path: root/arch/powerpc/platforms/85xx/smp.c
2011-05-19powerpc: Consolidate ipi message mux and demuxMilton Miller
Consolidate the mux and demux of ipi messages into smp.c and call a new smp_ops callback to actually trigger the ipi. The powerpc architecture code is optimised for having 4 distinct ipi triggers, which are mapped to 4 distinct messages (ipi many, ipi single, scheduler ipi, and enter debugger). However, several interrupt controllers only provide a single software triggered interrupt that can be delivered to each cpu. To resolve this limitation, each smp_ops implementation created a per-cpu variable that is manipulated with atomic bitops. Since these lines will be contended they are optimialy marked as shared_aligned and take a full cache line for each cpu. Distro kernels may have 2 or 3 of these in their config, each taking per-cpu space even though at most one will be in use. This consolidation removes smp_message_recv and replaces the single call actions cases with direct calls from the common message recognition loop. The complicated debugger ipi case with its muxed crash handling code is moved to debug_ipi_action which is now called from the demux code (instead of the multi-message action calling smp_message_recv). I put a call to reschedule_action to increase the likelyhood of correctly merging the anticipated scheduler_ipi() hook coming from the scheduler tree; that single required call can be inlined later. The actual message decode is a copy of the old pseries xics code with its memory barriers and cache line spacing, augmented with a per-cpu unsigned long based on the book-e doorbell code. The optional data is set via a callback from the implementation and is passed to the new cause-ipi hook along with the logical cpu number. While currently only the doorbell implemntation uses this data it should be almost zero cost to retrieve and pass it -- it adds a single register load for the argument from the same cache line to which we just completed a store and the register is dead on return from the call. I extended the data element from unsigned int to unsigned long in case some other code wanted to associate a pointer. The doorbell check_self is replaced by a call to smp_muxed_ipi_resend, conditioned on the CPU_DBELL feature. The ifdef guard could be relaxed to CONFIG_SMP but I left it with BOOKE for now. Also, the doorbell interrupt vector for book-e was not calling irq_enter and irq_exit, which throws off cpu accounting and causes code to not realize it is running in interrupt context. Add the missing calls. Signed-off-by: Milton Miller <miltonm@bga.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-04-20powerpc/smp: smp_ops->kick_cpu() should be able to failMichael Ellerman
When we start a cpu we use smp_ops->kick_cpu(), which currently returns void, it should be able to fail. Convert it to return int, and update all uses. Convert all the current error cases to return -ENOENT, which is what would eventually be returned by __cpu_up() currently when it doesn't detect the cpu as coming up in time. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-03-15powerpc/85xx: Fix writing to spin table 'cpu-release-addr' on ppc64eKumar Gala
If the spin table is located in the linear mapping (which can happen if we have 4G or more of memory) we need to access the spin table via a cacheable coherent mapping like we do on ppc32 (and do explicit cache flush). See the following commit for the ppc32 version of this issue: commit d1d47ec6e62ab08d2ebb925fd9203abfad3adfbf Author: Peter Tyser <ptyser@xes-inc.com> Date: Fri Dec 18 16:50:37 2009 -0600 powerpc/85xx: Fix SMP when "cpu-release-addr" is in lowmem Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-14powerpc/85xx: flush dcache before resetting coresMatthew McClintock
When we do an mpic_reset_core we need to make sure the dcache is flushed. Signed-off-by: Matthew McClintock <msm@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-14powerpc/85xx: Minor fixups for kexec on 85xxMatthew McClintock
Make kexec_down_cpus atmoic since it will be incremented by all cores as they are coming down. Remove duplicate calls to mpc85xx_smp_kexec_down, now it's called by the crash and normal kexec pathway only once. Increase the timeout to wait for other cores to shutdown. Signed-off-by: Matthew McClintock <msm@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-14powerpc/85xx: Remove call to mpic_teardown_this_cpu in kexecMatthew McClintock
We no longer need to call this explicitly as a generic version is called by default. Signed-off-by: Matthew McClintock <msm@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-08powerpc/ppc64e: Fix link problem when building ppc64e_defconfigKumar Gala
arch/powerpc/platforms/built-in.o:(.toc1+0x18): undefined reference to `__early_start' This is due to the 85xx/smp.c not handling the 64-bit side properly. We need to set the entry point for secondary cores on ppc64e to generic_secondary_smp_init instead of __early_start that we due on ppc32. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-08-02powerpc/85xx: kexec for SMP 85xx BookE systemsMatthew McClintock
Adds support for kexec on 85xx machines for the BookE platform. Including support for SMP machines Based off work from Maxim Uvarov <muvarov@mvista.com> Signed-off-by: Matthew McClintock <msm@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-09powerpc/book3e: More doorbell cleanups. Sample the PIR registerBenjamin Herrenschmidt
