path: root/arch/powerpc/platforms
2011-05-11PM / PowerPC: Use struct syscore_ops instead of sysdevs for PMRafael J. Wysocki
Make some PowerPC architecture's code use struct syscore_ops objects for power management instead of sysdev classes and sysdevs. This simplifies the code and reduces the kernel's memory footprint. It also is necessary for removing sysdevs from the kernel entirely in the future. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-06powerpc: Add WSP platformDavid Gibson
Add a platform for the Wire Speed Processor, based on the PPC A2. This includes code for the ICS & OPB interrupt controllers, as well as a SCOM backend, and SCOM based cpu bringup. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Jack Miller <jack@codezen.org> Signed-off-by: Ian Munsie <imunsie@au1.ibm.com> Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-05-06powerpc/eeh: Display eeh error location for bus and deviceRichard A Lary
For adapters which have devices under a PCIe switch/bridge it is informative to display information for both the PCIe switch/bridge and the device on which the bus error was detected. rebased to powerpc-next Signed-off-by: Richard A Lary <rlary@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-05-06powerpc/pseries: Add support for IO event interruptsTseng-Hui (Frank) Lin
This patch adds support for handling IO Event interrupts which come through at the /event-sources/ibm,io-events device tree node. The interrupts come through ibm,io-events device tree node are generated by the firmware to report IO events. The firmware uses the same interrupt to report multiple types of events for multiple devices. Each device may have its own event handler. This patch implements a plateform interrupt handler that is triggered by the IO event interrupts come through ibm,io-events device tree node, pull in the IO events from RTAS and call device event handlers registered in the notifier list. Device event handlers are expected to use atomic_notifier_chain_register() and atomic_notifier_chain_unregister() to register/unregister their event handler in pseries_ioei_notifier_list list with IO event interrupt. Device event handlers are responsible to identify if the event belongs to the device event handler. The device event handle should return NOTIFY_OK after the event is handled if the event belongs to the device event handler, or NOTIFY_DONE otherwise. Signed-off-by: Tseng-Hui (Frank) Lin <thlin@us.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-05-04powerpc/pseries/eeh: Handle functional reset on non-PCIe deviceRichard A Lary
Fundamental reset is an optional reset type supported only by PCIe adapters. Handle the unexpected case where a non-PCIe device has requested a fundamental reset. Try hot-reset as a fallback to handle this case. Signed-off-by: Richard A Lary <rlary@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-05-04powerpc/pseries/eeh: Propagate needs_freset flag to device at PERichard A Lary
For multifunction adapters with a PCI bridge or switch as the device at the Partitionable Endpoint(PE), if one or more devices below PE sets dev->needs_freset, that value will be set for the PE device. In other words, if any device below PE requires a fundamental reset the PE will request a fundamental reset. Signed-off-by: Richard A Lary <rlary@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-05-04powerpc/pseries: Add page coalescing supportBrian King
Adds support for page coalescing, which is a feature on IBM Power servers which allows for coalescing identical pages between logical partitions. Hint text pages as coalesce candidates, since they are the most likely pages to be able to be coalesced between partitions. This patch also exports some page coalescing statistics available from firmware via lparcfg. [BenH: Moved a couple of things around to fix compile problems] Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-05-04powerpc: Convert old cpumask API into new oneKOSAKI Motohiro
Adapt new API. Almost change is trivial. Most important change is the below line because we plan to change task->cpus_allowed implementation. - ctx->cpus_allowed = current->cpus_allowed; Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-05-04powerpc: Add Initiate Coprocessor Store Word (icswx) supportTseng-Hui (Frank) Lin
Icswx is a PowerPC instruction to send data to a co-processor. On Book-S processors the LPAR_ID and process ID (PID) of the owning process are registered in the window context of the co-processor at initialization time. When the icswx instruction is executed the L2 generates a cop-reg transaction on PowerBus. The transaction has no address and the processor does not perform an MMU access to authenticate the transaction. The co-processor compares the LPAR_ID and the PID included in the transaction and the LPAR_ID and PID held in the window context to determine if the process is authorized to generate the transaction. The OS needs to assign a 16-bit PID for the process. This cop-PID needs to be updated during context switch. The cop-PID needs to be destroyed when the context is destroyed. Signed-off-by: Sonny Rao <sonnyrao@linux.vnet.ibm.com> Signed-off-by: Tseng-Hui (Frank) Lin <thlin@linux.vnet.ibm.com> Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-05-04powerpc/irq: Stop exporting irq_mapGrant Likely
First step in eliminating irq_map[] table entirely Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-04-27powerpc/eeh: Add support for ibm,configure-pe RTAS callRichard A. Lary
Added support for ibm,configure-pe RTAS call introduced with PAPR 2.2. Signed-off-by: Richard A. Lary <rlary@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-04-27powerpc: Free up some CPU feature bits by moving out MMU-related featuresMatt Evans
Some of the 64bit PPC CPU features are MMU-related, so this patch moves them to MMU_FTR_ bits. All cpu_has_feature()-style tests are moved to mmu_has_feature(), and seven feature bits are freed as a result. Signed-off-by: Matt Evans <matt@ozlabs.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-04-27powerpc/ps3: Update debug message for irq_set_chip_data()Geert Uytterhoeven
commit ec775d0e70eb6b7116406b3441cb8501c2849dd2 ("powerpc: Convert to new irq_* function names") changed a call from set_irq_chip_data() to irq_set_chip_data(), but forgot to update the corresponding debug message Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Geoff Levand <geoff@infradead.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-04-27powerpc/pci: Make IO workarounds init implicit when first bus is registeredMichael Ellerman
Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-04-27powerpc/pci: Move IO workarounds to the common kernel dirMichael Ellerman
