This file is only exporting symbols and so should use export.h
and not module.h header. But in doing the conversion, we will
uncover that it was implicitly using errno.h via module.h:
CC arch/powerpc/platforms/pseries/hvconsole.o
arch/powerpc/platforms/pseries/hvconsole.c: In function 'hvc_put_chars':
arch/powerpc/platforms/pseries/hvconsole.c:77: error: 'EIO' undeclared (first use in this function)
Removing the implicit presence of module.h from almost everywhere
will reveal this implicit usage of paca.h and string.h headers as
follows:
arch/powerpc/platforms/pseries/plpar_wrappers.h:22: error: implicit declaration of function 'get_lppaca'
arch/powerpc/platforms/pseries/plpar_wrappers.h:208: error: implicit declaration of function 'memcpy'
We've been getting the header implicitly via module.h in the past
but when we clean that up, we'll get this failure:
CC arch/powerpc/platforms/cell/beat_spu_priv1.o
In file included from arch/powerpc/platforms/cell/beat_spu_priv1.c:22:
arch/powerpc/include/asm/spu.h:190: error: field 'list_mutex' has incomplete type
make[2]: *** [arch/powerpc/platforms/cell/beat_spu_priv1.o] Error 1
This file only needs export.h to get EXPORT_SYMBOL, but in doing
so, it uncovers an implicit use of linux/cache.h as follows:
CC arch/powerpc/kernel/firmware.o
arch/powerpc/kernel/firmware.c:20: error: expected '=', ',', ';', 'asm' or '__attribute__' before '__read_mostly'
arch/powerpc/kernel/firmware.c:21: error: expected '=', ',', ';', 'asm' or '__attribute__' before '__used'
make[2]: *** [arch/powerpc/kernel/firmware.o] Error 1
We can convert this file to using export.h since it only wants
to export symbols, but when we do we'll see also that it was
implicitly getting notifier.h from module.h via this failure:
CC arch/powerpc/platforms/cell/spu_notify.o
arch/powerpc/platforms/cell/spu_notify.c:28: warning: type defaults to 'int' in declaration of 'BLOCKING_NOTIFIER_HEAD'
arch/powerpc/platforms/cell/spu_notify.c:28: warning: parameter names (without types) in function declaration
arch/powerpc/platforms/cell/spu_notify.c: In function 'spu_switch_notify':
arch/powerpc/platforms/cell/spu_notify.c:32: error: implicit declaration of function 'blocking_notifier_call_chain'
arch/powerpc/platforms/cell/spu_notify.c:32: error: 'spu_switch_notifier' undeclared (first use in this function)
This has been relying on the fact that the parent file would have
module.h (and thus nearly everything) present. But once we fix that,
we'll get stuck with this failure:
In file included from arch/powerpc/platforms/cell/beat_spu_priv1.c:26:
arch/powerpc/platforms/cell/beat_wrapper.h: In function 'beat_eeprom_write':
arch/powerpc/platforms/cell/beat_wrapper.h:160: error: implicit declaration of function 'memcpy'
and many more instances of the same. Fix it in advance.
They are getting it through device.h --> module.h path, but we want
to clean that up. This is a sample of what will happen if we don't:
pseries/iommu.c: In function 'tce_build_pSeriesLP':
pseries/iommu.c:136: error: implicit declaration of function 'show_stack'
pseries/eeh.c: In function 'eeh_token_to_phys':
pseries/eeh.c:359: error: 'init_mm' undeclared (first use in this function)
pseries/eeh_event.c: In function 'eeh_event_handler':
pseries/eeh_event.c:63: error: implicit declaration of function 'daemonize'
pseries/eeh_event.c:64: error: implicit declaration of function 'set_current_state'
pseries/eeh_event.c:64: error: 'TASK_INTERRUPTIBLE' undeclared (first use in this function)
pseries/eeh_event.c:64: error: (Each undeclared identifier is reported only once
pseries/eeh_event.c:64: error: for each function it appears in.)
