This patch updates percpu related symbols in powerpc such that percpu
symbols are unique and don't clash with local symbols. This serves
two purposes of decreasing the possibility of global percpu symbol
collision and allowing dropping per_cpu__ prefix from percpu symbols.
* arch/powerpc/kernel/perf_callchain.c: s/callchain/cpu_perf_callchain/
* arch/powerpc/kernel/setup-common.c: s/pvr/cpu_pvr/
* arch/powerpc/platforms/pseries/dtl.c: s/dtl/cpu_dtl/
* arch/powerpc/platforms/cell/interrupt.c: s/iic/cpu_iic/
Partly based on Rusty Russell's "alloc_percpu: rename percpu vars
which cause name clashes" patch.
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Cc: linuxppc-dev@ozlabs.org
[akpm@linux-foundation.org: fix KVM]
* mark struct vm_area_struct::vm_ops as const
* mark vm_ops in AGP code
But leave TTM code alone, something is fishy there with global vm_ops
being used.
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
* 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc:
Fix build of cpm_uart due to core changes
powerpc/8xx: Fix regression introduced by cache coherency rewrite
powerpc/4xx: Fix erroneous xmon warning on PowerPC 4xx
powerpc/mm: Fix 40x and 8xx vs. _PAGE_SPECIAL
powerpc: Cleanup linker script using new linker script macros.
powerpc: Fix ibm,client-architecture-support printout
powerpc: Increase NODES_SHIFT on 64bit from 4 to 8
powerpc/perf_counter: Fix vdso detection
powerpc: Move 64bit heap above 1TB on machines with 1TB segments
powerpc: Change archdata dma_data to a union
powerpc: Rename get_dma_direct_offset get_dma_offset
powerpc/mm: Remove duplicated #include
powerpc/book3e-64: Remove duplicated #include
powerpc: Check for unsupported relocs when using CONFIG_RELOCATABLE
powerpc/pmc: Don't access lppaca on Book3E
powerpc: kmalloc failure ignored in vio_build_iommu_table()
hvc_console: Provide (un)locked version for hvc_resize()
Signed-off-by: Tim Abbott <tabbott@ksplice.com>
Acked-by: Sam Ravnborg <sam@ravnborg.org>
* 'for-linus' of git://neil.brown.name/md: (97 commits)
md: raid-1/10: fix RW bits manipulation
md: remove unnecessary memset from multipath.
md: report device as congested when suspended
md: Improve name of threads created by md_register_thread
md: remove sparse warnings about lock context.
md: remove sparse waring "symbol xxx shadows an earlier one"
async_tx/raid6: add missing dma_unmap calls to the async fail case
ioat3: fix uninitialized var warnings
drivers/dma/ioat/dma_v2.c: fix warnings
raid6test: fix stack overflow
ioat2: clarify ring size limits
md/raid6: cleanup ops_run_compute6_2
md/raid6: eliminate BUG_ON with side effect
dca: module load should not be an error message
ioat: driver version 4.0
dca: registering requesters in multiple dca domains
async_tx: remove HIGHMEM64G restriction
dmaengine: sh: Add Support SuperH DMA Engine driver
dmaengine: Move all map_sg/unmap_sg for slave channel to its client
fsldma: Add DMA_SLAVE support
After upgrading to the latest kernel on my mpc875 userspace started
running incredibly slow (hours to get to a shell, even!).
I tracked it down to commit 8d30c14cab30d405a05f2aaceda1e9ad57800f36,
that patch removed a work-around for the 8xx. Adding it
back makes my problem go away.
Signed-off-by: Rex Feany <rfeany@mrv.com>
The xmon code relies on MSR_RI being non-zero to indicate that an exception
is recoverable. If it is not, it prints a warning message. However, the
PowerPC 4xx cores do not have an MSR_RI bit and this warning is produced for
every xmon event.
This introduces an unrecoverable_excp function to determine if an exception
is recoverable or not. This gets rid of the erroneous warnings on 4xx.
Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
The test to check whether we have _PAGE_SPECIAL defined is broken,
since we always define it, just not always to a meaninful value :-)
That broke 8xx and 40x under some circumstances.
This fixes it by adding _PAGE_SPECIAL for both of these since they
had a free PTE bit, and removing the condition around advertising
it.
On machines without the ibm,client-architecture-support call we were missing a
newline. We may as well print the full name in all its glory too - its
ibm,client-architecture-support, not ibm,client-architecture as I mistakenly
wrote (a name only an IBM architect could love).
For my penance I will write out ibm,client-architecture-support 100 times.
Before:
Calling ibm,client-architecture...command line: root=/dev/sda6 console=hvc0 quiet
After:
Calling ibm,client-architecture-support... not implemented
Some System p configurations can already have more than 16 nodes so we
need to increase NODES_SHIFT. I chose 256 to give us some room to grow in the
future, although we can look at something smaller if the memory bloat is
considered too much.
Unless we clamp MAX_ACTIVE_REGIONS we end up with 300kB of extra bloat in
early_node_map in mm/page_alloc.c:
< 6144 early_node_map
> 307200 early_node_map
due to:
#if MAX_NUMNODES >= 32
/* If there can be many nodes, allow up to 50 holes per node */
#define MAX_ACTIVE_REGIONS (MAX_NUMNODES*50)
#else
/* By default, allow up to 256 distinct regions */
#define MAX_ACTIVE_REGIONS 256
Since our memory is mostly contiguous it seems reasonable to keep this
at 256 for now. I also set 32bit to 32 to save space (is there any chance
a 32bit system will have more than 32 discontiguous memory ranges?).
Even with that fixed we have a few data structures that grow:
< 896 bootmem_node_data
> 14336 bootmem_node_data
< 1280 node_devices
> 20480 node_devices
< 25088 kmalloc_caches
> 59648 kmalloc_caches
< 1632 hstates
> 21792 hstates
perf_counter uses arch_vma_name() to detect a vdso region which in turn uses
current->mm->context.vdso_base. We need to initialise this before doing
the mmap or else we fail to detect the vdso.
If we are using 1TB segments and we are allowed to randomise the heap, we can
put it above 1TB so it is backed by a 1TB segment. Otherwise the heap will be
in the bottom 1TB which always uses 256MB segments and this may result in a
performance penalty.
This functionality is disabled when heap randomisation is turned off:
echo 1 > /proc/sys/kernel/randomize_va_space
which may be useful when trying to allocate the maximum amount of 16M or 16G
pages.
On a microbenchmark that repeatedly touches 32GB of memory with a stride of
256MB + 4kB (designed to stress 256MB segments while still mapping nicely into
the L1 cache), we see the improvement:
Force malloc to use heap all the time:
# export MALLOC_MMAP_MAX_=0 MALLOC_TRIM_THRESHOLD_=-1
Disable heap randomization:
# echo 1 > /proc/sys/kernel/randomize_va_space
# time ./test
12.51s
Enable heap randomization:
# echo 2 > /proc/sys/kernel/randomize_va_space
# time ./test
1.70s
Sometimes this is used to hold a simple offset, and sometimes
it is used to hold a pointer. This patch changes it to a union containing
void * and dma_addr_t. get/set accessors are also provided, because it was
getting a bit ugly to get to the actual data.
Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
The former is no longer really accurate with the swiotlb case now
a possibility. I also move it into dma-mapping.h - it no longer
needs to be in dma.c, and there are about to be some more accessors
that should all end up in the same place. A comment is added to
indicate that this function is not used in configs where there is no
simple dma offset, such as the iommu case.
Remove duplicated #include('s) in
arch/powerpc/mm/tlb_low_64e.S
Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com>
arch/powerpc/kernel/exceptions-64e.S
When using CONFIG_RELOCATABLE, we build the kernel as a position
independent executable. The kernel then uses a little bit of relocation
code to relocate itself. That code only deals with R_PPC64_RELATIVE
relocations though. If for some reason you use assembly constructs
such as LOAD_REG_IMMEDIATE() to load the address of a symbol, you'll
generate different kinds of relocations that won't be processed properly
and bad things will happen. (We have 2 such bugs today).
