This patch introduces zone_for_memory() to arch_add_memory() on sh to
ensure new, higher memory added into ZONE_MOVABLE if movable zone has
already setup.
Signed-off-by: Wang Nan <wangnan0@huawei.com>
Cc: Zhang Yanfei <zhangyanfei@cn.fujitsu.com>
Cc: Yinghai Lu <yinghai@kernel.org>
Cc: "Mel Gorman" <mgorman@suse.de>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Chris Metcalf <cmetcalf@tilera.com>
Use "pgdat_end_pfn()" instead of "pgdat->node_start_pfn +
pgdat->node_spanned_pages". Simplify the code, no functional change.
Signed-off-by: Xishi Qiu <qiuxishi@huawei.com>
Cc: James Hogan <james.hogan@imgtec.com>
Prepare for killing free_all_bootmem_node() by using free_all_bootmem().
Signed-off-by: Jiang Liu <jiang.liu@huawei.com>
Cc: Wen Congyang <wency@cn.fujitsu.com>
Cc: Tang Chen <tangchen@cn.fujitsu.com>
Prepare for removing num_physpages and simplify mem_init().
Concentrate code to modify totalram_pages into the mm core, so the arch
memory initialized code doesn't need to take care of it. With these
changes applied, only following functions from mm core modify global
variable totalram_pages: free_bootmem_late(), free_all_bootmem(),
free_all_bootmem_node(), adjust_managed_page_count().
With this patch applied, it will be much more easier for us to keep
totalram_pages and zone->managed_pages in consistence.
Cc: "Michael S. Tsirkin" <mst@redhat.com>
Cc: <sworddragon2@aol.com>
Cc: Jianguo Wu <wujianguo@huawei.com>
Cc: Joonsoo Kim <js1304@gmail.com>
Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Marek Szyprowski <m.szyprowski@samsung.com>
Cc: Michel Lespinasse <walken@google.com>
Cc: Minchan Kim <minchan@kernel.org>
Cc: Tejun Heo <tj@kernel.org>
Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Address more review comments from last round of code review.
1) Enhance free_reserved_area() to support poisoning freed memory with
pattern '0'. This could be used to get rid of poison_init_mem()
on ARM64.
2) A previous patch has disabled memory poison for initmem on s390
by mistake, so restore to the original behavior.
3) Remove redundant PAGE_ALIGN() when calling free_reserved_area().
Change signature of free_reserved_area() according to Russell King's
suggestion to fix following build warnings:
arch/arm/mm/init.c: In function 'mem_init':
arch/arm/mm/init.c:603:2: warning: passing argument 1 of 'free_reserved_area' makes integer from pointer without a cast [enabled by default]
free_reserved_area(__va(PHYS_PFN_OFFSET), swapper_pg_dir, 0, NULL);
In file included from include/linux/mman.h:4:0,
from arch/arm/mm/init.c:15:
include/linux/mm.h:1301:22: note: expected 'long unsigned int' but argument is of type 'void *'
extern unsigned long free_reserved_area(unsigned long start, unsigned long end,
mm/page_alloc.c: In function 'free_reserved_area':
>> mm/page_alloc.c:5134:3: warning: passing argument 1 of 'virt_to_phys' makes pointer from integer without a cast [enabled by default]
In file included from arch/mips/include/asm/page.h:49:0,
from include/linux/mmzone.h:20,
from include/linux/gfp.h:4,
from include/linux/mm.h:8,
from mm/page_alloc.c:18:
arch/mips/include/asm/io.h:119:29: note: expected 'const volatile void *' but argument is of type 'long unsigned int'
mm/page_alloc.c: In function 'free_area_init_nodes':
mm/page_alloc.c:5030:34: warning: array subscript is below array bounds [-Warray-bounds]
Also address some minor code review comments.
Use common help functions to free reserved pages.
Acked-by: Paul Mundt <lethal@linux-sh.org>
For removing memory, we need to remove page tables. But it depends on
architecture. So the patch introduce arch_remove_memory() for removing
page table. Now it only calls __remove_pages().
Note: __remove_pages() for some archtecuture is not implemented
(I don't know how to implement it for s390).
Signed-off-by: Wen Congyang <wency@cn.fujitsu.com>
Signed-off-by: Tang Chen <tangchen@cn.fujitsu.com>
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Jiang Liu <jiang.liu@huawei.com>
Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
Cc: Wu Jianguo <wujianguo@huawei.com>
The only function of memblock_analyze() is now allowing resize of
memblock region arrays. Rename it to memblock_allow_resize() and
update its users.