2011-04-27powerpc/pci: Split IO vs MMIO indirect access hooksMichael Ellerman
The goal is to avoid adding overhead to MMIO when only PIO is needed Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-04-27powerpc: Add A2 cpu supportBenjamin Herrenschmidt
Add the cputable entry, regs and setup & restore entries for the PowerPC A2 core. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-04-20powerpc/smp: smp_ops->kick_cpu() should be able to failMichael Ellerman
When we start a cpu we use smp_ops->kick_cpu(), which currently returns void, it should be able to fail. Convert it to return int, and update all uses. Convert all the current error cases to return -ENOENT, which is what would eventually be returned by __cpu_up() currently when it doesn't detect the cpu as coming up in time. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-04-20powerpc: Add NAP mode support on Power7 in HV modeBenjamin Herrenschmidt
Wakeup comes from the system reset handler with a potential loss of the non-hypervisor CPU state. We save the non-volatile state on the stack and a pointer to it in the PACA, which the system reset handler uses to restore things Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-04-20powerpc: Always use SPRN_SPRG_HSCRATCH0 when running in HV modePaul Mackerras
This uses feature sections to arrange that we always use HSPRG1 as the scratch register in the interrupt entry code rather than SPRG2 when we're running in hypervisor mode on POWER7. This will ensure that we don't trash the guest's SPRG2 when we are running KVM guests. To simplify the code, we define GET_SCRATCH0() and SET_SCRATCH0() macros like the GET_PACA/SET_PACA macros. Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-04-20powerpc: Base support for exceptions using HSRR0/1Benjamin Herrenschmidt
Pass the register type to the prolog, also provides alternate "HV" version of hardware interrupt (0x500) and adjust LPES accordingly We tag those interrupts by setting bit 0x2 in the trap number Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-04-20powerpc/xics: Rewrite XICS driverBenjamin Herrenschmidt
This is a significant rework of the XICS driver, too significant to conveniently break it up into a series of smaller patches to be honest. The driver is moved to a more generic location to allow new platforms to use it, and is broken up into separate ICP and ICS "backends". For now we have the native and "hypervisor" ICP backends and one common RTAS ICS backend. The driver supports one ICP backend instanciation, and many ICS ones, in order to accomodate future platforms with multiple possibly different interrupt "sources" mechanisms. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-04-18powerpc/powermac: Build fix with SMP and CPU hotplugBenjamin Herrenschmidt
2011-04-18powerpc/pseries: Use a kmem cache for DTL buffersNishanth Aravamudan
PAPR specifies that DTL buffers can not cross AMS environments (aka CMO in the PAPR) and can not cross a memory entitlement granule boundary (4k). This is found in section 14.11.3.2 H_REGISTER_VPA of the PAPR. kmalloc does not guarantee an alignment of the allocation, though, beyond 8 bytes (at least in my understanding). Create a special kmem cache for DTL buffers with the alignment requirement. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-04-07Merge branch 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6Linus Torvalds
* 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6: Fix common misspellings
2011-04-05powerpc/pseries: Fix build without CONFIG_HOTPLUG_CPUMatt Evans
Signed-off-by: Matt Evans <matt@ozlabs.au.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-04-05powerpc/pseries: Don't register global initcallBenjamin Herrenschmidt
2011-04-04Documentation: fix minor typos/spellingSylvestre Ledru
Fix some minor typos: * informations => information * there own => their own * these => this Signed-off-by: Sylvestre Ledru <sylvestre.ledru@scilab.org> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-01powerpc/pmac/smp: Remove no-longer needed preempt workaroundBenjamin Herrenschmidt
The generic code properly re-initializes the preempt count in the idle thread now Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-04-01powerpc/smp: Don't expose per-cpu "cpu_state" arrayBenjamin Herrenschmidt
Instead, keep it static, expose an accessor and use that from the PowerMac code. Avoids easy namespace collisions and will make it easier to consolidate with other implementations. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-04-01powerpc/pmac/smp: Fix CPU hotplug crashes on some machinesBenjamin Herrenschmidt
On some machines that use i2c to synchronize the timebases (such as PowerMac7,2/7,3 G5 machines), hotplug CPU would crash when putting back a new CPU online due to the underlying i2c bus being closed. This uses the newly added bringup_done() callback to move the close along with other housekeeping calls, and adds a CPU notifier to re-open the i2c bus around subsequent hotplug operations Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-04-01powerpc/pmac/smp: Properly NAP offlined CPU on G5Benjamin Herrenschmidt
The current code soft-disables, and then goes to NAP mode which turns interrupts on. That means that if an interrupt occurs, we will hit the masked interrupt code path which isn't what we want, as it will return with EE off, which will either get us out of NAP mode, or fail to enter it (according to spec). Instead, let's just rely on the fact that it is safe to take decrementer interrupts on an offline CPU and leave interrupts enabled. We can also get rid of the special case in asm for power4_cpu_offline_powersave() and just use power4_idle(). Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-04-01powerpc/pmac/smp: Remove HMT changes for PowerMac offline codeBenjamin Herrenschmidt
Those instructions do nothing on non-threaded processors such as 970's used on those machines. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-04-01powerpc/pmac/smp: Consolidate 32-bit and 64-bit PowerMac cpu_die in one fileBenjamin Herrenschmidt
2011-04-01powerpc/pmac/smp: Fixup smp_core99_cpu_disable() and use it on 64-bitBenjamin Herrenschmidt
Use the generic code, just add the MPIC priority setting, I don't see any use in mucking around with the decrementer, as 32-bit will have EE off all along, and 64-bit will be able to deal with it. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-04-01powerpc/pmac/smp: Fix 32-bit PowerMac cpu_dieBenjamin Herrenschmidt
Use generic cpu_state, call idle_task_exit() properly, and remove smp_core99_cpu_die() which isn't useful, the generic function does the job just fine.
