path: root/arch/powerpc
2009-08-12Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: arch/microblaze/include/asm/socket.h
2009-08-09Merge branch 'kvm-updates/2.6.31' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
* 'kvm-updates/2.6.31' of git://git.kernel.org/pub/scm/virt/kvm/kvm: KVM: Avoid redelivery of edge interrupt before next edge KVM: MMU: limit rmap chain length KVM: ia64: fix build failures due to ia64/unsigned long mismatches KVM: Make KVM_HPAGES_PER_HPAGE unsigned long to avoid build error on powerpc KVM: fix ack not being delivered when msi present KVM: s390: fix wait_queue handling KVM: VMX: Fix locking imbalance on emulation failure KVM: VMX: Fix locking order in handle_invalid_guest_state KVM: MMU: handle n_free_mmu_pages > n_alloc_mmu_pages in kvm_mmu_change_mmu_pages KVM: SVM: force new asid on vcpu migration KVM: x86: verify MTRR/PAT validity KVM: PIT: fix kpit_elapsed division by zero KVM: Fix KVM_GET_MSR_INDEX_LIST
2009-08-06perf_counter/powerpc: Check oprofile_cpu_type for NULL before using itBenjamin Herrenschmidt
If the current CPU doesn't support performance counters, cur_cpu_spec->oprofile_cpu_type can be NULL. The current perf_counter modules don't test for that case and would thus crash at boot time. Bug reported by David Woodhouse. Reported-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Paul Mackerras <paulus@samba.org> LKML-Reference: <19066.48028.446975.501454@cargo.ozlabs.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-05net: implement a SO_DOMAIN getsockoptionJan Engelhardt
This sockopt goes in line with SO_TYPE and SO_PROTOCOL. It makes it possible for userspace programs to pass around file descriptors — I am referring to arguments-to-functions, but it may even work for the fd passing over UNIX sockets — without needing to also pass the auxiliary information (PF_INET6/IPPROTO_TCP). Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-05net: implement a SO_PROTOCOL getsockoptionJan Engelhardt
Similar to SO_TYPE returning the socket type, SO_PROTOCOL allows to retrieve the protocol used with a given socket. I am not quite sure why we have that-many copies of socket.h, and why the values are not the same on all arches either, but for where hex numbers dominate, I use 0x1029 for SO_PROTOCOL as that seems to be the next free unused number across a bunch of operating systems, or so Google results make me want to believe. SO_PROTOCOL for others just uses the next free Linux number, 38. Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-05KVM: Make KVM_HPAGES_PER_HPAGE unsigned long to avoid build error on powerpcStephen Rothwell
Eliminates this compiler warning: arch/powerpc/kvm/../../../virt/kvm/kvm_main.c:1178: error: integer overflow in expression Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-07-29powerpc: Update defconfigs for embedded 6xx/7xxx, 8xx, 8{3,5,6}xxxKumar Gala
2009-07-29powerpc/86xx: Update GE Fanuc sbc310 default configurationMartyn Welch
General update of defconfig including the following notable changes: - Enable Highmem support. - Support for PCMCIA based daughter card. Signed-off-by: Martyn Welch <martyn.welch@gefanuc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-29powerpc/86xx: Update defconfig for GE Fanuc's PPC9AMartyn Welch
General update of defconfig including the following notable changes: - Enable GPIO access via sysfs on GE Fanuc's PPC9A. - Enable Highmem support. - Support for PCMCIA based daughter card. Signed-off-by: Martyn Welch <martyn.welch@gefanuc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-29powerpc/83xx: Fix PCI IO base address on MPC837xE-RDB boardsAnton Vorontsov
U-Boot maps PCI IO at 0xe0300000, while current dts files specify 0xe2000000. This leads to the following oops with CONFIG_8139TOO_PIO=y. 8139too Fast Ethernet driver 0.9.28 Machine check in kernel mode. Caused by (from SRR1=41000): Transfer error ack signal Oops: Machine check, sig: 7 [#1] MPC837x RDB [...] NIP [00000900] 0x900 LR [c0439df8] rtl8139_init_board+0x238/0x524 Call Trace: [cf831d90] [c0439dcc] rtl8139_init_board+0x20c/0x524 (unreliable) [cf831de0] [c043a15c] rtl8139_init_one+0x78/0x65c [cf831e40] [c0235250] pci_call_probe+0x20/0x30 [...] This patch fixes the issue by specifying the correct PCI IO base address. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-29powerpc/85xx: Don't scan for TBI PHY addresses on MPC8569E-MDS boardsAnton Vorontsov
Sometimes (e.g. when there are no UEMs attached to a board) fsl_pq_mdio_find_free() fails to find a spare address for a TBI PHY, this is because get_phy_id() returns bogus 0x0000ffff values (0xffffffff is expected), and therefore mdio bus probing fails with the following message: fsl-pq_mdio: probe of e0082120.mdio failed with error -16 And obviously ethernet doesn't work after this. This patch solves the problem by adding tbi-phy node into mdio node, so that we won't scan for spare addresses, we'll just use a fixed one. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-29powerpc/85xx: Fix ethernet link detection on MPC8569E-MDS boardsAnton Vorontsov