pseries/eeh_event.c: In function 'eeh_thread_launcher':
pseries/eeh_event.c:109: error: 'CLONE_KERNEL' undeclared (first use in this function)
hotplug-cpu.c: In function 'pseries_mach_cpu_die':
hotplug-cpu.c:115: error: implicit declaration of function 'idle_task_exit'
kernel/swsusp_64.c: In function 'do_after_copyback':
kernel/swsusp_64.c:17: error: implicit declaration of function 'touch_softlockup_watchdog'
cell/spufs/context.c: In function 'alloc_spu_context':
cell/spufs/context.c:60: error: implicit declaration of function 'get_task_mm'
cell/spufs/context.c:60: warning: assignment makes pointer from integer without a cast
cell/spufs/context.c: In function 'spu_forget':
cell/spufs/context.c:127: error: implicit declaration of function 'mmput'
pasemi/dma_lib.c: In function 'pasemi_dma_stop_chan':
pasemi/dma_lib.c:332: error: implicit declaration of function 'cond_resched'
sysdev/fsl_lbc.c: In function 'fsl_lbc_ctrl_irq':
sysdev/fsl_lbc.c:247: error: 'TASK_NORMAL' undeclared (first use in this function)
Add in sched.h so these get the definitions they are looking for.
They get it via module.h (via device.h) but we want to clean that up.
When we do, we'll get things like:
ibmebus.c:314: error: 'S_IWUSR' undeclared here (not in a function)
vio.c:972: error: 'S_IWUSR' undeclared here (not in a function)
so add in the stat header it is using explicitly in advance.
So that we can clean up the header files and not be relying
on implicit includes from device.h ---> module.h
Fix failures in powerpc associated with the previously allowed
implicit module.h presence that now lead to things like this:
arch/powerpc/mm/mmu_context_hash32.c:76:1: error: type defaults to 'int' in declaration of 'EXPORT_SYMBOL_GPL'
arch/powerpc/mm/tlb_hash32.c:48:1: error: type defaults to 'int' in declaration of 'EXPORT_SYMBOL'
arch/powerpc/kernel/pci_32.c:51:1: error: type defaults to 'int' in declaration of 'EXPORT_SYMBOL_GPL'
arch/powerpc/kernel/iomap.c:36:1: error: type defaults to 'int' in declaration of 'EXPORT_SYMBOL'
arch/powerpc/platforms/44x/canyonlands.c:126:1: error: type defaults to 'int' in declaration of 'EXPORT_SYMBOL'
arch/powerpc/kvm/44x.c:168:59: error: 'THIS_MODULE' undeclared (first use in this function)
[with several contibutions from Stephen Rothwell <sfr@canb.auug.org.au>]
With module.h being implicitly everywhere via device.h, the absence
of explicitly including something for EXPORT_SYMBOL went unnoticed.
Since we are heading to fix things up and clean module.h from the
device.h file, we need to explicitly include these files now.
It was coming in via device.h --> module.h etc. but we want to
clean that up. So explicitly include the header where init_mm
is being declared.
