path: root/arch/ppc64/kernel/pci.c
2005-11-14powerpc: Move most remaining ppc64 files over to arch/powerpcPaul Mackerras
Also deletes files in arch/ppc64 that are no longer used now that we don't compile with ARCH=ppc64 any more. Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-11-10powerpc: fix iSeries buildStephen Rothwell
Only MULTIPLATFORM has phbs_remap_io. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au>
2005-11-10[PATCH] ppc64: fix PCI IO mappingBenjamin Herrenschmidt
phbs_remap_io(), which maps the PCI IO space into the kernel virtual space, is called too early on powermac, and thus doesn't work. This fixes it by removing the call from all platforms and putting it back into the ppc64 common code where it belongs, after the actual probing of the bus. That means that before that call, only the ISA IO space (if any) is mapped, any PIO access (from quirks for example) will fail. This happens not to be a problem for now, but we'll have to rework that code if it becomes one in the future. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-11-10[PATCH] powerpc: merge code values for identifying platformsPaul Mackerras
This patch merges platform codes. systemcfg->platform is no longer used, systemcfg use in general is deprecated as much as possible (and renamed _systemcfg before it gets completely moved elsewhere in a future patch), _machine is now used on ppc64 along as ppc32. Platform codes aren't gone yet but we are getting a step closer. A bunch of asm code in head[_64].S is also turned into C code. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-11-07[PATCH] dlpar enable for OF pci probeJohn Rose
This patch contains the arch/ppc64 bits for enabling DLPAR and PCI Hotplug for the new OF-based PCI probe mechanism. This code path is currently broken. Signed-off-by: John Rose <johnrose@austin.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-10-29[PATCH] ppc: make phys_mem_access_prot() work with pfns instead of addressesRoland Dreier
Change the phys_mem_access_prot() function to take a pfn instead of an address. This allows mmap64() to work on /dev/mem for addresses above 4G on 32-bit architectures. We start with a pfn in mmap_mem(), so there's no need to convert to an address; in fact, it's actively bad, since the conversion can overflow when the address is above 4G. Similarly fix the ppc32 page_is_ram() function to avoid a conversion to an address by directly comparing to max_pfn. Working with max_pfn instead of high_memory fixes page_is_ram() to give the right answer for highmem pages. Signed-off-by: Roland Dreier <rolandd@cisco.com> Cc: Anton Blanchard <anton@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-10-22ppc64: Add a `primary' argument to pci_process_bridge_OF_rangesPaul Mackerras
... for consistency with ppc32 and to make the powermac merge easier. Also make it use just a single resource in the host bridge for multiple consecutive elements of the ranges property. Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-09-28powerpc: Move iSeries_pci.c to powerpc/platform/iseriesStephen Rothwell
and rename it to pci.c. This also required moving arch/ppc64/kernel/pci.h into include/asm-powerpc (called ppc-pci.h. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au>
2005-09-21[PATCH] ppc64: Fix PCI flags when using OF device treePaul Mackerras
My code to set up the PCI tree from the Open Firmware device tree was setting IORESOURCE_* flags on the resources for the devices, but not the PCI_BASE_ADDRESS_* flags. This meant that some drivers misbehaved, and /proc/pci showed the wrong types for the resources. This fixes it. Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-12ppc64: Set up PCI tree from Open Firmware device treePaul Mackerras
This adds code which gives us the option on ppc64 of instantiating the PCI tree (the tree of pci_bus and pci_dev structs) from the Open Firmware device tree rather than by probing PCI configuration space. The OF device tree has a node for each PCI device and bridge in the system, with properties that tell us what addresses the firmware has configured for them and other details. There are a couple of reasons why this is needed. First, on systems with a hypervisor, there is a PCI-PCI bridge per slot under the PCI host bridges. These PCI-PCI bridges have special isolation features for virtualization. We can't write to their config space, and we are not supposed to be reading their config space either. The firmware tells us about the address ranges that they pass in the OF device tree. Secondly, on powermacs, the interrupt controller is in a PCI device that may be behind a PCI-PCI bridge. If we happened to take an interrupt just at the point when the device or a bridge on the path to it was disabled for probing, we would crash when we try to access the interrupt controller. I have implemented a platform-specific function which is called for each PCI bridge (host or PCI-PCI) to say whether the code should look in the device tree or use normal PCI probing for the devices under that bridge. On pSeries machines we use the device tree if we're running under a hypervisor, otherwise we use normal probing. On powermacs we use normal probing for the AGP bridge, since the device for the AGP bridge itself isn't shown in the device tree (at least on my G5), and the device tree for everything else. This has been tested on a dual G5 powermac, a partition on a POWER5 machine (running under the hypervisor), and a legacy iSeries partition. Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-09-09Allow PCI config space syscalls to be used by 64-bit processes.Paul Mackerras
