path: root/arch/powerpc/sysdev
2008-04-24[POWERPC] Fix mv64x60 early console code to use cell-index propertyRemi Machet
The MPSC driver and prpmc2800.dts have been modified to use property 'cell-index' as the serial port number, but the early serial console driver for the mv64x60 has not been modified to use this new property. This fixes it. Signed-off-by: Remi Machet (rmachet@slac.stanford.edu) Acked-by: Dale Farnsworth <dale@farnsworth.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-04-24[POWERPC] Initialize all mv64x60 devices even if one failsRemi Machet
If one of the devices of the mv64x60 init fails, the remaining devices are not initialized. This changes the code to display an error and continue the initialization. Signed-off-by: Remi Machet (rmachet@slac.stanford.edu) Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-04-24[POWERPC] Use default values if necessary in mv64x60 I2C initializationRemi Machet
I2C parameters freq_m and freq_n are assigned defaults in the code, but if properties for those parameters are not found in the open firmware description the init routine returns an error and doesn't create the platform device. This changes the code so that it doesn't return an error if the properties are not found but instead uses the default values. Signed-off-by: Remi Machet (rmachet@slac.stanford.edu) Acked-by: Dale Farnsworth <dale@farnsworth.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-04-21Merge branch 'master' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (202 commits) [POWERPC] Fix compile breakage for 64-bit UP configs [POWERPC] Define copy_siginfo_from_user32 [POWERPC] Add compat handler for PTRACE_GETSIGINFO [POWERPC] i2c: Fix build breakage introduced by OF helpers [POWERPC] Optimize fls64() on 64-bit processors [POWERPC] irqtrace support for 64-bit powerpc [POWERPC] Stacktrace support for lockdep [POWERPC] Move stackframe definitions to common header [POWERPC] Fix device-tree locking vs. interrupts [POWERPC] Make pci_bus_to_host()'s struct pci_bus * argument const [POWERPC] Remove unused __max_memory variable [POWERPC] Simplify xics direct/lpar irq_host setup [POWERPC] Use pseries_setup_i8259_cascade() in pseries_mpic_init_IRQ() [POWERPC] Turn xics_setup_8259_cascade() into a generic pseries_setup_i8259_cascade() [POWERPC] Move xics_setup_8259_cascade() into platforms/pseries/setup.c [POWERPC] Use asm-generic/bitops/find.h in bitops.h [POWERPC] 83xx: mpc8315 - fix USB UTMI Host setup [POWERPC] 85xx: Fix the size of qe muram for MPC8568E [POWERPC] 86xx: mpc86xx_hpcn - Temporarily accept old dts node identifier. [POWERPC] 86xx: mark functions static, other minor cleanups ...
2008-04-17Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6
2008-04-17[POWERPC] fsl_soc: Factor fsl_get_sys_freq() out of the wdt and spi inits.Scott Wood
Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-04-17[POWERPC] CPM: Always use new binding.Scott Wood
The kconfig entry can go away once arch/ppc and references to the config in drivers are removed. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-04-17[POWERPC] QE: fix sparse warningsAnton Vorontsov
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-04-17[POWERPC] QE: export qe_get_brg_clk()Anton Vorontsov
qe_get_brg_clk() will be used by the fsl_gtm routines. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-04-17[POWERPC] QE: implement qe_muram_offsetAnton Vorontsov
qe_muram_offset is the reverse of the qe_muram_addr, will be used for the Freescale QE USB Host Controller driver. This patch also moves qe_muram_addr into the qe.h header, plus adds __iomem hints to use with sparse. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-04-17[POWERPC] fsl_lbc: implement few UPM routinesAnton Vorontsov
Freescale UPM can be used to adjust localbus timings or to generate orbitrary, pre-programmed "patterns" on the external Localbus signals. This patch implements few routines so drivers could work with UPMs in safe and generic manner. So far there is just one user of these routines: Freescale UPM NAND driver. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-04-17[POWERPC] CPM2: Reset the CPM when early debugging is not enabled.Laurent Pinchart
Similarly to what is done for PQ1-based platforms, this patch resets the PQ2 Communication Processor Module in cpm2_reset() when early debugging is not enabled. This helps avoiding conflicts when the boot loader configured the CPM in an unexpected way. Signed-off-by: Laurent Pinchart <laurentp@cse-semaphore.com> Acked-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-04-16phy: Change mii_bus id field to a stringAndy Fleming
