path: root/arch/s390/include/asm/kvm_host.h
2012-07-20s390/comments: unify copyright messages and remove file namesHeiko Carstens
Remove the file name from the comment at top of many files. In most cases the file name was wrong anyway, so it's rather pointless. Also unify the IBM copyright statement. We did have a lot of sightly different statements and wanted to change them one after another whenever a file gets touched. However that never happened. Instead people start to take the old/"wrong" statements to use as a template for new files. So unify all of them in one go. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2012-04-30KVM: s390: Implement the directed yield (diag 9c) hypervisor call for KVMKonstantin Weitz
This patch implements the directed yield hypercall found on other System z hypervisors. It delegates execution time to the virtual cpu specified in the instruction's parameter. Useful to avoid long spinlock waits in the guest. Christian Borntraeger: moved common code in virt/kvm/ Signed-off-by: Konstantin Weitz <WEITZKON@de.ibm.com> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2012-03-08KVM: Introduce kvm_memory_slot::arch and move lpage_info into itTakuya Yoshikawa
Some members of kvm_memory_slot are not used by every architecture. This patch is the first step to make this difference clear by introducing kvm_memory_slot::arch; lpage_info is moved into it. Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-03-05KVM: s390: provide access guest registers via kvm_runChristian Borntraeger
This patch adds the access registers to the kvm_run structure. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-03-05KVM: s390: provide general purpose guest registers via kvm_runChristian Borntraeger
This patch adds the general purpose registers to the kvm_run structure. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-03-05KVM: s390: fix assumption for KVM_MAX_VCPUSCarsten Otte
This patch fixes definition of the idle_mask and the local_int array in kvm_s390_float_interrupt. Previous definition had 64 cpus max hardcoded instead of using KVM_MAX_VCPUS. Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-11-17KVM: s390: handle SIGP sense running interceptsCornelia Huck
SIGP sense running may cause an intercept on higher level virtualization, so handle it by checking the CPUSTAT_RUNNING flag. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-11-17KVM: s390: Fix RUNNING flag misinterpretationCornelia Huck
CPUSTAT_RUNNING was implemented signifying that a vcpu is not stopped. This is not, however, what the architecture says: RUNNING should be set when the host is acting on the behalf of the guest operating system. CPUSTAT_RUNNING has been changed to be set in kvm_arch_vcpu_load() and to be unset in kvm_arch_vcpu_put(). For signifying stopped state of a vcpu, a host-controlled bit has been used and is set/unset basically on the reverse as the old CPUSTAT_RUNNING bit (including pushing it down into stop handling proper in handle_stop()). Cc: stable@kernel.org Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-10-31Merge branch 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: (54 commits) [S390] Remove error checking from copy_oldmem_page() [S390] qdio: prevent dsci access without adapter interrupts [S390] irqstats: split IPI interrupt accounting [S390] add missing __tlb_flush_global() for !CONFIG_SMP [S390] sparse: fix sparse symbol shadow warning [S390] sparse: fix sparse NULL pointer warnings [S390] sparse: fix sparse warnings with __user pointers [S390] sparse: fix sparse warnings in math-emu [S390] sparse: fix sparse warnings about missing prototypes [S390] sparse: fix sparse ANSI-C warnings [S390] sparse: fix sparse static warnings [S390] sparse: fix access past end of array warnings [S390] dasd: prevent path verification before resume [S390] qdio: remove multicast polling [S390] qdio: reset outbound SBAL error states [S390] qdio: EQBS retry after CCQ 96 [S390] qdio: add timestamp for last queue scan time [S390] Introduce get_clock_fast() [S390] kvm: Handle diagnose 0x10 (release pages) [S390] take mmap_sem when walking guest page table ...
