path: root/arch/powerpc
2008-09-09lib: Correct printk %pF to work on all architecturesJames Bottomley
It was introduced by "vsprintf: add support for '%pS' and '%pF' pointer formats" in commit 0fe1ef24f7bd0020f29ffe287dfdb9ead33ca0b2. However, the current way its coded doesn't work on parisc64. For two reasons: 1) parisc isn't in the #ifdef and 2) parisc has a different format for function descriptors Make dereference_function_descriptor() more accommodating by allowing architecture overrides. I put the three overrides (for parisc64, ppc64 and ia64) in arch/kernel/module.c because that's where the kernel internal linker which knows how to deal with function descriptors sits. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Tony Luck <tony.luck@intel.com> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-08powerpc: Fix rare boot build breakageHugh Dickins
A make -j20 powerpc kernel build broke a couple of months ago saying: In file included from arch/powerpc/boot/gunzip_util.h:13, from arch/powerpc/boot/prpmc2800.c:21: arch/powerpc/boot/zlib.h:85: error: expected ‘:’, ‘,’, ‘;’, ‘}’ or ‘__attribute__’ before ‘*’ token arch/powerpc/boot/zlib.h:630: warning: type defaults to ‘int’ in declaration of ‘Byte’ arch/powerpc/boot/zlib.h:630: error: expected ‘;’, ‘,’ or ‘)’ before ‘*’ token It happened again yesterday: too rare for me to confirm the fix, but it looks like the list of dependants on gunzip_util.h was incomplete. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-09-08powerpc/spufs: Fix possible scheduling of a context to multiple SPEsAndre Detsch
We currently have a race when scheduling a context to a SPE - after we have found a runnable context in spusched_tick, the same context may have been scheduled by spu_activate(). This may result in a panic if we try to unschedule a context that has been freed in the meantime. This change exits spu_schedule() if the context has already been scheduled, so we don't end up scheduling it twice. Signed-off-by: Andre Detsch <adetsch@br.ibm.com> Signed-off-by: Jeremy Kerr <jk@ozlabs.org>
2008-09-05powerpc/spufs: Fix race for a free SPUJeremy Kerr
We currently have a race for a free SPE. With one thread doing a spu_yield(), and another doing a spu_activate(): thread 1 thread 2 spu_yield(oldctx) spu_activate(ctx) __spu_deactivate(oldctx) spu_unschedule(oldctx, spu) spu->alloc_state = SPU_FREE spu = spu_get_idle(ctx) - searches for a SPE in state SPU_FREE, gets the context just freed by thread 1 spu_schedule(ctx, spu) spu->alloc_state = SPU_USED spu_schedule(newctx, spu) - assumes spu is still free - tries to schedule context on already-used spu This change introduces a 'free_spu' flag to spu_unschedule, to indicate whether or not the function should free the spu after descheduling the context. We only set this flag if we're not going to re-schedule another context on this SPU. Add a comment to document this behaviour. Signed-off-by: Jeremy Kerr <jk@ozlabs.org>
2008-09-05powerpc/spufs: Fix multiple get_spu_context()Jeremy Kerr
Commit 8d5636fbca202f61fdb808fc9e20c0142291d802 introduced a reference count on SPU contexts during find_victim, but this may cause a leak in the reference count if we later find a better contender for a context to unschedule. Change the reference to after we've found our victim context, so we don't do the extra get_spu_context(). Signed-off-by: Jeremy Kerr <jk@ozlabs.org>
2008-09-03powerpc: Fix for getting CPU number in power_save_ppc32_restore()Kumar Gala
The calculation to get TI_CPU based off of SPRG3 was just plain wrong, meaning that we were getting garbage for the CPU number on 6xx/G3/G4 based SMP boxes in this code. Just offset off the stack pointer (to get to thread_info) like all the other references to TI_CPU do. This was pointed out by Chen Gong <G.Chen@freescale.com> [paulus@samba.org - use rlwinm r12,r11,... instead of rlwinm r12,r1,...; tophys()] Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-09-03powerpc: Fix build error with 64K pages and !hugetlbfsBenjamin Herrenschmidt
