path: root/arch/sh64/mm/init.c
2008-01-28sh: Kill off arch/sh64/mm.Paul Mundt
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-10-09sh64: Kill off obsolete linux/blk.h reference.Paul Mundt
This is just dead code, kill it off.. Reported-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-05-14sh64: generic quicklist support.Paul Mundt
2007-02-11[PATCH] optional ZONE_DMA: remove ZONE_DMA remains from sh/sh64Christoph Lameter
sh / sh64: Remove ZONE_DMA remains. Both arches do not need ZONE_DMA Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-09-26[PATCH] reduce MAX_NR_ZONES: fix MAX_NR_ZONES array initializationsChristoph Lameter
Fix array initialization in lots of arches The number of zones may now be reduced from 4 to 2 for many arches. Fix the array initialization for the zones array for all architectures so that it is not initializing a fixed number of elements. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-22[PATCH] remove set_page_count() outside mm/Nick Piggin
set_page_count usage outside mm/ is limited to setting the refcount to 1. Remove set_page_count from outside mm/, and replace those users with init_page_count() and set_page_refcounted(). This allows more debug checking, and tighter control on how code is allowed to play around with page->_count. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