Linux isn't able to detect link changes on ethernet ports that were used by U-Boot. This is because U-Boot wrongly clears interrupt polarity bit (INTPOL, 0x400) in the extended status register (EXT_SR, 0x1b) of Marvell PHYs. There is no easy way for PHY drivers to know IRQ line polarity (we could extract it from the device tree and pass it to phydevs, but that'll be quite a lot of work), so for now just reset the PHYs to their default states. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-29powerpc/mm: Fix SMP issue with MMU context handling codeKumar Gala
In switch_mmu_context() if we call steal_context_smp() to get a context to use we shouldn't fall through and than call steal_context_up(). Doing so can be problematic in that the 'mm' that steal_context_up() ends up using will not get marked dirty in the stale_map[] for other CPUs that might have used that mm. Thus we could end up with stale TLB entries in the other CPUs that can cause all kinda of havoc. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-27mm: Pass virtual address to [__]p{te,ud,md}_free_tlb()Benjamin Herrenschmidt
mm: Pass virtual address to [__]p{te,ud,md}_free_tlb() Upcoming paches to support the new 64-bit "BookE" powerpc architecture will need to have the virtual address corresponding to PTE page when freeing it, due to the way the HW table walker works. Basically, the TLB can be loaded with "large" pages that cover the whole virtual space (well, sort-of, half of it actually) represented by a PTE page, and which contain an "indirect" bit indicating that this TLB entry RPN points to an array of PTEs from which the TLB can then create direct entries. Thus, in order to invalidate those when PTE pages are deleted, we need the virtual address to pass to tlbilx or tlbivax instructions. The old trick of sticking it somewhere in the PTE page struct page sucks too much, the address is almost readily available in all call sites and almost everybody implemets these as macros, so we may as well add the argument everywhere. I added it to the pmd and pud variants for consistency. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: David Howells <dhowells@redhat.com> [MN10300 & FRV] Acked-by: Nick Piggin <npiggin@suse.de> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [s390] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-15powerpc: Fix another bug in move of altivec code to vector.SAndreas Schwab
When moving load_up_altivec to vector.S a typo in a comment caused a thinko setting the wrong variable. Signed-off-by: Andreas Schwab <schwab@linux-m68k.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-07-15powerpc: Fix booke user_disable_single_step()Dave Kleikamp
On booke processors, gdb is seeing spurious SIGTRAPs when setting a watchpoint. user_disable_single_step() simply quits when the DAC is non-zero. It should be clearing the DBCR0_IC and DBCR0_BT bits from the dbcr0 register and TIF_SINGLESTEP from the thread flag. Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-07-12headers: smp_lock.h reduxAlexey Dobriyan
* Remove smp_lock.h from files which don't need it (including some headers!) * Add smp_lock.h to files which do need it * Make smp_lock.h include conditional in hardirq.h It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT This will make hardirq.h inclusion cheaper for every PREEMPT=n config (which includes allmodconfig/allyesconfig, BTW) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-10Merge branch 'perfcounters-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perfcounters-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (50 commits) perf report: Add "Fractal" mode output - support callchains with relative overhead rate perf_counter tools: callchains: Manage the cumul hits on the fly perf report: Change default callchain parameters perf report: Use a modifiable string for default callchain options perf report: Warn on callchain output request from non-callchain file x86: atomic64: Inline atomic64_read() again x86: atomic64: Clean up atomic64_sub_and_test() and atomic64_add_negative() x86: atomic64: Improve atomic64_xchg() x86: atomic64: Export APIs to modules x86: atomic64: Improve atomic64_read() x86: atomic64: Code atomic(64)_read and atomic(64)_set in C not CPP x86: atomic64: Fix unclean type use in atomic64_xchg() x86: atomic64: Make atomic_read() type-safe x86: atomic64: Reduce size of functions x86: atomic64: Improve atomic64_add_return() x86: atomic64: Improve cmpxchg8b() x86: atomic64: Improve atomic64_read() x86: atomic64: Move the 32-bit atomic64_t implementation to a .c file x86: atomic64: The atomic64_t data type should be 8 bytes aligned on 32-bit too perf report: Annotate variable initialization ...
