path: root/arch/sh/include/asm/smp.h
2010-04-26sh: CPU hotplug support.Paul Mundt
This adds preliminary support for CPU hotplug for SH SMP systems. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-04-26sh: provide percpu CPU states for hotplug notifiers.Paul Mundt
This provides percpu CPU states in preparation for CPU hotplug and the associated notifier chains. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-04-21sh: Move platform smp ops in to their own structure.Paul Mundt
This cribs the MIPS plat_smp_ops approach for wrapping up the platform ops. This will allow for mixing and matching different ops on the same platform in the future. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-09-24cpumask: remove arch_send_call_function_ipiRusty Russell
Now everyone is converted to arch_send_call_function_ipi_mask, remove the shim and the #defines. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-06-14cpumask: arch_send_call_function_ipi_mask: shRusty Russell
We're weaning the core code off handing cpumask's around on-stack. This introduces arch_send_call_function_ipi_mask(), and by defining it, the old arch_send_call_function_ipi is defined by the core code. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-12-13cpumask: convert struct clock_event_device to cpumask pointers.Rusty Russell
Impact: change calling convention of existing clock_event APIs struct clock_event_timer's cpumask field gets changed to take pointer, as does the ->broadcast function. Another single-patch change. For safety, we BUG_ON() in clockevents_register_device() if it's not set. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Ingo Molnar <mingo@elte.hu>
2008-09-08sh: generic clockevent broadcast support.Paul Mundt
This hooks up GENERIC_CLOCKEVENTS_BROADCAST and a dummy local timer, which we call in to from the timer IPI when no other local timer is provided. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-09-08sh: smp: Hook up a timer IPI stub.Paul Mundt
2008-09-08sh: smp: Hook in to the generic IPI handler for SH-X3 SMP.Paul Mundt
2008-09-08sh: smp: Provide a generic IPI handler.Paul Mundt
This provides a generic smp_message_recv() routine (based on the PPC one), that IPI IRQs can wrap in to. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-09-08sh: Kill off unused defines from asm/smp.h.Paul Mundt
2008-07-29sh: migrate to arch/sh/include/Paul Mundt
This follows the sparc changes a439fe51a1f8eb087c22dd24d69cebae4a3addac. Most of the moving about was done with Sam's directions at: http://marc.info/?l=linux-sh&m=121724823706062&w=2 with subsequent hacking and fixups entirely my fault. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