Having the id field be an int was making more complex bus topologies excessively difficult. For now, just convert it to a string, and change all instances of "bus->id = val" to snprintf(id, MII_BUS_ID_LEN, "%x", val). Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-17[POWERPC] Add MODULE_LICENSE to powerpc/sysdev/rtc_cmos_setup.cAdrian Bunk
This adds the missing MODULE_LICENSE("GPL"). Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-04-17Merge branch 'for-2.6.26' of ↵Paul Mackerras
master.kernel.org:/pub/scm/linux/kernel/git/olof/pasemi
2008-04-15[POWERPC] mv643xx_eth: Prepare to support multiple silicon blocksDale Farnsworth
The mv643xx_eth driver is being modified to support multiple instances of the ethernet silicon block on the same platform. Each block contains a single register bank containing the registers for up to three ports interleaved within that bank. This patch updates the PowerPC OF to platform_device glue code to support multiple silicon blocks, each with up to three ethernet ports. The main difference is that we now allow multiple mv64x60_shared platform_devices to be registered and we provide each port platform_device with a pointer to its associated shared platform_device. The pointer will not be used until the mv643xx_eth driver changes are committed. Signed-off-by: Dale Farnsworth <dale@farnsworth.org> Acked-by: Mark Greer <mgreer@mvista.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-04-15[POWERPC] prpmc2800: Clean up dts propertiesMark A. Greer
Remove several unused (or software config only) properties. Rename marvel node to "system-controller". Also, rename the "block-index" property to "cell-index" to conform to current practice. Signed-off-by: Mark A. Greer <mgreer@mvista.com> Signed-off-by: Dale Farnsworth <dale@farnsworth.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-04-15[POWERPC] mv64x60: Fix FDT compatible names: mv64x60 => mv64360Mark A. Greer
Compatible names should refer to a specific version of the hardware, without wildcards. Change each instance of mv64x60 to mv64360, which is the oldest version we currently support. Signed-off-by: Mark A. Greer <mgreer@mvista.com> Signed-off-by: Dale Farnsworth <dale@farnsworth.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-04-14Merge branch 'linux-2.6'Paul Mackerras
2008-04-07[POWERPC] kexec: MPIC ack interrupts at mpic_teardown_this_cpu()Valentine Barshak
We really need to ack interrupts at mpic_teardown, since not all platforms reset mpic at kernel start-up. For example, kexec'ed kernel hangs on P.A. Semi if mpic_eoi() isn't called. Signed-off-by: Valentine Barshak <vbarshak@ru.mvista.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2008-04-03[POWERPC] Fix CPM2 SCC1 clock initialization.Laurent Pinchart
A missing break statement in a switch caused cpm2_clk_setup() to initialize SCC2 instead of SCC1. Signed-off-by: Laurent Pinchart <laurentp@cse-semaphore.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-04-02[POWERPC] 4xx: Create common ppc4xx_reset_system() in ppc4xx_soc.cStefan Roese
This patch creates a common system reset routine for all 40x and 44x systems. Previously only a 44x routine existed. But since this system reset via the debug control register is common for 40x and 44x let's share this code for all those platforms in ppc4xx_soc.c. This patch also enables CONFIG_4xx_SOC for all 40x and 44x platforms. Tested on Kilauea (405EX) and Canyonlands (440EX). Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2008-04-02[POWERPC] 4xx: Fix PESDRn_UTLSET1 register setup on 460EX/GTStefan Roese
The patch fixes a bug, where the PESDRn_UTLSET1 register was setup wrongly resulting in a non working PCIe port 1. With this fix both PCIe ports work fine again. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2008-04-02[POWERPC] 4xx: Only reset PCIe PHY on 405EX systems when no link is detectedStefan Roese
Since the arch/powerpc PCI subsystem now does a complete re-assignment of the resources, we can move from the unconditional PCIe PHY reset to the conditional version. Now the PHY is only reset, if no link is established yet. An additional PHY reset (one is already done in U-Boot) leads to problems with some Atheros PCIe boards and some HP FPGA PCIe designs. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2008-04-01[POWERPC] Replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-03-26[POWERPC] 4xx: Add PPC4xx L2-cache support (440GX)Stefan Roese
