path: root/arch/s390/include/asm/system.h
2012-03-28Delete all instances of asm/system.hDavid Howells
Delete all instances of asm/system.h as they should be redundant by this point. Signed-off-by: David Howells <dhowells@redhat.com>
2012-03-28Disintegrate asm/system.h for S390David Howells
Disintegrate asm/system.h for S390. Signed-off-by: David Howells <dhowells@redhat.com> cc: linux-s390@vger.kernel.org
2012-03-11[S390] kernel: Add z/VM LGR detectionMichael Holzheu
Currently the following mechanisms are available to move active Linux on System z instances between machines: * z/VM 6.2 SSI (Single System Image) * Suspend/resume For moving Linux instances in this patch the term LGR (Linux Guest Relocation) is used. Because such an operation is critical, it should be detectable from Linux. With this patch for both, a live system and a kernel dump, the information about LGRs is accessible. To identify a guest, stsi and stfle data is used. A new function lgr_info_log() compares the current data (lgr_info_cur) with the last recorded one (lgr_info_last). In case the two data sets differ, lgr_info_cur is logged to the "lgr" s390dbf. The following trigger points call lgr_info_log(): * panic * die * kdump * LGR timer * PSW restart * QDIO recovery * resume This patch also changes the s390dbf hex_ascii view. Now only printable ASCII characters are shown. Reviewed-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-12-27[S390] sysctl: get rid of dead declarationHeiko Carsten
Remove dead sysctl_userprocess_debug. The variable is gone since we map our old userprocess_debug sysctl to the common code show_unhandled_signals sysctl on s390. Signed-off-by: Heiko Carsten <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-10-30[S390] sparse: fix sparse warnings about missing prototypesMartin Schwidefsky
Add prototypes and includes for functions used in different modules. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-10-30[S390] cleanup psw related bits and piecesMartin Schwidefsky
Split out addressing mode bits from PSW_BASE_BITS, rename PSW_BASE_BITS to PSW_MASK_BASE, get rid of psw_user32_bits, remove unused function enabled_wait(), introduce PSW_MASK_USER, and drop PSW_MASK_MERGE macros. Change psw_kernel_bits / psw_user_bits to contain only the bits that are always set in the respective mode. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-10-30[S390] Add real memory access functionsMichael Holzheu
Add access function for real memory needed by s390 kdump backend. Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-08-03[S390] Add PSW restart shutdown triggerMichael Holzheu
With this patch a new S390 shutdown trigger "restart" is added. If under z/VM "systerm restart" is entered or under the HMC the "PSW restart" button is pressed, the PSW located at 0 (31 bit) or 0x1a0 (64 bit) bit is loaded. Now we execute do_restart() that processes the restart action that is defined under /sys/firmware/shutdown_actions/on_restart. Currently the following actions are possible: reipl (default), stop, vmcmd, dump, and dump_reipl. Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2011-03-23[S390] xchg/cmpxchg: move to own header fileHeiko Carstens
Move xchg() and cmpxchg() functions to own header file like some other architectures have done. With this we make sure that system.h now really looks like a place where everything is gathered that doesn't fit anywhere else. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-01-12[S390] Randomize lower bits of stack addressHeiko Carstens
Randomize the lower bits of the stack address like x86 and powerpc. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-01-05[S390] ptrace cleanupMartin Schwidefsky
Overhaul program event recording and the code dealing with the ptrace user space interface. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-01-05[S390] pfault: delay register of pfault interruptHeiko Carstens
Use an early init call to initialize pfault. That way it is possible to use the register_external_interrupt() instead of the early variant. No need to enable pfault any earlier since it has only effect if user space processes are running. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-10-25[S390] cleanup facility list handlingMartin Schwidefsky
Store the facility list once at system startup with stfl/stfle and reuse the result for all facility tests. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-10-25[S390] switch_to: get rid of prev == next checkHeiko Carstens
schedule() makes sure that prev != next before calling switch_to(). Therefore remove the redundant check. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-10-25[S390] switch_to: dont restore/save access & fpu regs for kernel threadsHeiko Carstens
If the previous task was a kernel thread there is no need to save the contents of the fpu and access registers since they aren't used in kernel mode. For the same reason it is not necessary to restore these registers if the next task is a kernel thread. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-10-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-irqflagsLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-irqflags: Fix IRQ flag handling naming MIPS: Add missing #inclusions of <linux/irq.h> smc91x: Add missing #inclusion of <linux/irq.h> Drop a couple of unnecessary asm/system.h inclusions SH: Add missing consts to sys_execve() declaration Blackfin: Rename IRQ flags handling functions Blackfin: Add missing dep to asm/irqflags.h Blackfin: Rename DES PC2() symbol to avoid collision Blackfin: Split the BF532 BFIN_*_FIO_FLAG() functions to their own header Blackfin: Split PLL code from mach-specific cdef headers
2010-10-18sched: Consolidate account_system_vtime extern declarationVenkatesh Pallipadi
Just a minor cleanup patch that makes things easier to the following patches. No functionality change in this patch. Signed-off-by: Venkatesh Pallipadi <venki@google.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1286237003-12406-3-git-send-email-venki@google.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-10-07Fix IRQ flag handling namingDavid Howells
