr_get_interval to use __kernel_timespec y2038: utimes: Rework #ifdef guards for compat syscalls ...
2018-10-23Merge tag 'regulator-v5.0' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator Pull regulator updates from Mark Brown: "The biggest chunk of the regulator changes for this release outside of the new drivers is the conversion of the fixed regulator to use the GPIO descriptor API, there's a small addition to the GPIO API plus a bunch of updates to board files to implement it. This is some really welcome work from Linus Walleij that's had a bunch of review and has been sitting in -next for a while so I'm fairly happy there's no major issues. - Helpers for overlapping linear ranges. - Display opmode and consumer requested load in the regualtor_summary file in debugfs, plus a fix there. - Support for the fun and entertaining power off mechanism that the pfuze100 hardware implements. - Conversion of the fixed regulator API to use GPIO descriptors, including pulling in a bunch of patches to a bunch of board files. - New drivers for Cirrus Logic Lochnagar, Qualcomm PMS405, Rohm BD71847, ST PMIC1, and TI LM363x devices" * tag 'regulator-v5.0' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator: (36 commits) regulator: lochnagar: Use a consisent comment style for SPDX header regulator: bd718x7: Remove struct bd718xx_pmic regulator: Fetch enable gpiods nonexclusive regulator/gpio: Allow nonexclusive GPIO access regulator: lochnagar: Add support for the Cirrus Logic Lochnagar regulator: stpmic1: Return REGULATOR_MODE_INVALID for invalid mode regulator: stpmic1: add stpmic1 regulator driver dt-bindings: regulator: document stpmic1 pmic regulators regulator: axp20x: Mark expected switch fall-throughs regulator: bd718xx: fix build warning on x86_64 regulator: fixed: Default enable high on DT regulators regulator: bd718xx: rename bd71837 to 718xx regulator: bd718XX use pickable ranges regulator/mfd: bd718xx: rename bd71837/bd71847 common instances regulator: Support regulators where voltage ranges are selectable mfd: dt bindings: add BD71847 device-tree binding documentation regulator: dt bindings: add BD71847 device-tree binding documentation regulator/mfd: Support ROHM BD71847 power management IC regulator: da905{2,5}: Remove unnecessary array check regulator: qcom: Add PMS405 regulators ...
2018-10-23Merge tag 'mtd/for-4.20' of git://git.infradead.org/linux-mtdLinus Torvalds
Pull mtd updates from Boris Brezillon: "SPI NOR core changes: - Support non-uniform erase size - Support controllers with limited TX fifo size Driver changes: - m25p80: Re-issue a WREN command after each write access - cadence: Pass a proper dir value to dma_[un]map_single() - fsl-qspi: Check fsl_qspi_get_seqid() return val make sure 4B addressing opcodes are properly handled - intel-spi: Add a new PCI entry for Ice Lake Raw NAND core changes: - Two batchs of cleanups of the NAND API, including: * Deprecating a lot of interfaces (now replaced by ->exec_op()). * Moving code in separate drivers (JEDEC, ONFI), in private files (internals), in platform drivers, etc. * Functions/structures reordering. * Exclusive use of the nand_chip structure instead of the MTD one all across the subsystem. - Addition of the nand_wait_readrdy/rdy_op() helpers. Raw NAND controllers drivers changes: - Various coccinelle patches. - Marvell: * Use regmap_update_bits() for syscon access. * More documentation. * BCH failure path rework. * More layouts to be supported. * IRQ handler complete() condition fixed. - Fsl_ifc: * SRAM initialization fixed for newer controller versions. - Denali: * Fix licenses mismatch and use a SPDX tag. * Set SPARE_AREA_SKIP_BYTES register to 8 if unset. - Qualcomm: * Do not include dma-direct.h. - Docg4: * Removed. - Ams-delta: * Use of a GPIO lookup table * Internal machinery changes. Raw NAND chip drivers changes: - Toshiba: * Add support for Toshiba memory BENAND * Pass a single nand_chip object to the status helper. - ESMT: * New driver to retrieve