HAVE_ARCH_UNMAPPED_AREA and HAVE_ARCH_UNMAPPED_AREA_TOPDOWN must be defined whenever CONFIG_PPC_MM_SLICES is enabled, not just when CONFIG_HUGETLB_PAGE is. They used to be always defined together but this is no longer the case since 3a8247cc2c856930f34eafce33f6a039227ee175 ("powerpc: Only demote individual slices rather than whole process"). Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-09-03powerpc: Work around gcc's -fno-omit-frame-pointer bugTony Breeds
This bug is causing random crashes (http://bugzilla.kernel.org/show_bug.cgi?id=11414). -fno-omit-frame-pointer is only needed on powerpc when -pg is also supplied, and there is a gcc bug that causes incorrect code generation on 32-bit powerpc when -fno-omit-frame-pointer is used---it uses stack locations below the stack pointer, which is not allowed by the ABI because those locations can and sometimes do get corrupted by an interrupt. This ensures that CONFIG_FRAME_POINTER is only selected by ftrace. When CONFIG_FTRACE is enabled we also pass -mno-sched-epilog to work around the gcc codegen bug. Patch based on work by: Andreas Schwab <schwab@suse.de> Segher Boessenkool <segher@kernel.crashing.org> Signed-off-by: Tony Breeds <tony@bakeyournoodle.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-09-03powerpc: Make sure _etext is after all kernel textStephen Rothwell
This makes core_kernel_text() (and therefore kernel_text_address()) return the correct result. Currently all the __devinit routines (at least) will not be considered to be kernel text. This is just a quick fix for 2.6.27 - hopefully we will be able to fix this better in 2.6.28. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-09-03powerpc: Only make kernel text pages of linear mapping executablePaul Mackerras
Commit bc033b63bbfeb6c4b4eb0a1d083c650e4a0d2af8 ("powerpc/mm: Fix attribute confusion with htab_bolt_mapping()") moved the check for whether we should make pages of the linear mapping executable from htab_bolt_mapping into its callers, including htab_initialize. A side-effect of this is that the decision is now made once for each contiguous section in the LMB array rather than for each page individually. This can often mean that the whole of the linear mapping ends up being executable. This reverts to the previous behaviour, where individual pages are checked for being part of the kernel text or not, by moving the check back down into htab_bolt_mapping. Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-09-03powerpc: Fix uninitialised variable in VSX alignment codeMichael Neuling
This fixes an uninitialised variable in the VSX alignment code. It can cause warnings from GCC (noticed with gcc-4.1.1). Gcc is actually correct in this instance, and this bug could cause the alignment interrupt handler to send a SIGSEGV to the process on a legitimate access. Signed-off-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-08-27Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (55 commits) sctp: fix random memory dereference with SCTP_HMAC_IDENT option. sctp: correct bounds check in sctp_setsockopt_auth_key wan: Missing capability checks in sbni_ioctl() e100, fix iomap read qeth: preallocated header account offset qeth: l2 write unicast list to hardware qeth: use -EOPNOTSUPP instead of -ENOTSUPP. ibm_newemac: Don't call dev_mc_add() before device is registered net: don't grab a mutex within a timer context in gianfar forcedeth: fix checksum flag net/usb/mcs7830: add set_mac_address net/usb/mcs7830: new device IDs [netdrvr] smc91x: fix resource removal (null ptr deref) ibmveth: fix bad UDP checksums [netdrvr] hso: dev_kfree_skb crash fix [netdrvr] hso: icon 322 detection fix atl1: disable TSO by default atl1e: multistatement if missing braces igb: remove 82576 quad adapter drivers/net/skfp/ess.c: fix compile warnings ...