This patch adds support for the 256k L2 cache found on some IBM/AMCC 4xx PPC's. It introduces a common 4xx SoC file (sysdev/ppc4xx_soc.c) which currently "only" adds the L2 cache init code. Other common 4xx stuff can be added later here. The L2 cache handling code is a copy of Eugene's code in arch/ppc with small modifications. Tested on AMCC Taishan 440GX. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2008-03-26[POWERPC] 4xx: Use dcri_clrset() for PCIe indirect dcr read/modify/write accessValentine Barshak
Use dcri_clrset() for PCIe SDR0 read/modify/write access. Signed-off-by: Valentine Barshak <vbarshak@ru.mvista.com> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2008-03-26[POWERPC] 4xx: Add 460EX PCIe support to 4xx pci driverStefan Roese
All this code is needed to properly initialize the 460EX PCIe host bridge(s). We re-initialize all ports again, even though this has been done in the bootloader (U-Boot) before. This way we make sure, that we always run the latest init code in Linux and don't depend on code versions from U-Boot. Unfortunately all IBM/AMCC chips currently supported in this PCIe driver need a different reset-/init-sequence. Tested on AMCC Canyonlands eval board. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2008-03-26Merge branch 'linux-2.6'Paul Mackerras
2008-03-24[POWERPC] Fix Oops with TQM5200 on TQM5200Anatolij Gustschin
The "bestcomm-core" driver defines its of_match table as follows static struct of_device_id mpc52xx_bcom_of_match[] = { { .type = "dma-controller", .compatible = "fsl,mpc5200-bestcomm", }, { .type = "dma-controller", .compatible = "mpc5200-bestcomm", }, {}, }; so while registering the driver, the driver's probe function won't be called, because the device tree node doesn't have a device_type property. Thus the driver's bcom_engine structure won't be allocated. Referencing this structure later causes observed Oops. Checking bcom_eng pointer for NULL before referencing data pointed by it prevents oopsing, but fec driver still doesn't work (because of the lost bestcomm match and resulted task allocation failure). Actually the compatible property exists and should match and so the fec driver should work. This removes .type = "dma-controller" from the bestcomm driver's mpc52xx_bcom_of_match table to solve the problem. Signed-off-by: Anatolij Gustschin <agust@denx.de> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-03-24[POWERPC] mpc5200: Fix null dereference if bestcomm fails to initializeGrant Likely
If the bestcomm initialization fails, calls to the task allocate function should fail gracefully instead of oopsing with a NULL deref. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-03-24[POWERPC] Fix crash in init_ipic_sysfs on efikaOlaf Hering
The global primary_ipic in arch/powerpc/sysdev/ipic.c can remain NULL if ipic_init() fails, which will happen on machines that don't have an ipic interrupt controller. init_ipic_sysfs() will crash in that case. Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-03-13Merge branch 'linux-2.6'Paul Mackerras
2008-03-10[POWERPC] QE: Make qe_get_firmware_info reentrantIonut Nicu
The function was returning NULL the second time it was called if the firmware was uploaded from the boot loader or the first time it was called if the firmware was uploaded from the kernel. Signed-off-by: Ionut Nicu <ionut.nicu@freescale.com> Acked-By: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-03-07[POWERPC] QE: Fix QE firmware uploading limitTimur Tabi
Fix a typo in qe_upload_firmware() that prevented uploading firmware on systems with more than one RISC core. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-02-26[POWERPC] mpic: Make sparse happyJohannes Berg
I was running sparse on something else and noticed sparse warnings and especially the bogus code that is fixed by the first hunk of this patch, so I fixed them all while at it. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Milton Miller <miltonm@bga.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-02-26Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/lmb-2.6Paul Mackerras
2008-02-21[POWERPC] pasemi: Remove warning in mpic_pasemi_msi.cOlof Johansson
Remove warning: arch/powerpc/sysdev/mpic_pasemi_msi.c: In function 'pasemi_msi_setup_msi_irqs': arch/powerpc/sysdev/mpic_pasemi_msi.c:135: warning: 'addr' is used uninitialized in this function Turns out addr wasn't even used, it's a leftover from the u3msi code. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-02-13[LIB]: Make PowerPC LMB code generic so sparc64 can use it too.David S. Miller
2008-02-06[POWERPC] Add missing native dcr dcr_ind_lock spinlockValentine Barshak