git://git.kernel.org/pub/scm/linux/kernel/git/avi/kvm
* 'kvm-updates/3.2' of git://git.kernel.org/pub/scm/linux/kernel/git/avi/kvm: (75 commits)
KVM: SVM: Keep intercepting task switching with NPT enabled
KVM: s390: implement sigp external call
KVM: s390: fix register setting
KVM: s390: fix return value of kvm_arch_init_vm
KVM: s390: check cpu_id prior to using it
KVM: emulate lapic tsc deadline timer for guest
x86: TSC deadline definitions
KVM: Fix simultaneous NMIs
KVM: x86 emulator: convert push %sreg/pop %sreg to direct decode
KVM: x86 emulator: switch lds/les/lss/lfs/lgs to direct decode
KVM: x86 emulator: streamline decode of segment registers
KVM: x86 emulator: simplify OpMem64 decode
KVM: x86 emulator: switch src decode to decode_operand()
KVM: x86 emulator: qualify OpReg inhibit_byte_regs hack
KVM: x86 emulator: switch OpImmUByte decode to decode_imm()
KVM: x86 emulator: free up some flag bits near src, dst
KVM: x86 emulator: switch src2 to generic decode_operand()
KVM: x86 emulator: expand decode flags to 64 bits
KVM: x86 emulator: split dst decode to a generic decode_operand()
KVM: x86 emulator: move memop, memopp into emulation context
* 'fbdev-next' of git://github.com/schandinat/linux-2.6: (270 commits)
video: platinumfb: Add __devexit_p at necessary place
drivers/video: fsl-diu-fb: merge diu_pool into fsl_diu_data
drivers/video: fsl-diu-fb: merge diu_hw into fsl_diu_data
drivers/video: fsl-diu-fb: only DIU modes 0 and 1 are supported
drivers/video: fsl-diu-fb: remove unused panel operating mode support
drivers/video: fsl-diu-fb: use an enum for the AOI index
drivers/video: fsl-diu-fb: add several new video modes
drivers/video: fsl-diu-fb: remove broken screen blanking support
drivers/video: fsl-diu-fb: move some definitions out of the header file
drivers/video: fsl-diu-fb: fix some ioctls
video: da8xx-fb: Increased resolution configuration of revised LCDC IP
OMAPDSS: picodlp: add missing #include <linux/module.h>
fb: fix au1100fb bitrot.
mx3fb: fix NULL pointer dereference in screen blanking.
video: irq: Remove IRQF_DISABLED
smscufx: change edid data to u8 instead of char
OMAPDSS: DISPC: zorder support for DSS overlays
OMAPDSS: DISPC: VIDEO3 pipeline support
OMAPDSS/OMAP_VOUT: Fix incorrect OMAP3-alpha compatibility setting
video/omap: fix build dependencies
Fix up conflicts in:
- drivers/staging/xgifb/XGI_main_26.c
Changes to XGIfb_pan_var()
- drivers/video/omap/{lcd_apollon.c,lcd_ldp.c,lcd_overo.c}
Removed (or in the case of apollon.c, merged into the generic
DSS panel in drivers/video/omap2/displays/panel-generic-dpi.c)
git://git.kernel.org/pub/scm/linux/kernel/git/hch/vfs-queue
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/hch/vfs-queue: (21 commits)
leases: fix write-open/read-lease race
nfs: drop unnecessary locking in llseek
ext4: replace cut'n'pasted llseek code with generic_file_llseek_size
vfs: add generic_file_llseek_size
vfs: do (nearly) lockless generic_file_llseek
direct-io: merge direct_io_walker into __blockdev_direct_IO
direct-io: inline the complete submission path
direct-io: separate map_bh from dio
direct-io: use a slab cache for struct dio
direct-io: rearrange fields in dio/dio_submit to avoid holes
direct-io: fix a wrong comment
direct-io: separate fields only used in the submission path from struct dio
vfs: fix spinning prevention in prune_icache_sb
vfs: add a comment to inode_permission()
vfs: pass all mask flags check_acl and posix_acl_permission
vfs: add hex format for MAY_* flag values
vfs: indicate that the permission functions take all the MAY_* flags
compat: sync compat_stats with statfs.
vfs: add "device" tag to /proc/self/mountstats
cleanup: vfs: small comment fix for block_invalidatepage
Fix up trivial conflict in fs/gfs2/file.c (llseek changes)
This was found by inspection while tracking a similar
bug in compat_statfs64, that has been fixed in mainline
since decemeber.
- This fixes a bug where not all of the f_spare fields
were cleared on mips and s390.
- Add the f_flags field to struct compat_statfs
- Copy f_flags to userspace in case someone cares.
- Use __clear_user to copy the f_spare field to userspace
to ensure that all of the elements of f_spare are cleared.