The perl script tries to filter out "known" bad ones. It's possible
that we are missing some in the case of a weak function that nobody
implements, we'll see if we get false positive and fix it.
Signed-off-by: Tony Breeds <tony@bakeyournoodle.com>
It doesn't exist !
Prevent NULL dereference if kmalloc() fails.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: (39 commits)
cpumask: Move deprecated functions to end of header.
cpumask: remove unused deprecated functions, avoid accusations of insanity
cpumask: use new-style cpumask ops in mm/quicklist.
cpumask: use mm_cpumask() wrapper: x86
cpumask: use mm_cpumask() wrapper: um
cpumask: use mm_cpumask() wrapper: mips
cpumask: use mm_cpumask() wrapper: mn10300
cpumask: use mm_cpumask() wrapper: m32r
cpumask: use mm_cpumask() wrapper: arm
cpumask: Use accessors for cpu_*_mask: um
cpumask: Use accessors for cpu_*_mask: powerpc
cpumask: Use accessors for cpu_*_mask: mips
cpumask: Use accessors for cpu_*_mask: m32r
cpumask: remove arch_send_call_function_ipi
cpumask: arch_send_call_function_ipi_mask: s390
cpumask: arch_send_call_function_ipi_mask: powerpc
cpumask: arch_send_call_function_ipi_mask: mips
cpumask: arch_send_call_function_ipi_mask: m32r
cpumask: arch_send_call_function_ipi_mask: alpha
cpumask: remove obsolete topology_core_siblings and topology_thread_siblings: ia64
* remove asm/atomic.h inclusion from linux/utsname.h --
not needed after kref conversion
* remove linux/utsname.h inclusion from files which do not need it
NOTE: it looks like fs/binfmt_elf.c do not need utsname.h, however
due to some personality stuff it _is_ needed -- cowardly leave ELF-related
headers and files alone.
Use the accessors rather than frobbing bits directly (the new versions
are const).
Signed-off-by: Mike Travis <travis@sgi.com>
Now everyone is converted to arch_send_call_function_ipi_mask, remove
the shim and the #defines.
We're weaning the core code off handing cpumask's around on-stack.
This introduces arch_send_call_function_ipi_mask(), and by defining
it, the old arch_send_call_function_ipi is defined by the core code.
topology_thread_siblings: powerpc
There were replaced by topology_core_cpumask and topology_thread_cpumask.
cpumask_of_pcibus() is the new version.
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-next: (30 commits)
Use macros for .data.page_aligned section.
Use macros for .bss.page_aligned section.
Use new __init_task_data macro in arch init_task.c files.
kbuild: Don't define ALIGN and ENTRY when preprocessing linker scripts.
arm, cris, mips, sparc, powerpc, um, xtensa: fix build with bash 4.0
kbuild: add static to prototypes
kbuild: fail build if recordmcount.pl fails
kbuild: set -fconserve-stack option for gcc 4.5
kbuild: echo the record_mcount command
gconfig: disable "typeahead find" search in treeviews
kbuild: fix cc1 options check to ensure we do not use -fPIC when compiling
checkincludes.pl: add option to remove duplicates in place
markup_oops: use modinfo to avoid confusion with underscored module names
checkincludes.pl: provide usage helper
checkincludes.pl: close file as soon as we're done with it
ctags: usability fix
kernel hacking: move STRIP_ASM_SYMS from General
gitignore usr/initramfs_data.cpio.bz2 and usr/initramfs_data.cpio.lzma
kbuild: Check if linker supports the -X option
kbuild: introduce ld-option
Fix trivial conflict in scripts/basic/fixdep.c
* 'timers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
itimers: Add tracepoints for itimer
hrtimer: Add tracepoint for hrtimers
timers: Add tracepoints for timer_list timers
cputime: Optimize jiffies_to_cputime(1)
itimers: Simplify arm_timer() code a bit
itimers: Fix periodic tics precision
itimers: Merge ITIMER_VIRT and ITIMER_PROF
Trivial header file include conflicts in kernel/fork.c
For /proc/kcore, each arch registers its memory range by kclist_add().
