path: root/arch/sh/kernel/ftrace.c
2018-11-27sh/function_graph: Simplify with function_graph_enter()Steven Rostedt (VMware)
The function_graph_enter() function does the work of calling the function graph hook function and the management of the shadow stack, simplifying the work done in the architecture dependent prepare_ftrace_return(). Have superh use the new code, and remove the shadow stack management as well as having to set up the trace structure. This is needed to prepare for a fix of a design bug on how the curr_ret_stack is used. Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Rich Felker <dalias@libc.org> Cc: linux-sh@vger.kernel.org Cc: stable@kernel.org Fixes: 03274a3ffb449 ("tracing/fgraph: Adjust fgraph depth before calling trace return callback") Reviewed-by: Masami Hiramatsu <mhiramat@kernel.org> Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-27sh/ftrace: Remove only user of ftrace_arch_read_dyn_info()Steven Rostedt
I noticed that there's only one user of ftrace_arch_read_dyn_info(). That was used a while ago during the NMI updating in x86, and superh copied it to implement its version of handling NMIs during stop_machine(). But that is a debug feature, and this code hasn't been touched since 2009. Also, x86 no longer does the ftrace updates with stop_machine() and instead uses breakpoints. If superh needs to modify its code, it should implement the breakpoint conversion, and remove stop_machine(). Which also gets rid of the NMI issue. Anyway, I want to nuke ftrace_arch_read_dyn_info() and this gets rid of the one user, which is for an arch that shouldn't need it anymore. Link: http://lkml.kernel.org/r/20170626181749.2ce954d1@gandalf.local.home Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Rich Felker <dalias@libc.org> Cc: linux-sh@vger.kernel.org Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
2016-10-06Merge tag 'trace-v4.9' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull tracing updates from Steven Rostedt: "This release cycle is rather small. Just a few fixes to tracing. The big change is the addition of the hwlat tracer. It not only detects SMIs, but also other latency that's caused by the hardware. I have detected some latency from large boxes having bus contention" * tag 'trace-v4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: tracing: Call traceoff trigger after event is recorded ftrace/scripts: Add helper script to bisect function tracing problem functions tracing: Have max_latency be defined for HWLAT_TRACER as well tracing: Add NMI tracing in hwlat detector tracing: Have hwlat trace migrate across tracing_cpumask CPUs tracing: Add documentation for hwlat_detector tracer tracing: Added hardware latency tracer ftrace: Access ret_stack->subtime only in the function profiler function_graph: Handle TRACE_BPUTS in print_graph_comment tracing/uprobe: Drop isdigit() check in create_trace_uprobe
2016-09-02tracing: Add NMI tracing in hwlat detectorSteven Rostedt (Red Hat)
As NMIs can also cause latency when interrupts are disabled, the hwlat detectory has no way to know if the latency it detects is from an NMI or an SMI or some other hardware glitch. As ftrace_nmi_enter/exit() funtions are no longer used (except for sh, which isn't supported anymore), I converted those to "arch_ftrace_nmi_enter/exit" and use ftrace_nmi_enter/exit() to check if hwlat detector is tracing or not, and if so, it calls into the hwlat utility. Since the hwlat detector only has a single kthread that is spinning with interrupts disabled, it marks what CPU it is on, and if the NMI callback happens on that CPU, it records the time spent in that NMI. This is added to the output that is generated by the hwlat detector as: #3 inner/outer(us): 9/9 ts:1470836488.206734548 #4 inner/outer(us): 0/8 ts:1470836497.140808588 #5 inner/outer(us): 0/6 ts:1470836499.140825168 nmi-total:5 nmi-count:1 #6 inner/outer(us): 9/9 ts:1470836501.140841748 All time is still tracked in microseconds. The NMI information is only shown when an NMI occurred during the sample. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2016-08-24ftrace: Add return address pointer to ftrace_ret_stackJosh Poimboeuf
Storing this value will help prevent unwinders from getting out of sync with the function graph tracer ret_stack. Now instead of needing a stateful iterator, they can compare the return address pointer to find the right ret_stack entry. Note that an array of 50 ftrace_ret_stack structs is allocated for every task. So when an arch implements this, it will add either 200 or 400 bytes of memory usage per task (depending on whether it's a 32-bit or 64-bit platform). Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Byungchul Park <byungchul.park@lge.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Kees Cook <keescook@chromium.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Nilay Vaish <nilayvaish@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/a95cfcc39e8f26b89a430c56926af0bb217bc0a1.1471607358.git.jpoimboe@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-12-23sh: ftrace: Fix the comments for ftrace_modify_code()Li Bin
There is no need to worry about module and __init text disappearing case, because that ftrace has a module notifier that is called when a module is being unloaded and before the text goes away and this code grabs the ftrace_lock mutex and removes the module functions from the ftrace list, such that it will no longer do any modifications to that module's text, the update to make functions be traced or not is done under the ftrace_lock mutex as well. And by now, __init section codes should not been modified by ftrace, because it is black listed in recordmcount.c and ignored by ftrace. Link: http://lkml.kernel.org/r/1449367378-29430-5-git-send-email-huawei.libin@huawei.com Cc: linux-sh@vger.kernel.org Suggested-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Li Bin <huawei.libin@huawei.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2014-07-18sh: ftrace: Add call to ftrace_graph_is_dead() in function graph codeSteven Rostedt (Red Hat)