On some architectures f_spare is has 5 ints and on some
architectures f_spare only has 4 ints. Which makes
the previous technique of clearing each int individually
broken.
I don't expect anyone actually uses the old statfs system
call anymore but if they do let them benefit from having
the compat and the native version working the same.
* 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (27 commits)
rtmutex: Add missing rcu_read_unlock() in debug_rt_mutex_print_deadlock()
lockdep: Comment all warnings
lib: atomic64: Change the type of local lock to raw_spinlock_t
locking, lib/atomic64: Annotate atomic64_lock::lock as raw
locking, x86, iommu: Annotate qi->q_lock as raw
locking, x86, iommu: Annotate irq_2_ir_lock as raw
locking, x86, iommu: Annotate iommu->register_lock as raw
locking, dma, ipu: Annotate bank_lock as raw
locking, ARM: Annotate low level hw locks as raw
locking, drivers/dca: Annotate dca_lock as raw
locking, powerpc: Annotate uic->lock as raw
locking, x86: mce: Annotate cmci_discover_lock as raw
locking, ACPI: Annotate c3_lock as raw
locking, oprofile: Annotate oprofilefs lock as raw
locking, video: Annotate vga console lock as raw
locking, latencytop: Annotate latency_lock as raw
locking, timer_stats: Annotate table_lock as raw
locking, rwsem: Annotate inner lock as raw
locking, semaphores: Annotate inner lock as raw
locking, sched: Annotate thread_group_cputimer as raw
Fix up conflicts in kernel/posix-cpu-timers.c manually: making
cputimer->cputime a raw lock conflicted with the ABBA fix in commit
bcd5cff7216f ("cputimer: Cure lock inversion").
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
* 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (79 commits)
TTY: serial_core: Fix crash if DCD drop during suspend
tty/serial: atmel_serial: bootconsole removed from auto-enumerates
Revert "TTY: call tty_driver_lookup_tty unconditionally"
tty/serial: atmel_serial: add device tree support
tty/serial: atmel_serial: auto-enumerate ports
tty/serial: atmel_serial: whitespace and braces modifications
tty/serial: atmel_serial: change platform_data variable name
tty/serial: RS485 bindings for device tree
TTY: pty, release tty in all ptmx_open fail paths
TTY: make tty_add_file non-failing
TTY: drop driver reference in tty_open fail path
8250_pci: Fix kernel panic when pch_uart is disabled
h8300: drivers/serial/Kconfig was moved
parport_pc: release IO region properly if unsupported ITE887x card is found
tty: Support compat_ioctl get/set termios_locked
hvc_console: display printk messages on console.
TTY: snyclinkmp: forever loop in tx_load_dma_buffer()
tty/n_gsm: avoid fifo overflow in gsm_dlci_data_output
tty/n_gsm: fix a bug in gsm_dlci_data_output (adaption = 2 case)
Fix up Conflicts in:
- drivers/tty/serial/8250_pci.c
Trivial conflict with removed duplicate device ID
- drivers/tty/serial/atmel_serial.c
Annoying silly conflict between "specify the port num via
platform_data" and other changes to atmel_console_init
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1745 commits)
dp83640: free packet queues on remove
dp83640: use proper function to free transmit time stamping packets
ipv6: Do not use routes from locally generated RAs
|PATCH net-next] tg3: add tx_dropped counter
be2net: don't create multiple RX/TX rings in multi channel mode
be2net: don't create multiple TXQs in BE2
be2net: refactor VF setup/teardown code into be_vf_setup/clear()
be2net: add vlan/rx-mode/flow-control config to be_setup()
net_sched: cls_flow: use skb_header_pointer()
ipv4: avoid useless call of the function check_peer_pmtu
TCP: remove TCP_DEBUG
net: Fix driver name for mdio-gpio.c
ipv4: tcp: fix TOS value in ACK messages sent from TIME_WAIT
rtnetlink: Add missing manual netlink notification in dev_change_net_namespaces
ipv4: fix ipsec forward performance regression
jme: fix irq storm after suspend/resume
route: fix ICMP redirect validation
net: hold sock reference while processing tx timestamps
tcp: md5: add more const attributes
Add ethtool -g support to virtio_net
- drivers/net/Kconfig:
The split-up generated a trivial conflict with removal of a
stale reference to Documentation/networking/net-modules.txt.