the ECC requirements from the 5th ID byte. MTD changes: - physmap cleanups/fixe - gpio-addr-flash cleanups/fixes" * tag 'mtd/for-4.20' of git://git.infradead.org/linux-mtd: (93 commits) jffs2: free jffs2_sb_info through jffs2_kill_sb() mtd: spi-nor: fsl-quadspi: fix read error for flash size larger than 16MB mtd: spi-nor: intel-spi: Add support for Intel Ice Lake SPI serial flash mtd: maps: gpio-addr-flash: Convert to gpiod mtd: maps: gpio-addr-flash: Replace array with an integer mtd: maps: gpio-addr-flash: Use order instead of size mtd: spi-nor: fsl-quadspi: Don't let -EINVAL on the bus mtd: devices: m25p80: Make sure WRITE_EN is issued before each write mtd: spi-nor: Support controllers with limited TX FIFO size mtd: spi-nor: cadence-quadspi: Use proper enum for dma_[un]map_single mtd: spi-nor: parse SFDP Sector Map Parameter Table mtd: spi-nor: add support to non-uniform SFDP SPI NOR flash memories mtd: rawnand: marvell: fix the IRQ handler complete() condition mtd: rawnand: denali: set SPARE_AREA_SKIP_BYTES register to 8 if unset mtd: rawnand: r852: fix spelling mistake "card_registred" -> "card_registered" mtd: rawnand: toshiba: Pass a single nand_chip object to the status helper mtd: maps: gpio-addr-flash: Use devm_* functions mtd: maps: gpio-addr-flash: Fix ioremapped size mtd: maps: gpio-addr-flash: Replace custom printk mtd: physmap_of: Release resources on error ...
2018-10-03mtd: rawnand: Move platform_nand_xxx definitions out of rawnand.hBoris Brezillon
platform_nand_xxx definitions are just used by the plat_nand driver. Let's move those definitions out of the core/driver-agnostic rawnand.h header. Signed-off-by: Boris Brezillon <boris.brezillon@bootlin.com> Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
2018-10-03mtd: rawnand: Create a legacy struct and move ->IO_ADDR_{R, W} thereBoris Brezillon
We regularly have new NAND controller drivers that are making use of fields/hooks that we want to get rid of but can't because of all the legacy drivers that we might break if we do. So, instead of removing those fields/hooks, let's move them to a sub-struct which is clearly documented as deprecated. We start with the ->IO_ADDR_{R,W] fields. Signed-off-by: Boris Brezillon <boris.brezillon@bootlin.com> Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
2018-10-03mtd: rawnand: plat_nand: Pass a nand_chip object to all platform_nand_ctrl hooksBoris Brezillon
Let's make the raw NAND API consistent by patching all helpers and hooks to take a nand_chip object instead of an mtd_info one or remove the mtd_info object when both are passed. In order to do that, we first need to update the platform_nand_ctrl hooks to take a nand_chip object instead of an mtd_info. We add temporary plat_nand_xxx() wrappers to the do the mtd -> chip conversion, but those will be dropped when patching nand_chip hooks to take a nand_chip object. Signed-off-by: Boris Brezillon <boris.brezillon@bootlin.com> Reviewed-by: Alexander Sverdlin <alexander.sverdlin@gmail.com> Acked-by: Alexander Sverdlin <alexander.sverdlin@gmail.com> Acked-by: Robert Jarzmik <robert.jarzmik@free.fr> Acked-by: Krzysztof Halasa <khalasa@piap.pl> Acked-by: Paul Burton <paul.burton@mips.com> Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
2018-10-02tty/serial_core: add ISO7816 infrastructureNicolas Ferre
Add the ISO7816 ioctl and associated accessors and data structure. Drivers can then use this common implementation to handle ISO7816 (smart cards). Signed-off-by: Nicolas Ferre <nicolas.ferre@microchip.com> [ludovic.desroches@microchip.com: squash and rebase, removal of gpios, checkpatch fixes] Signed-off-by: Ludovic Desroches <ludovic.desroches@microchip.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-28SH: use for_each_of_cpu_node iteratorRob Herring
Use the for_each_of_cpu_node iterator to iterate over cpu nodes. This has the side effect of defaulting to iterating using "cpu" node names in preference to the deprecated (for FDT) device_type == "cpu". Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Rich Felker <dalias@libc.org> Cc: linux-sh@vger.kernel.org Signed-off-by: Rob Herring <robh@kernel.org>
