path: root/arch/powerpc/platforms/maple
2011-06-29powerpc/maple: Register CPC925 EDAC device on all boards with CPC925Dmitry Eremin-Solenikov
Currently Maple setup code creates cpc925_edac device only on Motorola ATCA-6101 blade. Make setup code check bridge revision and enable EDAC on all U3H bridges. Verified on Momentum MapleD (ppc970fx kit) board. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-03-29powerpc: Convert to new irq_* function namesThomas Gleixner
Scripted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-09-02powerpc/maple: Add of_node_put to avoid memory leakJulia Lawall
Add a call to of_node_put in the error handling code following a call to of_find_node_by_path. The semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r exists@ local idexpression x; expression E,E1; statement S; @@ *x = (of_find_node_by_path |of_find_node_by_name |of_find_node_by_phandle |of_get_parent |of_get_next_parent |of_get_next_child |of_find_compatible_node |of_match_node )(...); ... if (x == NULL) S <... when != x = E *if (...) { ... when != of_node_put(x) when != if (...) { ... of_node_put(x); ... } ( return <+...x...+>; | * return ...; ) } ...> of_node_put(x); // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-07-14lmb: rename to memblockYinghai Lu
via following scripts FILES=$(find * -type f | grep -vE 'oprofile|[^K]config') sed -i \ -e 's/lmb/memblock/g' \ -e 's/LMB/MEMBLOCK/g' \ $FILES for N in $(find . -name lmb.[ch]); do M=$(echo $N | sed 's/lmb/memblock/g') mv $N $M done and remove some wrong change like lmbench and dlmb etc. also move memblock.c from lib/ to mm/ Suggested-by: Ingo Molnar <mingo@elte.hu> Acked-by: "H. Peter Anvin" <hpa@zytor.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-06-18edac: cpc925 MC platform device setupHarry Ciao
Fix up the number of cells for the values of CPC925 Memory Controller, and setup related platform device during system booting up, against which CPC925 Memory Controller EDAC driver would be matched. Signed-off-by: Harry Ciao <qingtao.cao@windriver.com> Cc: Doug Thompson <norsk5@yahoo.com> Cc: Michael Ellerman <michael@ellerman.id.au> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Kumar Gala <galak@gate.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-22powerpc/maple: Add a quirk to disable MSI for IPR on BiminiMichael Ellerman
Something in the HW or FW setup is busted and MSIs aren't working with IPR on Bimini, so until we figure out exaxtly what's up, we quirk them out Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-03-11powerpc/kconfig: Kill PPC_MULTIPLATFORMBenjamin Herrenschmidt
CONFIG_PPC_MULTIPLATFORM is a remain of the pre-powerpc days and isn't really meaningful anymore. It was basically equivalent to PPC64 || 6xx. This removes it along with the following changes: - 32-bit platforms that relied on PPC32 && PPC_MULTIPLATFORM now rely on 6xx which is what they want anyway. - A new symbol, PPC_BOOK3S, is defined that represent compliance with the "Server" variant of the architecture. This is set when either 6xx or PPC64 is set and open the door for future BOOK3E 64-bit. - 64-bit platforms that relied on PPC64 && PPC_MULTIPLATFORM now use PPC64 && PPC_BOOK3S - A separate and selectable CONFIG_PPC_OF_BOOT_TRAMPOLINE option is now used to control the use of prom_init.c Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-12-23powerpc: Remove default kexec/crash_kernel ops assignmentsAnton Vorontsov
Default ops are implicit now. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-10-15Merge commit 'origin'Benjamin Herrenschmidt
Manual fixup of conflicts on: arch/powerpc/include/asm/dcr-regs.h drivers/net/ibm_newemac/core.h
2008-09-06Remove asm/a.out.h files for all architectures without a.out support.Adrian Bunk
This patch also includes the required removal of (unused) inclusion of <asm/a.out.h> <linux/a.out.h>'s in the arch/ code for these architectures. [dwmw2: updated for 2.6.27-rc] Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-08-20powerpc: Use bcd2bin/bin2bcdAdrian Bunk
This changes powerpc to use the new bcd2bin/bin2bcd functions instead of the obsolete BCD_TO_BIN/BIN_TO_BCD macros. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-05-14[POWERPC] Fix sparse warnings in arch/powerpc/kernelMichael Ellerman
Make a few things static in lparcfg.c Make init and exit routines static in rtas_flash.c Make things static in rtas_pci.c Make some functions static in rtas.c Make fops static in rtas-proc.c Remove unneeded extern for do_gtod in smp.c Make clocksource_init() static in time.c Make last_tick_len and ticklen_to_xs static in time.c Move the declaration of the pvr per-cpu into smp.h Make kexec_smp_down() and kexec_stack static in machine_kexec_64.c Don't return void in arch_teardown_msi_irqs() in msi.c Move declaration of GregorianDay()into asm/time.h Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-03-26[POWERPC] maple: Kill fixup_maple_ideNathan Lynch
This function has been a no-op for about 18 months; it's there in the history should anyone need to resurrect it. Signed-off-by: Nathan Lynch <ntl@pobox.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-03-26[POWERPC] maple: Use platform name in define_machine()Nathan Lynch