2011-04-01powerpc/smp: Remove unused smp_ops->cpu_enable()Benjamin Herrenschmidt
Remove the last remnants of cpu_enable(), everybody uses the normal __cpu_up() path now Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-04-01powerpc/smp: soft-replugged CPUs must go back to start_secondaryBenjamin Herrenschmidt
Various thing are torn down when a CPU is hot-unplugged. That CPU is expected to go back to start_secondary when re-plugged to re initialize everything, such as clock sources, maps, ... Some implementations just return from cpu_die() callback in the idle loop when the CPU is "re-plugged". This is not enough. We fix it using a little asm trampoline which resets the stack and calls back into start_secondary as if we were all fresh from boot. The trampoline already existed on ppc64, but we add it for ppc32 Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-03-30powerpc/cell: Use handle_edge_eoi_irq for realThomas Gleixner
Missed one instance when moving that to the core code. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: linuxppc-dev@lists.ozlabs.org Cc: michael@ellerman.id.au Cc: mingo@elte.hu Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-03-30powerpc/pseries/smp: query-cpu-stopped-state support won't changeMilton Miller
If a given firmware doesn't have a token to support query-cpu-stopped-state, its not likely to change during the lifetime of the kernel. Only print this information once, not once per secondary thread. While here, make the line wrap grep friendly. Signed-off-by: Milton Miller <miltonm@bga.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-03-30powerpc/xics: Use hwirq for xics domain irq numberMilton Miller
To try to avoid future confusion, rename irq to hwirq when it refers to a xics domain number instead of a linux irq number. Signed-off-by: Milton Miller <miltonm@bga.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-03-30powerpc/xics: Fix numberspace mismatch from irq_desc conversionMilton Miller
commit 79f26c268ebad29bd75d078cfc09d3d82b30ccbd (powerpc: platforms/pseries irq_data conversion) pushed irq_desc down into many functions, dererencing the descriptor irq field as late as possible. But it incorrectly passed a linix virtural irq number to RTAS, resulting in the interrupt not being disabled and possibly other bad things, such as another interrupt being disabled and/or a checkstop. In addition this missed the point of xics_mask_unknown_vec and the seperation of xics_mask_real_irq from xics_mask_irq. When xics_mask_unknown_vec is called it's because the hardware delivered an irq source for which we have no linux irq allocated, and thefore we can not have an irq_desc allocated. Revert xics_mask_real_irq to its prior version, naming the argument hwirq to highlight the difference. Signed-off-by: Milton Miller <miltonm@bga.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-03-30powerpc/nvram: Don't overwrite oops/panic report on normal shutdownJim Keniston
For normal halt, reboot, and poweroff events, refrain from overwriting the lnx,oops-log partition. Also, don't save the dmesg buffer on an emergency-restart event if we've already saved it earlier in panic(). Signed-off-by: Jim Keniston <jkenisto@us.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-03-29powerpc: Convert to new irq_* function namesThomas Gleixner
Scripted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29powerpc: cell: Fix the irq_desc accessThomas Gleixner
The core irq_set_type() function updates the flow type when the chip callback returns 0. It also updates irq_data, so this can be used in irq_ack() to check for the level bit. That avoids a redundant sparse irq lookup. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29powerpc: mac: pic: Use irqd_is_level_type()Thomas Gleixner
No need for a redundant sparse irq lookup. irqdata provides the same information. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29powerpc: media5200: Remove pointless set_irq_type()Thomas Gleixner
The irq chip has no irq_set_type() callback. So calling the call is pointless. Set IRQ_LEVEL via the proper accessor. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29powerpc: Use proper accessors for IRQ_* flagsThomas Gleixner
Use the proper accessors instead of open access to irq_desc. Converted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-28powerpc: cell: Use the core flow handlerThomas Gleixner
The core handler is a full equivalent replacement. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
