path: root/arch/s390/kernel/process.c
2015-02-10s390/process: free vx save area when releasing tasksHendrik Brueckner
If a task uses vector registers, a save area is allocated to save/restore register states. Free the save area when releasing the task. Found the Memory leak with kmemleak: unreferenced object 0x72885e00 (size 512): comm "vx-test", pid 26123, jiffies 4294945635 (age 256.810s) hex dump (first 32 bytes): 00 00 00 00 00 00 00 00 00 00 00 01 db 71 06 41 .............q.A 00 00 00 00 00 00 00 00 24 f7 a9 a7 51 94 79 bb ........$...Q.y. backtrace: [<00000000002d1c8a>] kmem_cache_alloc_trace+0x272/0x3d0 [<00000000001014ac>] alloc_vector_registers+0x54/0x138 [<00000000001017c8>] data_exception+0x158/0x1b0 [<00000000008b551e>] pgm_check_handler+0x13e/0x180 [<00000000800008b6>] 0x800008b6 Signed-off-by: Hendrik Brueckner <brueckner@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2015-01-22s390: avoid z13 cache aliasingMartin Schwidefsky
Avoid cache aliasing on z13 by aligning shared objects to multiples of 512K. The virtual addresses of a page from a shared file needs to have identical bits in the range 2^12 to 2^18. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2014-12-08s390/simd: clear vector register pointer on fork/cloneMartin Schwidefsky
The copy_thread function fails to reset the p->thread.vxrs pointer. This causes the child to use the same vector register save area, causing both data corruptions and multiple frees of the memory for the save area after the tasks sharing the save area terminate. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2014-10-27s390/kprobes: make use of NOKPROBE_SYMBOL()Heiko Carstens
Use NOKPROBE_SYMBOL() instead of __kprobes annotation. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2014-10-09s390/idle: consolidate idle functions and definitionsMartin Schwidefsky
Move the C functions and definitions related to the idle state handling to arch/s390/include/asm/idle.h and arch/s390/kernel/idle.c. The function s390_get_idle_time is renamed to arch_cpu_idle_time and vtime_stop_cpu to enabled_wait. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2014-05-20s390: split TIF bits into CIF, PIF and TIF bitsMartin Schwidefsky
The oi and ni instructions used in entry[64].S to set and clear bits in the thread-flags are not guaranteed to be atomic in regard to other CPUs. Split the TIF bits into CPU, pt_regs and thread-info specific bits. Updates on the TIF bits are done with atomic instructions, updates on CPU and pt_regs bits are done with non-atomic instructions. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-12-18s390/mm: optimize randomize_et_dyn for !PF_RANDOMIZEMartin Schwidefsky
Skip the call to brk_rnd() if the PF_RANDOMIZE flag is not set for the process. This avoids the costly get_random_int() call. Modify arch_randomize_brk() as well to make it look like randomize_et_dyn(). Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-10-24s390: fix save and restore of the floating-point-control registerMartin Schwidefsky
The FPC_VALID_MASK has been used to check the validity of the value to be loaded into the floating-point-control register. With the introduction of the floating-point extension facility and the decimal-floating-point additional bits have been defined which need to be checked in a non straight forward way. So far these bits have been ignored which can cause an incorrect results for decimal- floating-point operations, e.g. an incorrect rounding mode to be set after signal return. The static check with the FPC_VALID_MASK is replaced with a trial load of the floating-point-control value, see test_fp_ctl. In addition an information leak with the padding word between the floating-point-control word and the floating-point registers in the s390_fp_regs is fixed. Reported-by: Heiko Carstens <heiko.carstens@de.ibm.com> Reviewed-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-10-24s390/uaccess: always run the kernel in home spaceMartin Schwidefsky
Simplify the uaccess code by removing the user_mode=home option. The kernel will now always run in the home space mode. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-08-28s390/time: return with irqs disabled from psw_idleMartin Schwidefsky
