path: root/arch/s390/kvm/kvm-s390.h
2013-01-30s390/kvm: Fix instruction decodingChristian Borntraeger
Instructions with long displacement have a signed displacement. Currently the sign bit is interpreted as 2^20: Lets fix it by doing the sign extension from 20bit to 32bit and then use it as a signed variable in the addition (see kvm_s390_get_base_disp_rsy). Furthermore, there are lots of "int" in that code. This is problematic, because shifting on a signed integer is undefined/implementation defined if the bit value happens to be negative. Fortunately the promotion rules will make the right hand side unsigned anyway, so there is no real problem right now. Let's convert them anyway to unsigned where appropriate to avoid problems if the code is changed or copy/pasted later on. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Reviewed-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2013-01-07KVM: s390: Add support for channel I/O instructions.Cornelia Huck
Add a new capability, KVM_CAP_S390_CSS_SUPPORT, which will pass intercepts for channel I/O instructions to userspace. Only I/O instructions interacting with I/O interrupts need to be handled in-kernel: - TEST PENDING INTERRUPTION (tpi) dequeues and stores pending interrupts entirely in-kernel. - TEST SUBCHANNEL (tsch) dequeues pending interrupts in-kernel and exits via KVM_EXIT_S390_TSCH to userspace for subchannel- related processing. Reviewed-by: Marcelo Tosatti <mtosatti@redhat.com> Reviewed-by: Alexander Graf <agraf@suse.de> Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2013-01-07KVM: s390: In-kernel handling of I/O instructions.Cornelia Huck
Explicitely catch all channel I/O related instructions intercepts in the kernel and set condition code 3 for them. This paves the way for properly handling these instructions later on. Note: This is not architecture compliant (the previous code wasn't either) since setting cc 3 is not the correct thing to do for some of these instructions. For Linux guests, however, it still has the intended effect of stopping css probing. Reviewed-by: Marcelo Tosatti <mtosatti@redhat.com> Reviewed-by: Alexander Graf <agraf@suse.de> Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2013-01-07KVM: s390: Add support for machine checks.Cornelia Huck
Add support for injecting machine checks (only repressible conditions for now). This is a bit more involved than I/O interrupts, for these reasons: - Machine checks come in both floating and cpu varieties. - We don't have a bit for machine checks enabling, but have to use a roundabout approach with trapping PSW changing instructions and watching for opened machine checks. Reviewed-by: Alexander Graf <agraf@suse.de> Reviewed-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2013-01-07KVM: s390: Decoding helper functions.Cornelia Huck
Introduce helper functions for decoding the various base/displacement instruction formats. Reviewed-by: Alexander Graf <agraf@suse.de> Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2012-07-20s390/comments: unify copyright messages and remove file namesHeiko Carstens
Remove the file name from the comment at top of many files. In most cases the file name was wrong anyway, so it's rather pointless. Also unify the IBM copyright statement. We did have a lot of sightly different statements and wanted to change them one after another whenever a file gets touched. However that never happened. Instead people start to take the old/"wrong" statements to use as a template for new files. So unify all of them in one go. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2012-04-30KVM: s390: Handle sckpf instructionCornelia Huck
Handle the mandatory intercept SET CLOCK PROGRAMMABLE FIELD instruction. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2012-03-05KVM: s390: rework code that sets the prefixChristian Borntraeger
There are several places in the kvm module, which set the prefix register. Since we need to flush the cpu, lets combine this operation into a helper function. This helper will also explicitely mask out the unused bits. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-03-05KVM: s390: ucontrol: export page faults to userCarsten Otte
This patch introduces a new exit reason in the kvm_run structure named KVM_EXIT_S390_UCONTROL. This exit indicates, that a virtual cpu has regognized a fault on the host page table. The idea is that userspace can handle this fault by mapping memory at the fault location into the cpu's address space and then continue to run the virtual cpu. Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-03-05KVM: s390: add parameter for KVM_CREATE_VMCarsten Otte