2008-08-27fs_enet: Fix SCC Ethernet on CPM2, and crash in fs_enet_rx_napi()Heiko Schocher
Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Vitaly Bordug <vitb@kernel.crashing.org> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-08-26Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: powerpc: Update defconfigs for most non-embedded platforms powerpc: Export CMO_PageSize powerpc/ps3: Fix ioremap of spu shadow regs powerpc/ps3: Rework htab code to remove ioremap powerpc/ps3: Update ps3_defconfig powerpc/cell/oprofile: Avoid double vfree of profile buffer powerpc: Update defconfigs for FSL PPC boards powerpc: Add cuImage.mpc866ads to the bootwrapper as a cuboot-8xx target cpm2: Fix race condition in CPM2 GPIO library. powerpc: fix memory leaks in QE library powerpc/85xx: TQM8548: DTS file fixes and cleanup powerpc: Fix whitespace merge in mpc8641 hpcn device tree
2008-08-26powerpc: Update defconfigs for most non-embedded platformsPaul Mackerras
2008-08-26powerpc: Export CMO_PageSizeAndrew Morton
This fixes an error building powerpc allmodconfig: ERROR: "CMO_PageSize" [arch/powerpc/platforms/pseries/cmm.ko] undefined! Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-08-26powerpc/ps3: Fix ioremap of spu shadow regsMasakazu Mokuno
Fix the ioremap of the spu shadow regs on the PS3. The current PS3 hypervisor requires the spu shadow regs to be mapped with the PTE page protection bits set as read-only (PP=3). This implementation uses the low level __ioremap() to bypass the page protection settings inforced by ioremap_flags() to get the needed PTE bits set for the shadow regs. This fixes a runtime failure on the PS3 introduced by the powerpc ioremap_prot rework of commit a1f242ff460e4b50a045fa237c3c56cce9eabf83 ("powerpc ioremap_prot"). Signed-off-by: Masakazu Mokuno <mokuno@sm.sony.co.jp> CC: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-08-26powerpc/ps3: Rework htab code to remove ioremapMasakazu Mokuno
Rework the PS3 MMU hash table code to remove the need to ioremap the hash table by using the HV calls lv1_insert_htab_entry() and lv1_read_htab_entries(). This fixes a runtime failure on the PS3 introduced by the powerpc ioremap_prot rework of commit a1f242ff460e4b50a045fa237c3c56cce9eabf83 ("powerpc ioremap_prot"). Signed-off-by: Masakazu Mokuno <mokuno@sm.sony.co.jp> CC: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-08-26powerpc/ps3: Update ps3_defconfigGeoff Levand
Update ps3_defconfig. Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-08-23removed unused #include <linux/version.h>'sAdrian Bunk
This patch lets the files using linux/version.h match the files that #include it. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-21powerpc: Update defconfigs for FSL PPC boardsKumar Gala
Since we are updated defconfigs I went ahead and moved the asp8347_defconfig under 83xx/ and the mpc8536_ds_defconfig under 85xx/ as that is where they should have been to start with. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-08-21powerpc: Add cuImage.mpc866ads to the bootwrapper as a cuboot-8xx targetScott Wood
This patch fixes the following build error with mpc866_ads_defconfig: <-- snip --> ... WRAP arch/powerpc/boot/cuImage.mpc866ads powerpc64-linux-ld: arch/powerpc/boot/cuboot-mpc866ads.o: No such file: No such file or directory make[2]: *** [arch/powerpc/boot/cuImage.mpc866ads] Error 1 <-- snip --> Reported-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-08-21cpm2: Fix race condition in CPM2 GPIO library.Laurent Pinchart
The CPM2 GPIO library code uses the non thread-safe clrbits32/setbits32 macros. This patch protects them with a spinlock. Signed-off-by: Laurent Pinchart <laurentp@cse-semaphore.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-08-20powerpc: fix memory leaks in QE libraryTimur Tabi
Fix two memory leaks in the Freescale QE library: add a missing kfree() in ucc_fast_init() and ucc_slow_init() if the ioremap() fails, and update ucc_fast_free() and ucc_slow_free() to call iounmap() if necessary. Based on a patch from Tony Breeds <tony@bakeyournoodle.com>. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-08-20powerpc/85xx: TQM8548: DTS file fixes and cleanupWolfgang Grandegger
