path: root/arch/s390/lib/string.c
2009-03-26[S390] use compiler builtin versions of strlen/strcpy/strcatHeiko Carstens
Use builtin variants if gcc 4 or newer is used to compile the kernel. Generates better code than the asm variants. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-07-12[S390] Fix sparse warnings.Heiko Carstens