This patch introduces a new config option for user controlled kernel virtual machines. It introduces a parameter to KVM_CREATE_VM that allows to set bits that alter the capabilities of the newly created virtual machine. The parameter is passed to kvm_arch_init_vm for all architectures. The only valid modifier bit for now is KVM_VM_S390_UCONTROL. This requires CAP_SYS_ADMIN privileges and creates a user controlled virtual machine on s390 architectures. Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-07-24[S390] remove kvm mmu reload on s390Carsten Otte
This patch removes the mmu reload logic for kvm on s390. Via Martin's new gmap interface, we can safely add or remove memory slots while guest CPUs are in-flight. Thus, the mmu reload logic is not needed anymore. Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-07-24[S390] Use gmap translation for accessing guest memoryCarsten Otte
This patch removes kvm-s390 internal assumption of a linear mapping of guest address space to user space. Previously, guest memory was translated to user addresses using a fixed offset (gmsor). The new code uses gmap_fault to resolve guest addresses. Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-07-24[S390] kvm: handle tprot interceptsChristian Borntraeger
When running a kvm guest we can get intercepts for tprot, if the host page table is read-only or not populated. This patch implements the most common case (linux memory detection). This also allows host copy on write for guest memory on newer systems. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-08-01KVM: s390: Fix build failure due to centralized vcpu locking patchesChristian Borntraeger
This patch fixes ERROR: "__kvm_s390_vcpu_store_status" [arch/s390/kvm/kvm.ko] undefined! triggered by commit 3268c56840dcee78c3e928336550f4e1861504c4 (kvm.git) Author: Avi Kivity <avi@redhat.com> Date: Thu May 13 12:21:46 2010 +0300 KVM: s390: Centrally lock arch specific vcpu ioctls Reported-by: Sachin Sant <sachinp@in.ibm.com> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-05-17KVM: use the correct RCU API for PROVE_RCU=yLai Jiangshan
The RCU/SRCU API have already changed for proving RCU usage. I got the following dmesg when PROVE_RCU=y because we used incorrect API. This patch coverts rcu_deference() to srcu_dereference() or family API. =================================================== [ INFO: suspicious rcu_dereference_check() usage. ] --------------------------------------------------- arch/x86/kvm/mmu.c:3020 invoked rcu_dereference_check() without protection! other info that might help us debug this: rcu_scheduler_active = 1, debug_locks = 0 2 locks held by qemu-system-x86/8550: #0: (&kvm->slots_lock){+.+.+.}, at: [<ffffffffa011a6ac>] kvm_set_memory_region+0x29/0x50 [kvm] #1: (&(&kvm->mmu_lock)->rlock){+.+...}, at: [<ffffffffa012262d>] kvm_arch_commit_memory_region+0xa6/0xe2 [kvm] stack backtrace: Pid: 8550, comm: qemu-system-x86 Not tainted 2.6.34-rc4-tip-01028-g939eab1 #27 Call Trace: [<ffffffff8106c59e>] lockdep_rcu_dereference+0xaa/0xb3 [<ffffffffa012f6c1>] kvm_mmu_calculate_mmu_pages+0x44/0x7d [kvm] [<ffffffffa012263e>] kvm_arch_commit_memory_region+0xb7/0xe2 [kvm] [<ffffffffa011a5d7>] __kvm_set_memory_region+0x636/0x6e2 [kvm] [<ffffffffa011a6ba>] kvm_set_memory_region+0x37/0x50 [kvm] [<ffffffffa015e956>] vmx_set_tss_addr+0x46/0x5a [kvm_intel] [<ffffffffa0126592>] kvm_arch_vm_ioctl+0x17a/0xcf8 [kvm] [<ffffffff810a8692>] ? unlock_page+0x27/0x2c [<ffffffff810bf879>] ? __do_fault+0x3a9/0x3e1 [<ffffffffa011b12f>] kvm_vm_ioctl+0x364/0x38d [kvm] [<ffffffff81060cfa>] ? up_read+0x23/0x3d [<ffffffff810f3587>] vfs_ioctl+0x32/0xa6 [<ffffffff810f3b19>] do_vfs_ioctl+0x495/0x4db [<ffffffff810e6b2f>] ? fget_light+0xc2/0x241 [<ffffffff810e416c>] ? do_sys_open+0x104/0x116 [<ffffffff81382d6d>] ? retint_swapgs+0xe/0x13 [<ffffffff810f3ba6>] sys_ioctl+0x47/0x6a [<ffffffff810021db>] system_call_fastpath+0x16/0x1b Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-03-01KVM: switch vcpu context to use SRCUMarcelo Tosatti
2009-10-04KVM: s390: fix memsize >= 4GChristian Borntraeger
commit 628eb9b8a8f3 KVM: s390: streamline memslot handling introduced kvm_s390_vcpu_get_memsize. This broke guests >=4G, since this function returned an int. This patch changes the return value to a long. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-09-10KVM: s390: streamline memslot handlingChristian Ehrhardt