Modify the psw_idle waiting logic in entry[64].S to return with interrupts disabled. This avoids potential issues with udelay and interrupt loops as interrupts are not reenabled after clock comparator interrupts. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-04-08s390: Use generic idle loopThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Paul McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Reviewed-by: Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: Magnus Damm <magnus.damm@gmail.com> Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> Link: http://lkml.kernel.org/r/20130321215235.090816526@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-11-28flagday: don't pass regs to copy_thread()Al Viro
2012-11-28s390: switch to generic fork/vfork/cloneAl Viro
2012-10-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull generic execve() changes from Al Viro: "This introduces the generic kernel_thread() and kernel_execve() functions, and switches x86, arm, alpha, um and s390 over to them." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: (26 commits) s390: convert to generic kernel_execve() s390: switch to generic kernel_thread() s390: fold kernel_thread_helper() into ret_from_fork() s390: fold execve_tail() into start_thread(), convert to generic sys_execve() um: switch to generic kernel_thread() x86, um/x86: switch to generic sys_execve and kernel_execve x86: split ret_from_fork alpha: introduce ret_from_kernel_execve(), switch to generic kernel_execve() alpha: switch to generic kernel_thread() alpha: switch to generic sys_execve() arm: get rid of execve wrapper, switch to generic execve() implementation arm: optimized current_pt_regs() arm: introduce ret_from_kernel_execve(), switch to generic kernel_execve() arm: split ret_from_fork, simplify kernel_thread() [based on patch by rmk] generic sys_execve() generic kernel_execve() new helper: current_pt_regs() preparation for generic kernel_thread() um: kill thread->forking um: let signal_delivered() do SIGTRAP on singlestepping into handler ...
2012-09-30s390: switch to generic kernel_thread()Al Viro
2012-09-30s390: fold kernel_thread_helper() into ret_from_fork()Al Viro
... and don't bother with syscall return path in case of kernel threads. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-09-30s390: fold execve_tail() into start_thread(), convert to generic sys_execve()Al Viro
2012-09-26s390/process: add missing header includeHeiko Carstens
Add appropriate header file: arch/s390/kernel/process.c:327:15: warning: symbol 'arch_align_stack' was not declared. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-09-26s390: add support for runtime instrumentationJan Glauber
Allow user-space threads to use runtime instrumentation (RI). To enable RI for a thread there is a new s390 specific system call, sys_s390_runtime_instr, that takes as parameter a realtime signal number. If the RI facility is available the system call sets up a control block for the calling thread with the appropriate permissions for the thread to modify the control block. The user-space thread can then use the store and modify RI instructions to alter the control block and start/stop the instrumentation via RION/RIOFF. If the user specified program buffer runs full RI triggers an external interrupt. The external interrupt is translated to a real-time signal that is delivered to the thread that enabled RI on that CPU. The number of the real-time signal is the number specified in the RI system call. So, user-space can select any available real-time signal number in case the application itself uses real-time signals for other purposes. The kernel saves the RI control blocks on task switch only if the running thread was enabled for RI. Therefore, the performance impact on task switch should be negligible if RI is not used. RI is only enabled for user-space mode and is disabled for the supervisor state. Reviewed-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-07-20s390/vtimer: rework virtual timer interfaceMartin Schwidefsky
The current virtual timer interface is inherently per-cpu and hard to use. The sole user of the interface is appldata which uses it to execute a function after a specific amount of cputime has been used over all cpus. Rework the virtual timer interface to hook into the cputime accounting. This makes the interface independent from the CPU timer interrupts, and makes the virtual timers global as opposed to per-cpu. Overall the code is greatly simplified. The downside is that the accuracy is not as good as the original implementation, but it is still good enough for appldata. Reviewed-by: Jan Glauber <jang@linux.vnet.ibm.com> Reviewed-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-07-20s390/comments: unify copyright messages and remove file namesHeiko Carstens
