commit d911e03d097bdc01363df5d81c43f69432eb785c upstream.
Since ed4f209 "s390/time: fix sched_clock() overflow" a new helper function
is used to avoid overflows when converting TOD format values to nanosecond
values.
The kvm interrupt code formerly however only worked by accident because of
an overflow. It tried to program a timer that would expire in more than ~29
years. Because of the old TOD-to-nanoseconds overflow bug the real expiry
value however was much smaller, but now it isn't anymore.
This however triggers yet another bug in the function that programs the clock
comparator s390_next_ktime(): if the absolute "expires" value is after 2042
this will result in an overflow and the programmed value is lower than the
current TOD value which immediatly triggers a clock comparator (= timer)
interrupt.
Since the timer isn't expired it will be programmed immediately again and so
on... the result is a dead system.
To fix this simply program the maximum possible value if an overflow is
detected.
Reported-by: Christian Borntraeger <borntraeger@de.ibm.com>
Tested-by: Christian Borntraeger <borntraeger@de.ibm.com>
commit ed4f20943cd4c7b55105c04daedf8d63ab6d499c upstream.
Converting a 64 Bit TOD format value to nanoseconds means that the value
must be divided by 4.096. In order to achieve that we multiply with 125
and divide by 512.
When used within sched_clock() this triggers an overflow after appr.
417 days. Resulting in a sched_clock() return value that is much smaller
than previously and therefore may cause all sort of weird things in
subsystems that rely on a monotonic sched_clock() behaviour.
To fix this implement a tod_to_ns() helper function which converts TOD
values without overflow and call this function from both places that
open coded the conversion: sched_clock() and kvm_s390_handle_wait().
Reviewed-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
commit fa968ee215c0ca91e4a9c3a69ac2405aae6e5d2f upstream.
If user space is running in primary mode it can switch to secondary
or access register mode, this is used e.g. in the clock_gettime code
of the vdso. If a signal is delivered to the user space process while
it has been running in access register mode the signal handler is
executed in access register mode as well which will result in a crash
most of the time.
Set the address space control bits in the PSW to the default for the
execution of the signal handler and make sure that the previous
address space control is restored on signal return. Take care
that user space can not switch to the kernel address space by
modifying the registers in the signal frame.
[bwh: Backported to 3.2:
- Adjust filename
- The RI bit is not included in PSW_MASK_USER]
commit c985cb37f1b39c2c8035af741a2a0b79f1fbaca7 upstream.
Because of a change in the s390 arch backend of binutils (commit 23ecd77
"Pick the default arch depending on the target size" in binutils repo)
31 bit builds will fail since the linker would now try to create 64 bit
binary output.
Fix this by setting OUTPUT_ARCH to s390:31-bit instead of s390.
Thanks to Andreas Krebbel for figuring out the issue.
Fixes this build error:
LD init/built-in.o
s390x-4.7.2-ld: s390:31-bit architecture of input file
`arch/s390/kernel/head.o' is incompatible with s390:64-bit output
Cc: Andreas Krebbel <Andreas.Krebbel@de.ibm.com>
[bwh: Backported to 3.2: adjust context]
commit e85871218513c54f7dfdb6009043cb638f2fecbe upstream.
The native 31 bit and the compat behaviour for the mmap system calls differ:
In native 31 bit mode the passed in address for the mmap system call will be
unmodified passed to sys_mmap_pgoff().
In compat mode however the passed in address will be modified with
compat_ptr() which masks out the most significant bit.
The result is that in native 31 bit mode each mmap request (with MAP_FIXED)
will fail where the most significat bit is set, while in compat mode it
may succeed.
This odd behaviour was introduced with d3815898 "[S390] mmap: add missing
compat_ptr conversion to both mmap compat syscalls".
To restore a consistent behaviour accross native and compat mode this
patch functionally reverts the above mentioned commit.
commit 82aabdb6f1eb61e0034ec23901480f5dd23db7c4 upstream.
The compat wrappers incorrectly called the non compat versions of
the system process_vm system calls.
commit 0008204ffe85d23382d6fd0f971f3f0fbe70bae2 upstream.
The s390 idle accounting code uses a sequence counter which gets used
when the per cpu idle statistics get updated and read.