Due to the missing compatible property for the SOC, the MPC I2C buses are not found any more. This patch fixes this issue. Furthermore it corrects the name of the SOC node and adds the missing I2C node for the RTC. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-08-20powerpc: Fix whitespace merge in mpc8641 hpcn device treeKumar Gala
When we coverted the .dts to v1 we lost a space between the irq and its polarity/sense information. This causes a bit of chaos as the reset of the blob is off by one cell. This was noticed by booting and getting errors w/ATA due to lock of interrupts. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-08-20Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: powerpc: Fix vio_bus_probe oops on probe error powerpc/ibmebus: Restore "name" sysfs attribute on ibmebus devices powerpc: Fix /dev/oldmem interface for kdump powerpc/spufs: Remove invalid semicolon after if statement powerpc/spufs: reference context while dropping state mutex in scheduler powerpc/spufs: fix npc setting for NOSCHED contexts
2008-08-20powerpc: Fix vio_bus_probe oops on probe errorBrian King
When CMO is enabled and booted on a non CMO system and the VIO device's probe function fails, an oops can result since vio_cmo_bus_remove is called when it should not. This fixes it by avoiding the vio_cmo_bus_remove call on platforms that don't implement CMO. cpu 0x0: Vector: 300 (Data Access) at [c00000000e13b3d0] pc: c000000000020d34: .vio_cmo_bus_remove+0xc0/0x1f4 lr: c000000000020ca4: .vio_cmo_bus_remove+0x30/0x1f4 sp: c00000000e13b650 msr: 8000000000009032 dar: 0 dsisr: 40000000 current = 0xc00000000e0566c0 paca = 0xc0000000006f9b80 pid = 2428, comm = modprobe enter ? for help [c00000000e13b6e0] c000000000021d94 .vio_bus_probe+0x2f8/0x33c [c00000000e13b7a0] c00000000029fc88 .driver_probe_device+0x13c/0x200 [c00000000e13b830] c00000000029fdac .__driver_attach+0x60/0xa4 [c00000000e13b8c0] c00000000029f050 .bus_for_each_dev+0x80/0xd8 [c00000000e13b980] c00000000029f9ec .driver_attach+0x28/0x40 [c00000000e13ba00] c00000000029f630 .bus_add_driver+0xd4/0x284 [c00000000e13baa0] c0000000002a01bc .driver_register+0xc4/0x198 [c00000000e13bb50] c00000000002168c .vio_register_driver+0x40/0x5c [c00000000e13bbe0] d0000000003b3f1c .ibmvfc_module_init+0x70/0x109c [ibmvfc] [c00000000e13bc70] c0000000000acf08 .sys_init_module+0x184c/0x1a10 [c00000000e13be30] c000000000008748 syscall_exit+0x0/0x40 Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-08-20powerpc/ibmebus: Restore "name" sysfs attribute on ibmebus devicesJoachim Fenkes
Recent of_platform changes made of_bus_type_init() overwrite the bus type's .dev_attrs list, meaning that the "name" attribute that ibmebus devices previously had is no longer present. This is a user-visible regression which breaks the userspace eHCA support, since the eHCA userspace driver relies on the name attribute to check for valid adapters. This fixes it by providing the "name" attribute in the generic OF device code instead. Tested on POWER. Signed-off-by: Joachim Fenkes <fenkes@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-08-20powerpc: Fix /dev/oldmem interface for kdumpMichael Ellerman
A change to __ioremap() broke reading /dev/oldmem because we're no longer able to ioremap pfn 0 (d177c207, "[PATCH] powerpc: IOMMU: don't ioremap null addresses"). We actually don't need to ioremap for anything that's part of the linear mapping, so just read it directly. Also make sure we're only reading one page or less at a time. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Sachin Sant <sachinp@in.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-08-20Merge branch 'merge' of ↵Paul Mackerras
git://git.kernel.org/pub/scm/linux/kernel/git/jk/spufs into merge
2008-08-19powerpc/spufs: Remove invalid semicolon after if statementIlpo Järvinen
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: Jeremy Kerr <jk@ozlabs.org>
2008-08-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6: ata: add missing ATA_* defines ata: add missing ATA_CMD_* defines ata: add missing ATA_ID_* defines (take 2) sgiioc4: fixup message on resource allocation failure ide-cd: use bcd2bin/bin2bcd cdrom: handle TOC gdrom: add dummy audio_ioctl handler viocd: add dummy audio ioctl handler cleanup powerpc/include/asm/ide.h drivers/ide/pci/: use __devexit_p()
2008-08-18cleanup powerpc/include/asm/ide.hAdrian Bunk