The include/asm-powerpc/dcr-native.h declares extern spinlock_t dcr_ind_lock; but it's actually isn't defined. This patch adds a missing dcr_ind_lock. Signed-off-by: Valentine Barshak <vbarshak@ru.mvista.com> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2008-02-06Merge branch 'for-2.6.25' of ↵Paul Mackerras
master.kernel.org:/pub/scm/linux/kernel/git/galak/powerpc into for-2.6.25
2008-02-06[POWERPC] arch/powerpc/sysdev: Add missing of_node_putJulia Lawall
The functions of_find_compatible_node and of_find_node_by_type both call of_node_get on their result. So any error handling code thereafter should call of_node_put(np). This is taken care of in the case where there is a goto out, but not when there is a direct return. The function irq_alloc_host puts np into the returned structure, which is stored in the global variable mpc8xx_pic_host, so the reference count should be set for the lifetime of that variable. The current solution ups the reference count again in the argument to irq_alloc_host so that it can be decremented on the way out. This seems a bit unnecessary, and also doesn't work in the case where irq_alloc_host fails, because then the reference count only goes does by one, whereas it should go down by two. A better solution is to not increment the reference count in the argument to irq_alloc_host and only decrement it on the way out in an error case. The problem was found using the following semantic match. (http://www.emn.fr/x-info/coccinelle/) // <smpl> @@ type T,T1,T2; identifier E; statement S; expression x1,x2,x3; int ret; @@ T E; ... * E = \(of_get_parent\|of_find_compatible_node\)(...); if (E == NULL) S ... when != of_node_put(...,(T1)E,...) when != if (E != NULL) { ... of_node_put(...,(T1)E,...); ...} when != x1 = (T1)E when != E = x3; when any if (...) { ... when != of_node_put(...,(T2)E,...) when != if (E != NULL) { ... of_node_put(...,(T2)E,...); ...} when != x2 = (T2)E ( * return; | * return ret; ) } // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Kumar Gala <galak@gate.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-02-05[POWERPC] qe_lib: fix few fluffy negligencesAnton Vorontsov
One is intoduced by me (of_node_put() absence) and another was present already (not checking for NULL). Found by Stephen Rothwell. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Acked-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-02-05[POWERPC] FSL: fix mpc83xx_spi device registrationKim Phillips
calling platform_device_register after platform_device_alloc causes this: kobject (c3841a70): tried to init an initialized object, something is seriously wrong. Call Trace: [c381fe20] [c0007bb8] show_stack+0x3c/0x194 (unreliable) [c381fe50] [c01322a8] kobject_init+0xb8/0xbc [c381fe60] [c01591cc] device_initialize+0x30/0x9c [c381fe80] [c015ee34] platform_device_register+0x1c/0x34 [c381fea0] [c02f1fe0] of_fsl_spi_probe+0x21c/0x22c [c381ff30] [c02f2044] fsl_spi_init+0x54/0x160 [c381ff60] [c02f3924] __machine_initcall_mpc832x_rdb_mpc832x_spi_init+0x120/0x138 [c381ff70] [c02e61b4] kernel_init+0x98/0x284 [c381fff0] [c000f740] kernel_thread+0x44/0x60 fixed by calling platform_device_add (second half of platform_device_register) instead. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-31Merge branch 'linux-2.6'Paul Mackerras
2008-01-31Merge branch 'for-2.6.25' of git://git.secretlab.ca/git/linux-2.6-mpc52xxPaul Mackerras
2008-01-28[POWERPC] 83xx: ipic: add interrupt vector 94Kim Phillips
This is used on the mpc8315 SoC for TDM DMA error interrupts. Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-28[POWERPC] fsl_spi: stop using device_type = "spi"Anton Vorontsov
Also: - rename "fsl_spi" to "fsl,spi"; - add and use cell-index property, if found; - split probing code out of fsl_spi_init, thus we can call it for legacy device_type probing and new "compatible" probing. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-28spi_mpc83xx: use brg-frequency for SPI in QEAnton Vorontsov
In case of QE we can use brg-frequency (which is qeclk/2). Thus no need to divide sysclk in the spi_mpc83xx. This patch also adds code to use get_brgfreq() on QE chips. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-28[POWERPC] QE: get rid of most device_types and modelAnton Vorontsov
Now we're searching for "fsl,qe", "fsl,qe-muram", "fsl,qe-muram-data" and "fsl,qe-ic". Unfortunately it's still impossible to remove device_type = "qe" from the existing device trees because older u-boots are looking for it. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