This patch relocates the variables kvm-s390 uses to track guest mem addr/size. As discussed dropping the variables at struct kvm_arch level allows to use the common vcpu->request based mechanism to reload guest memory if e.g. changes via set_memory_region. The kick mechanism introduced in this series is used to ensure running vcpus leave guest state to catch the update. Signed-off-by: Christian Ehrhardt <ehrhardt@linux.vnet.ibm.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-09-10KVM: s390: infrastructure to kick vcpus out of guest stateChristian Ehrhardt
To ensure vcpu's come out of guest context in certain cases this patch adds a s390 specific way to kick them out of guest context. Currently it kicks them out to rerun the vcpu_run path in the s390 code, but the mechanism itself is expandable and with a new flag we could also add e.g. kicks to userspace etc. Signed-off-by: Christian Ehrhardt <ehrhardt@linux.vnet.ibm.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-06-10KVM: s390: use hrtimer for clock wakeup from idle - v2Christian Borntraeger
This patch reworks the s390 clock comparator wakeup to hrtimer. The clock comparator is a per-cpu value that is compared against the TOD clock. If ckc <= TOD an external interrupt 1004 is triggered. Since the clock comparator and the TOD clock have a much higher resolution than jiffies we should use hrtimers to trigger the wakeup. This speeds up guest nanosleep for small values. Since hrtimers callbacks run in hard-irq context, I added a tasklet to do the actual work with enabled interrupts. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Christian Ehrhardt <ehrhardt@de.ibm.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-03-24KVM: s390: Fix problem state check for b2 interceptsChristian Borntraeger
The kernel handles some priviledged instruction exits. While I was unable to trigger such an exit from guest userspace, the code should check for supervisor state before emulating a priviledged instruction. I also renamed kvm_s390_handle_priv to kvm_s390_handle_b2. After all there are non priviledged b2 instructions like stck (store clock). Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-04-27KVM: s390: intercepts for diagnose instructionsChristian Borntraeger
This patch introduces interpretation of some diagnose instruction intercepts. Diagnose is our classic architected way of doing a hypercall. This patch features the following diagnose codes: - vm storage size, that tells the guest about its memory layout - time slice end, which is used by the guest to indicate that it waits for a lock and thus cannot use up its time slice in a useful way - ipl functions, which a guest can use to reset and reboot itself In order to implement ipl functions, we also introduce an exit reason that causes userspace to perform various resets on the virtual machine. All resets are described in the principles of operation book, except KVM_S390_RESET_IPL which causes a reboot of the machine. Acked-by: Martin Schwidefsky <martin.schwidefsky@de.ibm.com> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-27KVM: s390: interprocessor communication via sigpChristian Borntraeger
This patch introduces in-kernel handling of _some_ sigp interprocessor signals (similar to ipi). kvm_s390_handle_sigp() decodes the sigp instruction and calls individual handlers depending on the operation requested: - sigp sense tries to retrieve information such as existence or running state of the remote cpu - sigp emergency sends an external interrupt to the remove cpu - sigp stop stops a remove cpu - sigp stop store status stops a remote cpu, and stores its entire internal state to the cpus lowcore - sigp set arch sets the architecture mode of the remote cpu. setting to ESAME (s390x 64bit) is accepted, setting to ESA/S390 (s390, 31 or 24 bit) is denied, all others are passed to userland - sigp set prefix sets the prefix register of a remote cpu For implementation of this, the stop intercept indication starts to get reused on purpose: a set of action bits defines what to do once a cpu gets stopped: ACTION_STOP_ON_STOP really stops the cpu when a stop intercept is recognized ACTION_STORE_ON_STOP stores the cpu status to lowcore when a stop intercept is recognized Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-27KVM: s390: intercepts for privileged instructionsChristian Borntraeger
