path: root/arch/sh/mm/tlb-sh4.c
2007-09-21sh: Fix up extended mode TLB for SH-X2+ cores.Paul Mundt
The extended mode TLB requires both 64-bit PTEs and a 64-bit pgprot, correspondingly, the PGD also has to be 64-bits, so fix that up. The kernel and user permission bits really are decoupled in early cuts of the silicon, which means that we also have to set corresponding kernel permissions on user pages or we end up with user pages that the kernel simply can't touch (!). Finally, with those things corrected, really enable MMUCR.ME and correct the PTEA value (this simply needs to be the upper 32-bits of the PTE, with the size and protection bit encoding). Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-09-21sh: Support explicit L1 cache disabling.Paul Mundt
This reworks the cache mode configuration in Kconfig, and allows for explicit selection of write-back/write-through/off configurations. All of the cache flushing routines are optimized away for the off case. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-03-05sh: Revert lazy dcache writeback changes.Paul Mundt
These ended up causing too many problems on older parts, revert for now.. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-02-13sh: Local TLB flushing variants for SMP prep.Paul Mundt
Rename the existing flush routines to local_ variants for use by the IPI-backed global flush routines on SMP. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-02-13sh: Lazy dcache writeback optimizations.Paul Mundt
This converts the lazy dcache handling to the model described in Documentation/cachetlb.txt and drops the ptep_get_and_clear() hacks used for the aliasing dcaches on SH-4 and SH7705 in 32kB mode. As a bonus, this slightly cuts down on the cache flushing frequency. With that and the PTEA handling out of the way, the update_mmu_cache() implementations can be consolidated, and we no longer have to worry about which configuration the cache is in for the SH7705 case. And finally, explicitly disable the lazy writeback on SMP (SH-4A). Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2006-09-27sh: Add flag for MMU PTEA capability.Paul Mundt
Add CPU_HAS_PTEA, refactor some of the cpu flag settings. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2006-09-27sh: Support for SH7770/SH7780 CPU subtypes.Paul Mundt
Merge support for SH7770 and SH7780 SH-4A subtypes. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
