path: root/arch/s390/kernel/time.c
2011-01-05[S390] irq: have detailed statistics for interrupt typesHeiko Carstens
Up to now /proc/interrupts only has statistics for external and i/o interrupts but doesn't split up them any further. This patch adds a line for every single interrupt source so that it is possible to easier tell what the machine is/was doing. Part of the output now looks like this; CPU0 CPU2 CPU4 EXT: 3898 4232 2305 I/O: 782 315 245 CLK: 1029 1964 727 [EXT] Clock Comparator IPI: 2868 2267 1577 [EXT] Signal Processor TMR: 0 0 0 [EXT] CPU Timer TAL: 0 0 0 [EXT] Timing Alert PFL: 0 0 0 [EXT] Pseudo Page Fault [...] NMI: 0 1 1 [NMI] Machine Checks Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-01-05[S390] add kprobes annotationsMartin Schwidefsky
Add kprobes annotations to get the massive 'probe kernel.function("*") {}' stress test working. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-10-25[S390] cleanup lowcore access from external interruptsMartin Schwidefsky
Read external interrupts parameters from the lowcore in the first level interrupt handler in entry[64].S. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-08-06Merge branch 'timers-timekeeping-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-timekeeping-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: um: Fix read_persistent_clock fallout kgdb: Do not access xtime directly powerpc: Clean up obsolete code relating to decrementer and timebase powerpc: Rework VDSO gettimeofday to prevent time going backwards clocksource: Add __clocksource_updatefreq_hz/khz methods x86: Convert common clocksources to use clocksource_register_hz/khz timekeeping: Make xtime and wall_to_monotonic static hrtimer: Cleanup direct access to wall_to_monotonic um: Convert to use read_persistent_clock timkeeping: Fix update_vsyscall to provide wall_to_monotonic offset powerpc: Cleanup xtime usage powerpc: Simplify update_vsyscall time: Kill off CONFIG_GENERIC_TIME time: Implement timespec_add x86: Fix vtime/file timestamp inconsistencies Trivial conflicts in Documentation/feature-removal-schedule.txt Much less trivial conflicts in arch/powerpc/kernel/time.c resolved as per Thomas' earlier merge commit 47916be4e28c ("Merge branch 'powerpc.cherry-picks' into timers/clocksource")
2010-07-27[S390] etr: fix clock synchronization raceMartin Schwidefsky
The etr events switch-to-local and sync-check disable the synchronous clock and schedule a work queue that tries to get the clock back into sync. If another switch-to-local or sync-check event occurs while the work queue function etr_work_fn still runs the eacr.es bit and the clock_sync_word can become inconsistent because check_sync_clock only uses the clock_sync_word to determine if the clock is in sync or not. The second pass of the etr_work_fn will reset the eacr.es bit but will leave the clock_sync_word intact. Fix this race by moving the reset of the eacr.es bit into the switch-to-local and sync-check functions and by checking the eacr.es bit as well to decide if the clock needs to be synced. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-07-27timkeeping: Fix update_vsyscall to provide wall_to_monotonic offsetJohn Stultz
update_vsyscall() did not provide the wall_to_monotoinc offset, so arch specific implementations tend to reference wall_to_monotonic directly. This limits future cleanups in the timekeeping core, so this patch fixes the update_vsyscall interface to provide wall_to_monotonic, allowing wall_to_monotonic to be made static as planned in Documentation/feature-removal-schedule.txt Signed-off-by: John Stultz <johnstul@us.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Anton Blanchard <anton@samba.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Tony Luck <tony.luck@intel.com> LKML-Reference: <1279068988-21864-7-git-send-email-johnstul@us.ibm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-05-08Merge branch 'cpu_stop' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/tj/misc into sched/core
2010-05-06stop_machine: reimplement using cpu_stopTejun Heo