Prevailing practice for define_machine() in powerpc is to use the platform name when the platform has only one define_machine() statement, but maple uses "maple_md". This caused me some head-scratching when writing some new code that uses machine_is(maple). Use "maple" instead of "maple_md". There should not be any behavioral change -- fixup_maple_ide() calls machine_is(maple) but the body of the function is ifdef'd out. Signed-off-by: Nathan Lynch <ntl@pobox.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-02-13[LIB]: Make PowerPC LMB code generic so sparc64 can use it too.David S. Miller
2008-01-17[POWERPC] Use <linux/of_{platform, device}.h> and not <asm/...> variants.Jon Loeliger
Signed-off-by: Jon Loeliger <jdl@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-12-21[POWERPC] Make non-PCI build work againStephen Rothwell
Maple and pasemi both require PCI as does CONFIG_OF_PLATFORM_PCI. The default setting of CONFIG_ISA_DMA_API is set to match the protection around the relevant routines in asm/dma.h. I also had to remove the PMAC platform from the combined build. The precis is that to build a 64 bit kernel with no PCI, you can only include pSeries and iSeries. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-12-11[POWERPC] pci_controller->arch_data really is a struct device_node *Stephen Rothwell
2007-10-19remove asm/bitops.h includesJiri Slaby
remove asm/bitops.h includes including asm/bitops directly may cause compile errors. don't include it and include linux/bitops instead. next patch will deny including asm header directly. Cc: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-17[POWERPC] maple pci_ops: Use named structure member initializersNathan Lynch
2007-08-17[POWERPC] Remove gratuitous reads from maple PCI config space methodsNathan Lynch
The maple PCI configuration space write methods read the written location immediately after the write is performed, presumably in order to flush the write. However, configuration space writes are not allowed to be posted, making these reads gratuitous. Furthermore, this behavior potentially causes us to violate the PCI PM spec when changing between e.g. D0 and D3 states, because a delay of up to 10ms may be required before the OS accesses configuration space after the write which initiates the transition. It definitely causes a system hang for me with a Broadcom 5721 PCIE network adapter, which is fixed by this change. Therefore this removes the gratuitous reads from u3_agp_write_config, u3_ht_write_config, and u4_pcie_write_config. Signed-off-by: Nathan Lynch <ntl@pobox.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-07-26[POWERPC] Fix Maple platform ISA busBenjamin Herrenschmidt
The Maple platform has ISA IOs but didn't call the new functions to actually map those, thus crashing when trying to access the nvram. This fixes Maple and JS2x using SLOF. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-06-29[POWERPC] rename add_bridge to avoid namespace clashesArnd Bergmann
Many platforms currently define their own add_bridge function, some of them globally. This breaks some multiplatform configurations. Prefixing each of these functions with the platform name avoids this problem. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2007-06-14[POWERPC] Rewrite IO allocation & mapping on powerpc64Benjamin Herrenschmidt
This rewrites pretty much from scratch the handling of MMIO and PIO space allocations on powerpc64. The main goals are: - Get rid of imalloc and use more common code where possible - Simplify the current mess so that PIO space is allocated and mapped in a single place for PCI bridges - Handle allocation constraints of PIO for all bridges including hot plugged ones within the 2GB space reserved for IO ports, so that devices on hotplugged busses will now work with drivers that assume IO ports fit in an int. - Cleanup and separate tracking of the ISA space in the reserved low 64K of IO space. No ISA -> Nothing mapped there. I booted a cell blade with IDE on PIO and MMIO and a dual G5 so far, that's it :-) With this patch, all allocations are done using the code in mm/vmalloc.c, though we use the low level __get_vm_area with explicit start/stop constraints in order to manage separate areas for vmalloc/vmap, ioremap, and PCI IOs. This greatly simplifies a lot of things, as you can see in the diffstat of that patch :-) A new pair of functions pcibios_map/unmap_io_space() now replace all of the previous code that used to manipulate PCI IOs space. The allocation is done at mapping time, which is now called from scan_phb's, just before the devices are probed (instead of after, which is by itself a bug fix). The only other caller is the PCI hotplug code for hot adding PCI-PCI bridges (slots). imalloc is gone, as is the "sub-allocation" thing, but I do beleive that hotplug should still work in the sense that the space allocation is always done by the PHB, but if you unmap a child bus of this PHB (which seems to be possible), then the code should properly tear down all the HPTE mappings for that area of the PHB allocated IO space. I now always reserve the first 64K of IO space for the bridge with the ISA bus on it. I have moved the code for tracking ISA in a separate file which should also make it smarter if we ever are capable of hot unplugging or re-plugging an ISA bridge. This should have a side effect on platforms like powermac where VGA IOs will no longer work. This is done on purpose though as they would have worked semi-randomly before. The idea at this point is to isolate drivers that might need to access those and fix them by providing a proper function to obtain an offset to the legacy IOs of a given bus. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-07[POWERPC] Rename device_is_compatible to of_device_is_compatibleStephen Rothwell
for consistency with other Open Firmware interfaces (and Sparc). This is just a straight replacement. This leaves the compatibility define in place. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-24[POWERPC] Rename MPIC_BROKEN_U3 to MPIC_U3_HT_IRQSMichael Ellerman
Rename MPIC_BROKEN_U3 to something a little more descriptive. Its effect is to enable support for HT irqs behind the PCI-X/HT bridge on U3/U4 (aka. CPC9x5) parts. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-13[POWERPC] Rename get_property to of_get_property: arch/powerpcStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-13[POWERPC] Make struct property's value a void *Stephen Rothwell
2007-04-13[POWERPC] Rename prom_n_addr_cells to of_n_addr_cellsStephen Rothwell
This is more consistent and gets us closer to the Sparc code. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-13[POWERPC] Remove unused inclusion of linux/ide.hOlaf Hering
Remove unneeded inclusion of linux/ide.h It does not compile with CONFIG_BLOCK=n. Remove asm/ide.h from ksyms file, it gets included earlier via linux/ide.h. Compile tested with all defconfig files. Signed-off-by: Olaf Hering <olaf@aepfle.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-03-22[POWERPC] Split several platforms into their respective Kconfig fileKumar Gala
Moved pseries, iseries, chrp, prep, maple and pasemi into their respective arch/powerpc/platform/*/Kconfig files out of arch/powerpc/Kconfig Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-02-07[POWERPC] Maple: use mmio nvramNathan Lynch
Some systems supported by the maple platform (e.g. JS2x blades running SLOF) are able to use the mmio_nvram backend for reading and writing nvram. This is an improvement over the current situation -- no nvram access from userspace at all. Select MMIO_NVRAM for the maple platform. Initialize the mmio_nvram backend from maple setup code. Signed-off-by: Nathan Lynch <ntl@pobox.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-07[POWERPC] Maple: don't override bus-range supplied by firmwareNathan Lynch
This workaround was copy-pasted from the powermac code. It's not necessary for maple. Signed-off-by: Nathan Lynch <ntl@pobox.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-01-24[POWERPC] maple: improve CPC9x5 host bridge detectionNathan Lynch
Identify CPC9x5 PCI Express, AGP, and HT host bridges using device_type and compatible properties, which is a more flexible method than using the name property (which can differ between firmwares and models). Signed-off-by: Nathan Lynch <ntl@pobox.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-01-09[POWERPC] Fix unbalanced uses of of_node_putNathan Lynch
The (maple|pasemi)_init_IRQ functions call of_node_put(root) once more than they should, causing the refcount of the root node to underflow, which triggers the WARN_ON in kref_get. Signed-off-by: Nathan Lynch <ntl@pobox.com> Acked-by: Olof Johansson <olof@lixom.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-12-08[POWERPC] maple: Use RTAS for reboot and haltNathan Lynch
On maple, use the RTAS "system-reboot" and "power-off" methods if they are available. Signed-off-by: Nathan Lynch <ntl@pobox.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-12-08[POWERPC] maple: Match "pcie" name for CPC945Nathan Lynch
Some firmwares have "pcie" for the "name" property of the CPC945 PCI Express host bridge. Check for "pcie" in addition to "pci" so we don't miss it. Signed-off-by: Nathan Lynch <ntl@pobox.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-12-04[POWERPC] Make pci_read_irq_line the defaultBenjamin Herrenschmidt
This patch reworks the way IRQs are fixed up on PCI for arch powerpc. It makes pci_read_irq_line() called by default in the PCI code for devices that are probed, and add an optional per-device fixup in ppc_md for platforms that really need to correct what they obtain from pci_read_irq_line(). It also removes ppc_md.irq_bus_setup which was only used by pSeries and should not be needed anymore. I've also removed the pSeries s7a workaround as it can't work with the current interrupt code anyway. I'm trying to get one of these machines working so I can test a proper fix for that problem. I also haven't updated the old-style fixup code from 85xx_cds.c because it's actually buggy :) It assigns pci_dev->irq hard coded numbers which is no good with the new IRQ mapping code. It should at least use irq_create_mapping(NULL, hard_coded_number); and possibly also set_irq_type() to set them as level low. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-10[POWERPC] Fix Maple secondary IDE interruptBenjamin Herrenschmidt
