Several fixes as well where the +1 was missing.
Done via coccinelle scripts like:
struct resource *ptr;
- ptr->end - ptr->start + 1
+ resource_size(ptr)
and some grep and typing.
Mostly uncompiled, no cross-compilers.
Manual merge of arch/powerpc/kernel/smp.c and add missing scheduler_ipi()
call to arch/powerpc/platforms/cell/interrupt.c
Make some PowerPC architecture's code use struct syscore_ops
objects for power management instead of sysdev classes and sysdevs.
This simplifies the code and reduces the kernel's memory footprint.
It also is necessary for removing sysdevs from the kernel entirely in
the future.
First step in eliminating irq_map[] table entirely
Scripted with coccinelle.
The core irq_set_type() function updates the flow type when the chip
callback returns 0. So setting the type is bogus.
The new core code allows to update the type in irq_data and return
IRQ_SET_MASK_OK_NOCOPY, so the core code will not touch it, except for
setting the IRQ_LEVEL flag.
Use the proper accessors for setting the irq handlers.
Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca>
ipic_lock needs to be a real spinlock in RT. Convert it to
raw_spinlock.
Now we use printf style alignment there is no need to manually space
these fields.
Writing a driver using SCLPC on the MPC5200B I detected, that the
intspec arrays to map irqs to Linux virq cannot be const, because the
mapping and xlate functions only take non const pointers. All those
functions do not modify the intspec, so a const pointer could be used.
Signed-off-by: Roman Fietze <roman.fietze@telemotive.de>
The typename member of struct irq_chip was kept for migration purposes
and is obsolete since more than 2 years. Fix up the leftovers.
Cc: linuxppc-dev@ozlabs.org
Acked-by: Geoff Levand <geoffrey.levand@am.sony.com>
get_irq_desc() is a powerpc-specific version of irq_to_desc(). That
is reason enough to remove it, but it also doesn't know about sparse
irq_desc support which irq_to_desc() does (when we enable it).
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
Error handling code following a kzalloc should free the allocated data.
The semantic match that finds the problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
// <smpl>
@r exists@
local idexpression x;
statement S;
expression E;
identifier f,f1,l;
position p1,p2;
expression *ptr != NULL;
x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...);
if (x == NULL) S
<... when != x
when != if (...) { <+...x...+> }
x->f1 = E
(x->f1 == NULL || ...)
f(...,x->f1,...)
return \(0\|<+...x...+>\|ptr\);
return@p2 ...;
@script:python@
p1 << r.p1;
p2 << r.p2;
print "* file: %s kmalloc %s return %s" % (p1[0].file,p1[0].line,p2[0].line)
// </smpl>
in case the interrupt controller was used in an earlier life then it is
possible it is that some of its sources were used and are still unmask.
If the (unmasked) device is active and is creating interrupts (or one
interrupts was pending since the interrupts were disabled) then the boot
process "ends" very soon. Once external interrupts are enabled, we land in
-> do_IRQ
-> call ppc_md.get_irq()
-> ipic_read() gets the source number
-> irq_linear_revmap(source)
-> revmap[source] == NO_IRQ
-> irq_find_mapping(source) returns NO_IRQ because no source
is registered
-> source is NO_IRQ, ppc_spurious_interrupts gets incremented, no
further action.