Reimplement stop_machine using cpu_stop. As cpu stoppers are guaranteed to be available for all online cpus, stop_machine_create/destroy() are no longer necessary and removed. With resource management and synchronization handled by cpu_stop, the new implementation is much simpler. Asking the cpu_stop to execute the stop_cpu() state machine on all online cpus with cpu hotplug disabled is enough. stop_machine itself doesn't need to manage any global resources anymore, so all per-instance information is rolled into struct stop_machine_data and the mutex and all static data variables are removed. The previous implementation created and destroyed RT workqueues as necessary which made stop_machine() calls highly expensive on very large machines. According to Dimitri Sivanich, preventing the dynamic creation/destruction makes booting faster more than twice on very large machines. cpu_stop resources are preallocated for all online cpus and should have the same effect. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Dimitri Sivanich <sivanich@sgi.com>
2010-04-22[S390] vdso: use ntp adjusted clock multiplierHendrik Brueckner
Commit "timekeeping: Fix clock_gettime vsyscall time warp" (0696b711e) introduced the new parameter "mult" to update_vsyscall(). This parameter contains the internal NTP adjusted clock multiplier. The s390x vdso did not use this adjusted multiplier. Instead, it used the constant clock multiplier for gettimeofday() and clock_gettime() variants. This may result in observable time warps as explained in commit 0696b711e. Make the NTP adjusted clock multiplier available to the s390x vdso implementation and use it for time calculations. Cc: <stable@kernel.org> Signed-off-by: Hendrik Brueckner <brueckner@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (62 commits) msi-laptop: depends on RFKILL msi-laptop: Detect 3G device exists by standard ec command msi-laptop: Add resume method for set the SCM load again msi-laptop: Support some MSI 3G netbook that is need load SCM msi-laptop: Add threeg sysfs file for support query 3G state by standard 66/62 ec command msi-laptop: Support standard ec 66/62 command on MSI notebook and nebook Driver core: create lock/unlock functions for struct device sysfs: fix for thinko with sysfs_bin_attr_init() sysfs: Kill unused sysfs_sb variable. sysfs: Pass super_block to sysfs_get_inode driver core: Use sysfs_rename_link in device_rename sysfs: Implement sysfs_rename_link sysfs: Pack sysfs_dirent more tightly. sysfs: Serialize updates to the vfs inode sysfs: windfarm: init sysfs attributes sysfs: Use sysfs_attr_init and sysfs_bin_attr_init on module dynamic attributes sysfs: Document sysfs_attr_init and sysfs_bin_attr_init sysfs: Use sysfs_attr_init and sysfs_bin_attr_init on dynamic attributes sysfs: Use one lockdep class per sysfs attribute. sysfs: Only take active references on attributes. ...
2010-03-08[S390] Cleanup xtime usageJohn Stultz
This replaces direct xtime usage in the s390 arch with timekeeping accessors, so we can further clean up the timekeeping core. Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-03-07sysdev: Pass attribute in sysdev_class attributes show/storeAndi Kleen
Passing the attribute to the low level IO functions allows all kinds of cleanups, by sharing low level IO code without requiring an own function for every piece of data. Also drivers can extend the attributes with own data fields and use that in the low level function. Similar to sysdev_attributes and normal attributes. This is a tree-wide sweep, converting everything in one go. No functional changes in this patch other than passing the new argument everywhere. Tested on x86, the non x86 parts are uncompiled. Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-02-26[S390] time: remove unused codeHeiko Carstens
2009-12-09Merge branch 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: (72 commits) [S390] 3215/3270 console: remove wrong comment [S390] dasd: remove BKL from extended error reporting code [S390] vmlogrdr: remove BKL [S390] vmur: remove BKL [S390] zcrypt: remove BKL [S390] 3270: remove BKL [S390] vmwatchdog: remove lock_kernel() from open() function [S390] monwriter: remove lock_kernel() from open() function [S390] monreader: remove lock_kernel() from open() function [S390] s390: remove unused nfsd #includes [S390] ftrace: build ftrace.o when CONFIG_FTRACE_SYSCALLS is set for s390 [S390] etr/stp: put correct per cpu variable [S390] tty3270: move keyboard compat ioctls [S390] sclp: improve servicability setting [S390] s390: use change recording override for kernel mapping [S390] MAINTAINERS: Add s390 drivers block [S390] use generic sockios.h header file [S390] use generic termbits.h header file [S390] smp: remove unused typedef and defines [S390] cmm: free pages on hibernate. ...