This patch introduces in-kernel handling of some intercepts for privileged instructions: handle_set_prefix() sets the prefix register of the local cpu handle_store_prefix() stores the content of the prefix register to memory handle_store_cpu_address() stores the cpu number of the current cpu to memory handle_skey() just decrements the instruction address and retries handle_stsch() delivers condition code 3 "operation not supported" handle_chsc() same here handle_stfl() stores the facility list which contains the capabilities of the cpu handle_stidp() stores cpu type/model/revision and such handle_stsi() stores information about the system topology Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-27KVM: s390: interrupt subsystem, cpu timer, waitpswCarsten Otte
This patch contains the s390 interrupt subsystem (similar to in kernel apic) including timer interrupts (similar to in-kernel-pit) and enabled wait (similar to in kernel hlt). In order to achieve that, this patch also introduces intercept handling for instruction intercepts, and it implements load control instructions. This patch introduces an ioctl KVM_S390_INTERRUPT which is valid for both the vm file descriptors and the vcpu file descriptors. In case this ioctl is issued against a vm file descriptor, the interrupt is considered floating. Floating interrupts may be delivered to any virtual cpu in the configuration. The following interrupts are supported: SIGP STOP - interprocessor signal that stops a remote cpu SIGP SET PREFIX - interprocessor signal that sets the prefix register of a (stopped) remote cpu INT EMERGENCY - interprocessor interrupt, usually used to signal need_reshed and for smp_call_function() in the guest. PROGRAM INT - exception during program execution such as page fault, illegal instruction and friends RESTART - interprocessor signal that starts a stopped cpu INT VIRTIO - floating interrupt for virtio signalisation INT SERVICE - floating interrupt for signalisations from the system service processor struct kvm_s390_interrupt, which is submitted as ioctl parameter when injecting an interrupt, also carrys parameter data for interrupts along with the interrupt type. Interrupts on s390 usually have a state that represents the current operation, or identifies which device has caused the interruption on s390. kvm_s390_handle_wait() does handle waitpsw in two flavors: in case of a disabled wait (that is, disabled for interrupts), we exit to userspace. In case of an enabled wait we set up a timer that equals the cpu clock comparator value and sleep on a wait queue. [christian: change virtio interrupt to 0x2603] Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-27KVM: s390: sie intercept handlingChristian Borntraeger
This path introduces handling of sie intercepts in three flavors: Intercepts are either handled completely in-kernel by kvm_handle_sie_intercept(), or passed to userspace with corresponding data in struct kvm_run in case kvm_handle_sie_intercept() returns -ENOTSUPP. In case of partial execution in kernel with the need of userspace support, kvm_handle_sie_intercept() may choose to set up struct kvm_run and return -EREMOTE. The trivial intercept reasons are handled in this patch: handle_noop() just does nothing for intercepts that don't require our support at all handle_stop() is called when a cpu enters stopped state, and it drops out to userland after updating our vcpu state handle_validity() faults in the cpu lowcore if needed, or passes the request to userland Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-27KVM: s390: arch backend for the kvm kernel moduleHeiko Carstens
This patch contains the port of Qumranet's kvm kernel module to IBM zSeries (aka s390x, mainframe) architecture. It uses the mainframe's virtualization instruction SIE to run virtual machines with up to 64 virtual CPUs each. This port is only usable on 64bit host kernels, and can only run 64bit guest kernels. However, running 31bit applications in guest userspace is possible. The following source files are introduced by this patch arch/s390/kvm/kvm-s390.c similar to arch/x86/kvm/x86.c, this implements all arch callbacks for kvm. __vcpu_run calls back into sie64a to enter the guest machine context arch/s390/kvm/sie64a.S assembler function sie64a, which enters guest context via SIE, and switches world before and after that include/asm-s390/kvm_host.h contains all vital data structures needed to run virtual machines on the mainframe include/asm-s390/kvm.h defines kvm_regs and friends for user access to guest register content arch/s390/kvm/gaccess.h functions similar to uaccess to access guest memory arch/s390/kvm/kvm-s390.h header file for kvm-s390 internals, extended by later patches Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