2018-09-20dma-mapping: merge direct and noncoherent opsChristoph Hellwig
All the cache maintainance is already stubbed out when not enabled, but merging the two allows us to nicely handle the case where cache maintainance is required for some devices, but not others. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Paul Burton <paul.burton@mips.com> # MIPS parts
2018-09-17regulator: fixed: Convert to use GPIO descriptor onlyLinus Walleij
As we augmented the regulator core to accept a GPIO descriptor instead of a GPIO number, we can augment the fixed GPIO regulator to look up and pass that descriptor directly from device tree or board GPIO descriptor look up tables. Some boards just auto-enumerate their fixed regulator platform devices and I have assumed they get names like "fixed-regulator.0" but it's pretty hard to guess this. I need some testing from board maintainers to be sure. Other boards are straight forward, using just plain "fixed-regulator" (ID -1) or "fixed-regulator.1" hammering down the device ID. It seems the da9055 and da9211 has never got around to actually passing any enable gpio into its platform data (not the in-tree code anyway) so we can just decide to simply pass a descriptor instead. The fixed GPIO-controlled regulator in mach-pxa/ezx.c was confusingly named "*_dummy_supply_device" while it is a very real device backed by a GPIO line. There is nothing dummy about it at all, so I renamed it with the infix *_regulator_* as part of this patch set. Intel MID portions tested by Andy. Tested-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> # Check the x86 BCM stuff Acked-by: Tony Lindgren <tony@atomide.com> # OMAP1,2,3 maintainer Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Reviewed-by: Janusz Krzysztofik <jmkrzyszt@gmail.com> Reviewed-by: Mike Rapoport <rppt@linux.vnet.ibm.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2018-08-29asm-generic: Remove unneeded __ARCH_WANT_SYS_LLSEEK macroArnd Bergmann
The sys_llseek sytem call is needed on all 32-bit architectures and none of the 64-bit ones, so we can remove the __ARCH_WANT_SYS_LLSEEK guard and simplify the include/asm-generic/unistd.h header further. Since 32-bit tasks can run either natively or in compat mode on 64-bit architectures, we have to check for both !CONFIG_64BIT and CONFIG_COMPAT. There are a few 64-bit architectures that also reference sys_llseek in their 64-bit ABI (e.g. sparc), but I verified that those all select CONFIG_COMPAT, so the #if check is still correct here. It's a bit odd to include it in the syscall table though, as it's the same as sys_lseek() on 64-bit, but with strange calling conventions. Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2018-08-29y2038: Remove newstat family from default syscall setArnd Bergmann
We have four generations of stat() syscalls: - the oldstat syscalls that are only used on the older architectures - the newstat family that is used on all 64-bit architectures but lacked support for large files on 32-bit architectures. - the stat64 family that is used mostly on 32-bit architectures to replace newstat - statx() to replace all of the above, adding 64-bit timestamps among other things. We already compile stat64 only on those architectures that need it, but newstat is always built, including on those that don't reference it. This adds a new __ARCH_WANT_NEW_STAT symbol along the lines of __ARCH_WANT_OLD_STAT and __ARCH_WANT_STAT64 to control compilation of newstat. All architectures that need it use an explict define, the others now get a little bit smaller, and future architecture (including 64-bit targets) won't ever see it. Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2018-08-24kbuild: rename LDFLAGS to KBUILD_LDFLAGSMasahiro Yamada