This patch removes code that became unused through IDE changes and the arch/ppc/ removal. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-08-18powerpc: Use generic compat_sys_old_readdirChristoph Hellwig
Use the generic compat_sys_old_readdir instead of the powerpc one which is almost the same except for the almost complete lack of error handling. Note that we can't just use SYSCALL() in systbl.h because the native syscall is named old_readdir, not sys_old_readdir. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-08-18powerpc/kexec: Fix up KEXEC_CONTROL_CODE_SIZE missed during conversionPaul Collins
Commit 163f6876f5c3ff8215e900b93779e960a56b3694 missed one, resulting in the following compile error: AS arch/powerpc/kernel/misc_32.o arch/powerpc/kernel/misc_32.S: Assembler messages: arch/powerpc/kernel/misc_32.S:902: Error: unsupported relocation against KEXEC_CONTROL_CODE_SIZE make[2]: *** [arch/powerpc/kernel/misc_32.o] Error 1 make[1]: *** [arch/powerpc/kernel] Error 2 make: *** [vmlinux] Error 2 I grepped arch/ and found no further instances. Signed-off-by: Paul Collins <paul@ondioline.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-08-18powerpc: Remove dead module_find_bug codeSteven Rostedt
Doing some various "make randconfig", I came across an error when CONFIG_BUG was not set: arch/powerpc/kernel/module.c: In function 'module_find_bug': arch/powerpc/kernel/module.c:111: error: increment of pointer to unknown structure arch/powerpc/kernel/module.c:111: error: arithmetic on pointer to an incomplete type arch/powerpc/kernel/module.c:112: error: dereferencing pointer to incomplete type Looking further into this, I found that module_find_bug, defined in powerpc arch code, is not called anywhere, so this just removes it. There is a static module_find_bug in lib/bug.c but that is a separate issue. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-08-18powerpc: Add CMO enabled flag and paging space data to lparcfgRobert Jennings
Add a field in lparcfg output to indicate whether the kernel is running on a dedicated or shared memory lpar. Added fields to show the paging space pool IDs and the CMO page size. Submitted-by: Robert Jennings <rcj@linux.vnet.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-08-18powerpc: Fix CMM page loaning on 64k page kernel with 4k hardware pagesBrian King
If the firmware page size used for collaborative memory overcommit is 4k, but the kernel is using 64k pages, the page loaning is currently broken as it only marks the first 4k page of each 64k page as loaned. This fixes this to iterate through each 4k page and mark them all as loaned/active. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: Robert Jennings <rcj@linux.vnet.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-08-18powerpc: Make CMO paging space pool ID and page size availableRobert Jennings
During platform setup, save off the primary/secondary paging space pool IDs and the page size. Added accessors in hvcall.h for these variables. This is needed for a subsequent fix. Submitted-by: Robert Jennings <rcj@linux.vnet.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-08-18powerpc: Fix lockdep IRQ tracing bugBenjamin Herrenschmidt
A small bogon sneaked into the ppc64 lockdep support. A test is branching slightly off causing a clobbered register value to overwrite the irq state under some circumstances. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-08-18powerpc: Fix TLB invalidation on boot on 32-bitRocky Craig
The intent of "flush_tlbs" is to invalidate all TLB entries by doing a TLB invalidate instruction for all pages in the address range 0 to 0x00400000. A loop counter is set up at the high value and decremented by page size. However, the loop is only done once as the sense of the conditional branch at the loop end does not match the setup/decrement. This fixes it to do the whole range by correcting the branch condition. Signed-off-by: Rocky Craig <rocky.craig@hp.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-08-18powerpc: Fix loss of vdso on fork on 32-bitBenjamin Herrenschmidt
When we fork, init_new_context() improperly resets the vdso_base of the new context to 0. That means that the new process loses access to the vdso for signal trampolines. The initialization should be unnecessary anyway as the context on a fresh mm should be 0 in the first place and binfmt_elf will initialize that value for a newly loaded process. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-08-15kexec jump: rename KEXEC_CONTROL_CODE_SIZE to KEXEC_CONTROL_PAGE_SIZEHuang Ying