* The following users remain the same other than renaming.
arm/mm/init.c::arm_memblock_init()
microblaze/kernel/prom.c::early_init_devtree()
powerpc/kernel/prom.c::early_init_devtree()
openrisc/kernel/prom.c::early_init_devtree()
sh/mm/init.c::paging_init()
sparc/mm/init_64.c::paging_init()
unicore32/mm/init.c::uc32_memblock_init()
* In the following users, analyze was used to update total size which
is no longer necessary.
powerpc/kernel/machine_kexec.c::reserve_crashkernel()
powerpc/mm/init_32.c::MMU_init()
powerpc/mm/tlb_nohash.c::__early_init_mmu()
powerpc/platforms/ps3/mm.c::ps3_mm_add_memory()
powerpc/platforms/embedded6xx/wii.c::wii_memory_fixups()
sh/kernel/machine_kexec.c::reserve_crashkernel()
* x86/kernel/e820.c::memblock_x86_fill() was directly setting
memblock_can_resize before populating memblock and calling analyze
afterwards. Call memblock_allow_resize() before start populating.
memblock_can_resize is now static inside memblock.c.
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
memblock_init() initializes arrays for regions and memblock itself;
however, all these can be done with struct initializers and
memblock_init() can be removed. This patch kills memblock_init() and
initializes memblock with struct initializer.
The only difference is that the first dummy entries don't have .nid
set to MAX_NUMNODES initially. This doesn't cause any behavior
difference.
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
* 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits)
Revert "tracing: Include module.h in define_trace.h"
irq: don't put module.h into irq.h for tracking irqgen modules.
bluetooth: macroize two small inlines to avoid module.h
ip_vs.h: fix implicit use of module_get/module_put from module.h
nf_conntrack.h: fix up fallout from implicit moduleparam.h presence
include: replace linux/module.h with "struct module" wherever possible
include: convert various register fcns to macros to avoid include chaining
crypto.h: remove unused crypto_tfm_alg_modname() inline
uwb.h: fix implicit use of asm/page.h for PAGE_SIZE
pm_runtime.h: explicitly requires notifier.h
linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h
miscdevice.h: fix up implicit use of lists and types
stop_machine.h: fix implicit use of smp.h for smp_processor_id
of: fix implicit use of errno.h in include/linux/of.h
of_platform.h: delete needless include <linux/module.h>
acpi: remove module.h include from platform/aclinux.h
miscdevice.h: delete unnecessary inclusion of module.h
device_cgroup.h: delete needless include <linux/module.h>
net: sch_generic remove redundant use of <linux/module.h>
net: inet_timewait_sock doesnt need <linux/module.h>
Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in
- drivers/media/dvb/frontends/dibx000_common.c
- drivers/media/video/{mt9m111.c,ov6650.c}
- drivers/mfd/ab3550-core.c
- include/linux/dmaengine.h
Add PHYSICAL_START kernel configuration parameter to set the address at
which the kernel should be loaded.
It has been observed on an sh7757lcr that simply modifying MEMORY_START
does not achieve this goal for 32bit sh. This is due to MEMORY_OFFSET in
arch/sh/kernel/vmlinux.lds.S bot being based on MEMORY_START on such
systems.
Signed-off-by: Simon Horman <horms@verge.net.au>
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
Fold all the mmu_gather rework patches into one for submission
Reported-by: Hugh Dickins <hughd@google.com>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Richard Weinberger <richard@nod.at>
Cc: Nick Piggin <npiggin@kernel.dk>
Cc: Namhyung Kim <namhyung@gmail.com>
This adds in a callback to the machvec to allow platforms to do early
reservations through memblock.
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: (110 commits)
sh: i2c-sh7760: Replase from ctrl_* to __raw_*
sh: clkfwk: Shuffle around to match the intc split up.
sh: clkfwk: modify for_each_frequency end condition
sh: fix clk_get() error handling
sh: clkfwk: Fix fault in frequency iterator.
sh: clkfwk: Add a helper for rate rounding by divisor ranges.
sh: clkfwk: Abstract rate rounding helper.
sh: clkfwk: support clock remapping.
sh: pci: Convert to upper/lower_32_bits() helpers.
sh: mach-sdk7786: Add support for the FPGA SRAM.
sh: Provide a generic SRAM pool for tiny memories.
sh: pci: Support secondary FPGA-driven PCIe clocks on SDK7786.
sh: pci: Support slot 4 routing on SDK7786.
sh: Fix up PMB locking.
sh: mach-sdk7786: Add support for fpga gpios.
sh: use pr_fmt for clock framework, too.
sh: remove name and id from struct clk
sh: free-without-alloc fix for sh_mobile_lcdcfb
sh: perf: Set up perf_max_events.
sh: perf: Support SH-X3 hardware counters.