2009-07-10sched: INIT_PREEMPT_COUNTPeter Zijlstra
Pull the initial preempt_count value into a single definition site. Maintainers for: alpha, ia64 and m68k, please have a look, your arch code is funny. The header magic is a bit odd, but similar to the KERNEL_DS one, CPP waits with expanding these macros until the INIT_THREAD_INFO macro itself is expanded, which is in arch/*/kernel/init_task.c where we've already included sched.h so we're good. Cc: tony.luck@intel.com Cc: rth@twiddle.net Cc: geert@linux-m68k.org Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-08powerpc: Don't use alloc_bootmem() in init_IRQ() pathAnton Vorontsov
This patch fixes various badnesses like this for all interrupt controllers: ------------[ cut here ]------------ Badness at c04db9dc [verbose debug info unavailable] NIP: c04db9dc LR: c04db9ac CTR: 00000000 REGS: c053de30 TRAP: 0700 Not tainted (2.6.31-rc1-00432-ge69b2b5-dirty) MSR: 00021000 <ME,CE> CR: 22020084 XER: 00000000 TASK = c0500480[0] 'swapper' THREAD: c053c000 GPR00: 00000001 c053dee0 c0500480 00000000 00000050 00000020 3fffffff 00000000 GPR08: 00000001 c0540000 e0080080 00000000 22000084 64183600 3ff8f800 00000000 GPR16: 841b0240 449a0303 00000000 00000000 00000000 00000000 00000000 c04f5bf4 GPR24: 00000000 00000000 00000000 00000050 00000020 00000000 3fffffff 00000050 NIP [c04db9dc] alloc_arch_preferred_bootmem+0x48/0x74 LR [c04db9ac] alloc_arch_preferred_bootmem+0x18/0x74 Call Trace: [c053dee0] [c000a5a4] __of_address_to_resource+0x44/0xd0 (unreliable) [c053def0] [c04dba58] ___alloc_bootmem_nopanic+0x50/0x108 [c053df20] [c04dbb28] ___alloc_bootmem+0x18/0x50 [c053df30] [c04d5de0] qe_ic_init+0x5c/0x1b0 [c053df70] [c04d77b0] mpc85xx_mds_pic_init+0xb8/0x10c [c053dfb0] [c04cf374] init_IRQ+0x28/0x3c p.s. commit 85355bb272db31a3f2dd99d547eef794805e1319 ("powerpc: Fix mpic alloc warning") missed some alloc_bootmem() instances, this is now fixed. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Acked-by: Timur Tabi <timur@freescale.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-07-08powerpc: Fix spin_event_timeout() to be robust over context switchesGrant Likely
Current implementation of spin_event_timeout can be interrupted by an IRQ or context switch after testing the condition, but before checking the timeout. This can cause the loop to report a timeout when the condition actually became true in the middle. This patch adds one final check of the condition upon exit of the loop if the last test of the condition was still false. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Timur Tabi <timur@freescale.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-07-08powerpc: Use pr_devel() in do_dcache_icache_coherency()Michael Ellerman
pr_debug() can now result in code being generated even when DEBUG is not defined. That's not really desirable in some places. With CONFIG_DYNAMIC_DEBUG=y: size before: text data bss dec hex filename 2036 368 8 2412 96c arch/powerpc/mm/pgtable.o size after: text data bss dec hex filename 1677 248 8 1933 78d arch/powerpc/mm/pgtable.o Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-07-08powerpc/cell: Use pr_devel() in axon_msi.cMichael Ellerman
pr_debug() can now result in code being generated even when DEBUG is not defined. That's not really desirable in some places. With CONFIG_DYNAMIC_DEBUG=y: size before: text data bss dec hex filename 7083 1616 0 8699 21fb arch/powerpc/../axon_msi.o size after: text data bss dec hex filename 5772 1208 0 6980 1b44 arch/powerpc/../axon_msi.o Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-07-08powerpc: Use pr_devel() in arch/powerpc/mm/gup.cMichael Ellerman
pr_debug() can now result in code being generated even when DEBUG is not defined. That's not really desirable in some places. With CONFIG_DYNAMIC_DEBUG=y: size before: text data bss dec hex filename 3252 384 0 3636 e34 arch/powerpc/mm/gup.o size after: text data bss dec hex filename 2576 96 0 2672 a70 arch/powerpc/mm/gup.o Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-07-08powerpc: Cleanup & use pr_devel() in arch/powerpc/mm/slb.cMichael Ellerman
pr_debug() can now result in code being generated even when DEBUG is not defined. That's not really desirable in some places. With CONFIG_DYNAMIC_DEBUG=y: size before: text data bss dec hex filename 3261 416 4 3681 e61 arch/powerpc/mm/slb.o size after: text data bss dec hex filename 2861 248 4 3113 c29 arch/powerpc/mm/slb.o Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-07-08powerpc/perf_counter: Remove duplicated #includeHuang Weiyi