Remove it from the new location instead.
- fs/sysfs/dir.c:
Fairly nasty conflicts with the sysfs rb-tree usage, conflicting
with Eric Biederman's changes for tagged directories.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (59 commits)
MAINTAINERS: linux-m32r is moderated for non-subscribers
linux@lists.openrisc.net is moderated for non-subscribers
Drop default from "DM365 codec select" choice
parisc: Kconfig: cleanup Kernel page size default
Kconfig: remove redundant CONFIG_ prefix on two symbols
cris: remove arch/cris/arch-v32/lib/nand_init.S
microblaze: add missing CONFIG_ prefixes
h8300: drop puzzling Kconfig dependencies
MAINTAINERS: microblaze-uclinux@itee.uq.edu.au is moderated for non-subscribers
tty: drop superfluous dependency in Kconfig
ARM: mxc: fix Kconfig typo 'i.MX51'
Fix file references in Kconfig files
aic7xxx: fix Kconfig references to READMEs
Fix file references in drivers/ide/
thinkpad_acpi: Fix printk typo 'bluestooth'
bcmring: drop commented out line in Kconfig
btmrvl_sdio: fix typo 'btmrvl_sdio_sd6888'
doc: raw1394: Trivial typo fix
CIFS: Don't free volume_info->UNC until we are entirely done with it.
treewide: Correct spelling of successfully in comments
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
Acked-by: Randy Dunlap <rdunlap@xenotime.net>
net/batman-adv/soft-interface.c
The Freescale DIU video controller supports five video "modes", but only
the first two are used by the driver. The other three are special modes
that don't make sense for a framebuffer driver. Therefore, there's no
point in keeping a global variable that indicates which mode we're
supposed to use.
Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
Apple Quad G5 has some oddity in it's device-tree which causes the new
generic matching code to fail to relate nodes for PCI-E devices below U4
with their respective struct pci_dev. This breaks graphics on those
machines among others.
This fixes it using a quirk which copies the node pointer from the host
bridge for the root complex, which makes the generic code work for the
children afterward.
There are numerous broken references to Documentation files (in other
Documentation files, in comments, etc.). These broken references are
caused by typo's in the references, and by renames or removals of the
Documentation files. Some broken references are simply odd.
Fix these broken references, sometimes by dropping the irrelevant text
they were part of.
With a KVM guest operating in SMT4 mode (i.e. 4 hardware threads per
core), whenever a CPU goes idle, we have to pull all the other
hardware threads in the core out of the guest, because the H_CEDE
hcall is handled in the kernel. This is inefficient.
This adds code to book3s_hv_rmhandlers.S to handle the H_CEDE hcall
in real mode. When a guest vcpu does an H_CEDE hcall, we now only
exit to the kernel if all the other vcpus in the same core are also
idle. Otherwise we mark this vcpu as napping, save state that could
be lost in nap mode (mainly GPRs and FPRs), and execute the nap
instruction. When the thread wakes up, because of a decrementer or
external interrupt, we come back in at kvm_start_guest (from the
system reset interrupt vector), find the `napping' flag set in the
paca, and go to the resume path.
This has some other ramifications. First, when starting a core, we
now start all the threads, both those that are immediately runnable and
those that are idle. This is so that we don't have to pull all the
threads out of the guest when an idle thread gets a decrementer interrupt
and wants to start running. In fact the idle threads will all start
with the H_CEDE hcall returning; being idle they will just do another
H_CEDE immediately and go to nap mode.
This required some changes to kvmppc_run_core() and kvmppc_run_vcpu().