The IDE driver will pick up the PCI IRQ for both channels on Maple despite the fact that it's in legacy mode. This works around it by "hiding" the PCI IRQ of the AMD8111 IDE controller when it's configured in legacy mode on the Maple platform, thus causing the driver to call pci_get_legacy_ide_irq() which will return the correct interrupts for both channels. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-10[POWERPC] Make U4 PCIe work on mapleBenjamin Herrenschmidt
The Maple support code was missing code for U4/CPC945 PCIe. This adds it, enabling it to work on tigerwood boards, and possibly also js21 using SLOF. Also disable an obsolete firmware workaround. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-09-26[POWERPC] maple/pci iomem annotationsAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-09-22[POWERPC] Demacrofy arch/powerpc/platforms/maple/pci.cNathan Lynch
Noticed that the U3_*CFA macros have some typos: #define U3_HT_CFA0(devfn, off) \ ((((unsigned long)devfn) << 8) | offset) (refers to offset rather than off) #define U3_AGP_CFA0(devfn, off) \ ((1 << (unsigned long)PCI_SLOT(dev_fn)) \ | (((unsigned long)PCI_FUNC(dev_fn)) << 8) \ (refers to dev_fn rather than devfn) Things happen to work, but there doesn't seem to be any reason these shouldn't be functions. Overall behavior should be unchanged. Signed-off-by: Nathan Lynch <ntl@pobox.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-09-22[POWERPC] Maple U3 HT - reject inappropriate config space accessNathan Lynch
When there is a PCI-X mode 2 capable device behind the HT<->PCI-X bridge, the pci core decides that the device has the extended 4K config space, even though the bus is not operating in mode 2. This is because the u3_ht pci ops silently accept offsets greater than 255 but use only the 8 least significant bits, which means reading at offset 0x100 gets the data at offset 0x0, and causes confusion for lspci. Reject accesses to configuration space offsets greater than 255. Signed-off-by: Nathan Lynch <ntl@pobox.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-08-01Merge branch 'merge'Paul Mackerras
2006-07-31[POWERPC] maple: Constify & voidify get_property()Jeremy Kerr
Now that get_property() returns a void *, there's no need to cast its return value. Also, treat the return value as const, so we can constify get_property later. maple platform changes. Built for maple_defconfig Signed-off-by: Jeremy Kerr <jk@ozlabs.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-07-28[POWERPC] Fix new interrupt code (MPIC detection)Segher Boessenkool
As the code comment already says, the Maple device-tree is incorrect here; make the Linux code detect the correct thing, too. Signed-off-by: Segher Boessenkool <segher@kernel.crashing.org> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-07-28[POWERPC] Fix new interrupt code (MPIC endianness)Segher Boessenkool
All U3/U4 based systems are big-endian, not all express it in their device trees. Signed-off-by: Segher Boessenkool <segher@kernel.crashing.org> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-07-03[POWERPC] Add new interrupt mapping core and change platforms to use itBenjamin Herrenschmidt
This adds the new irq remapper core and removes the old one. Because there are some fundamental conflicts with the old code, like the value of NO_IRQ which I'm now setting to 0 (as per discussions with Linus), etc..., this commit also changes the relevant platform and driver code over to use the new remapper (so as not to cause difficulties later in bisecting). This patch removes the old pre-parsing of the open firmware interrupt tree along with all the bogus assumptions it made to try to renumber interrupts according to the platform. This is all to be handled by the new code now. For the pSeries XICS interrupt controller, a single remapper host is created for the whole machine regardless of how many interrupt presentation and source controllers are found, and it's set to match any device node that isn't a 8259. That works fine on pSeries and avoids having to deal with some of the complexities of split source controllers vs. presentation controllers in the pSeries device trees. The powerpc i8259 PIC driver now always requests the legacy interrupt range. It also has the feature of being able to match any device node (including NULL) if passed no device node as an input. That will help porting over platforms with broken device-trees like Pegasos who don't have a proper interrupt tree. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-07-03[POWERPC] Fix booting on Momentum "Apache" board (a Maple derivative)Benjamin Herrenschmidt
This extends the maple device-tree workarounds to work on the Apache board as well, and extends the maple platform probing code to recognize the Apache board. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
