path: root/arch/powerpc/platforms/iseries/proc.c
2010-02-09powerpc: Remove trailing space in messagesFrans Pop
Signed-off-by: Frans Pop <elendil@planet.nl> Cc: linuxppc-dev@ozlabs.org Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-04-29powerpc: use non-racy method for proc entries creationDenis V. Lunev
Use proc_create()/proc_create_data() to make sure that ->proc_fops and ->data be setup before gluing PDE to main tree. Add correct ->owner to proc_fops to fix reading/module unloading race. Signed-off-by: Denis V. Lunev <den@openvz.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] mark struct file_operations const 2Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. [akpm@osdl.org: sparc64 fix] Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-09[POWERPC] iSeries: fix proc/iSeries initialisationStephen Rothwell
These proc files should only be created if we are running on legacy iSeries. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-06-28[POWERPC] Clean up it_lp_queue.hStephen Rothwell
No more StudlyCaps. Remove from a couple of places it is no longer needed. Use C style comments. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-11-02merge filename and modify references to iseries/it_lp_queue.hKelly Daly
Signed-off-by: Kelly Daly <kelly@au.ibm.com>
2005-11-02merge filename and modify references to iseries/hv_call_xm.hKelly Daly
2005-09-30ppc64 iseries: move some iSeries include filesStephen Rothwell
These files are only referenced from within arch/powerpc/platforms/iseries, so move them there. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au>
2005-09-28powerpc: move iSeries_proc.c to powerpc/platforms/iseriesStephen Rothwell
And renamed it to proc.c Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au>