These functions have been restructured to make them simpler and clearer.
We introduce a level of indirection in the wait queue that gets woken
when external and decrementer interrupts get generated for a vcpu, so
that we can have the 4 vcpus in a vcore using the same wait queue.
We need this because the 4 vcpus are being handled by one thread.
Secondly, when we need to exit from the guest to the kernel, we now
have to generate an IPI for any napping threads, because an HDEC
interrupt doesn't wake up a napping thread.
Thirdly, we now need to be able to handle virtual external interrupts
and decrementer interrupts becoming pending while a thread is napping,
and deliver those interrupts to the guest when the thread wakes.
This is done in kvmppc_cede_reentry, just before fast_guest_return.
Finally, since we are not using the generic kvm_vcpu_block for book3s_hv,
and hence not calling kvm_arch_vcpu_runnable, we can remove the #ifdef
from kvm_arch_vcpu_runnable.
This simplifies the way that the book3s_pr makes the transition to
real mode when entering the guest. We now call kvmppc_entry_trampoline
(renamed from kvmppc_rmcall) in the base kernel using a normal function
call instead of doing an indirect call through a pointer in the vcpu.
If kvm is a module, the module loader takes care of generating a
trampoline as it does for other calls to functions outside the module.
kvmppc_entry_trampoline then disables interrupts and jumps to
kvmppc_handler_trampoline_enter in real mode using an rfi[d].
That then uses the link register as the address to return to
(potentially in module space) when the guest exits.
This also simplifies the way that we call the Linux interrupt handler
when we exit the guest due to an external, decrementer or performance
monitor interrupt. Instead of turning on the MMU, then deciding that
we need to call the Linux handler and turning the MMU back off again,
we now go straight to the handler at the point where we would turn the
MMU on. The handler will then return to the virtual-mode code
(potentially in the module).
Along the way, this moves the setting and clearing of the HID5 DCBZ32
bit into real-mode interrupts-off code, and also makes sure that
we clear the MSR[RI] bit before loading values into SRR0/1.
The net result is that we no longer need any code addresses to be
stored in vcpu->arch.
This makes arch/powerpc/kvm/book3s_rmhandlers.S and
arch/powerpc/kvm/book3s_hv_rmhandlers.S be assembled as
separate compilation units rather than having them #included in
arch/powerpc/kernel/exceptions-64s.S. We no longer have any
conditional branches between the exception prologs in
exceptions-64s.S and the KVM handlers, so there is no need to
keep their contents close together in the vmlinux image.
In their current location, they are using up part of the limited
space between the first-level interrupt handlers and the firmware
NMI data area at offset 0x7000, and with some kernel configurations
this area will overflow (e.g. allyesconfig), leading to an
"attempt to .org backwards" error when compiling exceptions-64s.S.
Moving them out requires that we add some #includes that the
book3s_{,hv_}rmhandlers.S code was previously getting implicitly
via exceptions-64s.S.
There are multiple features in PowerPC KVM that can now be enabled
depending on the user's wishes. Some of the combinations don't make
sense or don't work though.
So this patch adds a way to check if the executing environment would
actually be able to run the guest properly. It also adds sanity
checks if PVR is set (should always be true given the current code
flow), if PAPR is only used with book3s_64 where it works and that
HV KVM is only used in PAPR mode.
Now that Book3S PV mode can also run PAPR guests, we can add a PAPR cap and
enable it for all Book3S targets. Enabling that CAP switches KVM into PAPR
mode.
PAPR defines hypercalls as SC1 instructions. Using these, the guest modifies
page tables and does other privileged operations that it wouldn't be allowed
to do in supervisor mode.
This patch adds support for PR KVM to trap these instructions and route them
through the same PAPR hypercall interface that we already use for HV style
KVM.
Recent Linux versions use the CFAR and PURR SPRs, but don't really care about
their contents (yet). So for now, we can simply return 0 when the guest wants
to read them.