One assumption on read access is that only when the sequence counter is
even and did not change while reading all values the result is valid.
On cpu hotplug however the per cpu data structure gets initialized via
a cpu hotplug notifier on CPU_ONLINE.
CPU_ONLINE however is too late, since the onlined cpu is already running
and might access the per cpu data. Worst case is that the data structure
gets initialized while an idle thread is updating its idle statistics.
This will result in an uneven sequence counter after an update.
As a result user space tools like top, which access /proc/stat in order
to get idle stats, will busy loop waiting for the sequence counter to
become even again, which will never happen until the queried cpu will
update its idle statistics again. And even then the sequence counter
will only have an even value for a couple of cpu cycles.
Fix this by moving the initialization of the per cpu idle statistics
to cpu_init(). I prefer that solution in favor of changing the
notifier to CPU_UP_PREPARE, which would be a different solution to
the problem.
commit 048cd4e51d24ebf7f3552226d03c769d6ad91658 upstream.
The new is_compat_task() define for the !COMPAT case in
include/linux/compat.h conflicts with a similar define in
arch/s390/include/asm/compat.h.
This is the minimal patch which fixes the build issues.
Cc: Jonathan Nieder <jrnieder@gmail.com>
commit cf1eb40f8f5ea12c9e569e7282161fc7f194fd62 upstream.
The conversion of the ktime to a value suitable for the clock comparator
does not take changes to wall_to_monotonic into account. In fact the
conversion just needs the boot clock (sched_clock_base_cc) and the
total_sleep_time.
This is applicable to 3.2+ kernels.
git commit 20b40a794baf3b4b "signal race with restarting system calls"
added code to the poke_user/poke_user_compat to reset the system call
restart information in the thread-info if the PSW address is changed.
The purpose of that change has been to workaround old gdbs that do
not know about the REGSET_SYSTEM_CALL. It turned out that this is not
a good idea, it makes the behaviour of the debuggee dependent on the
order of specific ptrace call, e.g. the REGSET_SYSTEM_CALL register
set needs to be written last. And the workaround does not really fix
old gdbs, inferior calls on interrupted restarting system calls do not
work either way.
The last breaking event address is a read-only value, the regset misses the
.set function. If a PTRACE_SETREGSET is done for NT_S390_LAST_BREAK we
get an oops due to a branch to zero:
Kernel BUG at 0000000000000002 verbose debug info unavailable
illegal operation: 0001 #1 SMP
Call Trace:
(<0000000000158294> ptrace_regset+0x184/0x188)
<00000000001595b6> ptrace_request+0x37a/0x4fc
<0000000000109a78> arch_ptrace+0x108/0x1fc
<00000000001590d6> SyS_ptrace+0xaa/0x12c
<00000000005c7a42> sysc_noemu+0x16/0x1c
<000003fffd5ec10c> 0x3fffd5ec10c
Last Breaking-Event-Address:
<0000000000158242> ptrace_regset+0x132/0x188
Add a nop .set function to prevent the branch to zero.
Cc: stable@kernel.org
The TIF_SYSCALL bit needs to be cleared if the debugger changes the state
of the ptraced process in regard to the presence of a system call.
Otherwise the system call will be restarted although the debugger set up
an inferior call.
In order to have the same behavior for kdump based stand-alone dump
as for the kexec method, the is_kdump_kernel() check (only true for
the kexec method) has to be replaced by the OLDMEM_BASE check (true
for both methods).
Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com>
Make sure that all cpus in a book on a z10 appear as book siblings
and not as core siblings. This fixes some performance regressions that
appeared after the book scheduling domain got introduced.
In ESA mode STCKF is not defined even if the facility bit is enabled.
To prevent an illegal operation we must also check if we run a 64 bit kernel.
To make the check perform well add the STCKF bit to the machine flags.
Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com>
When the kernel is started in kdump mode, zfcpdump should not be
initialized because both dump methods can't be used at the same time.