2009-12-07[S390] etr/stp: put correct per cpu variableHeiko Carstens
Fix this compile error in linux-next: arch/s390/kernel/time.c: In function 'get_sync_clock': arch/s390/kernel/time.c:337: error: 'clock_sync_sync' undeclared (first use in this function) Gets exposed because the new per cpu code references the variable passed to put_cpu_var. This was not a real bug. Reported-by: Sachin Sant <sachinp@in.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-11-17timekeeping: Fix clock_gettime vsyscall time warpLin Ming
Since commit 0a544198 "timekeeping: Move NTP adjusted clock multiplier to struct timekeeper" the clock multiplier of vsyscall is updated with the unmodified clock multiplier of the clock source and not with the NTP adjusted multiplier of the timekeeper. This causes user space observerable time warps: new CLOCK-warp maximum: 120 nsecs, 00000025c337c537 -> 00000025c337c4bf Add a new argument "mult" to update_vsyscall() and hand in the timekeeping internal NTP adjusted multiplier. Signed-off-by: Lin Ming <ming.m.lin@intel.com> Cc: "Zhang Yanmin" <yanmin_zhang@linux.intel.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Tony Luck <tony.luck@intel.com> LKML-Reference: <1258436990.17765.83.camel@minggr.sh.intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-09-18Merge branch 'timers-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (34 commits) time: Prevent 32 bit overflow with set_normalized_timespec() clocksource: Delay clocksource down rating to late boot clocksource: clocksource_select must be called with mutex locked clocksource: Resolve cpu hotplug dead lock with TSC unstable, fix crash timers: Drop a function prototype clocksource: Resolve cpu hotplug dead lock with TSC unstable timer.c: Fix S/390 comments timekeeping: Fix invalid getboottime() value timekeeping: Fix up read_persistent_clock() breakage on sh timekeeping: Increase granularity of read_persistent_clock(), build fix time: Introduce CLOCK_REALTIME_COARSE x86: Do not unregister PIT clocksource on PIT oneshot setup/shutdown clocksource: Avoid clocksource watchdog circular locking dependency clocksource: Protect the watchdog rating changes with clocksource_mutex clocksource: Call clocksource_change_rating() outside of watchdog_lock timekeeping: Introduce read_boot_clock timekeeping: Increase granularity of read_persistent_clock() timekeeping: Update clocksource with stop_machine timekeeping: Add timekeeper read_clock helper functions timekeeping: Move NTP adjusted clock multiplier to struct timekeeper ... Fix trivial conflict due to MIPS lemote -> loongson renaming.
2009-09-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (209 commits) [SCSI] fix oops during scsi scanning [SCSI] libsrp: fix memory leak in srp_ring_free() [SCSI] libiscsi, bnx2i: make bound ep check common [SCSI] libiscsi: add completion function for drivers that do not need pdu processing [SCSI] scsi_dh_rdac: changes for rdac debug logging [SCSI] scsi_dh_rdac: changes to collect the rdac debug information during the initialization [SCSI] scsi_dh_rdac: move the init code from rdac_activate to rdac_bus_attach [SCSI] sg: fix oops in the error path in sg_build_indirect() [SCSI] mptsas : Bump version to 3.04.12 [SCSI] mptsas : FW event thread and scsi mid layer deadlock in SYNCHRONIZE CACHE command [SCSI] mptsas : Send DID_NO_CONNECT for pending IOs of removed device [SCSI] mptsas : PAE Kernel more than 4 GB kernel panic [SCSI] mptsas : NULL pointer on big endian systems causing Expander not to tear off [SCSI] mptsas : Sanity check for phyinfo is added [SCSI] scsi_dh_rdac: Add support for Sun StorageTek ST2500, ST2510 and ST2530 [SCSI] pmcraid: PMC-Sierra MaxRAID driver to support 6Gb/s SAS RAID controller [SCSI] qla2xxx: Update version number to 8.03.01-k6. [SCSI] qla2xxx: Properly delete rports attached to a vport. [SCSI] qla2xxx: Correct various NPIV issues. [SCSI] qla2xxx: Correct qla2x00_eh_wait_on_command() to wait correctly. ...