The doorbells use the content of the PIR register to match messages from other CPUs. This may or may not be the same as our linux CPU number, so using that as the "target" is no right. Instead, we sample the PIR register at boot on every processor and use that value subsequently when sending IPIs. We also use a per-cpu message mask rather than a global array which should limit cache line contention. Note: We could use the CPU number in the device-tree instead of the PIR register, as they are supposed to be equivalent. This might prove useful if doorbells are to be used to kick CPUs out of FW at boot time, thus before we can sample the PIR. This is however not the case now and using the PIR just works. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-02-13powerpc/85xx: Fix SMP when "cpu-release-addr" is in lowmemPeter Tyser
Recent U-Boot commit 5ccd29c3679b3669b0bde5c501c1aa0f325a7acb caused the "cpu-release-addr" device tree property to contain the physical RAM location that secondary cores were spinning at. Previously, the "cpu-release-addr" property contained a value referencing the boot page translation address range of 0xfffffxxx, which then indirectly accessed RAM. The "cpu-release-addr" is currently ioremapped and the secondary cores kicked. However, due to the recent change in "cpu-release-addr", it sometimes points to a memory location in low memory that cannot be ioremapped. For example on a P2020-based board with 512MB of RAM the following error occurs on bootup: <...> mpic: requesting IPIs ... __ioremap(): phys addr 0x1ffff000 is RAM lr c05df9a0 Unable to handle kernel paging request for data at address 0x00000014 Faulting instruction address: 0xc05df9b0 Oops: Kernel access of bad area, sig: 11 [#1] SMP NR_CPUS=2 P2020 RDB Modules linked in: <... eventual kernel panic> Adding logic to conditionally ioremap or access memory directly resolves the issue. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Nate Case <ncase@xes-inc.com> Reported-by: Dipen Dudhat <B09055@freescale.com> Tested-by: Dipen Dudhat <B09055@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-11powerpc/85xx: Fix SMP compile error and allow NULL for smp_opsKumar Gala
The following commit introduced a compile error since it removed the implementation of smp_85xx_basic_setup: commit 77c0a700c1c292edafa11c1e52821ce4636f81b0 Author: Benjamin Herrenschmidt <benh@kernel.crashing.org> Date: Fri Aug 28 14:25:04 2009 +1000 powerpc: Properly start decrementer on BookE secondary CPUs Make it so that smp_ops probe() and setup_cpu() can be set to NULL. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-08-28powerpc: Properly start decrementer on BookE secondary CPUsBenjamin Herrenschmidt
This moves the code to start the decrementer on 40x and BookE into a separate function which is now called from time_init() and secondary_time_init(), before the respective clock sources are registered. We also remove the 85xx specific code for doing it from the platform code. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-08-20powerpc: Move definitions of secondary CPU spinloop to header fileBenjamin Herrenschmidt
Those definitions are currently declared extern in the .c file where they are used, move them to a header file instead. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-06-23powerpc/85xx: Fix issue found by lockdep trace in smp_85xx_kick_cpuKumar Gala
lockdep trace found the following: ------------[ cut here ]------------ Badness at c007baf0 [verbose debug info unavailable] NIP: c007baf0 LR: c007bad8 CTR: 00000000 REGS: ef855e00 TRAP: 0700 Tainted: G W (2.6.30-06736-g12a31df-dirty) MSR: 00021000 <ME,CE> CR: 24044022 XER: 20000000 TASK = ef858000[1] 'swapper' THREAD: ef854000 CPU: 0 GPR00: 00000000 ef855eb0 ef858000 00000001 000000d0 f1000000 ffbc8000 ffffffff GPR08: 000000d0 c0760000 c0710000 00000007 2fffffff 1004a388 7ffd9400 00000000 GPR16: 00000000 7ffcd100 7ffcd100 7ffcd100 c059cd78 c075c498 c057da7c ffffffff GPR24: ffbc8000 f1000000 00000001 c00bf8b0 c07595d4 000000d0 00021000 000000d0 NIP [c007baf0] lockdep_trace_alloc+0xc0/0xf0 LR [c007bad8] lockdep_trace_alloc+0xa8/0xf0 Call Trace: [ef855eb0] [c007ba60] lockdep_trace_alloc+0x30/0xf0 (unreliable) [ef855ec0] [c00cb3ac] kmem_cache_alloc+0x2c/0xf0 [ef855ee0] [c00bf8b0] __get_vm_area_node+0x80/0x1c0 [ef855f10] [c0017580] __ioremap_caller+0x1d0/0x1e0 [ef855f40] [c057da7c] smp_85xx_kick_cpu+0x64/0x124 [ef855f60] [c0599180] __cpu_up+0xd0/0x1a4 [ef855f80] [c05997c4] cpu_up+0x14c/0x1e0 [ef855fc0] [c05732a0] kernel_init+0x100/0x1c4 [ef855ff0] [c0011524] kernel_thread+0x4c/0x68 Instruction dump: 8009c174 2f800000 409e0048 73c08000 40820040 4818980d 2f830000 419effa0 3d20c076 8009c388 2f800000 409eff90 <0fe00000> 4bffff88 60000000 60000000 We were calling ioremap after we local_irq_restore(flags). A simple reorder fixes the problem. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-03-11powerpc/85xx: Update smp support to handle doorbells and non-mpic initKumar Gala
Use device tree to determine if we actually have an MPIC and use CPU feature to decide if we should use doorbells for IPIs. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-12-30powerpc/85xx: Add local_irq_restore in error handling codeJulia Lawall
There is a call to local_irq_restore in the normal exit case, so it would seem that there should be one on an error return as well. The semantic patch that makes this change is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @@ expression l; expression E,E1,E2; @@ local_irq_save(l); ... when != local_irq_restore(l) when != spin_unlock_irqrestore(E,l) when any when strict ( if (...) { ... when != local_irq_restore(l) when != spin_unlock_irqrestore(E1,l) + local_irq_restore(l); return ...; } | if (...) + {local_irq_restore(l); return ...; + } | spin_unlock_irqrestore(E2,l); | local_irq_restore(l); ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-12-03powerpc/85xx: Add support for SMP initializationKumar Gala
Added 85xx specifc smp_ops structure. We use ePAPR style boot release and the MPIC for IPIs at this point. Additionally added routines for secondary cpu entry and initializtion. Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Trent Piepho <tpiepho@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