Remove duplicated #include('s) in arch/powerpc/kernel/mpc7450-pmu.c arch/powerpc/kernel/ppc970-pmu.c Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-07-08powerpc: Use pr_devel() in arch/powerpc/mm/mmu_context_nohash.cMichael Ellerman
pr_debug() can now result in code being generated even when DEBUG is not defined. That's not really desirable in some places. With CONFIG_DYNAMIC_DEBUG=y: size before: text data bss dec hex filename 1508 48 28 1584 630 powerpc/mm/mmu_context_nohash.o size after: text data bss dec hex filename 1088 0 28 1116 45c powerpc/mm/mmu_context_nohash.o Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-07-08powerpc/pseries: Use pr_devel() in xics.cMichael Ellerman
pr_debug() can now result in code being generated even when DEBUG is not defined. That's not really desirable in some places. With CONFIG_DYNAMIC_DEBUG=y: size before: text data bss dec hex filename 7720 5488 296 13504 34c0 platforms/pseries/xics.o size after: text data bss dec hex filename 7535 5456 296 13287 33e7 platforms/pseries/xics.o Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-07-08powerpc: Remove unnecessary semicolonsJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-07-08powerpc/pseries: Use pr_devel() in pseries LPAR HPTE routinesMichael Ellerman
pr_debug() can now result in code being generated even when DEBUG is not defined. That's not really desirable in some places. In particular, pSeries_lpar_hpte_insert() goes from 185 instructions to 77 instructions as a result of this patch. Luckily that code isn't called very often ... With CONFIG_DYNAMIC_DEBUG=y: size before: text data bss dec hex filename 7284 1552 296 9132 23ac platforms/pseries/lpar.o size after: text data bss dec hex filename 5806 1096 296 7198 1c1e platforms/pseries/lpar.o Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-07-08Merge commit 'jwb/merge' into mergeBenjamin Herrenschmidt
2009-07-05powerpc/44x: Fix build error with -Werror for Warp platformJosh Boyer
With -Werror enabled during the build, the warp.c file fails to build due to the temp_isr function not containing a return statement. This fixes the build error and documents that the function never returns. Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2009-07-06powerpc/4xx: Have Warp take advantage of GPIO LEDs default-state = keepSean MacLennan
The GPIO LEDS driver now has a default state of "keep". Update the Warp DTS and platform file to take advantage of this new state. This removes the hardcoding of the two LEDs on the Warp. Signed-off-by: Sean MacLennan <smaclennan@pikatech.com> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2009-07-06powerpc/44x: Update Warp defconfigSean MacLennan
* Enable GPIO LEDS and LED triggers * Move to SLUB * Enable HOTPLUG * Enable timestamps on printks * Enable UBIFS * Enable in-kernel config Signed-off-by: Sean MacLennan <smaclennan@pikatech.com> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2009-07-01powerpc/perf_counter: Enable alternate PR/HV bits for POWER7Anton Blanchard
POWER7 has the same PR/HV bit layout as POWER6, so set the flag. Signed-off-by: Anton Blanchard <anton@samba.org> Acked-by: Paul Mackerras <paulus@samba.org> Cc: a.p.zijlstra@chello.nl Cc: benh@kernel.crashing.org LKML-Reference: <20090701030701.GI3563@kryten> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-30Merge branch 'perfcounters-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perfcounters-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (47 commits) perf report: Add --symbols parameter perf report: Add --comms parameter perf report: Add --dsos parameter perf_counter tools: Adjust only prelinked symbol's addresses perf_counter: Provide a way to enable counters on exec perf_counter tools: Reduce perf stat measurement overhead/skew perf stat: Use percentages for scaling output perf_counter, x86: Update x86_pmu after WARN() perf stat: Micro-optimize the code: memcpy is only required if no event is selected and !null_run perf stat: Improve output perf stat: Fix multi-run stats perf stat: Add -n/--null option to run without counters perf_counter tools: Remove dead code perf_counter: Complete counter swap perf report: Print sorted callchains per histogram entries perf_counter tools: Prepare a small callchain framework perf record: Fix unhandled io return value perf_counter tools: Add alias for 'l1d' and 'l1i' perf-report: Add bare minimum PERF_EVENT_READ parsing perf-report: Add modes for inherited stats and no-samples ...