2011-10-30[S390] kvm: Handle diagnose 0x10 (release pages)Christian Borntraeger
Linux on System z uses a ballooner based on diagnose 0x10. (aka as collaborative memory management). This patch implements diagnose 0x10 on the guest address space. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-10-30KVM: s390: implement sigp external callChristian Ehrhardt
Implement sigp external call, which might be required for guests that issue an external call instead of an emergency signal for IPI. This fixes an issue with "KVM: unknown SIGP: 0x02" when booting such an SMP guest. Signed-off-by: Christian Ehrhardt <ehrhardt@linux.vnet.ibm.com> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-07-24[S390] kvm: make sigp emerg smp capableChristian Ehrhardt
SIGP emerg needs to pass the source vpu adress into __LC_CPU_ADDRESS of the target guest. Signed-off-by: Christian Ehrhardt <ehrhardt@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-07-24[S390] Use gmap translation for accessing guest memoryCarsten Otte
This patch removes kvm-s390 internal assumption of a linear mapping of guest address space to user space. Previously, guest memory was translated to user addresses using a fixed offset (gmsor). The new code uses gmap_fault to resolve guest addresses. Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-07-24[S390] use gmap address spaces for kvm guest imagesCarsten Otte
This patch switches kvm from using (Qemu's) user address space to Martin's gmap address space. This way QEMU does not have to use a linker script in order to fit large guests at low addresses in its address space. Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-07-24[S390] kvm: handle tprot interceptsChristian Borntraeger
When running a kvm guest we can get intercepts for tprot, if the host page table is read-only or not populated. This patch implements the most common case (linux memory detection). This also allows host copy on write for guest memory on newer systems. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-08-01KVM: Remove unnecessary divide operationsJoerg Roedel
This patch converts unnecessary divide and modulo operations in the KVM large page related code into logical operations. This allows to convert gfn_t to u64 while not breaking 32 bit builds. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-08-01KVM: s390: Don't exit SIE on SIGP sense runningChristian Borntraeger
Newer (guest) kernels use sigp sense running in their spinlock implementation to check if the other cpu is running before yielding the processor. This revealed some wrong guest settings, causing unnecessary exits for every sigp sense running. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-09-14Merge branch 'kvm-updates/2.6.32' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
* 'kvm-updates/2.6.32' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (202 commits) MAINTAINERS: update KVM entry KVM: correct error-handling code KVM: fix compile warnings on s390 KVM: VMX: Check cpl before emulating debug register access KVM: fix misreporting of coalesced interrupts by kvm tracer KVM: x86: drop duplicate kvm_flush_remote_tlb calls KVM: VMX: call vmx_load_host_state() only if msr is cached KVM: VMX: Conditionally reload debug register 6 KVM: Use thread debug register storage instead of kvm specific data KVM guest: do not batch pte updates from interrupt context KVM: Fix coalesced interrupt reporting in IOAPIC KVM guest: fix bogus wallclock physical address calculation KVM: VMX: Fix cr8 exiting control clobbering by EPT KVM: Optimize kvm_mmu_unprotect_page_virt() for tdp KVM: Document KVM_CAP_IRQCHIP KVM: Protect update_cr8_intercept() when running without an apic KVM: VMX: Fix EPT with WP bit change during paging KVM: Use kvm_{read,write}_guest_virt() to read and write segment descriptors KVM: x86 emulator: Add adc and sbb missing decoder flags KVM: Add missing #include ...
2009-09-11[S390] Get rid of cpuid.h header file.Heiko Carstens
Merge cpuid.h header file into cpu.h. While at it convert from typedef to struct declaration and also convert cio code to use proper lowcore structure instead of casts. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-09-10KVM: Prepare memslot data structures for multiple hugepage sizesJoerg Roedel
[avi: fix build on non-x86] Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-09-10KVM: s390: streamline memslot handlingChristian Ehrhardt
This patch relocates the variables kvm-s390 uses to track guest mem addr/size. As discussed dropping the variables at struct kvm_arch level allows to use the common vcpu->request based mechanism to reload guest memory if e.g. changes via set_memory_region. The kick mechanism introduced in this series is used to ensure running vcpus leave guest state to catch the update. Signed-off-by: Christian Ehrhardt <ehrhardt@linux.vnet.ibm.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-09-10KVM: s390: infrastructure to kick vcpus out of guest stateChristian Ehrhardt
To ensure vcpu's come out of guest context in certain cases this patch adds a s390 specific way to kick them out of guest context. Currently it kicks them out to rerun the vcpu_run path in the s390 code, but the mechanism itself is expandable and with a new flag we could also add e.g. kicks to userspace etc. Signed-off-by: Christian Ehrhardt <ehrhardt@linux.vnet.ibm.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-06-28KVM: s390: Allow stfle instruction in the guestChristian Borntraeger
2.6.31-rc introduced an architecture level set checker based on facility bits. e.g. if the kernel is compiled to run only on z9, several facility bits are checked very early and the kernel refuses to boot if a z9 specific facility is missing. Until now kvm on s390 did not implement the store facility extended (STFLE) instruction. A 2.6.31-rc kernel that was compiled for z9 or higher did not boot in kvm. This patch implements stfle. This patch should go in before 2.6.31. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-06-10KVM: s390: use hrtimer for clock wakeup from idle - v2Christian Borntraeger
This patch reworks the s390 clock comparator wakeup to hrtimer. The clock comparator is a per-cpu value that is compared against the TOD clock. If ckc <= TOD an external interrupt 1004 is triggered. Since the clock comparator and the TOD clock have a much higher resolution than jiffies we should use hrtimers to trigger the wakeup. This speeds up guest nanosleep for small values. Since hrtimers callbacks run in hard-irq context, I added a tasklet to do the actual work with enabled interrupts. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Christian Ehrhardt <ehrhardt@de.ibm.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-04-14[S390] s390: move machine flags to lowcoreChristian Ehrhardt
Currently the storage of the machine flags is a globally exported unsigned long long variable. By moving the storage location into the lowcore struct we allow assembler code to check machine_flags directly even without needing a register. Addtionally the lowcore and therefore the machine flags too will be in cache most of the time. Signed-off-by: Christian Ehrhardt <ehrhardt@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-03-24KVM: Remove old kvm_guest_debug structsJan Kiszka
Remove the remaining arch fragments of the old guest debug interface that now break non-x86 builds. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-08-01[S390] move include/asm-s390 to arch/s390/include/asmMartin Schwidefsky