'readelf -n' on the s390 vmlinux file generates lots of warnings about
corrupt notes. The reason is that the 'NOTE' program header has incorrect
file and memory sizes. The problem is that the section following the
NOTES section do not switch to a different phdr and they get added to
the NOTE program section. Add a dummy entry to the linker script that
switches to the data phdr before the start of the RODATA section.
git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen
* 'upstream/jump-label-noearly' of git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen:
jump-label: initialize jump-label subsystem much earlier
x86/jump_label: add arch_jump_label_transform_static()
s390/jump-label: add arch_jump_label_transform_static()
jump_label: add arch_jump_label_transform_static() to optimise non-live code updates
sparc/jump_label: drop arch_jump_label_text_poke_early()
x86/jump_label: drop arch_jump_label_text_poke_early()
jump_label: if a key has already been initialized, don't nop it out
stop_machine: make stop_machine safe and efficient to call early
jump_label: use proper atomic_t initializer
- arch/x86/kernel/jump_label.c
Added __init_or_module to arch_jump_label_text_poke_early vs
removal of that function entirely
- kernel/stop_machine.c
same patch ("stop_machine: make stop_machine safe and efficient
to call early") merged twice, with whitespace fix in one version
Currently it can happen that the pre-allocated ELF header contains a wrong
memory map which would result in errors when copying /proc/vmcore.
In order to still get a valid vmcore, we (temporarily) disable the error
checking in copy_oldmem_page(). This will then produce zero pages for those
memory regions.
We use both the external call and emergency call IPIs to signal remote
cpus. Therefore it makes sense to account them differently withing
/proc/irqstats so we actually know what happened.
Use __force to quiet sparse warnings about user address space.
Fix three sparse warnings in math-emu / sysinfo:
arch/s390/kernel/sysinfo.c:448:17: error: return expression in void function
arch/s390/kernel/sysinfo.c:445:25: warning: shift too big (32) for type unsigned int
Add prototypes and includes for functions used in different modules.
Make functions and data static to avoid sparse warnings.
Remove unnecessary code to avoid false positives from sparse, e.g.
arch/s390/kernel/compat_signal.c:221:61: warning: invalid access past the end of 'set32' (8 8)
On sie_fault we need to switch back to user ASCE. Otherwise we get
interresting effects when exiting to "userspace" while the guest
space is still active.
Signed-off-by: Carsten Otte <cotte@de.ibm.com>
Use a sigp sense running to decide which signal processor order to use
for an ipi. If the target cpu is running use external call, if the target
cpu is not running use emergency signal.
Add support for CHSC I/O interrupt statistics in /proc/interrupts.
Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com>
The user space program can change its addressing mode between the
24-bit, 31-bit and the 64-bit mode if the kernel is 64 bit. Currently
the kernel always forces the standard amode on signal delivery and
signal return and on ptrace: 64-bit for a 64-bit process, 31-bit for
a compat process and 31-bit kernels. Change the signal and ptrace code
to allow the full range of addressing modes. Signal handlers are
run in the standard addressing mode for the process.
One caveat is that even an 31-bit compat process can switch to the
64-bit mode. The next signal will switch back into the 31-bit mode
and there is no room in the 31-bit compat signal frame to store the
information that the program came from the 64-bit mode.
Split out addressing mode bits from PSW_BASE_BITS, rename PSW_BASE_BITS
to PSW_MASK_BASE, get rid of psw_user32_bits, remove unused function
enabled_wait(), introduce PSW_MASK_USER, and drop PSW_MASK_MERGE macros.
Change psw_kernel_bits / psw_user_bits to contain only the bits that
are always set in the respective mode.
Add an explicit TIF_SYSCALL bit that indicates if a task is inside
a system call. The svc_code in the pt_regs structure is now only
valid if TIF_SYSCALL is set. With this definition TIF_RESTART_SVC
can be replaced with TIF_SYSCALL. Overall do_signal is a bit more
readable and it saves a few lines of code.
An instruction with an address right below the adress limit for the
current addressing mode will wrap. The instruction restart logic in
the protection fault handler and the signal code need to follow the
wrapping rules to find the correct instruction address.
For a ERESTARTNOHAND/ERESTARTSYS/ERESTARTNOINTR restarting system call
do_signal will prepare the restart of the system call with a rewind of
the PSW before calling get_signal_to_deliver (where the debugger might
take control). For A ERESTART_RESTARTBLOCK restarting system call
do_signal will set -EINTR as return code.