In usual,
- range of physical memory
- range of vmalloc area
- text, etc...
are registered but "range of physical memory" has some troubles. It
doesn't updated at memory hotplug and it tend to include unnecessary
memory holes. Now, /proc/iomem (kernel/resource.c) includes required
physical memory range information and it's properly updated at memory
hotplug. Then, it's good to avoid using its own code(duplicating
information) and to rebuild kclist for physical memory based on
/proc/iomem.
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
Cc: WANG Cong <xiyou.wangcong@gmail.com>
Originally, walk_memory_resource() was introduced to traverse all memory
of "System RAM" for detecting memory hotplug/unplug range. For doing so,
flags of IORESOUCE_MEM|IORESOURCE_BUSY was used and this was enough for
memory hotplug.
But for using other purpose, /proc/kcore, this may includes some firmware
area marked as IORESOURCE_BUSY | IORESOUCE_MEM. This patch makes the
check strict to find out busy "System RAM".
Note: PPC64 keeps their own walk_memory_resouce(), which walk through
ppc64's lmb informaton. Because old kclist_add() is called per lmb, this
patch makes no difference in behavior, finally.
And this patch removes CONFIG_MEMORY_HOTPLUG check from this function.
Because pfn_valid() just show "there is memmap or not* and cannot be used
for "there is physical memory or not", this function is useful in generic
to scan physical memory range.
Cc: Américo Wang <xiyou.wangcong@gmail.com>
Cc: Roland Dreier <rolandd@cisco.com>
For /proc/kcore, vmalloc areas are registered per arch. But, all of them
registers same range of [VMALLOC_START...VMALLOC_END) This patch unifies
them. By this. archs which have no kclist_add() hooks can see vmalloc
area correctly.
Presently, kclist_add() only eats start address and size as its arguments.
Considering to make kclist dynamically reconfigulable, it's necessary to
know which kclists are for System RAM and which are not.
This patch add kclist types as
KCORE_RAM
KCORE_VMALLOC
KCORE_TEXT
KCORE_OTHER
This "type" is used in a patch following this for detecting KCORE_RAM.
eSDHC block in MPC837x SOCs reports inverted write-protect state, soon
sdhci-of driver will look for sdhci,wp-inverted properties to decide
whether apply a specific quirk.
So, document the property and add it to device tree source files.
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
Cc: Pierre Ossman <pierre@ossman.eu>
Cc: Kumar Gala <galak@kernel.crashing.org>
Cc: David Vrabel <david.vrabel@csr.com>
Cc: Ben Dooks <ben@fluff.org>
Cc: Sascha Hauer <s.hauer@pengutronix.de>
Cc: <linux-mmc@vger.kernel.org>
Make all seq_operations structs const, to help mitigate against
revectoring user-triggerable function pointers.
This is derived from the grsecurity patch, although generated from scratch
because it's simpler than extracting the changes from there.
Signed-off-by: James Morris <jmorris@namei.org>
Acked-by: Serge Hallyn <serue@us.ibm.com>
Acked-by: Casey Schaufler <casey@schaufler-ca.com>
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx into for-linus
* 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
perf_event, powerpc: Fix compilation after big perf_counter rename
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (34 commits)
trivial: fix typo in aic7xxx comment
trivial: fix comment typo in drivers/ata/pata_hpt37x.c
trivial: typo in kernel-parameters.txt
trivial: fix typo in tracing documentation
trivial: add __init/__exit macros in drivers/gpio/bt8xxgpio.c
trivial: add __init macro/ fix of __exit macro location in ipmi_poweroff.c
trivial: remove unnecessary semicolons
trivial: Fix duplicated word "options" in comment
trivial: kbuild: remove extraneous blank line after declaration of usage()
trivial: improve help text for mm debug config options
trivial: doc: hpfall: accept disk device to unload as argument
trivial: doc: hpfall: reduce risk that hpfall can do harm
trivial: SubmittingPatches: Fix reference to renumbered step
trivial: fix typos "man[ae]g?ment" -> "management"
trivial: media/video/cx88: add __init/__exit macros to cx88 drivers
trivial: fix typo in CONFIG_DEBUG_FS in gcov doc
trivial: fix missing printk space in amd_k7_smp_check
trivial: fix typo s/ketymap/keymap/ in comment
trivial: fix typo "to to" in multiple files
trivial: fix typos in comments s/DGBU/DBGU/
Add a flag for mmap that will be used to request a huge page region that
will look like anonymous memory to user space. This is accomplished by
using a file on the internal vfsmount. MAP_HUGETLB is a modifier of
MAP_ANONYMOUS and so must be specified with it. The region will behave
the same as a MAP_ANONYMOUS region using small pages.