Fix up trivial conflicts (perf_max_events got removed) in arch/sh/kernel/perf_event.c
We need to round memory regions correctly -- specifically, we need to
round reserved region in the more expansive direction (lower limit
down, upper limit up) whereas usable memory regions need to be rounded
in the more restrictive direction (lower limit up, upper limit down).
This introduces two set of inlines:
memblock_region_memory_base_pfn()
memblock_region_memory_end_pfn()
memblock_region_reserved_base_pfn()
memblock_region_reserved_end_pfn()
Although they are antisymmetric (and therefore are technically
duplicates) the use of the different inlines explicitly documents the
programmer's intention.
The lack of proper rounding caused a bug on ARM, which was then found
to also affect other architectures.
Reported-by: Russell King <rmk@arm.linux.org.uk>
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
LKML-Reference: <4CB4CDFD.4020105@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6
CC: Paul Mundt <lethal@linux-sh.org>
via following scripts
FILES=$(find * -type f | grep -vE 'oprofile|[^K]config')
sed -i \
-e 's/lmb/memblock/g' \
-e 's/LMB/MEMBLOCK/g' \
$FILES
for N in $(find . -name lmb.[ch]); do
M=$(echo $N | sed 's/lmb/memblock/g')
mv $N $M
done
and remove some wrong change like lmbench and dlmb etc.
also move memblock.c from lib/ to mm/
Suggested-by: Ingo Molnar <mingo@elte.hu>
Acked-by: "H. Peter Anvin" <hpa@zytor.com>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
page_table_range_init() presently allocates a PUD page for the 3-level
page table case on X2 TLB configurations on each successive call. This
results in the previous PUD page being trampled when PMDs with an
overlapping PUD are initialized. This case was triggered by putting
persistent kmaps immediately below the fixmap range for highmem.
The reserve_crashkernel() definition is in asm/kexec.h which is only
dragged in via linux/kexec.h if CONFIG_KEXEC is set. Just switch over to
asm/kexec.h unconditionally to fix up the build.
This reworks much of the bootmem setup and initialization code allowing
us to get rid of duplicate work between the NUMA and non-NUMA cases. The
end result is that we end up with a much more flexible interface for
supporting more complex topologies (fake NUMA, highmem, etc, etc.) which
is entirely LMB backed. This is an incremental step for more NUMA work as
well as gradually enabling migration off of bootmem entirely.
This plugs in a memory init callback in the machvec to permit boards to
wire up various bits of memory directly in to LMB. A generic machvec
implementation is provided that simply wraps around the normal
Kconfig-derived memory start/size.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
This implements a bit of rework for the PMB code, which permits us to
kill off the legacy PMB mode completely. Rather than trusting the boot
loader to do the right thing, we do a quick verification of the PMB
contents to determine whether to have the kernel setup the initial
mappings or whether it needs to mangle them later on instead.
If we're booting from legacy mappings, the kernel will now take control
of them and make them match the kernel's initial mapping configuration.
This is accomplished by breaking the initialization phase out in to
multiple steps: synchronization, merging, and resizing. With the recent
rework, the synchronization code establishes page links for compound
mappings already, so we build on top of this for promoting mappings and
reclaiming unused slots.
At the same time, the changes introduced for the uncached helpers also
permit us to dynamically resize the uncached mapping without any
particular headaches. The smallest page size is more than sufficient for
mapping all of kernel text, and as we're careful not to jump to any far
off locations in the setup code the mapping can safely be resized
regardless of whether we are executing from it or not.
This adds some helper routines for uncached mapping support. This
simplifies some of the cases where we need to check the uncached mapping
boundaries in addition to giving us a centralized location for building
more complex manipulation on top of.
This splits out the uncached mapping support under its own config option,
presently only used by 29-bit mode and 32-bit + PMB. This will make it
possible to optionally add an uncached mapping on sh64 as well as booting
without an uncached mapping for 32-bit.
Now that cached_to_uncached works as advertized in 32-bit mode and we're
never going to be able to map < 16MB anyways, there's no need for the
special uncached section. Kill it off.
This provides a variable for tracking the uncached mapping size, and uses
it for pretty printing the uncached lowmem range. Beyond this, we'll also
be building on top of this for figuring out from where the remainder of
P2 becomes usable when constructing unrelated mappings.
This cribs the pretty printing from arch/x86/mm/init_32.c to dump the
virtual memory layout on boot. This is primarily intended as a debugging
aid, given that the newer CPUs have full control over their address space
and as such have little to nothing in common with the legacy layout.
Presently __in_29bit_mode() is only defined for the PMB case, but
it's also easily derived from the CONFIG_29BIT and CONFIG_32BIT &&
CONFIG_PMB=n cases.