There are two issues with this approach:
1) strace never sees ERESTARTNOHAND, ERESTARTSYS, ERESTARTNOINTR or
ERESTART_RESTARTBLOCK as the rewinding already took place or the
return code has been changed to -EINTR
2) if get_signal_to_deliver does not return with a signal to deliver
the restart via the repeat of the svc instruction is left in place.
This opens a race if another signal is made pending before the
system call instruction can be reexecuted. The original system call
will be restarted even if the second signal would have ended the
system call with -EINTR.
These two issues can be solved by dropping the early rewind of the
system call before get_signal_to_deliver has been called and by using
the TIF_RESTART_SVC magic to do the restart if no signal has to be
delivered. The only situation where the system call restart via the
repeat of the svc instruction is appropriate is when a SA_RESTART
signal is delivered to user space.
Unfortunately this breaks inferior calls by the debugger again. The
system call number and the length of the system call instruction is
lost over the inferior call and user space will see ERESTARTNOHAND/
ERESTARTSYS/ERESTARTNOINTR/ERESTART_RESTARTBLOCK. To correct this a
new ptrace interface is added to save/restore the system call number
and system call instruction length.
Remove the save_area_64 field from the 0xe00 - 0xf00 area in the lowcore.
Use a free slot in the save_area array instead.
This patch implements the crash_map_pages() function for s390.
KEXEC_CRASH_MEM_ALIGN is set to HPAGE_SIZE, in order to support
kernel mappings that use large pages. We also use HPAGE_SIZE alignment
for CONFIG_HUGETLB_PAGE=n in order to have the same 1 MiB alignment on
all s390 systems.
This patch defines for s390 an ABI defined pointer to the vmcoreinfo note at
a well known address. With this patch tools are able to find this information
in dumps created by stand-alone or hypervisor dump tools.
This patch provides the architecture specific part of the s390 kdump
support.
PSW restart can be triggered on offline CPUs. If this happens, currently
the PSW restart code fails, because functions like smp_processor_id()
do not work on offline CPUs. This patch fixes this as follows:
If PSW restart is triggered on an offline CPU, the PSW restart (sigp restart)
is done a second time on another CPU that is online and the old CPU is
stopped afterwards.
Use the ENTRY macro for the system call wrapper sys_setns_wrapper
similarly to the other wrappers.
git commit 5e9a2692 "[S390] ptrace cleanup" introduced a regression
for the case when both a user PER set (e.g. a storage alteration trace) and
PTRACE_SINGLESTEP are active. The new code will overrule the user PER set
with a instruction-fetch PER set over the whole address space for ptrace
single stepping. The inferior process will be stopped after each instruction
with an instruction fetch event. Any other events that may have occurred
concurrently are not reported (e.g. storage alteration event) because the
control bits for them are not set. The solution is to merge the PER control
bits of the user PER set with the PER_EVENT_IFETCH control bit for
PTRACE_SINGLESTEP.
Fix this warning:
WARNING: vmlinux.o(.text+0x199b6): Section mismatch in reference from
the function alloc_masks() to the function .init.text:__alloc_bootmem()
The .start function and indirectly the .next function of the show_cpuinfo
sequential operation uses NR_CPUS as limit instead of nr_cpu_ids.
This can cause warnings like this:
WARNING: at /usr/src/linux/include/linux/cpumask.h:107
Process lscpu (pid: 575, task: 000000007deb4338, ksp: 000000007794f588)
Krnl PSW : 0704000180000000 0000000000106db4 (show_cpuinfo+0x108/0x234)
R:0 T:1 IO:1 EX:1 Key:0 M:1 W:0 P:0 AS:0 CC:0 PM:0 EA:3
Krnl GPRS: 0000000000000003 0000000000791988 000000000071b478 0000000000000004
0000000000000001 0000000000000000 000000007d139500 0000000000000400
0000000000000000 000000000070e24c 000000007d48d600 0000000000000005
000000007d48d600 00000000004dfa10 0000000000106cf8 000000007794fcc0
Krnl Code: 0000000000106da8: 95001000 cli 0(%r1),0
0000000000106dac: a774ffac brc 7,106d04
0000000000106db0: a7f40001 brc 15,106db2
>0000000000106db4: 92011000 mvi 0(%r1),1
0000000000106db8: a7f4ffa6 brc 15,106d04
0000000000106dbc: c0e5000065b4 brasl %r14,113924
0000000000106dc2: c09000303a45 larl %r9,70e24c
0000000000106dc8: c020001eefd4 larl %r2,4e4d70
Replacing NR_CPUS with nr_cpu_ids fixes it.