Fix the IRQ flag handling naming. In linux/irqflags.h under one configuration, it maps: local_irq_enable() -> raw_local_irq_enable() local_irq_disable() -> raw_local_irq_disable() local_irq_save() -> raw_local_irq_save() ... and under the other configuration, it maps: raw_local_irq_enable() -> local_irq_enable() raw_local_irq_disable() -> local_irq_disable() raw_local_irq_save() -> local_irq_save() ... This is quite confusing. There should be one set of names expected of the arch, and this should be wrapped to give another set of names that are expected by users of this facility. Change this to have the arch provide: flags = arch_local_save_flags() flags = arch_local_irq_save() arch_local_irq_restore(flags) arch_local_irq_disable() arch_local_irq_enable() arch_irqs_disabled_flags(flags) arch_irqs_disabled() arch_safe_halt() Then linux/irqflags.h wraps these to provide: raw_local_save_flags(flags) raw_local_irq_save(flags) raw_local_irq_restore(flags) raw_local_irq_disable() raw_local_irq_enable() raw_irqs_disabled_flags(flags) raw_irqs_disabled() raw_safe_halt() with type checking on the flags 'arguments', and then wraps those to provide: local_save_flags(flags) local_irq_save(flags) local_irq_restore(flags) local_irq_disable() local_irq_enable() irqs_disabled_flags(flags) irqs_disabled() safe_halt() with tracing included if enabled. The arch functions can now all be inline functions rather than some of them having to be macros. Signed-off-by: David Howells <dhowells@redhat.com> [X86, FRV, MN10300] Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> [Tile] Signed-off-by: Michal Simek <monstr@monstr.eu> [Microblaze] Tested-by: Catalin Marinas <catalin.marinas@arm.com> [ARM] Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> [AVR] Acked-by: Tony Luck <tony.luck@intel.com> [IA-64] Acked-by: Hirokazu Takata <takata@linux-m32r.org> [M32R] Acked-by: Greg Ungerer <gerg@uclinux.org> [M68K/M68KNOMMU] Acked-by: Ralf Baechle <ralf@linux-mips.org> [MIPS] Acked-by: Kyle McMartin <kyle@mcmartin.ca> [PA-RISC] Acked-by: Paul Mackerras <paulus@samba.org> [PowerPC] Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [S390] Acked-by: Chen Liqin <liqin.chen@sunplusct.com> [Score] Acked-by: Matt Fleming <matt@console-pimps.org> [SH] Acked-by: David S. Miller <davem@davemloft.net> [Sparc] Acked-by: Chris Zankel <chris@zankel.net> [Xtensa] Reviewed-by: Richard Henderson <rth@twiddle.net> [Alpha] Reviewed-by: Yoshinori Sato <ysato@users.sourceforge.jp> [H8300] Cc: starvik@axis.com [CRIS] Cc: jesper.nilsson@axis.com [CRIS] Cc: linux-cris-kernel@axis.com
2010-05-17[S390] improve irq tracing code in entry[64].SMartin Schwidefsky
The system call path in entry[64].S is run with interrupts enabled. Remove the irq tracing check from the system call exit code. If a program check interrupted a context enabled for interrupts do a call to trace_irq_off_caller in the program check handler before branching to the system call exit code. Restructure the system call and io interrupt return code to avoid avoid the lpsw[e] to disable machine checks. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-03-24[S390] system.h: Fix compile error for 1 and 2 byte cmpxchgChristian Borntraeger
commit 024914477e15ef8b17f271ec47f1bb8a589f0806 "memcg: move charges of anonymous swap" revealed that the 1 byte and 2 byte cmpxchg is currently broken: arch/s390/include/asm/system.h: Assembler messages: arch/s390/include/asm/system.h:241: Error: junk at end of line: `(%r5)' make[1]: *** [mm/page_cgroup.o] Error 1 make[1]: *** Waiting for unfinished jobs.... It turned out that commit 987bcdacb18a3adc2a48d85c9b005069c2f4dd7b ([S390] use inline assembly contraints available with gcc 3.3.3) broke the inline assembly. The or operands are now in constraint 3 and 4 instead of 2 and 3. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-03-24[S390] zcore: CPU registers are not saved under LPARMichael Holzheu
To save the registers for all CPUs a sigp "store status" is done that stores the registers to address absolute zero. To access storage at absolute zero, normally the address of the prefix register of the accessing CPU has to be used. This does not work when large pages are active (currently only under LPAR). In order to fix that problem, instead of memcpy memcpy_real is used, which switches to real mode where prefixing works. Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-02-26[S390] use inline assembly contraints available with gcc 3.3.3Martin Schwidefsky
Drop support to compile the kernel with gcc versions older than 3.3.3. This allows us to use the "Q" inline assembly contraint on some more inline assemblies without duplicating a lot of complex code (e.g. __xchg and __cmpxchg). The distinction for older gcc versions can be removed which saves a few lines and simplifies the code. Reviewed-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-09-11[S390] Enable guest page hinting by default.Heiko Carstens
Get rid of the PAGE_STATES config option and enable guest page hinting by default. It can be disabled by specifying "cmma=off" at the command line. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-06-16[S390] s390: hibernation support for s390Hans-Joachim Picht
This patch introduces the hibernation backend support to the s390 architecture. Now it is possible to suspend a mainframe Linux guest using the following command: echo disk > /sys/power/state Signed-off-by: Hans-Joachim Picht <hans@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-12-31[PATCH] improve precision of process accounting.Martin Schwidefsky
The unit of the cputime accouting values that are stored per process is currently a microsecond. The CPU timer has a maximum granularity of 2**-12 microseconds. There is no benefit in storing the per process values in the lesser precision and there is the disadvantage that the backend has to do the rounding to microseconds. The better solution is to use the maximum granularity of the CPU timer as cputime unit. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-12-25[S390] Remove config options.Martin Schwidefsky
On s390 we always want to run with precise cputime accounting. Remove the config options VIRT_TIMER and VIRT_CPU_ACCOUNTING. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-12-25[S390] Move stfle to header file.Heiko Carstens
stfle will be needed by the ap_bus module to figure out wether the AP queue adapter interruption facility is installed. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-08-01[S390] move include/asm-s390 to arch/s390/include/asmMartin Schwidefsky