Commit a0f97e06a43c ("kbuild: enable 'make CFLAGS=...' to add additional options to CC") renamed CFLAGS to KBUILD_CFLAGS. Commit 222d394d30e7 ("kbuild: enable 'make AFLAGS=...' to add additional options to AS") renamed AFLAGS to KBUILD_AFLAGS. Commit 06c5040cdb13 ("kbuild: enable 'make CPPFLAGS=...' to add additional options to CPP") renamed CPPFLAGS to KBUILD_CPPFLAGS. For some reason, LDFLAGS was not renamed. Using a well-known variable like LDFLAGS may result in accidental override of the variable. Kbuild generally uses KBUILD_ prefixed variables for the internally appended options, so here is one more conversion to sanitize the naming convention. I did not touch Makefiles under tools/ since the tools build system is a different world. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Reviewed-by: Palmer Dabbelt <palmer@sifive.com>
2018-08-17mm: convert return type of handle_mm_fault() caller to vm_fault_tSouptick Joarder
Use new return type vm_fault_t for fault handler. For now, this is just documenting that the function returns a VM_FAULT value rather than an errno. Once all instances are converted, vm_fault_t will become a distinct type. Ref-> commit 1c8f422059ae ("mm: change return type to vm_fault_t") In this patch all the caller of handle_mm_fault() are changed to return vm_fault_t type. Link: http://lkml.kernel.org/r/20180617084810.GA6730@jordon-HP-15-Notebook-PC Signed-off-by: Souptick Joarder <jrdr.linux@gmail.com> Cc: Matthew Wilcox <willy@infradead.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Tony Luck <tony.luck@intel.com> Cc: Matt Turner <mattst88@gmail.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Russell King <linux@armlinux.org.uk> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Michal Simek <monstr@monstr.eu> Cc: James Hogan <jhogan@kernel.org> Cc: Ley Foon Tan <lftan@altera.com> Cc: Jonas Bonn <jonas@southpole.se> Cc: James E.J. Bottomley <jejb@parisc-linux.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Palmer Dabbelt <palmer@sifive.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: David S. Miller <davem@davemloft.net> Cc: Richard Weinberger <richard@nod.at> Cc: Guan Xuetao <gxt@pku.edu.cn> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: "Levin, Alexander (Sasha Levin)" <alexander.levin@verizon.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-08-17sh: prefer _THIS_IP_ to current_text_addrNick Desaulniers
As part of the effort to reduce the code duplication between _THIS_IP_ and current_text_addr(), let's consolidate callers of current_text_addr() to use _THIS_IP_. Link: http://lkml.kernel.org/r/20180801185331.39535-1-ndesaulniers@google.com Signed-off-by: Nick Desaulniers <ndesaulniers@google.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Rich Felker <dalias@libc.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-08-17sh: make use of for_each_node_by_type()Dmitry Torokhov
Instead of open-coding the loop, let's use canned macro. Also make sure we are not leaking "cpus" node reference. Link: http://lkml.kernel.org/r/20180624224252.GA220395@dtor-ws Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Rich Felker <dalias@libc.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-08-16Merge tag 'pci-v4.19-changes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull pci updates from Bjorn Helgaas: - Decode AER errors with names similar to "lspci" (Tyler Baicar) - Expose AER statistics in sysfs (Rajat Jain) - Clear AER status bits selectively based on the type of recovery (Oza Pawandeep) - Honor "pcie_ports=native" even if HEST sets FIRMWARE_FIRST (Alexandru Gagniuc) - Don't clear AER status bits if we're using the "Firmware-First" strategy where firmware owns the registers (Alexandru Gagniuc) - Use sysfs_match_string() to simplify ASPM sysfs parsing (Andy Shevchenko) - Remove unnecessary includes of <linux/pci-aspm.h> (Bjorn Helgaas) - Defer DPC event handling to work queue (Keith Busch) - Use threaded IRQ for DPC bottom half (Keith Busch) - Print AER status while handling DPC events (Keith Busch) - Work around IDT switch ACS Source Validation erratum (James Puthukattukaran) - Emit diagnostics for all cases of PCIe Link downtraining (Links operating slower than they're capable of) (Alexandru Gagniuc) - Skip VFs when configuring Max Payload Size (Myron Stowe) - Reduce Root Port Max Payload Size if necessary when hot-adding a device below it (Myron Stowe) - Simplify SHPC existence/permission checks (Bjorn Helgaas) - Remove hotplug sample skeleton driver (Lukas Wunner) - Convert pciehp to threaded IRQ handling (Lukas Wunner) - Improve pciehp tolerance of missed events and initially unstable links (Lukas Wunner) - Clear spurious pciehp events on resume (Lukas Wunner) - Add pciehp runtime PM support, including for Thunderbolt controllers (Lukas Wunner) - Support interrupts from pciehp bridges in D3hot (Lukas Wunner) - Mark fall-through switch cases before enabling -Wimplicit-fallthrough (Gustavo A. R. Silva) - Move DMA-debug PCI init from arch code to PCI core (Christoph Hellwig) - Fix pci_request_irq() usage of IRQF_ONESHOT when no handler is supplied (Heiner Kallweit) - Unify PCI and DMA direction #defines (Shunyong Yang) - Add PCI_DEVICE_DATA() macro (Andy Shevchenko) - Check for VPD completion before checking for timeout (Bert Kenward) - Limit Netronome NFP5000 config space size to work around erratum (Jakub Kicinski) - Set IRQCHIP_ONESHOT_SAFE for PCI MSI irqchips (Heiner Kallweit) - Document ACPI description of PCI host bridges (Bjorn Helgaas) - Add "pci=disable_acs_redir=" parameter to disable ACS redirection for peer-to-peer DMA support (we don't have the peer-to-peer support yet; this is just one piece) (Logan Gunthorpe) - Clean up devm_of_pci_get_host_bridge_resources() resource allocation (Jan Kiszka) - Fixup resizable BARs after suspend/resume (Christian König) - Make "pci=earlydump" generic (Sinan Kaya) - Fix ROM BAR access routines to stay in bounds and check for signature correctly (Rex Zhu) - Add DMA alias quirk for Microsemi Switchtec NTB (Doug Meyer) - Expand documentation for pci_add_dma_alias() (Logan Gunthorpe) - To avoid bus errors, enable PASID only if entire path supports End-End TLP prefixes (Sinan Kaya) - Unify slot and bus reset functions and remove hotplug knowledge from callers (Sinan Kaya) - Add Function-Level Reset quirks for Intel and Samsung NVMe devices to fix guest reboot issues (Alex Williamson) - Add function 1 DMA alias quirk for Marvell 88SS9183 PCIe SSD Controller (Bjorn Helgaas) - Remove Xilinx AXI-PCIe host bridge arch dependency (Palmer Dabbelt) - Remove Aardvark outbound window configuration (Evan Wang) - Fix Aardvark bridge window sizing issue (Zachary Zhang) - Convert Aardvark to use pci_host_probe() to reduce code duplication (Thomas Petazzoni) - Correct the Cadence cdns_pcie_writel() signature (Alan Douglas) - Add Cadence support for optional generic PHYs (Alan Douglas) - Add Cadence power management ops (Alan Douglas) - Remove redundant variable from Cadence driver (Colin Ian King) - Add Kirin MSI support (Xiaowei Song) - Drop unnecessary root_bus_nr setting from exynos, imx6, keystone, armada8k, artpec6, designware-plat, histb, qcom, spear13xx (Shawn Guo) - Move link notification settings from DesignWare core to individual drivers (Gustavo Pimentel) - Add endpoint library MSI-X interfaces (Gustavo Pimentel) - Correct signature of endpoint library IRQ interfaces (Gustavo Pimentel) - Add DesignWare endpoint library MSI-X callbacks (Gustavo Pimentel) - Add endpoint library MSI-X test support (Gustavo Pimentel) - Remove unnecessary GFP_ATOMIC from Hyper-V "new child" allocation (Jia-Ju Bai) - Add more devices to Broadcom PAXC quirk (Ray Jui) - Work around corrupted Broadcom PAXC config space to enable SMMU and GICv3 ITS (Ray Jui) - Disable MSI parsing to work around broken Broadcom PAXC logic in some devices (Ray Jui) - Hide unconfigured functions to work around a Broadcom PAXC defect (Ray Jui) - Lower iproc log level to reduce console output during boot (Ray Jui) - Fix mobiveil iomem/phys_addr_t type usage (Lorenzo Pieralisi) - Fix