Remove the file name from the comment at top of many files. In most cases the file name was wrong anyway, so it's rather pointless. Also unify the IBM copyright statement. We did have a lot of sightly different statements and wanted to change them one after another whenever a file gets touched. However that never happened. Instead people start to take the old/"wrong" statements to use as a template for new files. So unify all of them in one go. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2012-03-28Disintegrate asm/system.h for S390David Howells
Disintegrate asm/system.h for S390. Signed-off-by: David Howells <dhowells@redhat.com> cc: linux-s390@vger.kernel.org
2012-03-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull s390 patches from Martin Schwidefsky: "The biggest patch is the rework of the smp code, something I wanted to do for some time. There are some patches for our various dump methods and one new thing: z/VM LGR detection. LGR stands for linux-guest- relocation and is the guest migration feature of z/VM. For debugging purposes we keep a log of the systems where a specific guest has lived." Fix up trivial conflict in arch/s390/kernel/smp.c due to the scheduler cleanup having removed some code next to removed s390 code. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: [S390] kernel: Pass correct stack for smp_call_ipl_cpu() [S390] Ensure that vmcore_info pointer is never accessed directly [S390] dasd: prevent validate server for offline devices [S390] Remove monolithic build option for zcrypt driver. [S390] stack dump: fix indentation in output [S390] kernel: Add OS info memory interface [S390] Use block_sigmask() [S390] kernel: Add z/VM LGR detection [S390] irq: external interrupt code passing [S390] irq: set __ARCH_IRQ_EXIT_IRQS_DISABLED [S390] zfcpdump: Implement async sdias event processing [S390] Use copy_to_absolute_zero() instead of "stura/sturg" [S390] rework idle code [S390] rework smp code [S390] rename lowcore field [S390] Fix gcc 4.6.0 compile warning
2012-03-11[S390] rework idle codeMartin Schwidefsky
Whenever the cpu loads an enabled wait PSW it will appear as idle to the underlying host system. The code in default_idle calls vtime_stop_cpu which does the necessary voodoo to get the cpu time accounting right. The udelay code just loads an enabled wait PSW. To correct this rework the vtime_stop_cpu/vtime_start_cpu logic and move the difficult parts to entry[64].S, vtime_stop_cpu can now be called from anywhere and vtime_start_cpu is gone. The correction of the cpu time during wakeup from an enabled wait PSW is done with a critical section in entry[64].S. As vtime_start_cpu is gone, s390_idle_check can be removed as well. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-03-01sched/rt: Use schedule_preempt_disabled()Thomas Gleixner
Coccinelle based conversion. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/n/tip-24swm5zut3h9c4a6s46x8rws@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-02-27compat: fix compile breakage on s390Heiko Carstens
The new is_compat_task() define for the !COMPAT case in include/linux/compat.h conflicts with a similar define in arch/s390/include/asm/compat.h. This is the minimal patch which fixes the build issues. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-17[S390] idle: avoid RCU usage in extended quiescent stateHeiko Carstens
Avoid calling wake_up() from our NMI "bottom halve" from RCU extended quiescent state in idle. wake_up() has RCU read-side critical sections but this will be completely ignored by RCU if the cpu is in extended quiescent state. Which means that whatever object is being accessed from within the read-side critical section can be freed concurrently from a different cpu. So make sure we leave extended quiescent state before calling wake_up(). Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-12-11nohz: Remove tick_nohz_idle_enter_norcu() / tick_nohz_idle_exit_norcu()Frederic Weisbecker
Those two APIs were provided to optimize the calls of tick_nohz_idle_enter() and rcu_idle_enter() into a single irq disabled section. This way no interrupt happening in-between would needlessly process any RCU job. Now we are talking about an optimization for which benefits have yet to be measured. Let's start simple and completely decouple idle rcu and dyntick idle logics to simplify. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2011-12-11nohz: Allow rcu extended quiescent state handling seperately from tick stopFrederic Weisbecker
