path: root/arch/powerpc/xmon/subr_prf.c
2005-11-08powerpc: Simplify and clean up the xmon terminal I/OPaul Mackerras
This factors out the common bits of arch/powerpc/xmon/start_*.c into a new nonstdio.c, and removes some stuff that was supposed to make xmon's I/O routines somewhat stdio-like but was never used. It also makes the parsing of the xmon= command line option common, so that ppc32 can now use xmon={off,on,early} also. Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-10-28powerpc: Merge xmonPaul Mackerras
The merged version follows the ppc64 version pretty closely mostly, and in fact ARCH=ppc64 now uses the arch/powerpc/xmon version. The main difference for ppc64 is that the 'p' command to call show_state (which was always pretty dodgy) has been replaced by the ppc32 'p' command, which calls a given procedure (so in fact the old 'p' command behaviour can be achieved with 'p $show_state'). Signed-off-by: Paul Mackerras <paulus@samba.org>