2009-06-26Merge commit 'kumar/next' into mergeBenjamin Herrenschmidt
2009-06-26powerpc/mm: Fix potential access to freed pages when using hugetlbfsBenjamin Herrenschmidt
When using 64k page sizes, our PTE pages are split in two halves, the second half containing the "extension" used to keep track of individual 4k pages when not using HW 64k pages. However, our page tables used for hugetlb have a slightly different format and don't carry that "second half". Our code that batched PTEs to be invalidated unconditionally reads the "second half" (to put it into the batch), which means that when called to invalidate hugetlb PTEs, it will access unrelated memory. It breaks when CONFIG_DEBUG_PAGEALLOC is enabled. This fixes it by only accessing the second half when the _PAGE_COMBO bit is set in the first half, which indicates that we are dealing with a "combo" page which represents 16x4k subpages. Anything else shouldn't have this bit set and thus not require loading from the second half. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-06-26powerpc/440: Fix warning early debug codeBenjamin Herrenschmidt
The function udbg_44x_as1_flush() has the wrong prototype causing a warning when enabling 440 early debug. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-06-26powerpc/of: Fix usage of dev_set_name() in of_device_alloc()Benjamin Herrenschmidt
dev_set_name() takes a format string, so use it properly and avoid a warning with recent gcc's Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-06-26powerpc/pasemi: Use raw spinlock in SMP TB syncBenjamin Herrenschmidt
spin_lock() can hang if called while the timebase is frozen, so use a raw lock instead, also disable interrupts while at it. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-06-26powerpc: Use one common impl. of RTAS timebase sync and use raw spinlockBenjamin Herrenschmidt
Several platforms use their own copy of what is essentially the same code, using RTAS to synchronize the timebases when bringing up new CPUs. This moves it all into a single common implementation and additionally turns the spinlock into a raw spinlock since the former can rely on the timebase not being frozen when spinlock debugging is enabled, and finally masks interrupts while the timebase is disabled. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-06-26powerpc/rtas: Turn rtas lock into a raw spinlockBenjamin Herrenschmidt
RTAS currently uses a normal spinlock. However it can be called from contexts where this is not necessarily a good idea. For example, it can be called while syncing timebases, with the core timebase being frozen. Unfortunately, that will deadlock in case of lock contention when spinlock debugging is enabled as the spin lock debugging code will try to use __delay() which ... relies on the timebase being enabled. Also RTAS can be used in some low level IRQ handling code path so it may as well be a raw spinlock for -rt sake. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-06-26powerpc: Add irqtrace support for 32-bit powerpcBenjamin Herrenschmidt
Based on initial work from: Dale Farnsworth <dale@farnsworth.org> Add the low level irq tracing hooks for 32-bit powerpc needed to enable full lockdep functionality. The approach taken to deal with the code in entry_32.S is that we don't trace all the transitions of MSR:EE when we just turn it off to peek at TI_FLAGS without races. Only when we are calling into C code or returning from exceptions with a state that have changed from what lockdep thinks. There's a little bugger though: If we take an exception that keeps interrupts enabled (such as an alignment exception) while interrupts are enabled, we will call trace_hardirqs_on() on the way back spurriously. Not a big deal, but to get rid of it would require remembering in pt_regs that the exception was one of the type that kept interrupts enabled which we don't know at this stage. (Well, we could test all cases for regs->trap but that sucks too much). Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Tested-by: Kumar Gala <galak@kernel.crashing.org>
