GregorianDay() is supposed to calculate the day of the week
(tm->tm_wday) for a given day/month/year. In that calcuation it
indexed into an array called MonthOffset using tm->tm_mon-1. However
tm_mon is zero-based, not one-based, so this is off-by-one. It also
means that every January, GregoiranDay() will access element -1 of
the MonthOffset array.
It also doesn't appear to be a correct algorithm either: see in
contrast kernel/time/timeconv.c's time_to_tm function.
It's been broken forever, which suggests no-one in userland uses
this. It looks like no-one in the kernel uses tm->tm_wday either
(see e.g. drivers/rtc/rtc-ds1305.c:319).
tm->tm_wday is conventionally set to -1 when not available in
hardware so we can simply set it to -1 and drop the function.
(There are over a dozen other drivers in drivers/rtc that do
this.)
Found using UBSAN.
Cc: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: Andrew Morton <akpm@linux-foundation.org> # as an example of what UBSan finds.
Cc: Alessandro Zummo <a.zummo@towertech.it>
Cc: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Cc: rtc-linux@googlegroups.com
Signed-off-by: Daniel Axtens <dja@axtens.net>
Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Disintegrate asm/system.h for PowerPC.
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
cc: linuxppc-dev@lists.ozlabs.org
This changes powerpc to use the new bcd2bin/bin2bcd functions
instead of the obsolete BCD_TO_BIN/BIN_TO_BCD macros.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Make a few things static in lparcfg.c
Make init and exit routines static in rtas_flash.c
Make things static in rtas_pci.c
Make some functions static in rtas.c
Make fops static in rtas-proc.c
Remove unneeded extern for do_gtod in smp.c
Make clocksource_init() static in time.c
Make last_tick_len and ticklen_to_xs static in time.c
Move the declaration of the pvr per-cpu into smp.h
Make kexec_smp_down() and kexec_stack static in machine_kexec_64.c
Don't return void in arch_teardown_msi_irqs() in msi.c
Move declaration of GregorianDay()into asm/time.h
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
Signed-off-by: Matt Mackall <mpm@selenic.com>
This patch removes all self references and fixes references to files
in the now defunct arch/ppc64 tree. I think this accomplises
everything wanted, though there might be a few references I missed.
Signed-off-by: Jon Mason <jdmason@us.ibm.com>
The changes to the device node structure broke Maple build. This fixes it.
Unfortunately I coudn't test as my Maple board appears to be dead.
Reserve the Maple RTC I/O resource. Needed now we use genrtc.
Signed-off-by: Segher Boessenkool <segher@kernel.crashing.org>