When running a PAPR guest, we need to handle a few hypercalls in kernel space,
most prominently the page table invalidation (to sync the shadows).
So this patch adds handling for a few PAPR hypercalls to PR mode KVM. I tried
to share the code with HV mode, but it ended up being a lot easier this way
around, as the two differ too much in those details.
v1 -> v2:
- whitespace fix
Until now, we always set HIOR based on the PVR, but this is just wrong.
Instead, we should be setting HIOR explicitly, so user space can decide
what the initial HIOR value is - just like on real hardware.
We keep the old PVR based way around for backwards compatibility, but
once user space uses the SREGS based method, we drop the PVR logic.
We have a few traps where we cache the instruction that cause the trap
for analysis later on. Since we now need to be able to distinguish
between SC 0 and SC 1 system calls and the only way to find out which
is which is by looking at the instruction, we also read out the instruction
causing the system call.
When running a PAPR guest, the guest is not allowed to set SDR1 - instead
the HTAB information is held in internal hypervisor structures. But all of
our current code relies on SDR1 and walking the HTAB like on real hardware.
So in order to not be too intrusive, we simply set SDR1 to the HTAB we hold
in host memory. That way we can keep the HTAB in user space, but use it from
kernel space to map the guest.
We have 3 privilege levels: problem state, supervisor state and hypervisor
state. Each of them can access different SPRs, so we need to check on every
SPR if it's accessible in the respective mode.
When running a PAPR guest, some things change. The privilege level drops
from hypervisor to supervisor, SDR1 gets treated differently and we interpret
hypercalls. For bisectability sake, add the flag now, but only enable it when
all the support code is there.
We need the compute_tlbie_rb in _pr and _hv implementations for papr
soon, so let's move it over to a common header file that both
implementations can leverage.
MAINTAINERS
drivers/net/Kconfig
drivers/net/ethernet/broadcom/bnx2x/bnx2x_link.c
drivers/net/ethernet/broadcom/tg3.c
drivers/net/wireless/iwlwifi/iwl-pci.c
drivers/net/wireless/iwlwifi/iwl-trans-tx-pcie.c
drivers/net/wireless/rt2x00/rt2800usb.c
drivers/net/wireless/wl12xx/main.c
Fast-forward merge with Linus to be able to merge patches
based on more recent version of the tree.
Signed-off-by: Vitaliy Ivanov <vitalivanov@gmail.com>
uic->lock is protecting the interrupt controller hardware. This lock
can not be preempted on -rt.
In mainline this change documents the low level nature of
the lock - otherwise there's no functional difference. Lockdep
and Sparse checking will work as usual.
Reported-by: Darcy L. Watkins <dwatkins@tranzeo.com>
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
* 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc:
powerpc/p1023rds: Fix the error of bank-width of nor flash
powerpc/85xx: enable caam crypto driver by default
powerpc/85xx: enable the audio drivers in the defconfigs
In the p1023rds, a physical bus of nor flash is 16 bits width.
The bank-width is width (in bytes) of the bus width. So, the
value of bank-width of nor flash is not one, and it should be
two.
Signed-off-by: Chunhe Lan <Chunhe.Lan@freescale.com>
corenet based SoCs have SEC4 h/w, so enable the SEC4 driver,
caam, and the algorithms it supports, and disable the
SEC2/3 driver, talitos.
Enable the audio drivers in the non-corenet 85xx defconfigs so that audio
is enabled on the Freescale P1022DS reference board.
These were missed in commit f5b940997397 "All Arch: remove linkage
for sys_nfsservctl system call" due to them having no sys_ prefix
(presumably).
Cc: NeilBrown <neilb@suse.de>
Cc: linuxppc-dev@lists.ozlabs.org
Cc: linux-parisc@vger.kernel.org
Acked-by: James Bottomley <James.Bottomley@hansenpartnership.com>
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/fbdev-3.x into fbdev-next
drivers/video/atmel_lcdfb.c