The pciconfig_iobase, pciconfig_read and pciconfig_write system calls were only implemented for 32-bit processes; for 64-bit processes they returned an ENOSYS error. This allows them to be used by 64-bit processes as well. The X server uses pciconfig_iobase at least, and this change is necessary to allow a 64-bit X server to work on my G5. Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-09-09[PATCH] Separate pci bits out of struct device_nodePaul Mackerras
This patch pulls the PCI-related junk out of struct device_node and puts it in a separate structure, struct pci_dn. The device_node now just has a void * pointer in it, which points to a struct pci_dn for nodes that represent PCI devices. It could potentially be used in future for device-specific data for other sorts of devices, such as virtual I/O devices. Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-09-08[PATCH] PCI: remove CONFIG_PCI_NAMESAdrian Bunk
This patch removes CONFIG_PCI_NAMES. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-08-04[PATCH] pci and yenta: pcibios_bus_to_resourceDominik Brodowski
In yenta_socket, we default to using the resource setting of the CardBus bridge. However, this is a PCI-bus-centric view of resources and thus needs to be converted to generic resources first. Therefore, add a call to pcibios_bus_to_resource() call in between. This function is a mere wrapper on x86 and friends, however on some others it already exists, is added in this patch (alpha, arm, ppc, ppc64) or still needs to be provided (parisc -- where is its pcibios_resource_to_bus() ?). Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-27[PATCH] PCI: fix-pci-mmap-on-ppc-and-ppc64.patchMichael Ellerman
This is an updated version of Ben's fix-pci-mmap-on-ppc-and-ppc64.patch which is in 2.6.12-rc4-mm1. It fixes the patch to work on PPC iSeries, removes some debug printks at Ben's request, and incorporates your fix-pci-mmap-on-ppc-and-ppc64-fix.patch also. Originally from Benjamin Herrenschmidt <benh@kernel.crashing.org> This patch was discussed at length on linux-pci and so far, the last iteration of it didn't raise any comment. It's effect is a nop on architecture that don't define the new pci_resource_to_user() callback anyway. It allows architecture like ppc who put weird things inside of PCI resource structures to convert to some different value for user visible ones. It also fixes mmap'ing of IO space on those archs. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-23[PATCH] pSeries - read irqs dynamicallyJohn Rose
For I/O DLPAR to work properly, the kernel needs to allow for dynamic assignment of the irq field of the pci_dev structure upon dynamic bus addition. This patch moves the assignment of that field from pSeries_final_fixup() to pcibios_fixup_bus(), which enables dynamic assignment for the children of a newly added bus. Currently, pci_devs receive their irq numbers in one of two ways. The irq line is either read at boot for all pci_devs, or read by the rpaphp module at slot enable time. The latter is no longer sufficient for DLPAR addition of slots that don't qualify as PCI-hotplug capable. This solution handles the cases of boot and dynamic add. Signed-off-by: John Rose <johnrose@austin.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-06-20[PATCH] Driver Core: arch: update device attribute callbacksYani Ioannou
Signed-off-by: Yani Ioannou <yani.ioannou@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-05-05[PATCH] ppc64: pgtable.h and other header cleanupsDavid Gibson
This patch started as simply removing a few never-used macros from asm-ppc64/pgtable.h, then kind of grew. It now makes a bunch of cleanups to the ppc64 low-level header files (with corresponding changes to .c files where necessary) such as: - Abolishing never-used macros - Eliminating multiple #defines with the same purpose - Removing pointless macros (cases where just expanding the macro everywhere turns out clearer and more sensible) - Removing some cases where macros which could be defined in terms of each other weren't - Moving imalloc() related definitions from pgtable.h to their own header file (imalloc.h) - Re-arranging headers to group things more logically - Moving all VSID allocation related things to mmu.h, instead of being split between mmu.h and mmu_context.h - Removing some reserved space for flags from the PMD - we're not using it. - Fix some bugs which broke compile with STRICT_MM_TYPECHECKS. Signed-off-by: David Gibson <dwg@au1.ibm.com> Acked-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] ppc64: Fix semantics of __ioremapBenjamin Herrenschmidt
This patch fixes ppc64 __ioremap() so that it stops adding implicitely _PAGE_GUARDED when the cache is not writeback, and instead, let the callers provide the flag they want here. This allows things like framebuffers to explicitely request a non-cacheable and non-guarded mapping which is more efficient for that type of memory without side effects. The patch also fixes all current callers to add _PAGE_GUARDED except btext, which is fine without it. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