Current IRQ statistics support does not show detail counts for I/O
interrupts which are processed internally only. The result is a
summation count which is way off such as this one:
CPU0 CPU1 CPU2
I/O: 1331 710 442
QAI: 15 16 16 [I/O] QDIO Adapter Interrupt
QDI: 1 0 0 [I/O] QDIO Interrupt
DAS: 706 645 381 [I/O] DASD
C15: 26 10 0 [I/O] 3215
C70: 0 0 0 [I/O] 3270
TAP: 0 0 0 [I/O] Tape
VMR: 0 0 0 [I/O] Unit Record Devices
LCS: 0 0 0 [I/O] LCS
CLW: 0 0 0 [I/O] CLAW
CTC: 0 0 0 [I/O] CTC
APB: 0 0 0 [I/O] AP Bus
Fix this by moving I/O interrupt accounting into the common I/O layer.
Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com>
* 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (23 commits)
time, s390: Get rid of compile warning
dw_apb_timer: constify clocksource name
time: Cleanup old CONFIG_GENERIC_TIME references that snuck in
time: Change jiffies_to_clock_t() argument type to unsigned long
alarmtimers: Fix error handling
clocksource: Make watchdog reset lockless
posix-cpu-timers: Cure SMP accounting oddities
s390: Use direct ktime path for s390 clockevent device
clockevents: Add direct ktime programming function
clockevents: Make minimum delay adjustments configurable
nohz: Remove "Switched to NOHz mode" debugging messages
proc: Consider NO_HZ when printing idle and iowait times
nohz: Make idle/iowait counter update conditional
nohz: Fix update_ts_time_stat idle accounting
cputime: Clean up cputime_to_usecs and usecs_to_cputime macros
alarmtimers: Rework RTC device selection using class interface
alarmtimers: Add try_to_cancel functionality
alarmtimers: Add more refined alarm state tracking
alarmtimers: Remove period from alarm structure
alarmtimers: Remove interval cap limit hack
This allows jump-label entries to be cheaply updated on code which is
not yet live.
Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
Acked-by: Jason Baron <jbaron@redhat.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Cc: Jan Glauber <jang@linux.vnet.ibm.com>
For s390 there is one additional byte associated with each page,
the storage key. This byte contains the referenced and changed
bits and needs to be included into the hibernation image.
If the storage keys are not restored to their previous state all
original pages would appear to be dirty. This can cause
inconsistencies e.g. with read-only filesystems.
"s390: Use direct ktime path for s390 clockevent device" in linux-next
introduces this compile warning:
arch/s390/kernel/time.c: In function 's390_next_ktime':
arch/s390/kernel/time.c:118:2: warning:
comparison of distinct pointer types lacks a cast [enabled by default]
Just use a u64 instead of an s64 variable. This is not a problem since it
will always contain a positive value.
Link: http://lkml.kernel.org/r/1316675957-5538-1-git-send-email-heiko.carstens@de.ibm.com
598841ca9919d008b520114d8a4378c4ce4e40a1 ([S390] use gmap address
spaces for kvm guest images) changed kvm to use a separate address
space for kvm guests. This address space was switched in __vcpu_run
In some cases (preemption, page fault) there is the possibility that
this address space switch is lost.
The typical symptom was a huge amount of validity intercepts or
random guest addressing exceptions.
Fix this by doing the switch in sie_loop and sie_exit and saving the
address space in the gmap structure itself. Also use the preempt
notifier.
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
Acked-by: Avi Kivity <avi@redhat.com>
The clock comparator on s390 uses the same format as the TOD clock.
If the value in the clock comparator is smaller than the current TOD
value an interrupt is pending. Use the CLOCK_EVT_FEAT_KTIME feature
to get the unmodified ktime of the next clockevent expiration and
use it to program the clock comparator without querying the TOD clock.
Cc: john stultz <johnstul@us.ibm.com>
Link: http://lkml.kernel.org/r/20110823133143.153017933@de.ibm.com