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
This patch fixes various badnesses like this for all interrupt
controllers:
Badness at c04db9dc [verbose debug info unavailable]
NIP: c04db9dc LR: c04db9ac CTR: 00000000
REGS: c053de30 TRAP: 0700 Not tainted (2.6.31-rc1-00432-ge69b2b5-dirty)
MSR: 00021000 <ME,CE> CR: 22020084 XER: 00000000
TASK = c0500480[0] 'swapper' THREAD: c053c000
GPR00: 00000001 c053dee0 c0500480 00000000 00000050 00000020 3fffffff 00000000
GPR08: 00000001 c0540000 e0080080 00000000 22000084 64183600 3ff8f800 00000000
GPR16: 841b0240 449a0303 00000000 00000000 00000000 00000000 00000000 c04f5bf4
GPR24: 00000000 00000000 00000000 00000050 00000020 00000000 3fffffff 00000050
NIP [c04db9dc] alloc_arch_preferred_bootmem+0x48/0x74
LR [c04db9ac] alloc_arch_preferred_bootmem+0x18/0x74
Call Trace:
[c053dee0] [c000a5a4] __of_address_to_resource+0x44/0xd0 (unreliable)
[c053def0] [c04dba58] ___alloc_bootmem_nopanic+0x50/0x108
[c053df20] [c04dbb28] ___alloc_bootmem+0x18/0x50
[c053df30] [c04d5de0] qe_ic_init+0x5c/0x1b0
[c053df70] [c04d77b0] mpc85xx_mds_pic_init+0xb8/0x10c
[c053dfb0] [c04cf374] init_IRQ+0x28/0x3c
p.s. commit 85355bb272db31a3f2dd99d547eef794805e1319 ("powerpc: Fix
mpic alloc warning") missed some alloc_bootmem() instances, this is
now fixed.
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
Acked-by: Timur Tabi <timur@freescale.com>
The interrupt pending register is write 1 clear. If there are more than
one external interrupts pending at the same time, acking the first
interrupt by reading pending register then OR the corresponding bit and
write back to pending register will also clear other interrupt pending
bits. That will cause loss of interrupt.
Signed-off-by: Da Yu <dayu@datangmobile.cn>
I noticed this doing some randconfig testing (.config below). I have
CONFIG_PM but no CONFIG_SUSPEND. Bug is against mainline.
arch/powerpc/sysdev/built-in.o: In function `ipic_suspend':
ipic.c:(.text+0x6b34): undefined reference to `fsl_deep_sleep'
make[1]: *** [.tmp_vmlinux1] Error 1
make: *** [sub-make] Error 2
Looks like #ifdef CONFIG_PM in arch/powerpc/sysdev/ipic.c should be
CONFIG_SUSPEND. d49747bdfb2ddebea24d1580da55b79d093d48a9 introduced
this.
Fix build when we have CONFIG_PM but no CONFIG_SUSPEND.
Signed-off-by: Michael Neuling <mikey@neuling.org>
Acked-by: Scott Wood <scottwood@freescale.com>
Basic PM support for 83xx. Standby is implemented as sleep.
Suspend-to-RAM is implemented as "deep sleep" (with the processor
turned off) on 831x.
When I changed irq_alloc_host() to take an of_node
(52964f87c64e6c6ea671b5bf3030fb1494090a48: "Add an optional
device_node pointer to the irq_host"), I botched the reference
counting semantics.
Stephen pointed out that it's irq_alloc_host()'s business if
it needs to take an additional reference to the device_node,
the caller shouldn't need to care.
If we do the call to of_address_to_resource() first, then we don't
need to worry about freeing the irq_host (which the code doesn't do
currently anyway).
The global primary_ipic in arch/powerpc/sysdev/ipic.c can remain NULL
if ipic_init() fails, which will happen on machines that don't have an
ipic interrupt controller. init_ipic_sysfs() will crash in that case.
This is used on the mpc8315 SoC for TDM DMA error interrupts.
Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com>
All kobjects require a dynamically allocated name now. We no longer
need to keep track if the name is statically assigned, we can just
unconditionally free() all kobject names on cleanup.
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Added ipic_info entries for vectors used by 512x that
were previously unused by 83xx.
Signed-off-by: John Rigby <jrigby@freescale.com>
Only external interrupts in edge detect mode support ack operation.
Therefore, in most cases ack is not needed. The patch makes ipic
ack only when it's needed. This could boost over all system performance.
Signed-off-by: Li Yang <leoli@freescale.com>
These interrupts are introduced by the latest Freescale SoC
such as MPC837x.
The majority of irq_host implementations (3 out of 4) are associated
with a device_node, and need to stash it somewhere. Rather than having
it somewhere different for each host, add an optional device_node pointer
to the irq_host structure.