The plans for _PAGE_WIRED were detailed in a comment with the fixmap
code, but as it's now all taken care of, we no longer have any reason for
keeping it around, particularly since it's no longer accurate. Kill it
off.
This adds in a mem_init_done to work out when a standard ioremap() is
possible, falling back to the fixmap based ioremap otherwise.
Generalise the code for setting and clearing pte's and allow TLB entries
to be pinned and unpinned if the _PAGE_WIRED flag is present.
Signed-off-by: Matt Fleming <matt@console-pimps.org>
Presently the thread_info allocators are special cased, depending on
THREAD_SHIFT < PAGE_SHIFT. This provides a sensible definition for them
regardless of configuration, in preparation for extended CPU state.
If using 64-bit PTEs and 4K pages then each page table has 512 entries
(as opposed to 1024 entries with 32-bit PTEs). Unlike MIPS, SH follows
the convention that all structures in the page table (pgd_t, pmd_t,
pgprot_t, etc) must be the same size. Therefore, 64-bit PTEs require
64-bit PGD entries, etc. Using 2-levels of page tables and 64-bit PTEs
it is only possible to map 1GB of virtual address space.
In order to map all 4GB of virtual address space we need to adopt a
3-level page table layout. This actually works out better for
CONFIG_SUPERH32 because we only waste 2 PGD entries on the P1 and P2
areas (which are untranslated) instead of 256.
Presently this was tacked on to the dma debug init bits from
fs_initcall(), which is far too late for devices setting up their own
per-device coherent areas.
Throw this in the beginning of mem_init(), as per the x86 iommu
allocation.
To allow the MMU to be switched between 29bit and 32bit mode at runtime
some constants need to swapped for functions that return a runtime
value.
For /proc/kcore, each arch registers its memory range by kclist_add().
In usual,
- range of physical memory
- range of vmalloc area
- text, etc...
are registered but "range of physical memory" has some troubles. It
doesn't updated at memory hotplug and it tend to include unnecessary
memory holes. Now, /proc/iomem (kernel/resource.c) includes required
physical memory range information and it's properly updated at memory
hotplug. Then, it's good to avoid using its own code(duplicating
information) and to rebuild kclist for physical memory based on
/proc/iomem.
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
Cc: WANG Cong <xiyou.wangcong@gmail.com>
For /proc/kcore, vmalloc areas are registered per arch. But, all of them
registers same range of [VMALLOC_START...VMALLOC_END) This patch unifies
them. By this. archs which have no kclist_add() hooks can see vmalloc
area correctly.
Presently, kclist_add() only eats start address and size as its arguments.
Considering to make kclist dynamically reconfigulable, it's necessary to
know which kclists are for System RAM and which are not.
This patch add kclist types as
KCORE_RAM
KCORE_VMALLOC
KCORE_TEXT
KCORE_OTHER
This "type" is used in a patch following this for detecting KCORE_RAM.
Commit 96177299416dbccb73b54e6b344260154a445375 ("Drop free_pages()")
modified nr_free_pages() to return 'unsigned long' instead of 'unsigned
int'. This made the casts to 'unsigned long' in most callers superfluous,
so remove them.
Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com>
Reviewed-by: Christoph Lameter <cl@linux-foundation.org>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Acked-by: Kyle McMartin <kyle@mcmartin.ca>
Acked-by: WANG Cong <xiyou.wangcong@gmail.com>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Haavard Skinnemoen <hskinnemoen@atmel.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Hirokazu Takata <takata@linux-m32r.org>
Cc: Chris Zankel <zankel@tensilica.com>
This fixes up the kmap_coherent/kunmap_coherent() interface for recent
changes both in the page fault path and the shared cache flushers, as
well as adding in some optimizations.
One of the key things to note here is that the TLB flush itself is
deferred until the unmap, and the call in to update_mmu_cache() itself
goes away, relying on the regular page fault path to handle the lazy
dcache writeback if necessary.
This paves the way for allowing individual CPUs to overload the
individual flushing routines that they care about without having to
depend on weak aliases. SH-4 is converted over initially, as it wires
up pretty much everything. The majority of the other CPUs will simply use
the default no-op implementation with their own region flushers wired up.
This provides a central point for CPU cache initialization routines.
This replaces the antiquated p3_cache_init() method, which the vast
majority of CPUs never cared about.
Now that sh64 also can use the uncached section, wire up the fixmap for
it as well.
set_pte_phys() presently uses the global flush_tlb_one(), which locks on
SMP trying to do the IPI. As we have not even initialized the other CPUs
at this point, switch to the local_ variant so the flush happens on the
boot CPU.
This kills off after_bootmem and switches to using slab_is_available()
instead. Presently the only place this is used is by the sh64 ioremap,
and there's not much point in keeping the reference around otherwise.