Rename KEXEC_CONTROL_CODE_SIZE to KEXEC_CONTROL_PAGE_SIZE, because control page is used for not only code on some platform. For example in kexec jump, it is used for data and stack too. [akpm@linux-foundation.org: unbreak powerpc and arm, finish conversion] Signed-off-by: Huang Ying <ying.huang@intel.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-14powerpc/spufs: reference context while dropping state mutex in schedulerJeremy Kerr
Based on an original patch from Christoph Hellwig <hch@lst.de>. Currently, there is a possible reference-after-free in the spusched code - contexts may be freed after we have released their state_mutex in spusched_tick and find_victim. This change takes a reference to the context before releasing the mutex, so that the context doesn't get destroyed. Signed-off-by: Jeremy Kerr <jk@ozlabs.org>
2008-08-13powerpc/spufs: fix npc setting for NOSCHED contextsJeremy Kerr
Currently, spu_run ignores the npc argument for contexts created with SPU_CREATE_NOSCHED. While this is correct for isolated contexts, there's no need to enforce the npc restriction on non-isolated NOSCHED contexts. This means that NOSCHED contexts can only ever run with an entry point of 0x0. This change to spu_run_init allows setting of the npc (and, while we're at it, the privcntl) for non-isolated NOSCHED contexts. This allows us to run NOSCHED contexts from any entry point. Signed-off-by: Jeremy Kerr <jk@ozlabs.org>
2008-08-12mm: Make generic weak get_user_pages_fast and EXPORT_GPL itRusty Russell
Out of line get_user_pages_fast fallback implementation, make it a weak symbol, get rid of CONFIG_HAVE_GET_USER_PAGES_FAST. Export the symbol to modules so lguest can use it. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-08-11Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: powerpc: Remove include/linux/harrier_defs.h powerpc: Do not ignore arch/powerpc/include powerpc: Delete completed "ppc removal" task from feature removal file powerpc/mm: Fix attribute confusion with htab_bolt_mapping() powerpc/pci: Don't keep ISA memory hole resources in the tree powerpc: Zero fill the return values of rtas argument buffer powerpc/4xx: Update defconfig files for 2.6.27-rc1 powerpc/44x: Incorrect NOR offset in Warp DTS powerpc/44x: Warp DTS changes for board updates powerpc/4xx: Cleanup Warp for i2c driver changes. powerpc/44x: Adjust warp-nand resource end address
2008-08-11powerpc: Do not ignore arch/powerpc/includeJunio C Hamano
Back when .gitignore file was added to arch/powerpc/ in 06f2138 ([POWERPC] Add files build to .gitignore, 2006-11-26), there indeed was nothing tracked in the ignored hierarchy and ignoring everything made sense. But we have very many tracked files there these days, and having a higher level .gitignore that ignores everything is asking for future troubles.. This should have been part of b8b572e (powerpc: Move include files to arch/powerpc/include/asm, 2008-08-01). Signed-off-by: Junio C Hamano <gitster@pobox.com> Acked-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-08-11powerpc/mm: Fix attribute confusion with htab_bolt_mapping()Benjamin Herrenschmidt
The function htab_bolt_mapping() is used to create permanent mappings in the MMU hash table, for example, in order to create the linear mapping of vmemmap. It's also used by early boot ioremap (before mem_init_done). However, the way ioremap uses it is incorrect as it passes it the protection flags in the "linux PTE" form while htab_bolt_mapping() expects them in the hash table format. This is made more confusing by the fact that some of those flags are actually in the same position in both cases. This fixes it all by making htab_bolt_mapping() take normal linux protection flags instead, and use a little helper to convert them to htab flags. Callers can now use the usual PAGE_* definitions safely. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> arch/powerpc/include/asm/mmu-hash64.h | 2 - arch/powerpc/mm/hash_utils_64.c | 65 ++++++++++++++++++++-------------- arch/powerpc/mm/init_64.c | 9 +--- 3 files changed, 44 insertions(+), 32 deletions(-) Signed-off-by: Paul Mackerras <paulus@samba.org>