mobiveil missing include file (Lorenzo Pieralisi) - Add mobiveil Kconfig/Makefile support (Lorenzo Pieralisi) - Fix mvebu I/O space remapping issues (Thomas Petazzoni) - Use generic pci_host_bridge in mvebu instead of ARM-specific API (Thomas Petazzoni) - Whitelist VMD devices with fast interrupt handlers to avoid sharing vectors with slow handlers (Keith Busch) * tag 'pci-v4.19-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (153 commits) PCI/AER: Don't clear AER bits if error handling is Firmware-First PCI: Limit config space size for Netronome NFP5000 PCI/MSI: Set IRQCHIP_ONESHOT_SAFE for PCI-MSI irqchips PCI/VPD: Check for VPD access completion before checking for timeout PCI: Add PCI_DEVICE_DATA() macro to fully describe device ID entry PCI: Match Root Port's MPS to endpoint's MPSS as necessary PCI: Skip MPS logic for Virtual Functions (VFs) PCI: Add function 1 DMA alias quirk for Marvell 88SS9183 PCI: Check for PCIe Link downtraining PCI: Add ACS Redirect disable quirk for Intel Sunrise Point PCI: Add device-specific ACS Redirect disable infrastructure PCI: Convert device-specific ACS quirks from NULL termination to ARRAY_SIZE PCI: Add "pci=disable_acs_redir=" parameter for peer-to-peer support PCI: Allow specifying devices using a base bus and path of devfns PCI: Make specifying PCI devices in kernel parameters reusable PCI: Hide ACS quirk declarations inside PCI core PCI: Delay after FLR of Intel DC P3700 NVMe PCI: Disable Samsung SM961/PM961 NVMe before FLR PCI: Export pcie_has_flr() PCI: mvebu: Drop bogus comment above mvebu_pcie_map_registers() ...
2018-08-15Merge tag 'media/v4.19-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media updates from Mauro Carvalho Chehab: - new Socionext MN88443x ISDB-S/T demodulator driver: mn88443x - new sensor drivers: ak7375, ov2680 and rj54n1cb0c - an old soc-camera sensor driver converted to the V4L2 framework: mt9v111 - a new Voice-Coil Motor (VCM) driver: dw9807-vcm - some cleanups at cx25821, removing legacy unused code - some improvements at ddbridge driver - new platform driver: vicodec - some DVB API cleanups, removing ioctls and compat code for old out-of-tree drivers that were never merged upstream - improvements at DVB core to support frontents that support both Satellite and non-satellite delivery systems - got rid of the unused VIDIOC_RESERVED V4L2 ioctl - some cleanups/improvements at gl861 ISDB driver - several improvements on ov772x, ov7670 and ov5640, imx274, ov5645, and smiapp sensor drivers - fixes at em28xx to support dual TS devices - some cleanups at V4L2/VB2 locking logic - some API improvements at media controller - some cec core and drivers improvements - some uvcvideo improvements - some improvements at platform drivers: stm32-dcmi, rcar-vin, coda, reneseas-ceu, imx, vsp1, venus, camss - lots of other cleanups and fixes * tag 'media/v4.19-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (406 commits) Revert "media: vivid: shut up warnings due to a non-trivial logic" siano: get rid of an unused return code for debugfs register media: isp: fix a warning about a wrong struct initializer media: radio-wl1273: fix return code for the polling routine media: s3c-camif: fix return code for the polling routine media: saa7164: fix return codes for the polling routine media: exynos-gsc: fix return code if mutex was interrupted media: mt9v111: Fix build error with no VIDEO_V4L2_SUBDEV_API media: xc4000: get rid of uneeded casts media: drxj: get rid of uneeded casts media: tuner-xc2028: don't use casts for printing sizes media: cleanup fall-through comments media: vivid: shut up warnings due to a non-trivial logic media: rtl28xxu: be sure that it won't go past the array size media: mt9v111: avoid going past the buffer media: vsp1_dl: add a description for cmdpool field media: sta2x11: add a missing parameter description media: v4l2-mem2mem: add descriptions to MC fields media: i2c: fix warning in Aptina MT9V111 media: imx: shut up a false positive warning ...
