None of these contain pci_ops, only IRQ routing bits, rename them
accordingly.
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
This follows the similar sort of scheme that the refactored SH7780 code
uses, using a 64MB CS3 mapping to handle the window0 case, and simply
discarding window1. This vastly simplifies the code, and allows most of
the board-specific setup to go die.
Nothing ended up using this anymore, so just kill it off.
Instead of sometimes exporting board_pci_channels[] in the board specific
code just export it in one place.
Signed-off-by: Magnus Damm <damm@igel.co.jp>
This patch adds an init callback to struct pci_channel and makes sure
it is initialized properly. Code is added to call this init function
from pcibios_init(). Return values are adjusted and a warning is is
printed if init fails.
These patches rework the pci code for the sh architecture.
Currently each board implements some kind of ioport to address mapping.
Some boards use generic_io_base others try passing addresses as io ports.
This is the first set of patches that try to unify the pci code as much
as possible to avoid duplicated code. This will in the end lead to fewer
lines board specific code and more generic code.
This patch makes sure a struct pci_channel pointer is passed along to
various pci functions such as pci_read_reg(), pci_write_reg(),
pci_fixup_pcic(), sh7751_pcic_init() and sh7780_pcic_init().
This adds support for the L-BOX RE2 router.
http://www.nttcom.co.jp/l-box/
L-BOX RE2 is a SH7751R-based router. It has CF, Cardbus, serial,
and LAN x2. This is one of the very few SH boards that a general
person can obtain now.
The L-BOX shipped with a 2.4.28 kernel, this is a rewritten patch
adding it to current git.