It is assumed that rcu won't be used once we switch to tickless mode and until we restart the tick. However this is not always true, as in x86-64 where we dereference the idle notifiers after the tick is stopped. To prepare for fixing this, add two new APIs: tick_nohz_idle_enter_norcu() and tick_nohz_idle_exit_norcu(). If no use of RCU is made in the idle loop between tick_nohz_enter_idle() and tick_nohz_exit_idle() calls, the arch must instead call the new *_norcu() version such that the arch doesn't need to call rcu_idle_enter() and rcu_idle_exit(). Otherwise the arch must call tick_nohz_enter_idle() and tick_nohz_exit_idle() and also call explicitly: - rcu_idle_enter() after its last use of RCU before the CPU is put to sleep. - rcu_idle_exit() before the first use of RCU after the CPU is woken up. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: David Miller <davem@davemloft.net> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Paul Mackerras <paulus@samba.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2011-12-11nohz: Separate out irq exit and idle loop dyntick logicFrederic Weisbecker
The tick_nohz_stop_sched_tick() function, which tries to delay the next timer tick as long as possible, can be called from two places: - From the idle loop to start the dytick idle mode - From interrupt exit if we have interrupted the dyntick idle mode, so that we reprogram the next tick event in case the irq changed some internal state that requires this action. There are only few minor differences between both that are handled by that function, driven by the ts->inidle cpu variable and the inidle parameter. The whole guarantees that we only update the dyntick mode on irq exit if we actually interrupted the dyntick idle mode, and that we enter in RCU extended quiescent state from idle loop entry only. Split this function into: - tick_nohz_idle_enter(), which sets ts->inidle to 1, enters dynticks idle mode unconditionally if it can, and enters into RCU extended quiescent state. - tick_nohz_irq_exit() which only updates the dynticks idle mode when ts->inidle is set (ie: if tick_nohz_idle_enter() has been called). To maintain symmetry, tick_nohz_restart_sched_tick() has been renamed into tick_nohz_idle_exit(). This simplifies the code and micro-optimize the irq exit path (no need for local_irq_save there). This also prepares for the split between dynticks and rcu extended quiescent state logics. We'll need this split to further fix illegal uses of RCU in extended quiescent states in the idle loop. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: David Miller <davem@davemloft.net> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Paul Mackerras <paulus@samba.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2011-10-30[S390] sparse: fix sparse warnings about missing prototypesMartin Schwidefsky
Add prototypes and includes for functions used in different modules. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-10-30[S390] cleanup psw related bits and piecesMartin Schwidefsky
Split out addressing mode bits from PSW_BASE_BITS, rename PSW_BASE_BITS to PSW_MASK_BASE, get rid of psw_user32_bits, remove unused function enabled_wait(), introduce PSW_MASK_USER, and drop PSW_MASK_MERGE macros. Change psw_kernel_bits / psw_user_bits to contain only the bits that are always set in the respective mode. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-05-23[S390] Remove unused includes in process.cJan Glauber
Remove unsused includes from arch/s390/kernel/process.c. Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-01-12[S390] Randomize PIEsHeiko Carstens
Randomize ELF_ET_DYN_BASE, which is used when loading position independent executables. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-01-12[S390] Randomise the brk regionHeiko Carstens
Randomize heap address like other architectures do already. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-01-12[S390] Randomize lower bits of stack addressHeiko Carstens
Randomize the lower bits of the stack address like x86 and powerpc. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-01-05[S390] ptrace cleanupMartin Schwidefsky
Overhaul program event recording and the code dealing with the ptrace user space interface. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-01-05[S390] smp/idle: call init_idle() before starting a new cpuHeiko Carstens
Call init_idle() which (re-)initializes the idle task structure before it gets used on a new cpu. That way we can also get rid of the odd preempt_enable_no_resched() call we have in the cpu offline path within cpu_idle(). That call prevented preempt count imbalances between cpu hotplug operations. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-01-05[S390] add kprobes annotationsMartin Schwidefsky