ftrace_stop() is going away as it disables parts of function tracing that affects users that should not be affected. But ftrace_graph_stop() is built on ftrace_stop(). Here's another example of killing all of function tracing because something went wrong with function graph tracing. Instead of disabling all users of function tracing on function graph error, disable only function graph tracing. To do this, the arch code must call ftrace_graph_is_dead() before it implements function graph. Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2014-03-07ftrace: Do not pass data to ftrace_dyn_arch_initJiri Slaby
As the data parameter is not really used by any ftrace_dyn_arch_init, remove that from ftrace_dyn_arch_init. This also removes the addr local variable from ftrace_init which is now unused. Note the documentation was imprecise as it did not suggest to set (*data) to 0. Link: http://lkml.kernel.org/r/1393268401-24379-4-git-send-email-jslaby@suse.cz Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: linux-arch@vger.kernel.org Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2014-03-07ftrace: Pass retval through return in ftrace_dyn_arch_init()Jiri Slaby
No architecture uses the "data" parameter in ftrace_dyn_arch_init() in any way, it just sets the value to 0. And this is used as a return value in the caller -- ftrace_init, which just checks the retval against zero. Note there is also "return 0" in every ftrace_dyn_arch_init. So it is enough to check the retval and remove all the indirect sets of data on all archs. Link: http://lkml.kernel.org/r/1393268401-24379-3-git-send-email-jslaby@suse.cz Cc: linux-arch@vger.kernel.org Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-02-17tracing: Unify arch_syscall_addr() implementationsMike Frysinger
Most implementations of arch_syscall_addr() are the same, so create a default version in common code and move the one piece that differs (the syscall table) to asm/syscall.h. New arch ports don't have to waste time copying & pasting this simple function. The s390/sparc versions need to be different, so document why. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <1264498803-17278-1-git-send-email-vapier@gentoo.org> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2009-12-11sh: ftrace: Fix up syscall tracing build.Paul Mundt
Syscall tracing metadata was shuffled around, update accordingly. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-10-13sh: ftrace: Make code modification NMI safe.Paul Mundt
This cribs the x86 implementation of ftrace_nmi_enter() and friends to make ftrace_modify_code() NMI safe, particularly on SMP configurations. For additional notes on the problems involved, see the comment below ftrace_call_replace(). Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-10-13sh: ftrace: Fix up syscall tracepoint support.Paul Mundt
Sync up with latest core changes in the syscalls tracing area: - tracing: Map syscall name to number (syscall_name_to_nr()) - tracing: Call arch_init_ftrace_syscalls at boot - tracing: add support tracepoint ids (set_syscall_{enter,exit}_id()) Taken from the s390 change. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-08-24sh: Move the FTRACE_SYSCALL_MAX definition in to asm/ftrace.h.Paul Mundt
Needed by ftrace changes in -tip. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-07-11sh: Function graph tracer supportMatt Fleming
Add both dynamic and static function graph tracer support for sh. Signed-off-by: Matt Fleming <matt@console-pimps.org> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-07-06sh: Add ftrace syscall tracing supportMatt Fleming
Now that I've added TIF_SYSCALL_FTRACE the thread flags do not fit into a single byte any more. Code testing them now needs to be aware of the upper and lower bytes. Signed-off-by: Matt Fleming <matt@console-pimps.org> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-06-11sh: Fix dynamic ftrace's NOP action.Matt Fleming
Ftrace on sh handles nop'ing out trace function calls differently than other architectures. Instead of inserting NOP instructions in place of the call to the function tracer we branch over the call instructions and continue executing the main body of the function. This patch fixes a bug in the implementation of ftrace_modify_code() where we check that the old value of the code we're about to replace is an expected one. In the ftrace_make_call() code path ftrace_modify_code() was comparing the old instruction value with NOP instructions. The compare was failing because we never actually insert NOP instructions. It makes sense to just get rid of the NOP instructions in ftrace_nop and compare the old code with the address of the function body if we're expecting ftrace to have nop'd out the function trace call. Signed-off-by: Matt Fleming <matt@console-pimps.org>
2009-06-11sh: Update my email addressMatt Fleming
Use my current email address as my gentoo account will be closed at some point. Signed-off-by: Matt Fleming <matt@console-pimps.org>
2008-12-22sh: Provide ftrace_make_call()/ftrace_make_nop().Paul Mundt
2008-12-22sh: dynamic ftrace support.Matt Fleming
First cut at dynamic ftrace support. Signed-off-by: Matt Fleming <mjf@gentoo.org> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
