This patch adds support for clock synchronization to an external time
reference (ETR). The external time reference sends an oscillator
signal and a synchronization signal every 2^20 microseconds to keep
the TOD clocks of all connected servers in sync. For availability
two ETR units can be connected to a machine. If the clock deviates
for more than the sync-check tolerance all cpus get a machine check
that indicates that the clock is out of sync. For the lovely details
how to get the clock back in sync see the code below.
Fix too slow clock by using CONFIG_GENERIC_TIME and adding a
clock source for the s390 time-of-day clock. As added benefit
we get rid of the s390 specific definition of do_gettimeofday
and do_settimeofday.
With 2.6.18-rc4-mm2, now wall_jiffies will always be the same as jiffies.
So we can kill wall_jiffies completely.
This is just a cleanup and logically should not change any real behavior
except for one thing: RTC updating code in (old) ppc and xtensa use a
condition "jiffies - wall_jiffies == 1". This condition is never met so I
suppose it is just a bug. I just remove that condition only instead of
kill the whole "if" block.
[heiko.carstens@de.ibm.com: s390 build fix and cleanup]
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
Cc: Andi Kleen <ak@muc.de>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Ian Molton <spyro@f2s.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: Hirokazu Takata <takata.hirokazu@renesas.com>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp>
Cc: Richard Curnow <rc@rc0.org.uk>
Cc: William Lee Irwin III <wli@holomorphy.com>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it>
Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp>
Cc: Chris Zankel <chris@zankel.net>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Roman Zippel <zippel@linux-m68k.org>
Pass ticks to do_timer() and update_times(), and adjust x86_64 and s390
timer interrupt handler with this change.
Currently update_times() calculates ticks by "jiffies - wall_jiffies", but
callers of do_timer() should know how many ticks to update. Passing ticks
get rid of this redundant calculation. Also there are another redundancy
pointed out by Martin Schwidefsky.
This cleanup make a barrier added by
5aee405c662ca644980c184774277fc6d0769a84 needless. So this patch removes
it.
As a bonus, this cleanup make wall_jiffies can be removed easily, since now
wall_jiffies is always synced with jiffies. (This patch does not really
remove wall_jiffies. It would be another cleanup patch)
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: john stultz <johnstul@us.ibm.com>
Acked-by: Russell King <rmk@arm.linux.org.uk>
Acked-by: Ralf Baechle <ralf@linux-mips.org>
Acked-by: "Luck, Tony" <tony.luck@intel.com>
Major cleanup of all s390 inline assemblies. They now have a common
coding style. Quite a few have been shortened, mainly by using register
asm variables. Use of the EX_TABLE macro helps as well. The atomic ops,
bit ops and locking inlines new use the Q-constraint if a newer gcc
is used. That results in slightly better code.
Thanks to Christian Borntraeger for proof reading the changes.
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
Add missing parentheses for type cast to u64.
Cc: Dave Jones <davej@redhat.com>
The 32 bit unsigned substraction (next - jiffies) in stop_hz_timer can
overflow if jiffies gets advanced between next_timer_interrupt and the read
under the xtime lock. The cast to a u64 then results in a large value
which causes the cpu to wait too long. Fix this by casting next and
jiffies independently to u64 before subtracting them.
(Spotted by Zachary Amsden <zach@vmware.com>)
Exploit rcu_needs_cpu() interface to keep the cpu 'ticking' if necessary.
Add monotonic_clock interface, used by the hangcheck-timer. On s390 this is
the same as sched_clock().
Signed-off-by: Jan Glauber <jan.glauber@de.ibm.com>
The least significant bit of the TOD clock value returned by get_clock
is the 4096th part of a microsecond. To get to nanoseconds the value
needs to be divided by 4096 and multiplied with 1000.
The current method multiplies first and then shifts the value to make the
result as precise as possible. The disadvantage is that the multiplication
with 1000 will overflow shortly after 52 days. sched_clock is used by the
scheduler for time stamp deltas, if an overflow occurs between two time stamps
the scheduler will get confused.
With the patch the problem occurs only after approx. one year, so the chance
to run into this overflow is extremly low.
finish_arch_switch needs to update the user cpu time as well, not just the
system cpu time. Otherwise the partial user cpu time of a process that is
stored in the lowcore will be (mis-)accounted to the next process.
The calculation of the value return by next_timer_interrupt from jiffies to
jiffies_64 is racy against xtime updates. We need to protect the calculation
with read_seqbegin/read_seqretry.
Define jiffies_64 in kernel/timer.c rather than having 24 duplicated
defines in each architecture.
This patch cleans up a commonly repeated set of changes to the NTP state
variables by adding two helper inline functions:
ntp_clear(): Clears the ntp state variables
ntp_synced(): Returns 1 if the system is synced with a time server.
This was compile tested for alpha, arm, i386, x86-64, ppc64, s390, sparc,
sparc64.
Signed-off-by: John Stultz <johnstul@us.ibm.com>
Fix overflow in calculation of the new tod value in stop_hz_timer and fix
wrong virtual timer list idle time in case the virtual timer is already
expired in stop_cpu_timer.
infrastructure for it.
Let it rip!
