path: root/arch/ppc/platforms/pmac_time.c
2006-01-15[PATCH] ppc: Remove powermac support from ARCH=ppcPaul Mackerras
This makes it possible to build kernels for PReP and/or CHRP with ARCH=ppc by removing the (non-building) powermac support. It's now also possible to select PReP and CHRP independently. Powermac users should now build with ARCH=powerpc instead of ARCH=ppc. (This does mean that it is no longer possible to build a 32-bit kernel for a G5.) Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-10-12Merge from Linus' treePaul Mackerras
2005-10-05[PATCH] ppc: Fix timekeeping with HZ=250 on some Mac modelsBenjamin Herrenschmidt
Older Macs which uses the VIA chip timers to calibrate the timebase used some code that wouldn't work if HZ wasn't divisible by 100... This fixes it at least for 250. Not totally perfect but should be enough for now (so it at least works with the default value which is now 250). There is still a potential issue with the core using CLOCK_TICK_RATE to maintain xtime and CLOCK_TICK_RATE value on ppc32 is pure crap, but that is a different problem, this patch at least brings us back to our previous situation. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-19[PATCH] powerpc: Remove sections use from ppcJon Loeliger
Here is a new patch that removes all notion of the pmac, prep, chrp and openfirmware initialization sections, and then unifies the sections.h files without those __pmac, etc, sections identifiers cluttering things up. Signed-off-by: Jon Loeliger <jdl@freescale.com> Signed-off-by: Kumar Gala <kumar.gala@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-06-27[PATCH] ppc32: Remove CONFIG_PMAC_PBOOKBenjamin Herrenschmidt
This patch removes CONFIG_PMAC_PBOOK (PowerBook support). This is now split into CONFIG_PMAC_MEDIABAY for the actual hotswap bay that some powerbooks have, CONFIG_PM for power management related code, and just left out of any CONFIG_* option for some generally useful stuff that can be used on non-laptops as well. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-24[PATCH] ppc trivial iomem annotations: pmac_time.cAl Viro
Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
