path: root/arch/s390/kernel/dis.c
2007-10-12[S390] disassembler: Remove redundant variable assignmentChristian Borntraeger
There is no need to assign "0" to "hops" twice. Remove one assigment. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-10-12[S390] disassembler: fix output for insns with 6 operands.Martin Schwidefsky
The termination condition of the loop that prints the operands of an instruction doesn't stop after the maximum of 6 operands. It continues with the operands of the next instruction format instead which create really long lines. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-08-22[S390] disassembler: fix b2 opcodes like srst, bsg, and othersChristian Borntraeger
The instruction table for b2 opcodes was missing an opfrag value for the cpya instruction. All instructions specified after cpya were not considered by the disassembler. The fix is simple and obvious - add the opfrag field to the cpya instruction. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2007-07-17[S390] Fix disassembly of RX_URRD, SI_URD & PC-relative instructions.Christian Borntraeger
The instructions with format RX_URRD and SI_URD and instructions with a PC relative operand are not disassembled correctly. For RX_URRD and SI_URD instructions find_insn sets opfrag to code[0]. The mask byte of these two formats is 0x00. table->opfrag will never be identical to (opfrag & opmask) and no matching instruction will be found. Set the mask byte to 0xff to actually check byte 0 against the table. For PC relative instructions the (unsigned) offset value needs to be casted to an signed integer so that negative branch offsets are handled correctly. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-05-08no longer #include <asm/kdebug.h>Adrian Bunk
Include the new linux/kdebug.h instead of asm/kdebug.h. Simply remove the asm/kdebug.h include if both had been included. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-27[S390] Improved oops output.Martin Schwidefsky
This patch adds two improvements to the oops output. First it adds an additional line after the PSW which decodes the different fields of it. Second a disassembler is added that decodes the instructions surrounding the faulting PSW. The output of a test oops now looks like this: kernel BUG at init/main.c:419 illegal operation: 0001 [#1] CPU: 0 Not tainted Process swapper (pid: 0, task: 0000000000464968, ksp: 00000000004be000) Krnl PSW : 0700000180000000 00000000000120b6 (rest_init+0x36/0x38) R:0 T:1 IO:1 EX:1 Key:0 M:0 W:0 P:0 AS:0 CC:0 PM:0 EA:3 Krnl GPRS: 0000000000000003 00000000004ba017 0000000000000022 0000000000000001 000000000003a5f6 0000000000000000 00000000004be6a8 0000000000000000 0000000000000000 00000000004b8200 0000000000003a50 0000000000008000 0000000000516368 000000000033d008 00000000000120b2 00000000004bdee0 Krnl Code: 00000000000120a6: e3e0f0980024 stg %r14,152(%r15) 00000000000120ac: c0e500014296 brasl %r14,3a5d8 00000000000120b2: a7f40001 brc 15,120b4 >00000000000120b6: 0707 bcr 0,%r7 00000000000120b8: eb7ff0500024 stmg %r7,%r15,80(%r15) 00000000000120be: c0d000195825 larl %r13,33d108 00000000000120c4: a7f13f00 tmll %r15,16128 00000000000120c8: a7840001 brc 8,120ca Call Trace: ([<00000000000120b2>] rest_init+0x32/0x38) [<00000000004be614>] start_kernel+0x37c/0x410 [<0000000000012020>] _ehead+0x20/0x80 Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