The patch also adds the MAP_STACK flag, which was previously defined only
on some architectures but not on others. Since MAP_STACK is meant to be a
hint only, architectures can define it without assigning a specific
meaning to it.
Cc: Eric B Munson <ebmunson@us.ibm.com>
Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk>
Cc: <linux-arch@vger.kernel.org>
Commit 96177299416dbccb73b54e6b344260154a445375 ("Drop free_pages()")
modified nr_free_pages() to return 'unsigned long' instead of 'unsigned
int'. This made the casts to 'unsigned long' in most callers superfluous,
so remove them.
Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com>
Reviewed-by: Christoph Lameter <cl@linux-foundation.org>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Acked-by: Kyle McMartin <kyle@mcmartin.ca>
Acked-by: WANG Cong <xiyou.wangcong@gmail.com>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Haavard Skinnemoen <hskinnemoen@atmel.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Hirokazu Takata <takata@linux-m32r.org>
Cc: Chris Zankel <zankel@tensilica.com>
This fixes two places in the powerpc perf_event (perf_counter) code
where 'list_entry' needs to be changed to 'group_entry', but were
missed in commit 65abc865 ("perf_counter: Rename list_entry ->
group_entry, counter_list -> group_list").
This also changes 'event' back to 'counter' in a couple of
contexts:
* Field and function names that deal with the limited-function
counters: it's really the hardware counters whose function is
limited, not the events that they count. Hence:
MAX_LIMITED_HWEVENTS -> MAX_LIMITED_HWCOUNTERS
limited_event -> limited_counter
freeze/thaw_limited_events -> freeze/thaw_limited_counters
* The machine-specific PMU description struct (struct power_pmu): this
renames 'n_event' back to 'n_counter' since it really describes how
many hardware counters the machine has. (Renaming this back avoids
a compile error in each of the machine-specific PMU back-ends where
they initialize their power_pmu struct.)
LKML-Reference: <19128.4280.813369.589704@cargo.ozlabs.ibm.com>
* 'perfcounters-rename-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
perf: Tidy up after the big rename
perf: Do the big rename: Performance Counters -> Performance Events
perf_counter: Rename 'event' to event_id/hw_event
perf_counter: Rename list_entry -> group_entry, counter_list -> group_list
Manually resolved some fairly trivial conflicts with the tracing tree in
include/trace/ftrace.h and kernel/trace/trace_syscalls.c.
* 'perfcounters-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
perf_counter, powerpc, sparc: Fix compilation after perf_counter_overflow() change
perf_counter: x86: Fix PMU resource leak
perf util: SVG performance improvements
perf util: Make the timechart SVG width dynamic
perf timechart: Show the duration of scheduler delays in the SVG
perf timechart: Show the name of the waker/wakee in timechart
* 'tracing-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
kernel/profile.c: Switch /proc/irq/prof_cpu_mask to seq_file
tracing: Export trace_profile_buf symbols
tracing/events: use list_for_entry_continue
tracing: remove max_tracer_type_len
function-graph: use ftrace_graph_funcs directly
tracing: Remove markers
tracing: Allocate the ftrace event profile buffer dynamically
tracing: Factorize the events profile accounting
trivial: fix typo "for for" in multiple files
Signed-off-by: Anand Gadiyar <gadiyar@ti.com>