Add kprobes annotations to get the massive 'probe kernel.function("*") {}' stress test working. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-10-25[S390] cpu hotplug/idle: move cpu_die call to enabled contextHeiko Carstens
There is no difference if cpu_die is called from enabled or disabled context. Except that the fast_gup code might be called via cpu_die -> idle_task_exit -> __mm_drop -> crst_table_free. Which in turn grabs and releases a spinlock using the _bh ops, which is not allowed in irq disabled context, since spin_unlock_bh will unconditionally enable interrupts again. To get rid of the warning emitted by the softirq code just move the code to enabled context. In this case this doesn't fix a bug, we just get rid of a warning. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-08-17Make do_execve() take a const filename pointerDavid Howells
Make do_execve() take a const filename pointer so that kernel_execve() compiles correctly on ARM: arch/arm/kernel/sys_arm.c:88: warning: passing argument 1 of 'do_execve' discards qualifiers from pointer target type This also requires the argv and envp arguments to be consted twice, once for the pointer array and once for the strings the array points to. This is because do_execve() passes a pointer to the filename (now const) to copy_strings_kernel(). A simpler alternative would be to cast the filename pointer in do_execve() when it's passed to copy_strings_kernel(). do_execve() may not change any of the strings it is passed as part of the argv or envp lists as they are some of them in .rodata, so marking these strings as const should be fine. Further kernel_execve() and sys_execve() need to be changed to match. This has been test built on x86_64, frv, arm and mips. Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-13Mark arguments to certain syscalls as being constDavid Howells
Mark arguments to certain system calls as being const where they should be but aren't. The list includes: (*) The filename arguments of various stat syscalls, execve(), various utimes syscalls and some mount syscalls. (*) The filename arguments of some syscall helpers relating to the above. (*) The buffer argument of various write syscalls. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-01-13[S390] remove superfluous TIF_USEDFPU bitMartin Schwidefsky
The TIF_USEDFPU bit is always 0 for s390 and it is not tested anywhere. Remove the bit. At the same time remove the calls to clear_used_math() as well. The PF_USED_MATH bit is never set for s390 either. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-01-13[S390] clear TIF_SINGLE_STEP for new process.Martin Schwidefsky
Clear the TIF_SINGLE_STEP bit in copy_thread. The new process did not get a PER event of its own. It is wrong deliver a SIGTRAP that was meant for the parent process. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-09-23headers: utsname.h reduxAlexey Dobriyan
* remove asm/atomic.h inclusion from linux/utsname.h -- not needed after kref conversion * remove linux/utsname.h inclusion from files which do not need it NOTE: it looks like fs/binfmt_elf.c do not need utsname.h, however due to some personality stuff it _is_ needed -- cowardly leave ELF-related headers and files alone. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22[S390] Convert sys_execve to function with parameters.Heiko Carstens
Use function parameters instead of accessing the pt_regs structure to get the parameters. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-09-22[S390] Convert sys_clone to function with parameters.Heiko Carstens
Use function parameters instead of accessing the pt_regs structure to get the parameters. Also merge the 31 and 64 bit versions since they are identical. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-06-18ptrace: remove PT_DTRACE from avr32, mn10300, parisc, s390, sh, xtensaOleg Nesterov
avr32, mn10300, parisc, s390, sh, xtensa: They never set PT_DTRACE, but clear it after do_execve(). Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: David Howells <dhowells@redhat.com> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: Matthew Wilcox <matthew@wil.cx> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Chris Zankel <chris@zankel.net> Acked-by: Roland McGrath <roland@redhat.com> Acked-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-12[S390] implement is_compat_taskHeiko Carstens
Implement is_compat_task and use it all over the place. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