2009-06-26powerpc: Map more memory early on 601 processorsBenjamin Herrenschmidt
The 32-bit kernel relies on some memory being mapped covering the kernel text,data and bss at least, early during boot before the full MMU setup is done. On 32-bit "classic" processors, this is done using BAT registers. On 601, the size of BATs is limited to 8M and we use 2 of them for that initial mapping. This can become quite tight when enabling features like lockdep, so let's use a 3rd one to bump that mapping from 16M to 24M. We keep the 4th BAT free as it can be useful for debugging early boot code to map things like serial ports. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-06-26powerpc/mm: Make k(un)map_atomic out of lineBenjamin Herrenschmidt
Those functions are way too big to be inline, besides, kmap_atomic() wants to call debug_kmap_atomic() which isn't exported for modules and causes module link failures. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-06-26powerpc: Fix mpic alloc warningKumar Gala
Since we can use kmalloc earlier we are getting the following since the mpic_alloc() code calls alloc_bootmem(). Move to using kzalloc() to remove the warning. ------------[ cut here ]------------ Badness at c0583248 [verbose debug info unavailable] NIP: c0583248 LR: c0583210 CTR: 00000004 REGS: c0741de0 TRAP: 0700 Not tainted (2.6.30-06736-g12a31df) MSR: 00021000 <ME,CE> CR: 22024024 XER: 00000000 TASK = c070d3b8[0] 'swapper' THREAD: c0740000 CPU: 0 <6>GPR00: 00000001 c0741e90 c070d3b8 00000001 00000210 00000020 3fffffff 00000000 <6>GPR08: 00000000 c0c85700 c04f8c40 0000002d 22044022 1004a388 7ffd9400 00000000 <6>GPR16: 00000000 7ffcd100 7ffcd100 7ffcd100 c04f8c40 00000000 c059f62c c075a0c0 <6>GPR24: c059f648 00000000 0000000f 00000210 00000020 00000000 3fffffff 00000210 NIP [c0583248] alloc_arch_preferred_bootmem+0x50/0x80 LR [c0583210] alloc_arch_preferred_bootmem+0x18/0x80 Call Trace: [c0741e90] [c07343b0] devtree_lock+0x0/0x24 (unreliable) [c0741ea0] [c0583b14] ___alloc_bootmem_nopanic+0x54/0x108 [c0741ee0] [c0583e18] ___alloc_bootmem+0x18/0x50 [c0741ef0] [c057b9cc] mpic_alloc+0x48/0x710 [c0741f40] [c057ecf4] mpc85xx_ds_pic_init+0x190/0x1b8 [c0741f90] [c057633c] init_IRQ+0x24/0x34 [c0741fa0] [c05738b8] start_kernel+0x260/0x3dc [c0741ff0] [c00003c8] skpinv+0x2e0/0x31c Instruction dump: 409e001c 7c030378 80010014 83e1000c 38210010 7c0803a6 4e800020 3d20c0c8 39295700 80090004 7c000034 5400d97e <0f000000> 2f800000 409e001c 38800000 BenH: Changed to use GFP_KERNEL, the allocator will do the right thing Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-06-26powerpc: Fix output from show_regsKumar Gala
For some reason we've had an explicit KERN_INFO for GPR dumps. With recent changes we get output like: <6>GPR00: 00000000 ef855eb0 ef858000 00000001 000000d0 f1000000 ffbc8000 ffffffff The KERN_INFO is causing the <6>. Don't see any reason to keep it around. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-06-26powerpc/pmac: Fix issues with PowerMac "PowerSurge" SMPBenjamin Herrenschmidt
The old PowerSurge SMP (ie, dual or quad 604 machines) code has numerous issues in modern world. One is cpu_possible_map is set too late (the device-tree is bogus) so we fail to allocate the interrupt stacks and crash. Another problem is the fact the timebase is frozen by the bringup of the second CPU so the delays in the generic code will hang, we need to move some of the calling procedure to inside the powermac code. This makes it boot again for me Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-06-26powerpc/amigaone: Limit ISA I/O range to 4k in the device treeGerhard Pircher
The kernel reserves the I/O address space from 0x0 to 0xfff for legacy ISA devices. Change the ranges property for the PCI2ISA bridge to match the kernels behavior, even if the ranges property isn't used for now. Signed-off-by: Gerhard Pircher <gerhard_pircher@gmx.net> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