2018-08-15Merge tag 'kconfig-v4.19-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild Pull Kconfig consolidation from Masahiro Yamada: "Consolidation of Kconfig files by Christoph Hellwig. Move the source statements of arch-independent Kconfig files instead of duplicating the includes in every arch/$(SRCARCH)/Kconfig" * tag 'kconfig-v4.19-2' of git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild: kconfig: add a Memory Management options" menu kconfig: move the "Executable file formats" menu to fs/Kconfig.binfmt kconfig: use a menu in arch/Kconfig to reduce clutter kconfig: include kernel/Kconfig.preempt from init/Kconfig Kconfig: consolidate the "Kernel hacking" menu kconfig: include common Kconfig files from top-level Kconfig kconfig: remove duplicate SWAP symbol defintions um: create a proper drivers Kconfig um: cleanup Kconfig files um: stop abusing KBUILD_KCONFIG
2018-08-14Merge tag 'dma-mapping-4.19' of git://git.infradead.org/users/hch/dma-mappingLinus Torvalds
Pull dma-mapping updates from Christoph Hellwig: - a series from Robin to fix bus imposed dma limits by adding a separate mask for them to struct device instead of trying to squeeze a second meaning out of the existing dma mask as we did before. This has ACKs from the various other subsystems touched - a small swiotlb cleanup from Kees (acked by Konrad) - conversion of nios2 and sh to the new generic dma-noncoherent code. Various other architecture conversions will come through the architectures maintainers trees. * tag 'dma-mapping-4.19' of git://git.infradead.org/users/hch/dma-mapping: sh: use generic dma_noncoherent_ops sh: split arch/sh/mm/consistent.c sh: use dma_direct_ops for the CONFIG_DMA_COHERENT case sh: introduce a sh_cacheop_vaddr helper sh: simplify get_arch_dma_ops OF: Don't set default coherent DMA mask ACPI/IORT: Don't set default coherent DMA mask iommu/dma: Respect bus DMA limit for IOVAs of/device: Set bus DMA mask as appropriate ACPI/IORT: Set bus DMA mask as appropriate dma-mapping: Generalise dma_32bit_limit flag ACPI/IORT: Support address size limit for root complexes of/platform: Initialise default DMA masks nios2: use generic dma_noncoherent_ops swiotlb: clean up reporting dma-mapping: relax warning for per-device areas
2018-08-13Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf update from Thomas Gleixner: "The perf crowd presents: Kernel updates: - Removal of jprobes - Cleanup and consolidatation the handling of kprobes - Cleanup and consolidation of hardware breakpoints - The usual pile of fixes and updates to PMUs and event descriptors Tooling updates: - Updates and improvements all over the place. Nothing outstanding, just the (good) boring incremental grump work" * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (103 commits) perf trace: Do not require --no-syscalls to suppress strace like output perf bpf: Include uapi/linux/bpf.h from the 'perf trace' script's bpf.h perf tools: Allow overriding MAX_NR_CPUS at compile time perf bpf: Show better message when failing to load an object perf list: Unify metric group description format with PMU event description perf vendor events arm64: Update ThunderX2 implementation defined pmu core events perf cs-etm: Generate branch sample for CS_ETM_TRACE_ON packet perf cs-etm: Generate branch sample when receiving a CS_ETM_TRACE_ON packet perf cs-etm: Support dummy address value for CS_ETM_TRACE_ON packet perf cs-etm: Fix start tracing packet handling perf build: Fix installation directory for eBPF perf c2c report: Fix crash for empty browser perf tests: Fix indexing when invoking subtests perf trace: Beautify the AF_INET & AF_INET6 'socket' syscall 'protocol' args perf trace beauty: Add beautifiers for 'socket''s 'protocol' arg perf trace beauty: Do not print NULL strarray entries perf beauty: Add a generator for IPPROTO_ socket's protocol constants tools include uapi: Grab a copy of linux/in.h perf tests: Fix complex event name parsing perf evlist: Fix error out while applying initial delay and LBR ...