2009-09-11[S390] introduce get_clock_monotonicHeiko Carstens
Introduce get_clock_monotonic() function which can be used to get a (fast) timestamp. Resolution is the same as for get_clock(). The only difference is that the timestamps are monotonic and don't jump backward or forward. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-09-05[SCSI] zfcp: Remove duplicated code for debug timestampsChristof Schmitt
The timestamp calculation used for s390dbf output is the same in a private zfcp function and in debug.c. Replace both with a common inline function. Reviewed-by: Swen Schillig <swen@vnet.ibm.com> Signed-off-by: Christof Schmitt <christof.schmitt@de.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-08-15timekeeping: Introduce read_boot_clockMartin Schwidefsky
Add the new function read_boot_clock to get the exact time the system has been started. For architectures without support for exact boot time a new weak function is added that returns 0. Use the exact boot time to initialize wall_to_monotonic, or xtime if the read_boot_clock returned 0. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Acked-by: John Stultz <johnstul@us.ibm.com> Cc: Daniel Walker <dwalker@fifo99.com> LKML-Reference: <20090814134811.296703241@de.ibm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-08-15timekeeping: Increase granularity of read_persistent_clock()Martin Schwidefsky
The persistent clock of some architectures (e.g. s390) have a better granularity than seconds. To reduce the delta between the host clock and the guest clock in a virtualized system change the read_persistent_clock function to return a struct timespec. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Acked-by: John Stultz <johnstul@us.ibm.com> Cc: Daniel Walker <dwalker@fifo99.com> LKML-Reference: <20090814134811.013873340@de.ibm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-08-15timekeeping: Introduce struct timekeeperMartin Schwidefsky
Add struct timekeeper to keep the internal values timekeeping.c needs in regard to the currently selected clock source. This moves the timekeeping intervals, xtime_nsec and the ntp error value from struct clocksource to struct timekeeper. The raw_time is removed from the clocksource as well. It gets treated like xtime as a global variable. Eventually xtime raw_time should be moved to struct timekeeper. [ tglx: minor cleanup ] Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Acked-by: John Stultz <johnstul@us.ibm.com> Cc: Daniel Walker <dwalker@fifo99.com> LKML-Reference: <20090814134809.613209842@de.ibm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-08-15clocksource: Cleanup clocksource selectionMartin Schwidefsky
If a non high-resolution clocksource is first set as override clock and then registered it becomes active even if the system is in one-shot mode. Move the override check from sysfs_override_clocksource to the clocksource selection. That fixes the bug and simplifies the code. The check in clocksource_register for double registration of the same clocksource is removed without replacement. To find the initial clocksource a new weak function in jiffies.c is defined that returns the jiffies clocksource. The architecture code can then override the weak function with a more suitable clocksource, e.g. the TOD clock on s390. [ tglx: Folded in a fix from John Stultz ] Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Acked-by: John Stultz <johnstul@us.ibm.com> Cc: Daniel Walker <dwalker@fifo99.com> LKML-Reference: <20090814134808.388024160@de.ibm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-06-22[S390] time: convert from bootmem to slabHeiko Carstens
The slab allocator is earlier available so convert the bootmem allocations to slab/gfp allocations. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-06-12[S390] ftrace: add function graph tracer supportHeiko Carstens
Function graph tracer support for s390. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-06-12[S390] profile_tick called twiceMartin Schwidefsky
profile_tick is called twice for every clock comparator interrupt. The generic clock event code does it in tick_sched_timer and the s390 backend code in clock_comparator_work. That is one too many, remove the one in the arch backend code. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-04-21clocksource: pass clocksource to read() callbackMagnus Damm
Pass clocksource pointer to the read() callback for clocksources. This allows us to share the callback between multiple instances. [hugh@veritas.com: fix powerpc build of clocksource pass clocksource mods] [akpm@linux-foundation.org: cleanup] Signed-off-by: Magnus Damm <damm@igel.co.jp> Acked-by: John Stultz <johnstul@us.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-14[S390] boot cputime accountingMartin Schwidefsky
Start the cpu time accounting very early to catch the cpu time spent for the initial kernel setup. To make the output of /proc/uptime match the sum of all cpu accounting values of the boot cpu reset xtime and wall_to_monotonic to sane values based on the TOD clock. The values set by timekeeping_init are off by up to a second. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-04-14[S390] add read_persistent_clockMartin Schwidefsky