It's useful to have access to struct ipic handle that just got created
in ipic_init().
For example, if we want to setup an external IRQ with out
a device node we need access ipic->irqhost to create the virtual to HW
IRQ mapping and to set the IRQ sense. With this we can mimic the old
sense array concept that existed in arch/ppc.
No need for ?: because of_node_get() can handle NULL argument.
Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl>
This causes ipic_set_irq_type to set the handler directly rather
than call set_irq_handler, which causes spinlock recursion because
the lock is already held when ipic_set_irq_type is called.
I'm also not convinced that ipic_set_irq_type should be changing the
handler at all. There seem to be several controllers that don't and
several that do. Those that do would break what appears to be a common
usage of calling set_irq_chip_and_handler followed by set_irq_type, if a
non-standard handler were to be used. OTOH, irq_create_of_mapping()
doesn't set the handler, but only calls set_irq_type().
This patch gets things working in the spinlock-debugging-enabled case,
but I'm curious as to where the handler setting is ideally supposed to be
done. I don't see any documentation on set_irq_type() that clarifies
what the semantics are supposed to be.
Remove struct pt_regs * from all handlers.
Also remove the regs argument from get_irq() functions.
Compile tested with arch/powerpc/config/* and
arch/ppc/configs/prep_defconfig
Signed-off-by: Olaf Hering <olaf@aepfle.de>
Many files include the filename at the beginning, serveral used a wrong one.
Signed-off-by: Uwe Zeisberger <Uwe_Zeisberger@digi.com>
This patch fixes the assignment of pending registers to IRQ numbers for
the IPIC; the code previously assigned all IRQs to the high pending word
regardless of which word the interrupt belonged to.
set IRQ sense
This converts ipic code to Benh's IRQ mods. For the IPIC, IRQ sense values in the device tree equal those in include/linux/irq.h; that's 8 for low assertion (most internal IRQs on mpc83xx), and 2 for high-to-low change.
spinlocks added to [un]mask, ack operations; default handler and type now set in host_map; and redundant condition check eliminated.
This patch-queue improves the generic IRQ layer to be truly generic, by adding
various abstractions and features to it, without impacting existing
functionality.
While the queue can be best described as "fix and improve everything in the
generic IRQ layer that we could think of", and thus it consists of many
smaller features and lots of cleanups, the one feature that stands out most is
the new 'irq chip' abstraction.
The irq-chip abstraction is about describing and coding and IRQ controller
driver by mapping its raw hardware capabilities [and quirks, if needed] in a
straightforward way, without having to think about "IRQ flow"
(level/edge/etc.) type of details.
This stands in contrast with the current 'irq-type' model of genirq
architectures, which 'mixes' raw hardware capabilities with 'flow' details.
The patchset supports both types of irq controller designs at once, and
converts i386 and x86_64 to the new irq-chip design.
As a bonus side-effect of the irq-chip approach, chained interrupt controllers
(master/slave PIC constructs, etc.) are now supported by design as well.
The end result of this patchset intends to be simpler architecture-level code
and more consolidation between architectures.
We reused many bits of code and many concepts from Russell King's ARM IRQ
layer, the merging of which was one of the motivations for this patchset.
This patch:
rename desc->handler to desc->chip.
Originally i did not want to do this, because it's a big patch. But having
both "desc->handler", "desc->handle_irq" and "action->handler" caused a
large degree of confusion and made the code appear alot less clean than it
truly is.
I have also attempted a dual approach as well by introducing a
desc->chip alias - but that just wasnt robust enough and broke
frequently.
So lets get over with this quickly. The conversion was done automatically
via scripts and converts all the code in the kernel.
This renaming patch is the first one amongst the patches, so that the
remaining patches can stay flexible and can be merged and split up
without having some big monolithic patch act as a merge barrier.
[akpm@osdl.org: build fix]
[akpm@osdl.org: another build fix]
Moved 83xx and QUICC Engine interrupt handling code into arch/powerpc
as a precursor of getting 83xx sub-arch building in arch/powerpc.