Add a read_persistent_clock function that does not just return 0. Since timekeeping_init calls the function before time_init has been called move reset_tod_clock to early.c to make sure that the TOD clock is running when read_persistent_clock is invoked. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-04-14[S390] stp synchronization retry timerMartin Schwidefsky
Add a timer that retries the clock synchronization via the server time protocol if there is a usable clock but the synchronization failed. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-03-26[S390] clock sync mode flagsMartin Schwidefsky
The clock sync mode flag CLOCK_SYNC_STP is not cleared when stp is set offline. In this case the get_sync_clock() function returns -EACCESS and the dasd driver will block all i/o until stp is enabled again. In addition get_sync_clock can return -EACCESS if the clock is not in sync instead of -EAGAIN. Rework the stp/etr online handling to fix these problems. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-01-23[S390] etr/stp: fix possible deadlockHeiko Carstens
Precreate stop_machine threads in case the machine supports ETR/STP. Otherwise we might deadlock if a time sync operation gets scheduled and the creation of stop_machine threads would cause disk I/O. This is just the minimal fix. The real fix would be to only precreate stop_machine threads if ETR/STP is actually used. But that would be a rather large and complicated patch. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2009-01-02Merge branch 'cpus4096-for-linus-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'cpus4096-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (66 commits) x86: export vector_used_by_percpu_irq x86: use logical apicid in x2apic_cluster's x2apic_cpu_mask_to_apicid_and() sched: nominate preferred wakeup cpu, fix x86: fix lguest used_vectors breakage, -v2 x86: fix warning in arch/x86/kernel/io_apic.c sched: fix warning in kernel/sched.c sched: move test_sd_parent() to an SMP section of sched.h sched: add SD_BALANCE_NEWIDLE at MC and CPU level for sched_mc>0 sched: activate active load balancing in new idle cpus sched: bias task wakeups to preferred semi-idle packages sched: nominate preferred wakeup cpu sched: favour lower logical cpu number for sched_mc balance sched: framework for sched_mc/smt_power_savings=N sched: convert BALANCE_FOR_xx_POWER to inline functions x86: use possible_cpus=NUM to extend the possible cpus allowed x86: fix cpu_mask_to_apicid_and to include cpu_online_mask x86: update io_apic.c to the new cpumask code x86: Introduce topology_core_cpumask()/topology_thread_cpumask() x86: xen: use smp_call_function_many() x86: use work_on_cpu in x86/kernel/cpu/mcheck/mce_amd_64.c ... Fixed up trivial conflict in kernel/time/tick-sched.c manually
2008-12-25[S390] convert time printks to pr_xxx macros.Martin Schwidefsky
2008-12-25[S390] Remove config options.Martin Schwidefsky
On s390 we always want to run with precise cputime accounting. Remove the config options VIRT_TIMER and VIRT_CPU_ACCOUNTING. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-12-25[S390] serialize stp/etr workMartin Schwidefsky
The work function dispatched with schedule_work() can be run twice on different cpus because run_workqueue clears the WORK_STRUCT_PENDING bit and then executes the function. Another cpu can call schedule_work() again and run the work function a second time before the first call is completed. This patch serialized the etr and stp work function with a mutex. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-12-25[S390] convert etr/stp to stop_machine interfaceHeiko Carstens
This converts the etr and stp code to the new stop_machine interface which allows to synchronize all cpus without allocating any memory. This way we get rid of the only reason why we haven't converted s390 to the generic IPI interface yet. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-12-25[S390] introduce vdso on s390Martin Schwidefsky
Add a vdso to speed up gettimeofday and clock_getres/clock_gettime for CLOCK_REALTIME/CLOCK_MONOTONIC. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-12-13cpumask: convert struct clock_event_device to cpumask pointers.Rusty Russell
Impact: change calling convention of existing clock_event APIs struct clock_event_timer's cpumask field gets changed to take pointer, as does the ->broadcast function. Another single-patch change. For safety, we BUG_ON() in clockevents_register_device() if it's not set. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Ingo Molnar <mingo@elte.hu>
2008-11-27[S390] fix/cleanup sched_clockChristian Borntraeger
CONFIG_PRINTK_TIME reveals that sched_clock has a wrong offset during boot: .. [ 0.000000] Movable zone: 0 pages used for memmap [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 775679 [ 0.000000] Kernel command line: dasd=4b6c root=/dev/dasda1 ro noinitrd [ 0.000000] PID hash table entries: 4096 (order: 12, 32768 bytes) [6920575.975232] console [ttyS0] enabled [6920575.987586] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes) [6920575.991404] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes) .. The s390 implementation of sched_clock uses the store clock instruction and subtracts jiffies_timer_cc. jiffies_timer_cc is a local variable in arch/s390/kernel/time.c and only used for sched_clock and monotonic clock. For historical reasons there is an offset on that value. With todays code this offset is unnecessary. By removing that offset we can get a sched_clock which returns the nanoseconds after time_init. This improves CONFIG_PRINTK_TIME. Since sched_clock is the only user, I have also renamed jiffies_timer_cc to sched_clock_base_cc. In addition, the local variable init_timer_cc is redundant and can be romved as well. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-10-10[S390] fix initialization of stpMartin Schwidefsky
chsc_sstpc returns -EIO on error and 0 on success but stp_reset checks against 1 instead of 0. chsc_sstpc used to return 1 on success, one call location has not been updated .. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-10-03[S390] nohz: Fix __udelay.Heiko Carstens
This fixes a regression that came with 934b2857cc576ae53c92a66e63fce7ddcfa74691 ("[S390] nohz/sclp: disable timer on synchronous waits."). If udelay() gets called from a disabled context it sets the clock comparator to a value where it expects the next interrupt. When the interrupt happens the clock comparator gets not reset and therefore the interrupt condition doesn't get cleared. The result is an endless timer interrupt loop. In addition this patch fixes also the following: rcutorture reveals that our __udelay implementation is still buggy, since it might schedule tasklets, but prevents their execution: NOHZ: local_softirq_pending 42 NOHZ: local_softirq_pending 02 NOHZ: local_softirq_pending 142 NOHZ: local_softirq_pending 02 To fix this we make sure that only the clock comparator interrupt is enabled when the enabled wait psw is loaded. Also no code gets called anymore which might schedule tasklets. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-08-01[S390] stp: fix section mismatch warning.Heiko Carstens
Fix these two (false positive) warnings by adding an __init annoation: WARNING: vmlinux.o(.text+0x7e6a): Section mismatch in reference from the function stp_reset() to the function .init.text:__alloc_bootmem() The function stp_reset() references the function __init __alloc_bootmem(). This is often because stp_reset lacks a __init annotation or the annotation of __alloc_bootmem is wrong. WARNING: vmlinux.o(.text+0x7ece): Section mismatch in reference from the function stp_reset() to the function .init.text:free_bootmem() The function stp_reset() references the function __init free_bootmem(). This is often because stp_reset lacks a __init annotation or the annotation of free_bootmem is wrong. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-07-21sysdev: Pass the attribute to the low level sysdev show/store functionAndi Kleen
This allow to dynamically generate attributes and share show/store functions between attributes. Right now most attributes are generated by special macros and lots of duplicated code. With the attribute passed it's instead possible to attach some data to the attribute and then use that in shared low level functions to do different things. I need this for the dynamically generated bank attributes in the x86 machine check code, but it'll allow some further cleanups. I converted all users in tree to the new show/store prototype. It's a single huge patch to avoid unbisectable sections. Runtime tested: x86-32, x86-64 Compiled only: ia64, powerpc Not compile tested/only grep converted: sh, arm, avr32 Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-15generic-ipi: more merge falloutIngo Molnar
fix more API change fallout in recently merged upstream changes. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-15Merge branch 'generic-ipi' into generic-ipi-for-linusIngo Molnar
Conflicts: arch/powerpc/Kconfig arch/s390/kernel/time.c arch/x86/kernel/apic_32.c arch/x86/kernel/cpu/perfctr-watchdog.c arch/x86/kernel/i8259_64.c arch/x86/kernel/ldt.c arch/x86/kernel/nmi_64.c arch/x86/kernel/smpboot.c arch/x86/xen/smp.c include/asm-x86/hw_irq_32.h include/asm-x86/hw_irq_64.h include/asm-x86/mach-default/irq_vectors.h include/asm-x86/mach-voyager/irq_vectors.h include/asm-x86/smp.h kernel/Makefile Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-14[S390] stp support.Martin Schwidefsky
Add support for clock synchronization with the server time protocol. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2008-06-26on_each_cpu(): kill unused 'retry' parameterJens Axboe
It's not even passed on to smp_call_function() anymore, since that was removed. So kill it. Acked-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
